2017 Audi Q7 Developer Mode
   #41
rlarsen
Copenhagen, Denmark
C?ID=78998
This thread was about Audi Q7 (4M) (8W + FV).
Did you see the models for the buttons ?
Your model is Audi A7 (4G), right ?
From SSP it is like this, I don't know if that can be used for Green Menu.
Hidden menu is both MENU + CAR together - this means first press CAR and then press MENU
   #42
satpat2
C?ID=255340
Ok tried this morning, system restart works but hidden menu or engineering mode does not work, tried a few times but no go, do you have the SSP for Audi A7
   #44
rlarsen
Copenhagen, Denmark
C?ID=78998
Can you post a photo of your MMI buttons ??
   #45
satpat2
C?ID=255340
rlarsen
Copenhagen, Denmark
C?ID=78998
Maybe you need to press both CAR + MENU at the same time - but normally it is working with one key at a time.
Here is a small YouTube showing the enabling
satpat2
C?ID=255340
watched and performed the video with no progress, this is suggesting to me that I haven't activated the green menu, how do I do this as I followed your CLB file in users folder, went to 5f and adaptation 10 and activated it and still no joy, am I missing something ?
   #48
rlarsen
Copenhagen, Denmark
C?ID=78998
Are you able to get into the "Engineering Menu" ??
   #49
satpat2
C?ID=255340
Yes but it's not useful, the buttons are different though, with some trial and error, it's the back, centre and top left of the four silver buttons
   #50
rlarsen
Copenhagen, Denmark
C?ID=78998
Engineering Menu is only BACK + CAR - but okay perfect that it is working :)
I think you need to try a few times - so you can press keys (CAR + MENU) simultaneously for 5-6 sec. - now that pressing them one a a time doesn't work.
   #51
satpat2
C?ID=255340
Engineering Menu is defo Menu, Centre Push Button and Top Left, tried 3 times and all with the same results
Restart is Menu, Centre and Top Right, checked 3 times
Hidden Menu, none of the key combinations work, in addition to this I have tried Menu, Centre and Bottom Left and Menu, Centre and Bottom Right, with no effect, this is a complete new set up and cant find anything on it.
is there anything I can try to help gain the knowledge but to ultimately find the solution for all other A7 users, I have a lot of extras on the car from advanced tech pack etc, would this have an effect on it ?
thanks
satpat2
C?ID=255340
Hey Folks
Great work, I can now confirm back and the bottom left of the silver keys gets you into the hidden green menu, it's changed dramatically, so can't see anywhere to do mods but we are progressing, thank you folks
   #53
Chris1083
C?ID=331772
Well, I was going to split this into a new thread, but the (relatively) new version of the forum software is giving me fits..
Thank you ! - I will put the scan into this thread so everything is there.
EDIT----oops you were faster :D
   #54
saad2021
Australia
C?ID=445293
Hi
I am unable to activate Developer mode in 5F. Out of Range message appears.
Please note
Using the latest VCDS SW
Security code 20103 is acceptable
Vcds-hex v2 cable.
Audio Q7 4M MY16
Any suggestion.
   #56
saad2021
Australia
C?ID=445293
@saad2021 Please post the complete Auto-Scan so we can see which 5F module is installed.
Hi Dana, as requested please find the auto-scan information below:
Sunday,13,June,2021,21:10:28:04643
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
VIN: WAUZZZ4M7GD033964   License Plate: AIP049
Mileage: 124223km-77188mi   Repair Order: 13June2021
Chassis Type: 4M-AU73 (4M2)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 36 39 3C 42 44 46 50
          52 5F 65 69 6C 6D 81 8B A5 AC BB BC CA CF
VIN: WAUZZZ4M7GD033964   Mileage: 124223km-77188miles
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 4M0 907 401     HW: 059 907 309 B
   Component: 3.0TDI EDC17  H45 0009
   Revision: 91H45---
   Coding: 2A2A40320576050334380000000000000000000000000000
   Shop #: WSC 52700 003 1048576
   ASAM Dataset: EV_ECM30TDI0114M0907401 001013
   ROD: EV_ECM30TDI0114M0907401.rod
   VCID: 6695BFC968E6EF0B15F-8032
   Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H03 1008
   Revision: --H03---
   Coding: 100000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011_AU49.rod
   VCID: 3B233EBD43E482E39A1-806E
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0521
   Coding: 289830B230A50A9996A75897008112A2E6A6DA140C0C50691A00484567655B
   Shop #: WSC 52329 002 1048576
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3FDB4AAD57FC9EC3B69-806A
   Part No SW: 4M0 959 760     HW: 4M0 959 760
   Component: MEM-BFS       008 0014
   Serial number: 00000174000999
   Coding: 002010000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMPasseSideCONTIAU736_AU37.rod
   VCID: 75B7E88525401493AC5-8020
   Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
   Component: Klima Zone 4  H52 0083
   Coding: 661809BC5544441112200180800000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 678BB2CD6FECF6032E9-8032
   Fresh air blower control module (front):
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000657022
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: E30845D7000000000001
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Coding: C2501942C16900CD010D06105B3F08F913033100800000000000000060001A01004100AB22B70A
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 005989516A82213B8F3-8054
   Wiper motor control module:
   Subsystem 1 - Part No SW: 4M2 955 119 A    HW: 4H1 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 150721  043 0893
   Serial number: 895653?0401520201926
   Coding: 1BC7F7
   Serial number: 60874454
   Coding: 02006E
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
   Component: E1 - LDS  H06 0008
   Serial number: 28 09 2015  00117124
   Automatic dimming interior mirror:
   Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
   Component: Y7_Innenspieg  H08 0002
   Serial number: GX1CE120101511520101
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4M0 947 135 AB    HW: 4M0 947 135
   Component: J528-Dachele  H13 0080
   Serial number: Q00060486
   Control head for driving and comfort functions:
   Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
   Component: SL-Q7NF/AU736  H09 0006
   Serial number: 00000000000000018088
65568 - Terminal 30-5
          U1415 00 [009] - Open circuit
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H08 0220
   Coding: 3476E7FB58FFEC0A949880A4
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 323D139994AE43AB497-8066
   Part No SW: 4M0 959 655     HW: 4M0 959 655
   Component: Airbag10.44   H50 0084
   Serial number: 003L100138LF
   Coding: AAFCF0D80C80000098F65033C08C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 78A9E1B1325269FBB73-802C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705J0302P00637
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706D0301P01661
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 062 410 15
   Serial number: 3577Y00B5198985511A0
   Subsystem 4 - Part No SW: -----------    HW: 442 062 410 15
   Serial number: 3587Y00B5198985532E8
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 309 15
   Serial number: 35177009B1C4E1E4423G
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 709 15
   Serial number: 35277009D1C4E1E1E2F
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 610 15
   Serial number: 3557500C51C70E42E21D
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 610 15
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500C51C70E47225B
   Center pedestrian protection crash sensor:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 909 15
   Component: PedP_Sensor_C  1C5 014A
   Serial number: 2307500A11C5DC25729A
   Driver's side crash data pedestrian protection 2:
   Subsystem 10 - Part No SW: -----------    HW: 442 421 110 15
   Component: PedPSensor_D2  21E 0887
   Serial number: I0M8U00B51A537D3B3AV
   Passenger's side crash data pedestrian protection 2:
   Subsystem 11 - Part No SW: -----------    HW: 442 421 110 15
   Component: PedPSensor_P2  21E 0887
   Serial number: I0N8U00B51A537D3D16S
   Central crash sensor X/Y:
   Subsystem 12 - Part No SW: -----------    HW: 410 201 610 15
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800C11BCC0E1E0CI
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 015F8C556188283380D-8054
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 4M0 920 790 A    HW: 4M0 920 790 A
   Component: FBenRDW       H12 0280
   Coding: 248400C06C9800080183E9601000200000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2D0700E58D901C53145-8078
   Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
   Component: Gateway       H13 4079
   Revision: 3C030052    Serial number: 5243C009A15929
   Coding: 0301000100008F407F070000005900325C120007008000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU73.rod
   VCID: 36352F8978C65F8B65F-8062
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20151030193558 01740
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 2396348203
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
   Component: Klima Zone 2  H52 0080
   Coding: 000000000000040100800080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 3537288565C054936C5-8060
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 A    HW: 4M0 907 397 A
   Component: LCM_MLBevoH05 0011
   ASAM Dataset: EV_LCMLeftHELLAAU736 001006
   Component: MEM-FS        008 0014
   Serial number: 00000174000827
   Coding: 00381B000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001006
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 5EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   ROD: EV_RearRadarS1BoschAU736.rod
   VCID: 343115816EBA4D9B5BB-8060
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000173606101
   Coding: 001C9B005E010080000130B0
   VCID: 42DD4359240EF32BD97-8016
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H19 0004
   Serial number: 0000354834
   Coding: B0110101000101
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 3333169D6BB44AA3421-8066
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   015 0344
   Coding: 01351E00000000C0630980006E00580203024000004F00502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94031591
131122 - Remote key 1
          B1479 04 [009] - Internal System Fault
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0014
   Serial number: 00000172698188
   Coding: FF201020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3C213DA146EA85DB93B-8068
   Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
   Component: TSG BFS       009 0039
   Serial number: 0000173603301
   VCID: 3E2537A950F697CBBDF-806A
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-041-K.clb
   Part No SW: 4M0 035 041 K    HW: 4M0 035 041 A
   Component: MU-P-LND-RW   050 1421
   Serial number: A657J0F7501017
   Coding: 01370608FF0A000013511101000A00102F001BE601700104DE
   ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
   VCID: 290FF4F5B9780073F8D-807C
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 803 BH    HW: -----------
   Component: ROW 2021  --- 0090
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ4015HV
   Multimedia system control head:
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0209
   Serial number: 29101500000000000190
   Compact disc data bank:
   Component: Gracenote2  --- 4007
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 4M0 907 273     HW: 4M0 907 273
   Component: RDKHUFAU736   H03 0009
   Serial number: 40000000003846
   ASAM Dataset: EV_RDKHUFAU736 002006
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 6D87C0E54D10DC53545-8038
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0211
   Revision: 9A001003    Serial number: 0378605584
   Coding: 0310000202000000
   Part No SW: 4M0 907 428 B    HW: 4M0 907 428
   Component: Areaview 2    H11 0301
   Serial number: C854606JG002013
   Coding: 02370601BF0FA10008404084
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004013
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 313F1C9591A878B330D-8064
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0143
   Revision: --------    Serial number: 30319012400000
   Coding: 0070
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
   VCID: 70B9D9915A2231BB7F3-8024
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 4M2 713 041 D    HW: 4M2 713 041 D
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20151002000996
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 270BF2CDAF6C3603EE9-8072
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 303919919AA271BB3F3-8064
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H12 0042
   Coding: 0407030600000401024023A7C50000B4A0F0C010C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F3B1AED879C6E43269-807A
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 6E85C7E94016274B6DF-803A
   Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
   Component: TSG HFS       009 0039
   Serial number: 0000173948804
   Coding: 000C990000010080000030A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 41DF4C552108E833C0D-8014
   Component: TSG HBFS      009 0039
   Serial number: 0000173932211
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 708000053602
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 73B3D69D2B340AA3821-8026
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 5EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   ROD: EV_RearRadarS2BoschAU736.rod
End----------(Elapsed Time: 02:27, VBatt start/end: 12.1V/12.1V)-----------
Dana
Western PA, USA
Thanks. Since you have a custom label file
Address 5F: Information Electr. (J794) Labels:* 4M0-035-041-K.clb​
Part No SW: 4M0 035 041 K HW: 4M0 035 041 A​
Component: MU-P-LND-RW 050 1421​
Serial number: A657J0F7501017​
Coding: 01370608FF0A000013511101000A00102F001BE601700104DE​
Shop #: WSC 31414 790 00001​
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115​
... I suspect it doesn't have provisions for SA code S12345 which allows you to enable Developer Mode.
I'm adding yours to the redirect file now. I'll send that to you via email shortly but make sure to move (or delete) the custom 4M0-035-041-K.clb file located in C:\Ross-Tech\VCDS\Labels so it doesn't prevent the redirect from loading the 4M0-035-MIB-HGH2 file in VCDS.
XPepino
Czech Republic
C?ID=91614
Hello, i finally made activation of Green Developer/Engineering menu.
In VCDS was not possible, with any security code :-(
I tried original VCP (sorry Uwe) and if i go to 5F - i have to change mode in "Diag. Session" from "Standard Diagnose" to "Engineering", finaly i dont need Security Code for Change 5F Developer mode to Active :-)
Hope it helps others :-)
May be there is another way via MIB Patch (from MIBSolution) but i did not try - only see in menu...
