Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: 2017 Audi Q7 Developer Mode
  1. #21
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by satpat2 View Post
    I thought there was supposed to be a MIB 1 or MIB 2 work around using SD card which is what I was advised in November of last year ?
    As I appreciate the pictures above can this only be seen when the hidden menu is unlocked ?
    A little confused now, thank you for all the support you folks have given so far
    Yes, you need to enable it in unit 5F to get access to the Green Menu (Hidden Menu) - but VCDS is no help here.
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
  2. #22
    Quote Originally Posted by rlarsen View Post
    It is not possible to enable with the VCDS cable on the newest models...
    I know - hidden menu (developer menu) is AFAIK also there on the newest models (A4/A5 B8.5
    http://mr-fix.info/mmi-hidden-green-menu-2g-3g/
    A4/A5 B9 - A6/A7 4G - Q7 4M
  3. Likes Dana, Uwe, DrPeter, jyoung8607 liked this post
  4. #23
    Oct 2016
    is VCDS a no go even in the future ? or just at the moment ?
  5. #24
    United States
    Hi Dan,
    We tested some stuff and I made a lbl file for your 4M1 Q7 part number in addition to Shaun's 8W0 flavor. It certainly isn't complete (no coding at all) but I can e-mail it to you for testing. I take it this is your personal car right?
    Best,
    Dana
    Edit, I sent the tester file to the admin@...... e-mail account with the subject 2017 Audi Q7 Developer Mode.
  6. Likes Dan@EuropaParts liked this post
  7. #25
    May 2015
    Copenhagen, Denmark
    No not tired yet
    Then why has no one then been able to use the VCDS cable for this - until your screen shot today ??
    What is your models installed option data for the shown apparently successful activation??
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  8. #26
    You just need a label with some macro instructions inside, which Dana just wrote for those two part numbers. If you post a scan showing the need maybe we can make you one too
    But it's definitely not a matter of writing directly to the EEPROM, just getting the adaptation to be accepted.
  9. Likes Uwe, Dana, D-Dub, Dan@EuropaParts liked this post
  10. #27
    May 2015
    Copenhagen, Denmark
    Good work
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  11. #28
    United States
    I missed this http://forums.ross-tech.com/showthre...ll=1#post91194
    > Address 5F: Information Electr. (J794) Labels: None
    > Part No SW: 4G1 035 021 F HW: 4G1 035 021 D
    > Component: MU-H-LND-EU 052 0670
    > Serial number: A733H0G7504554
    > Coding: 017503010000000013111102000A00332F000CE7F1700100DF
    > Shop #: WSC 02391 785 00200
    > ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
    > ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
    > VCID: 1D318F3E0CF36CAAB7-8048
    I didn't even look at the 4G/4H part number modules earlier so satpat2 feel free to bump this back up and we can look into that. Hopefully we have Q7 feedback at that time.
  12. Likes Eric, Dan@EuropaParts liked this post
  13. #29
    Dec 2016
    DE
    Quote Originally Posted by Eric View Post
    That's what I meant at the beginning of this thread. Thanks for shedding some light there, Eric.
  14. Likes Eric, Dana liked this post
  15. #30
    Jan 2015
    Piscataway, NJ, USA
    Hi Dan,
    Best,
    Dana
    Hi Dana,
    I tested it this morning and it worked! The developer mode adaptation can now be set to activated after entering S12345 security code. Consequently, the green menu can be activated by holding NAV/RADIO simultaneously. Thanks a lot for your assistance with this.
    Best,
    Daniil
    P.S. Yes, this is for my personal car.
  16. Likes Dana, Eric, jyoung8607, Uwe liked this post
