Results 1 to 5 of 5
Thread: Skoda Rapid Spaceback MY2016 5F Developer Mode
    May 2017
    i'm trying to enable the developer mode for my Swing infotainment system on my Skoda Rapid Spaceback MY2016.
    I've installed an external amp and want to get rid of the loudness option.
    According to some posts i should be able to activate the developer mode in 5F by using "S12345" as security key.
    But the controller does not accept the code. I've also tried "S20103" as code.
    Thanks in advance.
    Auto scan:
    Friday,09,February,2018,17:54:25:50134
    VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: TMBEE6NH7G4514259   License Plate:
    Mileage: 70961km-44093mi   Repair Order:
    Chassis Type: NH-SK25 (6C0)
    Scan: 01 03 08 09 10 15 17 19 44 5F 69
    VIN: TMBEE6NH7G4514259   Mileage: 70961km-44093miles
    Address 01: Engine (J623-CXMA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 EG    HW: 04L 907 309 E
       Component: R4 1,6L EDC   H22 1746
       Revision: 86H22---
       Coding: 01110032033401090000
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ECM16TDI01104L906021EG 001005
       ROD: EV_ECM16TDI01104L906021EG_001.rod
       VCID: 6E843FA7601B38178A9-803A
       Part No SW: 6R0 614 517 BQ    HW: 6R0 614 517 BQ
       Component: EBC 460 ESP   H52 0001
       Serial number: A00WOO8
       Coding: 43F84876897F00D7C225122F912B0079160900C1
       ASAM Dataset: EV_Brake1ESCEBC460PQ26L 003014
       ROD: EV_Brake1ESCEBC460PQ26L_003.rod
       VCID: 03527E135B99257F757-8056
    Address 08: Auto HVAC (J255)       Labels:| 6C0-907-044.clb
       Part No SW: 5JA 907 044 A    HW: 5JA 907 044 A
       Component: Climatronic   H02 0204
       Serial number:  1508281A-0492
       Coding: 111000001011000201
       ASAM Dataset: EV_ACClimaValeoPQ26 003001
       ROD: EV_ACClimaValeoPQ26.rod
       VCID: 392EDCFB69D5AFAF6FB-806C
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 C    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H08 0086
       Serial number: 001378140071
       Coding: 0C020850421520DB438040004007030800005900530A3500000000000000
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_BCMA0 005005
       ROD: EV_BCMA0_005.rod
       VCID: 3038E1DFBAAF6EE7D85-8064
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
       Component: FHSG DRV  007 0001
       Serial number: 00000000000002080396
       Coding: 011200
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Component: G355_FeuchteS  H07 0002
       Serial number: 21180980
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
       Component: PARKHILFE 3K  H10 0048
       Revision: --------    Serial number: 39231524301427
       Coding: 0001050101
       ASAM Dataset: EV_EPHVA14AU3700000 002022
       ROD: EV_EPHVA14AU3700000_SK25.rod
       VCID: 3A2CC3F76CD3A4B7661-806E
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 G    HW: 6C0 959 655 G
       Component: VW20Airbag816 001 0360
       Revision: --------    Serial number: 003RK000ACF1
       Coding: 88CCC00000800000540000C8002800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 372ADAC35FC1B9DF99F-8062
       Subsystem 1 - Part No SW: -----------    HW: 442 152 108 15
       Component: SideSensor_Df  1CA 0148
       Serial number: 3497A00C91C52F03D05O
       Subsystem 2 - Part No SW: -----------    HW: 442 150 908 15
       Component: SideSensor_Pf  1CA 0148
       Serial number: 3507A00B11BF9E00B32H
       Subsystem 3 - Part No SW: -----------    HW: 442 152 008 15
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00991C3DED3D43.
       Subsystem 4 - Part No SW: -----------    HW: 442 152 008 15
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A009B1C3DED253F%
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI3
       Part No SW: 5JA 920 741     HW: 5JA 920 741
       Component: KOMBI         208 1420
       Coding: 07240C002180000801083A001000000000000000
       VCID: 77AA1AC31F4179DF59F-8022
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H08 0086
       Revision: --------    Serial number: 001378140071
       Coding: 030100344F005A0000000000000000010001050000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 013020
       ROD: EV_GatewA0Lear_013_SK25.rod
       VCID: 6596408BB5EDFB4FFB3-8030
       Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000C1355190815
       Subsystem 2 - Part No SW: 6C0 915 181     HW: 6C0 915 181
       Component: J367-BDM  H08 0223
       Serial number: 62231D00144351519170
    Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
       Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  312 3232
       Serial number: CF971015
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016026
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 6D8638AB6D1DC30FB33-8038
       Part No SW: 5JA 035 871     HW: 5JA 035 871
       Component: MU-E--ER      852 6490
       Serial number: 29081500010738
       Coding: 03520300FF0000001111000400000A002F0000C40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       ROD: EV_MUEnt4CGen2LGE_VW48.rod
       VCID: 78A819FF125F76A7505-802C
              B201A 00 [009] -  -
              [Check software version management]
                        Reset counter: 67
                        Mileage: 70617 km
                        Date: 2018.02.01
                        Time: 18:08:59
                        Voltage terminal 30: 12.0 V
       Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
       Component: Anhaenger     H21 0203
       Revision: 8C001003    Serial number: 0378762280
       Coding: 0100000202000000
       Shop #: WSC 13765 790 00063
       VCID: 3E24CFE770FB88975A9-806A
    End----(Elapsed Time: 00:42, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Adap:
    Elapsed Time: 00:25
    ;SW:5JA-035-871   HW:5JA-035-871 ---  Information Electr. --- SA: 20103
    ;Component:MU-E--ER      852 6490, Coding:03520300FF0000001111000400000A002F0000C40000010000
    ;EV_MUEnt4CGen2LGE,001025,EV_MUEnt4CGen2LGE_VW48.rod
    ;Friday,09,February,2018,17:56:53:50134
    ;VCDS Version: Release 18.1.0 (x64)  Data version: 20180122 DS285.1
    ;VCID: 78A819FF125F76A7505-802C
    IDE00346-Summertime-automatic,manual ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,5E 05 A1 08 21 43 32 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,5E 05 A1 08 60 06 06 F6 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02063-Time display for start screen,2.0 s,1
    IDE02122-Developer mode,not activated ,1
    IDE02330-Number 2 for Info call,5E 06 91 84 16 66 87 76 F8 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,5E 06 91 84 16 38 91 09 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,30 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,30 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,30 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,30 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,30 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,30 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,30 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,30 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,30 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,30 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,30 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,30 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,30 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,30 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,30 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,30 ,49
    IDE02502-Confirmation of installation change,47 DA ,2
    IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
    IDE04550-Bluetooth: Sniff mode,On ,1
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
    MAS00951-Bluetooth,On ,1
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated ,60
    ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
    ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
    ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
    ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
    ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
    ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
    ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
    ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
    ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
    ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,activated ,60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,activated ,60
    ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,activated ,60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
    ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,activated ,60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,activated ,60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
    ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,activated ,60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
    ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,activated ,60
    ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,activated ,60
    ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
    ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,activated ,60
    ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,activated ,60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,CAB_9 ,64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9 ,64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,CAB_9 ,64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,CAB_9 ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,CAB_9 ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,CAB_9 ,64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,CAB_9 ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,CAB_9 ,64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
    ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,CAB_9 ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,CAB_9 ,64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,CAB_9 ,64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,CAB_9 ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9 ,64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,CAB_9 ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,CAB_9 ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,CAB_9 ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,CAB_9 ,64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,CAB_9 ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,CAB_9 ,64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9 ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,CAB_9 ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,CAB_9 ,64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,CAB_9 ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,CAB_9 ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,CAB_9 ,64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,CAB_9 ,64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,CAB_9 ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus ,64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Comfort data bus ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Comfort data bus ,8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
    ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
    ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,12
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,70 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,12
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,6 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,10 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,70 %,12
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %,12
    ENG117809-p_damping_Display,5 ms,1
    ENG117808-p_HMI_Display,13 %,1
    Elapsed Time: 00:24
  2. Likes Boki Ar liked this post
  3. #2
    Dec 2016
    DE
    The S12345 login must be stored in the label file to work, since it consists of a small macro that changes the diagnose mode to Engineering Session. If VCDS doesn't give the SA in the tool tip there is nothing you can do (except begging for RT to add it).
    Try and move 5J-5F.LBL (Not 5J-5F.CLB !) from:
    C:\Ross-Tech\VCDS\Labels
    to for example
    C:\Ross-Tech\VCDS
    Then I guess you have Labels for [5F].
  5. Likes FandaTDI liked this post
    May 2017
    Thank you guys.
    After moving the .LBL file out of the Labels folder, i was able to use the SA login and could also enable the developer mode.
    Finally i can disable that crappy loudness option and start calibrating my amp for besser sound.
    Mar 2014
    Italia
    Quote Originally Posted by OldBlacky View Post
    Thank you guys.
    So is it possible to disable the loudness on 5F MIB2 Unit? I have the same problem on my A4 with an external amp impossible to calibrate. Is it enough to activate developer mode using the S12345 Login?
