Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
Thread: 2017 Audi Q7 Developer Mode
    Maybe.
    In SSP for Audi A4 (8W), Q7 (4M), TT (FV) it is showed like this:
  2. Likes Uwe liked this post
  3. #12
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Jep - this is difficult to argue against that
    I got my "instructions" from here: http://audiwiki.bitt-c.at/index.php/...enü_aktivieren
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
  4. #13
    While at it, this is showed for System Reset.
  5. #14
    May 2015
    Copenhagen, Denmark
    Yes, I saw that in the same SSP - I have also updated the WiKi my self.
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  6. #15
    Oct 2016
    I tried the above on my A7, accepts security code of 20103 but won't change adaptation-10 developer mode activated ?, any help or is this not possible still on VCDS, I asked back in November but got no response so I thought I would try again
  7. #16
    Quote Originally Posted by satpat2 View Post
    Bring your car to our office and we'll figure out what needs to be done.
  8. #17
    May 2015
    Copenhagen, Denmark
    Here is a small wrap up of the available not always used menus:
    Hidden Menu/Green Menu:
    1. Enable "Hidden menu" (AFAIK not possible with VCDS).
    2. NAV/MAP (or CAR) + RADIO - First press NAV/MAP and keep it pressed, then RADIO pressing, and wait for about 5 Seconds - until the MMI screen show "Green Menu Loading...."
    Engineering Menu:
    1. Always available.
    2. NAV/Map (or CAR) + MEDIA - First press NAV/MAP and keep it pressed, then MEDIA pressing, and wait for about 5 Seconds - until the MMI screen show "Engineering Menu Loading...."
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  9. #18
    Oct 2016
    Where is your office ?
    Do you have one in the UK ?
  10. #19
    Oct 2016
    I thought there was supposed to be a MIB 1 or MIB 2 work around using SD card which is what I was advised in November of last year ?
    As I appreciate the pictures above can this only be seen when the hidden menu is unlocked ?
    A little confused now, thank you for all the support you folks have given so far
  11. #20
    No, we're in the US. The suggestion was tongue-in-cheek.
