Results 1 to 10 of 12
Thread: Desperate need of help Audi 8E Brake light fault
    Mar 2017
    Ireland
    Hi All
    new to this forum , we have never been caught out anything like this but as Audi have no record of this and i cannot find any thing and nothing makes sense .
    ok so we had brake light switch fault 00526 quick check with multi meter , so satisfied it was faulty ordered new one its a superseded part , fitted new part fault still on the system , checked with multi meter and the switch is working correctly this lead to further investigation , this is a two sided switch with 4 wires before anybody asks yes in every system abs/engine ecu, live data can be viewed and only one side is at fault , this is the red/brown + feed red/black signal wire
    so i have 12+ in the wires that should with one closed side sending 12+ back to abs until brake is pressed , the red/black wire should be 0v until brake pressed and then should be 12+ signal to abs ecu
    so once the new switch was fine i check the wires further, and i have 7v on the red/black signal return wire , chased all the wires for a short to the abs ecu , were right hand drive over here , so in the pass side foot well i opened the wire connection plug , with the plug open i checked from here back to the brake switch was checked and had in or around 6.56v in it so i was sure i had a wire issue , checked the other side to the abs ecu with the connection remade and pin red/black removed we had 8v so satisfied also had a wire issue on this side too
    when the circuit is remade the voltage drops to 7v
    after serious tracing i found what you see below which is wired in to the red/brown deliberately putting reduced voltage into the red/black and with the pin removed from the abs ecu i find the ecu is in fact sending out 8v on a signal pin which should accept 0 or 12v
    this is not a one off i have found the same in another a4 same year and i have now tested 3 abs ecu's from one with and with out the capacitor wired in to the brake light switch
    id say the extra faults in abs are due to pluggin and out ecu
    Thursday,09,March,2017,21:13:15:34799
    VCDS Version: 17.1.3.0
    Dealer/Shop Name: GUNT TUNING
    VIN: WAUZZZ8E45A076501   License Plate:
              67 69 75 76 77
    VIN: WAUZZZ8E45A076501   Mileage: 270630km-168161miles
    Address 01: Engine        Labels: 038-906-019-AVF.lbl
       Part No: 038 906 019 LJ
       Component: 1,9l R4 EDC 0000SG  5934
       Coding: 00002
       Shop #: WSC 06335
       VCID: 6AD0D60316F8061157-4B32
       WAUZZZ8E45A076501     AUZ6Z0D0303555
    16955 - Brake Switch (F)
                P0571 - 35-00 - Implausible Signal
    Readiness: 0 0 1 1 1
       Part No: 8E0 614 517
       Component: ABS/ESP front       4529
       Coding: 00000
       VCID: 65CAA53FFFE629697A-515A
                35-00 -  -
                36-00 - Open Circuit
                66-10 - Not Matched - Intermittent
       Part No: 8E0 820 043 AC
       Component:   A4 Klimaautomat   1424
       Coding: 00000
       Shop #: WSC 06335
       VCID: 62C0BE23EEC85E519F-5178
       Part No: 8E0 907 279 C
       Component: int. Lastmodul  RDW 0606
       Coding: 00001
       Shop #: WSC 06335
       VCID: 32600E63FEA88ED12F-4B32
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    01312 - Powertrain Data Bus
                79-10 - Please Check Fault Codes - Intermittent
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 J
       Component: Airbag 8.4EP        1002
       Coding: 0011602
       Shop #: WSC 06335 000 00000
       VCID: 3E782A536AF05AB1DB-515A
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
       Part No: 8E0 953 549 S
       Component: LenksŠulenmodul     0611
       Coding: 01001
       Shop #: WSC 06335
       VCID: 438E5BA751123759B4-4B18
       Part No: 8E0 920 950 M
       Component: KOMBI+WEGFAHRS. RB4 D42
       Coding: 00401
       Shop #: WSC 00186
       VCID: 336E0B6701B287D924-5178
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0704
       Coding: 00001
       VCID: 6BDED30719021F192C-513C
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
       Part No: 8E0 959 433 BC
       Component: KomfortgerŠt T3B    1512
       Coding: 06859
       Shop #: WSC
    Mar 2017
    Ireland
    [IMG]IMG_2675.JPG[/IMG]
    Moving to Car Repair Support.
    Mar 2017
    Ireland
    thanks for the help
    Hello OP and welcome to the VCDS forum.
    WTF is that in that wiring.........?
    Are you looking to start a fire?
    Please correct the FOD and install the correct parts for lights and wiring as per the Etka & RTFB using WD in repair manual.
    That's not OEM............ correct it or go buy some marshmallows!
    TUV what what what !
  6. #6
    Mar 2017
    Ireland
    sorry to say it is OE and i have now found it in 3 out of 8 ive checked in this year , every one identical and identical in every mannor heat shrink wiring and distance its placed from the switch .
    this is my point there is no repair manual to follow because none show this or a flow chart to test
    i had a bit of time yesterday , and removed more of the dash to get room , so i got brave and cut the red/black wire ecu side of the resistor/coil imput , tested and it does not match the one i cut from another car but the 8v is still in the loom , remove pin from abs ecu still there remove pin from engine ecu and its gone but the engine and abs ecu are bot placing 8v in the signal return red/black from the brake light switch , so what happened did something fry both ecu's and the resister , ive used 3 different abs ecu and all the same but the engine ecu was still implace at the time if i replace bith who is to say what will happen do i need to wire back in this set up in the pic
  7. #7
  8. #8
    Mar 2017
    Ireland
    6.5 yrs in Audi VW ALL normal procedures followed as i said they have nothing documented on it and it would be some one with experience of it who i'd say will be the only one able to shed light , thanks for the imput but I've 20 yrs at nothing but problems and never seen anything especially something undocumented
  9. #9
    Noise suppression circuit.
    Question is: Where exactly? And why?
  10. #10
    Yeah poor deployment of a Ferrite stick inverted.
    Op are you absolutely sure all fuses are OK?
    I suspect there is a blown one............or an open bay.
