Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Confirmed tweaks for 2017 Tiguan (MQB)
    Nov 2016
    Poland
    LED lights in door mirrors light, even in close:
    Modules 42 and 52 -> Coding -> Byte 01 -> Bit 5 deactivated
    DRL off when lights switch on position "0", but on when "AUTO":
    Module 09 -> Security Access enabled -> Adaptation -> search for "ENG115734" and change to inactive
    DLR option to switch on/off from menu (independent from above tweak):
    Module 09 -> Security Access enabled -> Adaptation -> search for "ENG116594" and select from dropdown "Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich" -> change to active
    Now you can go to Car Setup menu and you'll find extra tick to enable/disable DLRs.
    Refuel quantity on AID as one of Driving data options:
    Module 17 -> Coding -> Byte 10 -> Bit 4 activated
    Fan speed indicator (leds around button) when in AUTO mode:
    Module 08 -> Coding -> Byte 11 -> Bit 6 activated
    Disable "ingnition on" alarm, when drivers door open:
    Module 17 -> Adaptation -> search for "ignition" and select "actuator should appear as the only entry" from list -> change to "No display"
    Changing "blink" number on comfort blinkers:
    Module 09 -> Security Access -> Adaptation -> select "Turn Signal Controls-Komfortblinken Blinkzykien" -> change between 1 and 5
    Gauge/Needle sweep on AID
    Module 17 -> Coding -> Byte 01 -> Bit 00 activated
    "beep" when lock and unlock car doors
    Module 09 -> Security Access -> Adaptation -> search for "acknowledgement" and depending what you want, select active or inactive for available options with "Akustische" in description
    Sunroof comfort open/close
    Module 09 -> Security Access -> Adaptation -> search for "Sunroof-SAD Komfort" -> change to active (oeffnen - open / schliessen - close)
    Gold graphic details on AID
    Module 17 -> Adaptation -> search for "IDE02489" -> select one from 4 version (version 3 is gold, 1 and 2 looks identical for me)
    Hidden menu / service / testmode / "green" - whatever you want to call it ;)
    There are interesting features like handwriting recognition, but isn't work (recognize) when I tried it :(
    Probably you need to have active connection with VCDS interface to get "Testmode" menu item available.
    Module 5F -> Adaptation -> search for "IDE02122" (Developer mode) -> change to active -> press MENU button for a while.
    I don't remember did I use Security Access
    I'm sorry for poor quality of below pictures, I made a quick movie from "testmode" and below are freeze-frames to only show "something". I had no time to dig there, so maybe next time I'll do some photos.
    Threeway calling from Discover Media
    Module 5F -> Adaptation -> search for "ENG125042" (Vehicle configuration-Support_of_threeway_calling) -> change to active
    In settings section of Phone module, search for Conference tickbox.
    There are few others, I'll try to add them later when clean my notes from tests.
    Dec 2016
    What SA did you use as some these cannot be done without it and 31347 does not work. I have a 2016 MK2 Tiguan.
    Have you done the auto rain closing? I think it is the same as Superb settings.
    Nov 2016
    Poland
    Quote Originally Posted by welshkaiboy View Post
    Most of modules takes good old 31347 code from me - also sugessted by VCDS. One - but sorry, I don't remember which one - takes 20103. There was no suggestion on this module.
    No, I tried on two Tiguans and no rain closing success yet. But we had success on comfort close with panoramic sunroof.
    I must clean my notes to publish other confirmed tweaks.
    EDIT: not all modules require SA to make tweaks, check where I mention to use SA
  4. Likes Dana liked this post
    Dec 2016
    DE
    MY2016 Tiguans have another SA, when compared to other MQB. Unfortunately it is unknown.
  6. Likes Dana liked this post
    United States
    I agree, based on feedback we know some do not like 31347 even when the Security Access: Number of invalid keys Advanced Measuring data shows 0 (0 = good, no lock time). I do not have an alternative suggestion in that area but if we happen to locate it the label file (pop-up balloon) will be updated.
  8. Likes Uwe, TBAx liked this post
  9. #6
    Nov 2016
    Poland
    Like I said. I had no problem with 31347 and 20103 in 6m old Tiguan MQB based. Maybe there are some other Modules I didn't touch, but above tweaks worked with old codes.
    EDIT: if you want to compare module numbers, my first auto scans are published from months, and few days ago I posted complete adaptation maps for my and my friend Tiguans (32 modules).
  10. #7
    Nov 2016
    Poland
    I've updated first post, so enjoy
  11. Likes welshkaiboy liked this post
  12. #8
    Dec 2016
    MY2016 Tiguan module09 definitely does not like SA31347, it does not work even for simple comfort turns.
  13. #9
    Dec 2016
    Any luck in changing HBA speed I want to reduce the speed at which it comes on as i do a lot of driving in country lanes. It was simple on my old Tig to do.
  14. #10
    Nov 2016
    Poland
    Can you drop me your VIN on PM?
    You're probably interested in Module 9 -> Adaptation -> search for "ENG12163"
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h
    But I didn't try to change this.
  15. Likes welshkaiboy liked this post
