Results 1 to 10 of 12
Thread: 19: CAN Gateway Missing Label -2016 Jetta 1.4T CZTA Manual "S" with Tech.
    Verified VCDS User Roady900's Avatar
    Mar 2017
    Greetings All. I am new here so hopefully I am posting in the correct place.
    I just purchased the HEX-V2 and installed VCDS 17.1.3 (with data version: 20170320 DS267.7) and I updated the firmware on the V2. I am missing the label for 19: CAN Gateway. As per Peter Schumacher's email support, I performed the mapping procedures found at http://wiki.ross-tech.com/wiki/index...ol_Module_Maps and emailed them to support, along with logs and most recent autoscan. I am now waiting for Ross-Tech to respond, but thought it would be useful in case others have the same missing module. Also, wonder if any "regular" members have any insights...
    Below is my original autoscan (The data version is one generation older than the most current but the result is the same...:
    Monday,20,March,2017,17:25:58:35846
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
    Data version: 20170220 DS267.3
    VIN: 3VW167AJ6GM279042   License Plate: 16 JETTA 1.4T MAN S WITH TECH
    Mileage: 21230km-13191mi   Repair Order:
    Chassis Type: AJ (7E0)
    Scan: 01 03 04 08 09 15 17 19 25 44 5F 0B
    VIN: 3VW167AJ6GM279042   Mileage: 21230km-13191miles
    Address 01: Engine (J623-CZTA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AP    HW: 04E 907 309 AP
       Component: R4 1.4l TFS   H22 2953
       Revision: X5H22---
       Coding: 01110012232400000000
       Shop #: WSC 01795 002 1048576
       ASAM Dataset: EV_ECM14TFS01104E906023AP 003003
       ROD: EV_ECM14TFS01104E906023AP.rod
       VCID: 6E86C7A9301FC517CF5-803A
       CAN Converter 01:
    4012 - Cold Start Idle Air Control System
              P050A 00 [032] - Malfunction
       Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
       Component: ESP MK60EC1   H46 0175
       Revision: 00H46001
       Coding: A14B400C49290003850B02E8921B004021100012
       VCID: 75B4E8C555C9F6CF0EF-8020
    03409 - Rolling Mode recognized
                000 -  -  - Intermittent
                        Reset counter: 34
                        Mileage: 20871 km
                        Date: 2017.03.15
                        Time: 06:23:07
                        Count: 4096
                        Count: 396
                        Count: 43776
                        Count: 2816
                        Count: 253
       Part No SW: 5C0 820 047 CK    HW: 5C0 820 047 CK
       Component: J301  Klimaanlage   0210
       Revision: 2001402S    Serial number: 00000002963559
       Shop #: WSC 00066 790 00185
       VCID: 6B80CEBD0F8D303FE8B-803E
    Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 189     HW: 7E0 937 189
       Component: BCM PQ25 MMI3 H80 0733
       Revision: BA080001    Serial number: 18003310150014
       Coding: 7B994B1808AB0B0000392080240884D50FC6702E60004070B00010032844
       VCID: 71BCDCD521A1DAEFD27-8024
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Serial number: 14202585150924170057
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Serial number: 14102584151001110126
       Coding: 820000
       Subsystem 3 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
       Serial number: 2391515083501034AD1B
       Coding: 280000
       Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14102587150930201414
       Coding: 800000
       Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14102586150929130112
       Coding: 800000
    00077 - Windshield Wiper Stop Switch (F229)
                        Reset counter: 31
                        Mileage: 20791 km
                        Date: 2017.03.14
                        Time: 22:07:36
    Address 15: Airbags (J234)       Labels: 561-959-655.clb
       Part No SW: 561 959 655     HW: 561 959 655
       Component: AirbagVW11    001 0207
       Serial number: 003RXM01ZW5T
       Coding: 8CCCF000000000005000001AC20800000065
       ASAM Dataset: EV_AirbaVW11SMEVW411 001002
       ROD: EV_AirbaVW11SMEVW411.rod
       VCID: 6390A69DEBDD787F50B-8036
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003L2BEB
       Coding: 303141
       Subsystem 2 - Part No SW: -----------    HW: 480 001 109 15
       Serial number: 3570000000023865761A
       Subsystem 3 - Part No SW: -----------    HW: 480 001 109 15
       Serial number: 3580000000071A50761A
       Subsystem 4 - Part No SW: -----------    HW: 480 022 309 15
       Component: SideSensor_Dr  000 0148
       Serial number: 3510001BB1C1FED5117G
       Subsystem 5 - Part No SW: -----------    HW: 480 022 209 15
       Component: SideSensor_Pr  000 0148
       Serial number: 3520001B31BD63D2B65A
       Subsystem 6 - Part No SW: -----------    HW: 480 020 309 15
       Component: FrontSensor_D  000 0189
       Serial number: 3550001B51BE6062D6DG
       Subsystem 7 - Part No SW: -----------    HW: 480 020 309 15
       Component: FrontSensor_P  000 0189
       Serial number: 3560001B51BE6061B6AB
       Part No SW: 5C6 920 955 A    HW: 5C6 920 955 A
       Component: KOMBI         H04 1007
       Coding: 270A010000
       Shop #: WSC 00066 790 00319
       VCID: 2D0400A5FD99FE0FB6F-8078
       Part No SW: 7E0 909 901     HW: 7E0 937 189
       Component: GW-K-CAN TP20 H80 0733
       Revision: BA080001
       Coding: 102201
       VCID: 688AB1B1127B1B27859-803C
                        Date: 2016.07.30
                        Time: 00:00:00
       Component: IMMO          H04 1007
       VCID: 6A8ECBB90CF7293793D-803E
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 304    3501
       Revision: 00H22000
       VCID: 392C24F5355152AF2A7-806C
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 5C0 035 200     HW: 5C0 035 200
       Component: MU-S-S-US     H22 0245
       Serial number: VWZAZ2R0514126
       Coding: 02630100AA00000011220001001808001F0100D40020010002
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 52FE7359846781F7CBD-8006
    End----------(Elapsed Time: 01:38, VBatt start/end: 14.4V/14.4V)-----------
    Lovely. Virtual Gateway that's actually in the BCM...
    Looks like there's a German version of that file, not yet translated.
  3. Likes Eric liked this post
    Mar 2017
    Greetings Uwe. Quite surprised by your quick reply. I am new to VW, Ross-Tech, and VCDS, but I am in IT and a pretty quick study. From your many responses around the forum I get the sense that you are quite the personality and the creator of VCDS. You are the wizard behind the curtain? So far I am quite impressed with the V2 interface, VCDS, and the large active community you have built around your products.
    I must say I am a bit unsure of what to make of your reply. Perhaps if we spent an hour over a pint I would have a better read!
    Please correct me if I am wrong...but...I am presuming it is
    A) Negative that the module is virtual?
    B) Positive that there appears to be a German version of the file?
    C) Neutral in that there is no way to know if/when it will be translated to NAR?
    Would my presumptions be correct?
    Magdeburg, Germany
    It's absolutely not negative that this is a virtual module, standard Polo-platform electronics for the simple reason that it saves the manufacturer money. As far as the label file is concerned, the English version was done but hadn't been included in the last data version due to a mistake on my end. This will be fixed in the next update/data version.
  6. Likes DV52, Uwe, Roady900 liked this post
    Roady900: Hi - Yes indeed, he is the wizard behind the curtain - the puppet master who controls the marionette strings - the Benevolent Dictator supremo (albeit I secretly suspect that there is a disconnect between his bark and his bite). But enough of hagiography - I'm by no means an expert on your particular vehicle (hell, I'm not an expert on any particular vehicle), but if you look at your auto-scan and in particular, you note the part numbers for the Body Control Module (the module @ address hex09) and the Gateway - you see the following:
    So- both these module have the same hardware number - this tells him that the CAN Gateway is embedded into the BCM and hence Uwe's declaration "Virtual Gateway that's actually in the BCM..." I'm fairly certain that the Jetta thieved this arrangement from the 2010 Polo and the T5 (2010 as well?)
    The rest is as Sebastian says - Sebastian lodged his post as I was mid way through mine - apology Sebastian
  8. Likes Uwe, Roady900 liked this post
  9. #6
    Quote Originally Posted by Roady900 View Post
    Well, I'm the guy who started this thing 17 years ago. But I've turned over most of the wands and cauldrons to some of the fine folks that were attracted by the early spells I cast myself.
    I think it's negative because that makes it more difficult to upgrade it to a better/newer one at some point down the road.
  10. Likes Roady900 liked this post
  11. #7
    Mar 2017
    Great news! I have seen in other threads that sometimes you provide a label file for a user to manually dump in the labels folder. Might that be an option for me? I noticed the last data version was released on 20170320 and the previous version was 20170220 (Exactly one month). Is that standard practice or just coincidence?
  12. #8
    Just coincidence.
  13. #9
    Mar 2017
    Hi Don.
    Thank you for the information. Now I know to look out for this (future VW's etc). I guess this means that if a dealer were to update the bcm it could effect adaptations/coding of subsystems tied to it? Changed my Avatar. Hope it is to Uwe's liking.
  14. #10
    Mar 2017
    That's a great point. Although, my initial intent is not to get too crazy. If able, I want to add a traction control button kit. I am trying to get USP Motorsports to send a kit at a reduced price. They have it marked as not compatible with the 1.4T, but only because it has not been tested. I know coding will need to be done in the ABS module and have seen many threads/posts. If I have questions for other forum members about it is it better to post in the Tweaks section or the Retrofit section?
