what does these messages mean?
golfi_vend
Tartu, Estonia
C?ID=195131
First your WSC/importer/equipment data must be non-zero value. - Click yes, if unsure what that means.
Second that coding wasn't accepted. If memory serves correct, than this message could also appear when wrong wsc/importer/equipment data is inserted.
lukappaseidue
Italy
C?ID=211520
so it means (the first pic) that my MFL has not been coded?
lukappaseidue
Italy
C?ID=211520
Uwe, please, could You help me?
P.S. Thank You Golfi_vend for your reply
Please post up some real scan data so we can see how the 16 module is currently coded, what it currently has for WSC, Importer, and equipment number, and tell us what value you are trying to change the coding to.
lukappaseidue
Italy
C?ID=211520
here my autoscan
Tuesday,08,July,2014,22:34:26:14849
VCDS Version: 14.7.0.0
Data version: 20140601
VIN: WAUZZZ8V8DA078945   License Plate: ER292WG
Mileage: 20515km-12747mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V8DA078945   Mileage: 20515km-12747miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 AL    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5516
   Revision: 84H22---
   Coding: 02190012032401092000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM16TDI01104L906021AL 002009
   ROD: EV_ECM16TDI01104L906021AL.rod
   VCID: 6FEBA25FB6A70D4286-803A
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 12F162A220270A740180060401C82548460450806080A4F20259000405
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 7DF78817ECCB6FD204-8028
Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
   Part No SW: 8V0 820 047 B    HW: 8V0 820 047 B
   Component: AC Manuell el H09 0031
   Revision: 20017000    Serial number: 00000000015064
   Coding: 03000104002000001000000000000100
   ASAM Dataset: EV_AirCondiFrontManAU37X 008016
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 35675037947B77928C-8060
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011311200381
   Coding: 04000A42C2C1227D03844000001C07A8000C000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 468527FBF99DEC0A15-8013
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
   Component: WWS370 130412  041 0580
   Serial number:         130415184616
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A
   Component: G397_RLS  H06 0002
   Serial number: 20112867
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 05 03 2013  00000197
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  009 0026
   Revision: --------    Serial number: 60831310802177
   Coding: 0000040001
   ASAM Dataset: EV_EPHVA14AU3700000 002015
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 377B5A3F8E7785829E-8062
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Serial number: 003M2R017KNJ
   Coding: 98CCC0000C0000005C540000004800000065
   VCID: 4B9316CFE2FF1162CA-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 604 13
   Serial number: 35767000000A39309C0V
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 604 13
   Serial number: 358670000000279D0D0U
   Crash sensor for side airbag; rear driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 400 304 13
   Serial number: 3516502C50FEA2160304
   Crash sensor for side airbag; rear passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 304 13
   Serial number: 3526502C70FEA211930B
   Subsystem 5 - Part No SW: -----------    HW: 480 401 503 13
   Serial number: 35565029B0FAE894331R
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 604 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502A70FAE8A2F0B+
   Pedestrian protection crash sensor; passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 604 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 22965029D0FAE8A5530W
   Center pedestrian protection crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 604 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C90FBDE34C0B-
   Part No SW: 8V0 953 521 C    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 20041308490755
   Coding: AE08
   Shop #: WSC 30488 000 1048576
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 3A7D430BBD6598EA61-806F
   Part No SW: 8V0 920 870 B    HW: 8V0 920 870 B
   Component: KOMBI         H24 0570
   Coding: 07A40A002A80000804006800000000
   Part No SW: 5Q0 907 530 J    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1126
   Revision: --------    Serial number: 0000529803
   Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 008010
   ROD: EV_GatewLear_AU37.rod
   VCID: 3879590383698AFA97-806D
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 06 01 2014  B1288208
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051251001
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 12041303110049
   Coding: 001C0E205C00040000001002
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 3F8B321FA647BDC256-806A
   Coding: 81
   ROD: EV_SteerAssisMQB.rod
   VCID: 3D774817AC4BAFD244-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 06041306071109
   Coding: 001C06205E00040000001002
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3E754F1BA14DB4CA5D-806B
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Component: LWR-ECU       005 0070
   Coding: 018A000001000000
   VCID: 75E79037D4FB37924C-8020
   Part No SW: 8V0 035 864 B    HW: 8V0 035 864 B
   Component: MU-S-N-ER     040 0420
   Serial number: A3F00703143183
   Coding: 01730301FF00000021110001000A00002F0004440100010006
   Shop #: WSC 62665 001 1048576
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_AU37.rod
   Engine Control Module 2:
   Subsystem 1 - Part No SW: 8V0 919 866 A    HW: -----------
   Component:  ECE 2013  --- 0021
   Seat Adjustment Driver Side:
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DY3004UU
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000006031300010138
End-------------------------(Elapsed Time: 03:38)--------------------------
here my 16 module
	SW:8V0-953-521-C   HW:5Q0-953-549-A ---  Steering wheel
	Component:Lenks. Modul  007 0070	 Coding:AE08
	EV_SMLSKLOMQB	9001	EV_SMLSKLOMQB_AU37.rod
	Tuesday	8	July	2014	23:01:40:14849
	VCDS Version: Beta 14.7.0  Data version: 20140601
p_s_NWDF_spg	OFF
p_t_blinker_entprellen	40 ms
p_t_blinker_err_el_kurzschluss	200 ms
p_t_blinker_err_el_unterbrechung	1000 ms
p_t_blinker_err_fernlicht_haengt_aus	5000 ms
p_t_blinker_err_fernlicht_haengt_ein	300 s
p_t_blinker_err_gra_haengt_aus	5000 ms
p_t_blinker_err_gra_haengt_ein	300 s
p_t_blinker_err_lichthupe_haengt_aus	5000 ms
p_t_blinker_err_lichthupe_haengt_ein	300 s
p_t_blinker_err_unplausibel	200 ms
p_t_blinker_gra_entprellen	40 ms
p_t_blinker_sperrzeit	100 ms
p_t_entprellzeit_ueberspannung	90000 ms
p_t_entprellzeit_unterspannung	90000 ms
p_t_fas_entprellen	40 ms
p_t_gra_ea_error	200 ms
p_t_grahebel_entprellen	40 ms
p_t_grahebel_err_el_kurzschluss	200 ms
p_t_grahebel_err_el_unterbrechung	1000 ms
p_t_grahebel_err_gra_haengt_aus	5000 ms
p_t_grahebel_err_gra_haengt_ein	300 s
p_t_grahebel_err_unplausibel	200 ms
p_t_hupe_entprellen	40 ms
p_t_hupe_err_hinweis	2000 ms
p_t_hupe_err_hupe_haengt_aus	5000 ms
p_t_hupe_err_hupe_haengt_ein	60 s
p_t_hupe_indien_entprellen	500 ms
p_t_spannung_obere_schwelle	16.5 V
p_t_spannung_untere_schwelle	8.5 V
p_t_wischer_entprellen	40 ms
p_t_wischer_err_el_kurzschluss	200 ms
p_t_wischer_err_el_unterbrechung	1000 ms
p_t_wischer_err_intervallpoti_haengt_aus	5000 ms
p_t_wischer_err_intervallpoti_haengt_ein	300 s
p_t_wischer_err_mfa_haengt_aus	5000 ms
p_t_wischer_err_mfa_haengt_ein	300 s
p_t_wischer_err_waschen_haengt_aus	5000 ms
p_t_wischer_err_waschen_haengt_ein	300 s
p_t_wischer_err_wischen_haengt_aus	5000 ms
p_t_wischer_err_wischen_haengt_ein	300 s
p_t_wischer_intervall_entprellen	40 ms
p_t_wischer_winterstellung	60 s
I've retrofitted MFL, but I think there is something wrong
Module "steering wheel electronics (16)"
"Byte 0" "Bit 1" = 1 -> the windshield wiper lever
"Byte 0" "Bit 1" = 0 -> Multi-function steering wheel
I think that right coding is:
AC08
instead of
AE08.
I've also coded Modul 17:
Byte 10 Bit 7 must be 1.
Coding would be
07A40A002A8000080400E800000000
instead of
is it so?
Mari
C?ID=150535
Allready tried to do the coding via longcodinghelper?
OK, thank you for posting data that people can work with.
When you code your 16-Steering Column module, try giving it a different WSC than 30488, a non-zero importer number, and a plausible equipment number (something between 00001 and 99999 would be good).
As for the exact coding values, I will defer that to people who know more about those cars than I do.
lukappaseidue
Italy
C?ID=211520
Please, could You explane me how to do it?:rolleyes:
Change the values in the WorkShop Code, Importer, and Equipment number fields on the Coding screen .
lukappaseidue
Italy
C?ID=211520
You have been very clear.
Where can I find original value? (again, sorry for stupid question)
In my car has been added only Alarm and MFL, all other thing born with the car
Original value for what?
lukappaseidue
Italy
C?ID=211520
my 16 module have Imp value equal to 000, while almost all of others modules have 790 Imp code. Is it right? what's happen If i put 790 Imp code to 16 module?
it is normal the Imp codes are missing?
In replacement modules, yes. And many will not accept coding changes without a non-zero Importer code (and WSC and Equipment number).
