Results 1 to 10 of 14
Thread: what does these messages mean?
    Jun 2014
    Italy
    Question what does these messages mean?
    As the object.
    I was trying to code something on my A8 8V, but this two messages appeared.
    What does they mean?
    https://imageshack.com/i/ewLkfJCyj
    https://imageshack.com/i/idW64jptj
    Tartu, Estonia
    First your WSC/importer/equipment data must be non-zero value. - Click yes, if unsure what that means.
    Second that coding wasn't accepted. If memory serves correct, than this message could also appear when wrong wsc/importer/equipment data is inserted.
    The world is my oyster...
    Jun 2014
    Italy
    so it means (the first pic) that my MFL has not been coded?
    Jun 2014
    Italy
    Uwe, please, could You help me?
    P.S. Thank You Golfi_vend for your reply
    Please post up some real scan data so we can see how the 16 module is currently coded, what it currently has for WSC, Importer, and equipment number, and tell us what value you are trying to change the coding to.
    Jun 2014
    Italy
    here my autoscan
    Tuesday,08,July,2014,22:34:26:14849
    VCDS Version: 14.7.0.0
    Data version: 20140601
    VIN: WAUZZZ8V8DA078945   License Plate: ER292WG
    Mileage: 20515km-12747mi   Repair Order:
    Chassis Type: 8V (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
    VIN: WAUZZZ8V8DA078945   Mileage: 20515km-12747miles
    Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 021 AL    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 5516
       Revision: 84H22---
       Coding: 02190012032401092000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM16TDI01104L906021AL 002009
       ROD: EV_ECM16TDI01104L906021AL.rod
       VCID: 6FEBA25FB6A70D4286-803A
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 12F162A220270A740180060401C82548460450806080A4F20259000405
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 7DF78817ECCB6FD204-8028
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
       Part No SW: 8V0 820 047 B    HW: 8V0 820 047 B
       Component: AC Manuell el H09 0031
       Revision: 20017000    Serial number: 00000000015064
       Coding: 03000104002000001000000000000100
       ASAM Dataset: EV_AirCondiFrontManAU37X 008016
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 35675037947B77928C-8060
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011311200381
       Coding: 04000A42C2C1227D03844000001C07A8000C000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 468527FBF99DEC0A15-8013
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
       Component: WWS370 130412  041 0580
       Serial number:         130415184616
       Coding: 0A47F7
       Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A
       Component: G397_RLS  H06 0002
       Serial number: 20112867
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
       Serial number: 05 03 2013  00000197
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
       Component: PARKHILFE 4K  009 0026
       Revision: --------    Serial number: 60831310802177
       Coding: 0000040001
       ASAM Dataset: EV_EPHVA14AU3700000 002015
       ROD: EV_EPHVA14AU3700000_AU37.rod
       VCID: 377B5A3F8E7785829E-8062
       Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
       Serial number: 003M2R017KNJ
       Coding: 98CCC0000C0000005C540000004800000065
       VCID: 4B9316CFE2FF1162CA-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 001 604 13
       Serial number: 35767000000A39309C0V
       Crash sensor for side airbag; passenger side:
       Subsystem 2 - Part No SW: -----------    HW: 480 001 604 13
       Serial number: 358670000000279D0D0U
       Crash sensor for side airbag; rear driver side:
       Subsystem 3 - Part No SW: -----------    HW: 480 400 304 13
       Serial number: 3516502C50FEA2160304
       Crash sensor for side airbag; rear passenger side:
       Subsystem 4 - Part No SW: -----------    HW: 480 400 304 13
       Serial number: 3526502C70FEA211930B
       Subsystem 5 - Part No SW: -----------    HW: 480 401 503 13
       Serial number: 35565029B0FAE894331R
       Pedestrian protection crash sensor; driver side:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 604 13
       Component: PedP_Sensor_D  001 6149
       Serial number: 2286502A70FAE8A2F0B+
       Pedestrian protection crash sensor; passenger side:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 604 13
       Component: PedP_Sensor_P  001 6149
       Serial number: 22965029D0FAE8A5530W
       Center pedestrian protection crash sensor:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 604 13
       Component: PedP_Sensor_C  001 6149
       Serial number: 2306502C90FBDE34C0B-
       Part No SW: 8V0 953 521 C    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 20041308490755
       Coding: AE08
       Shop #: WSC 30488 000 1048576
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 3A7D430BBD6598EA61-806F
       Part No SW: 8V0 920 870 B    HW: 8V0 920 870 B
       Component: KOMBI         H24 0570
       Coding: 07A40A002A80000804006800000000
       Part No SW: 5Q0 907 530 J    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1126
       Revision: --------    Serial number: 0000529803
       Coding: 030100F40B0876005B000248080B00000001000000000000000000000000
       ASAM Dataset: EV_GatewLear 008010
       ROD: EV_GatewLear_AU37.rod
       VCID: 3879590383698AFA97-806D
       Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
       Serial number: 06 01 2014  B1288208
       Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
       Component: J367-BDM  H08 0192
       Serial number: 00000000004051251001
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 12041303110049
       Coding: 001C0E205C00040000001002
       ROD: EV_DCUDriveSideEWMAXKLO.rod
       VCID: 3F8B321FA647BDC256-806A
       Coding: 81
       ROD: EV_SteerAssisMQB.rod
       VCID: 3D774817AC4BAFD244-8068
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 06041306071109
       Coding: 001C06205E00040000001002
       ROD: EV_DCUPasseSideEWMAXKLO.rod
       VCID: 3E754F1BA14DB4CA5D-806B
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       Component: LWR-ECU       005 0070
       Coding: 018A000001000000
       VCID: 75E79037D4FB37924C-8020
       Part No SW: 8V0 035 864 B    HW: 8V0 035 864 B
       Component: MU-S-N-ER     040 0420
       Serial number: A3F00703143183
       Coding: 01730301FF00000021110001000A00002F0004440100010006
       Shop #: WSC 62665 001 1048576
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_AU37.rod
       Engine Control Module 2:
       Subsystem 1 - Part No SW: 8V0 919 866 A    HW: -----------
       Component:  ECE 2013  --- 0021
       Seat Adjustment Driver Side:
       Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H48 0013
       Serial number: AUZ8Z9DY3004UU
       Sound System:
       Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
       Component: ControlUnit_B  H33 0037
       Serial number: C1000006031300010138
    End-------------------------(Elapsed Time: 03:38)--------------------------
    here my 16 module
    	SW:8V0-953-521-C   HW:5Q0-953-549-A ---  Steering wheel
    	Component:Lenks. Modul  007 0070	 Coding:AE08
    	EV_SMLSKLOMQB	9001	EV_SMLSKLOMQB_AU37.rod
    	Tuesday	8	July	2014	23:01:40:14849
    	VCDS Version: Beta 14.7.0  Data version: 20140601
    p_s_NWDF_spg	OFF
    p_t_blinker_entprellen	40 ms
    p_t_blinker_err_el_kurzschluss	200 ms
    p_t_blinker_err_el_unterbrechung	1000 ms
    p_t_blinker_err_fernlicht_haengt_aus	5000 ms
    p_t_blinker_err_fernlicht_haengt_ein	300 s
    p_t_blinker_err_gra_haengt_aus	5000 ms
    p_t_blinker_err_gra_haengt_ein	300 s
    p_t_blinker_err_lichthupe_haengt_aus	5000 ms
    p_t_blinker_err_lichthupe_haengt_ein	300 s
    p_t_blinker_err_unplausibel	200 ms
    p_t_blinker_gra_entprellen	40 ms
    p_t_blinker_sperrzeit	100 ms
    p_t_entprellzeit_ueberspannung	90000 ms
    p_t_entprellzeit_unterspannung	90000 ms
    p_t_fas_entprellen	40 ms
    p_t_gra_ea_error	200 ms
    p_t_grahebel_entprellen	40 ms
    p_t_grahebel_err_el_kurzschluss	200 ms
    p_t_grahebel_err_el_unterbrechung	1000 ms
    p_t_grahebel_err_gra_haengt_aus	5000 ms
    p_t_grahebel_err_gra_haengt_ein	300 s
    p_t_grahebel_err_unplausibel	200 ms
    p_t_hupe_entprellen	40 ms
    p_t_hupe_err_hinweis	2000 ms
    p_t_hupe_err_hupe_haengt_aus	5000 ms
    p_t_hupe_err_hupe_haengt_ein	60 s
    p_t_hupe_indien_entprellen	500 ms
    p_t_spannung_obere_schwelle	16.5 V
    p_t_spannung_untere_schwelle	8.5 V
    p_t_wischer_entprellen	40 ms
    p_t_wischer_err_el_kurzschluss	200 ms
    p_t_wischer_err_el_unterbrechung	1000 ms
    p_t_wischer_err_intervallpoti_haengt_aus	5000 ms
    p_t_wischer_err_intervallpoti_haengt_ein	300 s
    p_t_wischer_err_mfa_haengt_aus	5000 ms
    p_t_wischer_err_mfa_haengt_ein	300 s
    p_t_wischer_err_waschen_haengt_aus	5000 ms
    p_t_wischer_err_waschen_haengt_ein	300 s
    p_t_wischer_err_wischen_haengt_aus	5000 ms
    p_t_wischer_err_wischen_haengt_ein	300 s
    p_t_wischer_intervall_entprellen	40 ms
    p_t_wischer_winterstellung	60 s
    I've retrofitted MFL, but I think there is something wrong
    Module "steering wheel electronics (16)"
    "Byte 0" "Bit 1" = 1 -> the windshield wiper lever
    "Byte 0" "Bit 1" = 0 -> Multi-function steering wheel
    I think that right coding is:
    AC08
    instead of
    AE08.
    I've also coded Modul 17:
    Byte 10 Bit 7 must be 1.
    Coding would be
    07A40A002A8000080400E800000000
    instead of
    is it so?
  7. #7
    Jun 2014
    Allready tried to do the coding via longcodinghelper?
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  8. #8
    OK, thank you for posting data that people can work with.
    When you code your 16-Steering Column module, try giving it a different WSC than 30488, a non-zero importer number, and a plausible equipment number (something between 00001 and 99999 would be good).
    As for the exact coding values, I will defer that to people who know more about those cars than I do.
    Jun 2014
    Italy
    Please, could You explane me how to do it?
  10. #10
    Change the values in the WorkShop Code, Importer, and Equipment number fields on the Coding screen .
