Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: Service Due Reset for 2011 Audi A4
  1. #31
    Jul 2014
    MI
    I can only find it if you give me the docid (which you can see if you go to View Saved Files).
    DOCID# 0000-4223
    Sure, access the instrument cluster and you will find it in the field labeled VAG Number.
    VAG # 8K0-920-950-H
  2. #32
    Try putting the following values in the channels in this sequence:
    50: 160
    51: 365
    44: 365
    49: 365
    45: 1
    02: 0
  3. #33
    Jul 2014
    MI
    Thanks for the help. The "service due" notice is gone.
    Should I be doing this sequence everytime I changed my oil?
  4. Likes Uwe liked this post
  5. #34
    No, all you should have to do when you change your oil is set channel 02 to 0.
    In addition, when you do your mileage based and time based inspections, you can set 53 and 55 to 0.
  6. #35
    Jul 2014
    MI
    Is there a sequence I should follow when setting the following channels to "0", Channel 02, 53 then 55?
  7. #36
    Quote Originally Posted by PinoySaMI View Post
    I think on those, it doesn't matter.
