Results 21 to 30 of 36
Thread: Service Due Reset for 2011 Audi A4
  1. #21
    Jul 2014
    MI
    I can put these back to its' original values.
  2. #22
    Quote Originally Posted by PinoySaMI View Post
    I would definitely recommend that.
  3. #23
    Jul 2014
    MI
    could these codes be the reason why I can't reset the "service due" notification on my dash board?
  4. #24
    Think about it; if you've set these to zero:
    42 - min mileage to service
    43 - max value to service
    44 - max time to service
    Then service will always be due!
  5. #25
    Jul 2014
    MI
    the previous values for both channels 42 and 43 were 150. Shouldn't they have different target numbers? Ch44 was 365.
  6. #26
    No, because NAR cars do not use "flexible" service intervals.
  7. #27
    Jul 2014
    MI
    I put back the values for channel 42-44. Below are the values for the following channels;
    2 - 0
    40 - 0
    41 - 0
    42 - 150
    43 - 150
    44 -365
    45 - 1
    49 - 365
    50 - 160
    51 - 0
    52 - 160
    53 - 0
    54 - 365
    55 - 0
    56 - 2818
    The "service due" notification is still showing.
  8. #28
    Sometimes you have to adjust those channels in a particular order...
    What's you're instrument cluster part number? Do we have an Auto-Scan from this car somewhere?
  9. #29
    Jul 2014
    MI
    I did am auto scan before I tried to reset the "service due" notice. I saved in the cloud.
    I don't know what my instrument cluster PN is. Can I search for it using the VCDS mobile?
  10. #30
    I can only find it if you give me the docid (which you can see if you go to View Saved Files).
    Sure, access the instrument cluster and you will find it in the field labeled VAG Number.
