Results 21 to 30 of 32
Thread: Can't Connect to Hex Net with Laptop
  1. #21
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Nuwandam View Post
    Im using my phone as a hotspot for the laptop and the HEX-NET. Not sure if i have those kind of options.
    Galaxy S7 Edge
    I'm not super stoked about that "Internal checks failed code 01" in your self-test screenshot. I haven't encountered that and I don't know what it means, so I don't know if it has any bearing on your problem. Perhaps Ross-Tech can comment.
    I also have a Galaxy S7 Edge, and it doesn't really have much in the way of config options. It should work fine for either VCDS Mobile and for VCDS Desktop via WiFi. The fact it's working for VCDS Mobile rules out having broken the few things you could potentially break. If you can reach VCDS Mobile, but VCDS Desktop isn't working, that's generally a firewall issue on your PC.
    Do you happen to have any third-party firewall or anti-virus / anti-malware (which often includes a firewall) installed? If so, try uninstalling that and repeating your test. If not, let's try making sure all settings are correct for the built-in Windows firewall.
    1) Open an elevated command prompt. Here are some instructions: Elevated Command Prompt on Windows 8. It's generally the same on Windows 10. Option one is the easiest.
    2) Enter the following two commands, exactly as shown:
    netsh advfirewall firewall delete rule name="VCDS" program="C:\Ross-Tech\VCDS\VCDS.exe"
    netsh advfirewall firewall delete rule name="VCDS" program="C:\Ross-Tech\VCDS-Beta\VCDS.exe"
    3) Close the command prompt -- just type "exit".
    4) Re-install VCDS, and at the beginning of the process, turn on the 'Open firewall for HEX-NET' checkbox - it's not on by default.
    5) Try running VCDS again, and see what happens.
    Jason
  2. Likes Santos, Eric, Dana, Uwe liked this post
  3. #22
    United States
    Thanks for pointing that out Jason! We did spot something goofy server side after you mentioned Internal checks failed.
    Landis,
    I think we need to RMA this HEX-NET. We will take care of that under Goodwill warranty so you only need to cover the trackable shipping method (of your choice) to us. Your RMA Number is 170321RA2.
    Please send it via a trackable method to:
    Ross-Tech, LLC
    Attention:170321RA2
    881 Sumneytown Pike
    Lansdale, PA 19446
    Tel: +1 267 638 2300
    Make sure to write the above RMA number on the package to prevent a delay in processing. Please include your shipping address in the package to make sure we send the return item back to the correct location.
    Best,
    Dana
    Ref RET?ID=5103
  4. Likes jyoung8607, Uwe, Nuwandam liked this post
  5. #23
    United States
    P.S. Don't hesitate to bump this thread back up if a few days pass after we receive the interface.
  6. Likes Uwe, Nuwandam liked this post
  7. #24
    Mar 2017
    No -- not from some website.
    Of course that website can't ping stuff inside your LAN.
    Open a CMD prompt window and type:
    PING 192.168.43.50
  8. Likes Uwe liked this post
  9. #25
    Mar 2017
    Quote Originally Posted by Santos View Post
    What kind of phone do you have? It is very possible the phone cannot pass the ports needed for VCDS.
    Also, are you aware the HEX-NET can act as a hotspot? You can eliminate the phone from this mix , Just press the red button on the HEX-NET (the middle LED will change to amber). On your PC search for the wireless network that begins with "HN". Connect and test should have no problems talking.
    Doesnt pass the test connected directly to the HEX-NET either.
  10. #26
    Mar 2017
    Landis,
    Ross-Tech, LLC
    Attention:170321RA2
    881 Sumneytown Pike
    Lansdale, PA 19446
    Best,
    Dana
    Ref RET?ID=5103
    Will get it out this week, thanks for the help everyone.
  11. Likes Dana liked this post
  12. #27
    Although we still want your HEX-NET back to have look at the source of the ""Internal checks failed", the above picture bothers me a bit.
    Are you switching networks in Windows after you've started VCDS?
    VCDS is trying 192.168.0.x, while you're connected to 192.168.43.x.
    If you switch networks, you should exit and re-start VCDS. IIRC, it only looks at your network setup when it starts up and does not try to keep up with changes in real-times.
  13. Likes jyoung8607 liked this post
  14. #28
    Mar 2017
    Yes, that time i switched to the HN network while VCDS was still open. I just closed it out, connected to the HN network and restarted VCDS and it gave the same message with the same IPs.
  15. #29
    Dec 2016
    DE
    Uhh, I got the same message (Interface not found using broadcast) on my business laptop when trying to use VCDS via the HN network, but have never seen it on my personal machine. I then just switched to a wired connection and never bothered again.
    I thought it might be a group policy, network device setting, or other that prevented broadcasts.
    Will follow this thread and can also reproduce the message, if you need any help debugging this.
  16. Likes Uwe liked this post
  17. #30
    Mar 2017
    Bumping this up, you received the interface on Monday.
