MK7 - GTI - DSG logging shift times etc.
GLoBaLReBeL
C?ID=303325
Hello Everyone,
I just recently got the new Hex-Net2 due to some issues I have been having with my DSG. I seem to be having trouble in up and down shifts from 1-2,2-3,3-4 and the VW dealership says they don't see anything wrong. I, however, can feel a delay in torque when the car shifts, both in D and in Manual modes. The stall/delay is there as I can feel it every time the car shifts and while it may not be enough for some to feel, when you drive a car for hours everyday that little issue starts to nag at you!
In any case, I'm trying to figure out a way that I can monitor a parameter or module that will allow me to show the 'slip/delay' during shifts. I was hoping someone might be able to give me some pointers/guidance as I'm the last hope for this (dealer has had the car 3 times with no luck)
P.S : Backstory
2K miles : took it in and they said no problems
4K miles: took it in again and told them of crazy peddal vibrations and the same shift problem (they said they checked fluid levels and everything is fine)
7K miles: Took it in again and they just said 'its normal for the DSG' (which it is not, as I've driven other GTIs and they do not exhibit this)
9K Miles: Performed a VCDS reset (via a friend) of all adaptations and followed the Ross-Tech Wiki for the re-adaptation for Clutch packs. This did help dramatically with the brake pedal vibrating, and the shifts *seemed* better for a day or two, but then went right back to its old ways.
Thank you EVERYONE/ANYONE in advance for your help. I'll be combing through everything over the next few days to see what I can find and monitor, but any help is appreciated
Please post an Auto-Scan so people can see exactly what TCM you have, what software it has in it, and so on.
GLoBaLReBeL
C?ID=303325
I am receiving my Hex-Net2 on Wed. I will be sure to post up a complete auto-scan that morning. I was trying to jump the gun and get ahead of the work :-)
GLoBaLReBeL
C?ID=303325
Welp, got my HEX-V2 in the mail today and was able to pull an auto-scan after work. Here's what I have.
Wednesday,22,March,2017,17:37:52:23324
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
VIN: hidden for security (Let me know if you need this for anything)   License Plate:
Mileage: 21426km-13313mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
VIN: Removed   Mileage: 21426km-13313miles
Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F381AF7E798FDBF843-807A
17178 - Databus
                    Mileage: 21068 km
                    Date: 2017.03.19
                    Time: 00:16:19
                    Coolant temperature: 20 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 11.972 V
                    Unlearning counter according OBD: 29
                    Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
                    Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
                    Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
                    Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
                    Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
                    Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
                    Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
                    Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
                    Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
                    Drivetrain coordinator: brake fault status-ESP: no error
                    Drivetrain coordinator: brake fault status-Deceleration controller: Available
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
                    Drivetrain coordinator: brake fault status-Bit 1: no error
                    Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
                    Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
                    Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
                    Drivetrain coordinator: brake fault status: 4
                    Drivetrain coordinator: brake function status-Parking Brake: not active
                    Drivetrain coordinator: brake function status-ACC: Not braking
                    Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
                    Drivetrain coordinator: brake function status-Driver: Not braking
                    Drivetrain coordinator: brake function status-Hill descent control: passive
                    Drivetrain coordinator: brake function status-ASR: no intervention
                    Drivetrain coordinator: brake function status-MSR: no intervention
                    Drivetrain coordinator: brake function status-ADS: no intervention
                    Drivetrain coordinator: brake function status-ABS: no intervention
                    Drivetrain coordinator: brake function status-EDL: no intervention
                    Drivetrain coordinator: brake function status-ASP: no intervention
                    Drivetrain coordinator: brake function status-AWV2: No warning pressure
                    Drivetrain coordinator: brake function status-Bit 4: no intervention
                    Drivetrain coordinator: brake function status-Bit 11: not passively cycled
                    Drivetrain coordinator: brake function status-Bit 12: not passively cycled
                    Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4903
   Revision: 06253104    Serial number: TFK01510011393
   ROD: EV_TCMDQ250021.rod
   VCID: 186AC12B72161A07F59-804C
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 53145000000099
   Coding: 01FA6BA1342309750080020981C82980D62C9000408194B400430050C008
   Shop #: WSC 01383 790 50316
   VCID: 4BC06E677340A19F88B-801E
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 85
                    Mileage: 21068 km
                    Date: 2017.03.19
                    Time: 00:16:19
   Revision: 00021000    Serial number: 0380786393
   Coding: 030C0C
   VCID: 3A2E3BA32CDA281723D-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004100100000000000010000002
   ROD: EV_ACManueBHBVW37X_SK48.rod
   VCID: 46D65F5368225CF7575-8012
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86582510151261
   Coding: 00111A464041A26969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00228
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 7AAEFBA36C5AE81763D-802E
   Component: WWS    150801  043 0581
   Serial number:         151204201343
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S5Y15M10D23H23M15S22
   Coding: 96A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694808832604151828
   Coding: 181803
   Serial number: 003GCR03DRFU
   VCID: 47C852576F2845FFAC3-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003YTQCL
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 409 15
   Serial number: 357000000000BB9CE61-
   Subsystem 3 - Part No SW: -----------    HW: 480 002 409 15
   Serial number: 3580000000065775861I
   Subsystem 4 - Part No SW: -----------    HW: 480 401 210 15
   Serial number: 3510002C91CCEA046218
   Subsystem 5 - Part No SW: -----------    HW: 480 402 109 15
   Serial number: 3520002B31D25F72E335
   Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3550002C91D1B62141A0
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
   Serial number: 3560002C71D1B62622A3
   Revision: FF033033    Serial number: 20151004500512
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0452855B1E9EAEE7091-8050
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD091AA980CF0502086A001000000000000000
   VCID: 2C020DFBD68E86A7A11-8078
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 11101510520456
   Coding: 0101000830085900FB00002A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewConti_013.rod
   VCID: 79ACE4AF695CE30F6A7-802C
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150001768000055365
   Coding: 31FFFF
   Revision: 00000000    Serial number: 15000212827002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3432159B0EBEDE67F91-8060
   Serial number: 20111506050A2E
   Coding: 003E13200000020000000000
   VCID: 43D046475B1069DF70B-8016
   Serial number: 00000000000002310344
   Coding: 011000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   ROD: EV_SteerAssisMQB_VW31.rod
   VCID: 392C24AF29DC230F2A7-806C
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA010SF7
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D84C0FF2D144FAFF6F-8038
0536 - Rear Right Bass Speaker
          B1067 F0 [008] - Short Circuit Between Poles
                    Reset counter: 97
                    Mileage: 20899 km
                    Date: 2017.03.16
                    Time: 02:13:30
                    Voltage terminal 30: 12.2 V
0565 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [008] - Open Circuit
                    Reset counter: 97
                    Mileage: 20899 km
                    Date: 2017.03.16
                    Time: 02:13:30
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [008] - Open Circuit
                    Reset counter: 97
                    Mileage: 20899 km
                    Date: 2017.03.16
                    Time: 02:13:30
   Serial number: 281015060504HU
   Coding: 003E13200C00020000000000
   VCID: 42DE4343440A60D77BD-8016
   Serial number: 00000000000001961907
   Coding: 091000
   Coding: 021A01010B000400
   VCID: 40DA494B4A0672C76D9-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 027300000000000051220002001808001F0203F40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6C82CDFB160E46A7E11-8038
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES00YCP
          B11CF 53 [009] - Deactivated
                    Reset counter: 38
                    Mileage: 20899 km
                    Date: 2017.03.16
                    Time: 02:13:23
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 134 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung: 05
                    SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung: 05
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Serial number: 150930200960
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 6B80CEE71300419FE8B-803E
End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
Let me know if I need to grab any other scans. I'm still reading up on all the options I have and am testing out things, but not making any changes as of yet. I'd like to start to be able to troubleshoot this damn DSG and get it FIXED. Any help at all is GREATLY appreciated.
OK, there's a crazy amount of data you could log from that transmission, but I'm not sure what would best represent "shift times".
Maybe start with both shaft input and output speeds?
IDE02720-ENG103810: Transmission input speed (RPM) shaft 1
IDE02721-ENG100916: Transmission input speed (RPM) shaft 2
IDE02722-ENG101964: Transmission output speed (RPM) shaft 1
IDE02723-ENG100382: Transmission output speed (RPM) shaft 2
GLoBaLReBeL
C?ID=303325
I'll grab those and monitor them and see what I get. I haven't used VCDS much, so I'll have to read up and see how to do this.
GLoBaLReBeL
C?ID=303325
After logging the params, it doesn't seem that I can deduce the shift times from the rpms of the input andn output shaft. Is there a way to get a list of what modules are available so that I can go through everything and start trying different things?(ie, is there somewhere I can input my transmission model or module # and see what parameters I can monitor?)
Also, I tried to find a way to speed up the logging so that I can capture more information (I read about a TURBO feature) but was unable to do so. I'm using the Advanced Measuring Values option and did not see anything that stated TURBO.
GLoBaLReBeL
C?ID=303325
I know I can connect to the car and go through a list, but that requires me sitting in my car for a long time. I was hoping for a web-site or forum that after entering in the correct model or serial (or whatever have you), it would provide me with a list of params that I can capture.
Not that I know of.
Not every module supports "Turbo" mode.
Did you try "Group UDS requests"?
You can also try to adjust some of the individual timing parameters on the Options screen. See our FAQ Entry 4.8.
GLoBaLReBeL
C?ID=303325
Not that I know of.
I did not try the group UDS requests option. I will try that again today on my way home from work.
I'll be sure to read up on the individual timing parameters to see if I can coax some more info out of them.
As a quick Q, how were you able to find those parameters to tell me to watch if there is no lookup? I'm guessing that you may have that feature, but nothing is available to the public yes?
Correct, I have access to some data sources that are not public.
However, I have a solution for you. While connected to your car, go to [Applications] -> [Controller Channel Map], and have a look at this page:
http://www.ross-tech.com/vcds/tour/controller-channels-map.php
GLoBaLReBeL
C?ID=303325
You just keep them coming don't ya!! :-) I'll be trying this out today after work and will report back. I wanted to say thank you again for your help as I've been o n multiple other forums without any assistance. If I figure this out and am able to log shift times repeatedly, I'll be sure to pass on the knowledge and hopefully it helps someone else.
GLoBaLReBeL
C?ID=303325
Still working on different options for logging times and just not coming up with anything definite. I notice the # of views, so I have a feeling others would like to do this as well. Feel free to chime in viewers with anything you may think of or tried. :-)
GLoBaLReBeL
C?ID=303325
Had my car looked at by VW and they said they topped off the transmission fluid and did the standard procedure for heating it up to 35C and than letting it drip until it stopped. Going to test fluid levels myself in a few days and check the fluid level through VCDS to verify. Still looking at finding a way to ID the problem as I still notice delayed shifts under light throttle application <30% throttle.
Sorry for lack of updates guys, just busy with work.
