Results 1 to 10 of 14
Thread: MK7 - GTI - DSG logging shift times etc.
    Mar 2017
    Smile MK7 - GTI - DSG logging shift times etc.
    Hello Everyone,
    I just recently got the new Hex-Net2 due to some issues I have been having with my DSG. I seem to be having trouble in up and down shifts from 1-2,2-3,3-4 and the VW dealership says they don't see anything wrong. I, however, can feel a delay in torque when the car shifts, both in D and in Manual modes. The stall/delay is there as I can feel it every time the car shifts and while it may not be enough for some to feel, when you drive a car for hours everyday that little issue starts to nag at you!
    In any case, I'm trying to figure out a way that I can monitor a parameter or module that will allow me to show the 'slip/delay' during shifts. I was hoping someone might be able to give me some pointers/guidance as I'm the last hope for this (dealer has had the car 3 times with no luck)
    P.S : Backstory
    2K miles : took it in and they said no problems
    4K miles: took it in again and told them of crazy peddal vibrations and the same shift problem (they said they checked fluid levels and everything is fine)
    7K miles: Took it in again and they just said 'its normal for the DSG' (which it is not, as I've driven other GTIs and they do not exhibit this)
    9K Miles: Performed a VCDS reset (via a friend) of all adaptations and followed the Ross-Tech Wiki for the re-adaptation for Clutch packs. This did help dramatically with the brake pedal vibrating, and the shifts *seemed* better for a day or two, but then went right back to its old ways.
    Thank you EVERYONE/ANYONE in advance for your help. I'll be combing through everything over the next few days to see what I can find and monitor, but any help is appreciated
    Please post an Auto-Scan so people can see exactly what TCM you have, what software it has in it, and so on.
  3. Likes GLoBaLReBeL liked this post
    Mar 2017
    I am receiving my Hex-Net2 on Wed. I will be sure to post up a complete auto-scan that morning. I was trying to jump the gun and get ahead of the work :-)
    Mar 2017
    Welp, got my HEX-V2 in the mail today and was able to pull an auto-scan after work. Here's what I have.
    Wednesday,22,March,2017,17:37:52:23324
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
    VIN: hidden for security (Let me know if you need this for anything)   License Plate:
    Mileage: 21426km-13313mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
    VIN: Removed   Mileage: 21426km-13313miles
    Address 01: Engine (J623-CXCA)       Labels: 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D00124424002F1000
       Shop #: WSC 00066 790 00202
       ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
       ROD: EV_ECM20TFS0205G0906259D.rod
       VCID: 2F381AF7E798FDBF843-807A
    17178 - Databus
                        Mileage: 21068 km
                        Date: 2017.03.19
                        Time: 00:16:19
                        Coolant temperature: 20 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 11.972 V
                        Unlearning counter according OBD: 29
                        Drivetrain coordinator: ACC fault status-ACC: Not active: although TSK passive
                        Drivetrain coordinator: ACC fault status-Start and stop request: Set at stopping speed
                        Drivetrain coordinator: ACC fault status-Bit 2: Not transmitted simultaneously
                        Drivetrain coordinator: ACC fault status-Bit 3: Does not reactivate after DTC-induced shutdown
                        Drivetrain coordinator: ACC fault status-Bit 4: Not active when limiter active
                        Drivetrain coordinator: ACC fault status-Bit 5: Transmits no undefined signals
                        Drivetrain coordinator: ACC fault status-Bit 6: Not active when main switch off
                        Drivetrain coordinator: ACC fault status-Bit 7: Not active when driver braking
                        Drivetrain coordinator: ACC fault status-Bit 8: Not active during the EPB emer. braking
                        Drivetrain coordinator: brake fault status-ESP: no error
                        Drivetrain coordinator: brake fault status-Deceleration controller: Available
                        Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
                        Drivetrain coordinator: brake fault status-Bit 1: no error
                        Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
                        Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
                        Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
                        Drivetrain coordinator: brake fault status: 4
                        Drivetrain coordinator: brake function status-Parking Brake: not active
                        Drivetrain coordinator: brake function status-ACC: Not braking
                        Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
                        Drivetrain coordinator: brake function status-Driver: Not braking
                        Drivetrain coordinator: brake function status-Hill descent control: passive
                        Drivetrain coordinator: brake function status-ASR: no intervention
                        Drivetrain coordinator: brake function status-MSR: no intervention
                        Drivetrain coordinator: brake function status-ADS: no intervention
                        Drivetrain coordinator: brake function status-ABS: no intervention
                        Drivetrain coordinator: brake function status-EDL: no intervention
                        Drivetrain coordinator: brake function status-ASP: no intervention
                        Drivetrain coordinator: brake function status-AWV2: No warning pressure
                        Drivetrain coordinator: brake function status-Bit 4: no intervention
                        Drivetrain coordinator: brake function status-Bit 11: not passively cycled
                        Drivetrain coordinator: brake function status-Bit 12: not passively cycled
                        Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
       Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4903
       Revision: 06253104    Serial number: TFK01510011393
       ROD: EV_TCMDQ250021.rod
       VCID: 186AC12B72161A07F59-804C
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 53145000000099
       Coding: 01FA6BA1342309750080020981C82980D62C9000408194B400430050C008
       Shop #: WSC 01383 790 50316
       VCID: 4BC06E677340A19F88B-801E
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Reset counter: 85
                        Mileage: 21068 km
                        Date: 2017.03.19
                        Time: 00:16:19
       Revision: 00021000    Serial number: 0380786393
       Coding: 030C0C
       VCID: 3A2E3BA32CDA281723D-806E
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
       Component: AC Manuell    H02 1001
       Revision: 00001K01
       Coding: 00020004100100000000000010000002
       ROD: EV_ACManueBHBVW37X_SK48.rod
       VCID: 46D65F5368225CF7575-8012
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 86582510151261
       Coding: 00111A464041A26969E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00228
       ROD: EV_BCMBOSCH_016_AU37.rod
       VCID: 7AAEFBA36C5AE81763D-802E
       Component: WWS    150801  043 0581
       Serial number:         151204201343
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S5Y15M10D23H23M15S22
       Coding: 96A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
       Component: J245 PS60.036  H06 0150
       Serial number: 03694808832604151828
       Coding: 181803
       Serial number: 003GCR03DRFU
       VCID: 47C852576F2845FFAC3-8012
       Occupant Detection:
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH000000000003YTQCL
       Coding: 303131
       Subsystem 2 - Part No SW: -----------    HW: 480 002 409 15
       Serial number: 357000000000BB9CE61-
       Subsystem 3 - Part No SW: -----------    HW: 480 002 409 15
       Serial number: 3580000000065775861I
       Subsystem 4 - Part No SW: -----------    HW: 480 401 210 15
       Serial number: 3510002C91CCEA046218
       Subsystem 5 - Part No SW: -----------    HW: 480 402 109 15
       Serial number: 3520002B31D25F72E335
       Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 3550002C91D1B62141A0
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 3560002C71D1B62622A3
       Revision: FF033033    Serial number: 20151004500512
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 0452855B1E9EAEE7091-8050
       Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
       Component: KOMBI         342 6420
       Coding: 0BAD091AA980CF0502086A001000000000000000
       VCID: 2C020DFBD68E86A7A11-8078
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 11101510520456
       Coding: 0101000830085900FB00002A1C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07027
       ROD: EV_GatewConti_013.rod
       VCID: 79ACE4AF695CE30F6A7-802C
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29150001768000055365
       Coding: 31FFFF
       Revision: 00000000    Serial number: 15000212827002
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_SK25.rod
       VCID: 3432159B0EBEDE67F91-8060
       Serial number: 20111506050A2E
       Coding: 003E13200000020000000000
       VCID: 43D046475B1069DF70B-8016
       Serial number: 00000000000002310344
       Coding: 011000
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8102
       ROD: EV_SteerAssisMQB_VW31.rod
       VCID: 392C24AF29DC230F2A7-806C
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0130
       Revision: 00000001    Serial number: VWZ8Z1FBA010SF7
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: 6D84C0FF2D144FAFF6F-8038
    0536 - Rear Right Bass Speaker
              B1067 F0 [008] - Short Circuit Between Poles
                        Reset counter: 97
                        Mileage: 20899 km
                        Date: 2017.03.16
                        Time: 02:13:30
                        Voltage terminal 30: 12.2 V
    0565 - Loudspeaker 1 in Double-Subwoofer
              B130C 13 [008] - Open Circuit
                        Reset counter: 97
                        Mileage: 20899 km
                        Date: 2017.03.16
                        Time: 02:13:30
    0570 - Loudspeaker 2 in Double-Subwoofer
              B130D 13 [008] - Open Circuit
                        Reset counter: 97
                        Mileage: 20899 km
                        Date: 2017.03.16
                        Time: 02:13:30
       Serial number: 281015060504HU
       Coding: 003E13200C00020000000000
       VCID: 42DE4343440A60D77BD-8016
       Serial number: 00000000000001961907
       Coding: 091000
       Coding: 021A01010B000400
       VCID: 40DA494B4A0672C76D9-8014
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 844     HW: 3Q0 035 844
       Component: MU-S-S-US     620 0613
       Coding: 027300000000000051220002001808001F0203F40120010002
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 6C82CDFB160E46A7E11-8038
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H52 1028
       Serial number: VWZ8Z9RES00YCP
              B11CF 53 [009] - Deactivated
                        Reset counter: 38
                        Mileage: 20899 km
                        Date: 2017.03.16
                        Time: 02:13:23
                        SDARS_tuner_status_2-Audio Signal: Available
                        SDARS_tuner_status_2-Antenna current: 134 mA
                        SDARS_tuner_status_2-Reception quality: optimum_signal
                        SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung: 05
                        SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung: 05
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2823A017F1E06000000
       ROD: EV_OCULowMQB.rod
       Serial number: 150930200960
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       VCID: 6B80CEE71300419FE8B-803E
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
    Let me know if I need to grab any other scans. I'm still reading up on all the options I have and am testing out things, but not making any changes as of yet. I'd like to start to be able to troubleshoot this damn DSG and get it FIXED. Any help at all is GREATLY appreciated.
    OK, there's a crazy amount of data you could log from that transmission, but I'm not sure what would best represent "shift times".
    Maybe start with both shaft input and output speeds?
    IDE02720-ENG103810: Transmission input speed (RPM) shaft 1
    IDE02721-ENG100916: Transmission input speed (RPM) shaft 2
    IDE02722-ENG101964: Transmission output speed (RPM) shaft 1
    IDE02723-ENG100382: Transmission output speed (RPM) shaft 2
    Mar 2017
    I'll grab those and monitor them and see what I get. I haven't used VCDS much, so I'll have to read up and see how to do this.
    Mar 2017
    After logging the params, it doesn't seem that I can deduce the shift times from the rpms of the input andn output shaft. Is there a way to get a list of what modules are available so that I can go through everything and start trying different things?(ie, is there somewhere I can input my transmission model or module # and see what parameters I can monitor?)
    Also, I tried to find a way to speed up the logging so that I can capture more information (I read about a TURBO feature) but was unable to do so. I'm using the Advanced Measuring Values option and did not see anything that stated TURBO.
  9. #8
    Mar 2017
    I know I can connect to the car and go through a list, but that requires me sitting in my car for a long time. I was hoping for a web-site or forum that after entering in the correct model or serial (or whatever have you), it would provide me with a list of params that I can capture.
  10. #9
    Quote Originally Posted by GLoBaLReBeL View Post
    Not that I know of.
    Not every module supports "Turbo" mode.
    Did you try "Group UDS requests"?
    You can also try to adjust some of the individual timing parameters on the Options screen. See our FAQ Entry 4.8.
  11. Likes GLoBaLReBeL liked this post
  12. #10
    Mar 2017
    Not that I know of.
    I did not try the group UDS requests option. I will try that again today on my way home from work.
    I'll be sure to read up on the individual timing parameters to see if I can coax some more info out of them.
    As a quick Q, how were you able to find those parameters to tell me to watch if there is no lookup? I'm guessing that you may have that feature, but nothing is available to the public yes?
