Results 1 to 7 of 7
Thread: Replacement USB Cable
    Jan 2017
    My HEX-USB+CAN VCDS has a damaged USB cable. The insulation near the male plug is split, exposing some wires (see pic). It works, even when wiggling the cable end, but at some point I imagine it will no longer work.
    Is it possible to order a replacement cable from Ross-Tech? Mind you, I bought the VCDS second-hand, so I'm not looking for a free repair; I just want to buy a replacement USB cable.
    I recently bought a new HEX-V2 and use it exclusively because the interface is faster than the old HEX+CAN. I want to repair the old one so I can resell it without the buyer having to worry about reliability.
    Sure, we can hook you up. You understand the other end is soldered to the board, right?
  3. Likes Jetta ,97 liked this post
    Jan 2017
    Fantastic! Who do I contact?
    Yes, the 4 USB leads are soldered to the CB. I searched earlier and found some good pics in this thread:
    http://forums.ross-tech.com/showthre...=cable+replace
    Those pics are for an earlier model VCDS, but I don't think it will be that different from mine.
    With soldering, I'm mediocre at best and my iron has no heat control. Rather than risk heat damage to the CB, I would snip the wires and leave them as leads to be spliced. After splicing color-to-color, I'd solder each joint and insulate individually with shrink-tubing. Looks like there's plenty of room in the head to store a bit more wire.
    Thanks!
  5. Likes Uwe liked this post
  6. #4
    Quote Originally Posted by bluestar View Post
    Support@Ross-Tech.com. Please include a link to this thread and the serial number of the HEX+CAN in question.
  7. Likes bluestar, Jetta ,97 liked this post
  8. #5
    United States
    Ref to: O?ID=340077
    Hi Paul,
    I created that HUC wire only order and sent you a reply via e-mail.
    -Dana
  9. Likes Uwe, bluestar, Jetta ,97, Viking liked this post
  10. #6
    Jan 2017
    Dana,
    I got your email. Thanks so much for providing a replacement cable. I'll await its arrival by mail.
    Ross-Tech's outstanding customer service is much appreciated!
    -Paul
  11. Likes Dana, DrPeter liked this post
  12. #7
    United States
    Internal ref: ST?ID=74224
    Paul, that wire shipped and tracking looks like you'll get it on Saturday.
  13. Likes bluestar, Uwe liked this post
