Results 1 to 10 of 14
Thread: 2.0 tdi skoda octavia vrs issues
    Feb 2017
    bonnie scotland UK
    hi guys
    since i have my car running after used ecu cured lot of faults also new intank pump an tandem pump due to oil an fuel mix also replaced injector loom
    am getting some other faults
    glow plug light flashing loss of turbo ie limp home turn it off engine restart full power again but some times it shuts down completely an is very hard to start normaly while giving it the beans or slowing down
    could it be dirty injectors due to oil
    sticky turbo
    n75
    crank sensor as dualmass seen better days due to get replaced with kavlar/carbon setup
    map sensor
    maf sensor
    as for egr blocked it off with blanking plate due to get deleted with delete pipe as well as remap to remove dpf also
    on scan 2 only showing injector fault but it jumps about 3 or 4 or 2 or 1 different injectors every scan
    i will post 3 scans one with injectors at idle values but they jump up an down hence am thinking dirt
    smell of diesel will burn you eyes out at rear of car u can see it
    i do have new seal kit blots etc for injectors an also a ultra sonic cleaner on hand to help
    Wednesday,08,March,2017,16:59:07:52445
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170220 DS267.3
    VIN: TMBEH21Z078013513   License Plate:
    Mileage: 256520km-159394mi   Repair Order:
    Chassis Type: 1Z (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
    VIN: TMBEH21Z078013513   Mileage: 256520km-159394miles
    Address 01: Engine        Labels: 03G-906-018-BMN.clb
       Part No SW: 03G 906 018 EL    HW: 03G 906 018 EL
       Component: R4 2.0l PPD1.2      9953
       Revision: --H22---    Serial number: SKZ7Z0F3704520
       Coding: 0000072
       Shop #: WSC 10091 074 64911
       VCID: 73E5A4601279F5D9E4-8026
    6 Faults Found:
    000665 - Boost Pressure Regulation
                   P0299 - 006 - Control Range Not Reached - Intermittent
                        Fault Status: 00010001
                        Reset counter: 40
                        Mileage: 256525 km
                        Time: 05:28:34
                        RPM: 2112 /min
                        Torque: 224.0 Nm
                            99.45 %
                        Voltage: 14.35 V
                        Pressure: 2619.9 mbar
                        Pressure: 1235.4 mbar
    001026 - EGR System
                   P0402 - 006 - Excessive Flow - Intermittent
                        Reset counter: 40
                        Mileage: 256525 km
                        Time: 05:28:34
    004710 - PD Unit Injector: Cylinder 3 (N242)
                   P1266 - 006 - Implausible Signal
                        Fault Status: 01100001
                        Reset counter: 40
                        Mileage: 256525 km
                        Time: 05:30:54
                        RPM: 2016 /min
                        Torque: 144.0 Nm
                            44.85 %
                        Text:  6.000    uF
                        Time: 0.00 ms
                        Text:  0.00    mJ
    004713 - PD Unit Injector: Cylinder 4 (N243)
                   P1269 - 006 - Implausible Signal - Intermittent
                        Reset counter: 40
                        Mileage: 256525 km
                        Time: 05:30:54
    004707 - PD Unit Injector: Cylinder 2 (N241)
                   P1263 - 006 - Implausible Signal - Intermittent
                        Fault Status: 00100001
                        Reset counter: 40
                        Mileage: 256525 km
                        Time: 05:30:54
                        RPM: 2016 /min
                        Torque: 144.0 Nm
                            62.40 %
                        Text:  5.250    uF
                        Time: 0.00 ms
                        Text:  0.00    mJ
    004704 - PD Unit Injector: Cylinder 1 (N240)
                   P1260 - 006 - Implausible Signal - Intermittent
                        Reset counter: 40
                        Mileage: 256525 km
                        Time: 05:30:54
    Readiness: N/A
       Revision: 00H11001
       Coding: 0006786
       Shop #: WSC 73430 790 00000
       Part No: 1Z0 907 044 H
       Component: ClimatronicPQ35 084 0305
       VCID: 3B754C407AA97D99FC-806E
                009 - Open or Short to Ground
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000004308895
       Coding: 01880F030004140000110D000000000000087F075C
       VCID: 2B557C008AC9ED196C-807E
       Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer SK351  012  0401
       Coding: 00063477
       Shop #: WSC 73430
       Component: Q4 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD0N8CY/
       Coding: 0020788
       VCID: 3D71425864BD73A9C2-8068
       Subsystem 1 - Serial number: 6332MSME125C5A48I
       Subsystem 2 - Serial number: 6342MSME1210007C
       Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
       Component: Lenksäulenmodul 035 0070
       Coding: 0000012
       VCID: 74E7A77C1777F2E1FD-8020
       Part No SW: 1Z0 920 912 E    HW: 1Z0 920 912 E
       Component: KOMBIINSTRUMENT VD1 1610
       Revision: V1610036    Serial number: SKZ7Z0F3704520
       Coding: 0003401
       Shop #: WSC 01286 386 08256
       VCID: 377D5070468159F918-8062
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 253
                        Mileage: 256525 km
                        Time: 00:06:24
    00771 - Fuel Level Sensor (G)
                        Reset counter: 253
                        Mileage: 256525 km
                        Time: 00:06:24
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Part No SW: 1K0 907 530 H    HW: 1K0 907 951
       Component: J533__Gateway   H12 0150
       Revision:   H12       Serial number: 31001067010707
       Coding: 3D3F074007001303
       VCID: 2C577F1C8FC7EA2165-8078
       Component: IMMO            VD1 1610
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
       Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
       Component: Tuer-SG         005 0954
       Coding: 0000756
       VCID: 387F534C4B9F568111-806C
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.074 H07 1806
       VCID: 35615A785C8DABE90A-8060
       Component:    KSG PQ35 G2  020 0202
       Coding: 01801A085283007F3F04850540085F96907CA0
       VCID: 0305F4A042D9C559F4-8056
       Subsystem 5 - Part No: 1Z0 951 171
       Component: Innenraumueberw.008 4801
       Coding: 00000000
       Shop #: WSC 73430
       Subsystem 6 - Part No: 1K0 951 605 C
       Subsystem 7 - Component:       NGS n.mounted
                        Reset counter: 38
                        Mileage: 256525 km
                        Time: 22:56:39
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
       Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
       Component: Tuer-SG         005 0944
       Coding: 0000756
       VCID: 3979564870954F89EE-806C
       Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
       Component: Radio FO3       019 0034
       Revision: 00019000    Serial number: SKZ7Z3F0041077
       Coding: 0000402
       VCID: 2E537514B9DB98314B-807A
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
       Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
       Component: Tuer-SG         005 0907
       Coding: 0000144
       Shop #: WSC 73430 790 1012544
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
       Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
       Coding: 0000144
    Address 76: Park Assist        Labels: 1Z0-919-283.lbl
       Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
       Component: Parkhilfe 4-Kan H04 0020
    End-------------------------(Elapsed Time: 01:44)--------------------------
    Mileage: 256550km-159412mi   Repair Order:
    VIN: TMBEH21Z078013513   Mileage: 256550km-159412miles
       Coding: 0000072
                        Reset counter: 40
                        Mileage: 256548 km
                        Time: 05:38:04
                        RPM: 1952 /min
                        Torque: 0.0 Nm
                        Speed: 29.0 km/h
                            41.73 %
                        Text:  6.000    uF
                        Time: 0.00 ms
                        Text:  0.00    mJ
    Readiness: N/A
       Revision: 00H11001
       Coding: 0006786
       Coding: 00063477
       Shop #: WSC 73430
       Coding: 0020788
       Coding: 0000012
       Coding: 0003401
                        Reset counter: 0
                        Mileage: 256536 km
                        Time: 05:20:35
       Coding: 0000756
       Coding: 00000000
       Shop #: WSC 73430
       Coding: 0000756
       Coding: 0000402
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:39)--------------------------
    Sunday,12,March,2017,16:57:46:52445
                    Address 01: Engine  (03G 906 018 EL)
    16:57:27 Group 013: Idle Stabilization (Injection Quantity Deviation)
      0.04 mg/str  Injection Quantity Deviation Cyl. 1
      -0.34 mg/str  Injection Quantity Deviation Cyl. 2
      -0.60 mg/str  Injection Quantity Deviation Cyl. 3
      0.90 mg/str  Injection Quantity Deviation Cyl. 4
    these jump up an down dirty injectors maybe
    Aug 2014
    Now permanent in Maryland, USA.
    I was trying to respond to this inquiry but I do not seem to understand what the exact issue is or the question. You mean loss of turbo effect? Have you done charge pressure check and what was the results?
    Bad cam settings for gap lash on PD rocker?
    Bad WG control, turbo or restricted exhaust or intake........or injector faults inducing limp mode.
    Feb 2017
    bonnie scotland UK
    Quote Originally Posted by TFSI View Post
    ok i will explain turbo works on car to start with after a couple of runs up an down gears then its starts to reduce power like holding back when that happens the glow plug light flashes an it does not rev over 3000 rpm till i turn car off an restart then i get boost back again but sometimes it kills the engine an is very hard to restart
    i hope everyone can understand now sorry for confusing anyone thanks
    Feb 2017
    bonnie scotland UK
    ok thanks do you know how to check them ie wg control etc injector faults runs fine but shuts down under boost call me a newbie still learning thanks
    Aug 2014
    Most likely exhaust line partly blocked. Whats the reading on mass air flow? Post MVBs on air intake, injection quantity,etc. Make sure diesel quality is good. Make sure all those vacuum lines are all intact. When the engine dies and hard to restart, what faults then do you have recorded in memory?
  7. Likes Uwe liked this post
    Feb 2017
    bonnie scotland UK
    ok thank you i will post them tomorrow also will try see if i can make it die an see what comes up think underboost fault an injector fault but it jumps from injector to injector
  9. #8
    Feb 2017
    bonnie scotland UK
    Tuesday,14,March,2017,16:40:46:52445
                    Address 01: Engine       Labels: 03G-906-018-BMN.CLB
    Control Module Part Number: 03G 906 018 EL    HW: 03G 906 018 EL
      Component and/or Version: R4 2.0l PPD1.2      9953
               Software Coding: 0000072
                Work Shop Code: WSC 10091 074 64911
    9 Faults Found:
                        Reset counter: 40
                        Mileage: 256548 km
                        Time: 05:38:04
                        RPM: 1952 /min
                        Torque: 0.0 Nm
                            65.13 %
                        Text:  5.375    uF
                        Time: 0.00 ms
                        Text:  0.00    mJ
    001025 - EGR System
                   P0401 - 006 - Insufficient Flow - MIL ON
                        Reset counter: 40
                        Mileage: 256548 km
                        Time: 05:38:04
    004720 - PD Unit Injector: Cylinder 4 (N243)
                   P1270 - 006 - Regulation Range Exceeded - Intermittent
                        Reset counter: 40
                        Mileage: 256551 km
                        Time: 02:47:54
                        RPM: 832 /min
                        Torque: 24.0 Nm
                            86.97 %
                        Text:  4.875    uF
                        Text: 14.00    mJ
                        Text:      3    mJ
                        Voltage: 63.25 V
    004711 - PD Unit Injector: Cylinder 3 (N242)
                   P1267 - 006 - Regulation Range Exceeded - Intermittent
                        Reset counter: 40
                        Mileage: 256551 km
                        Time: 02:47:54
                   P1266 - 006 - Implausible Signal - Intermittent
                        Reset counter: 40
                        Mileage: 256551 km
                        Time: 02:47:54
                        Reset counter: 40
                        Mileage: 256551 km
                        Time: 02:47:54
    004708 - PD Unit Injector: Cylinder 2 (N241)
                   P1264 - 006 - Regulation Range Exceeded - Intermittent
                        Reset counter: 40
                        Mileage: 256551 km
                        Time: 05:09:15
                        RPM: 2848 /min
                        Torque: 120.0 Nm
                            86.58 %
                        Text:  5.000    uF
                        Text: 13.75    mJ
                        Text:      3    mJ
                        Voltage: 63.25 V
                        Reset counter: 40
                        Mileage: 256551 km
                        Time: 05:09:15
                        Reset counter: 40
                        Mileage: 256552 km
                        Time: 05:27:47
                        RPM: 2720 /min
                        Torque: 112.0 Nm
                        Speed: 41.0 km/h
                            42.12 %
                        Text:  5.500    uF
                        Time: 0.00 ms
                        Text:  0.00    mJ
    Readiness: N/A
    Tuesday,14,March,2017,15:56:32:52445
    15:56:07 Group 010: Charge Pressure Control
      650.7 mg/str  Mass Air Flow (actual)
      1030.9 mbar  Atmospheric Pressure
      1326.2 mbar  Boost Pressure (actual)
      99.9 %  Accel. Pedal Pos. Sensor 1 (G79)
    15:57:40 Group 013: Idle Stabilization (Injection Quantity Deviation)
      -1.69 mg/str  Injection Quantity Deviation Cyl. 1
      0.58 mg/str  Injection Quantity Deviation Cyl. 2
      1.68 mg/str  Injection Quantity Deviation Cyl. 3
      -0.56 mg/str  Injection Quantity Deviation Cyl. 4
    16:01:03 Group 013: Idle Stabilization (Injection Quantity Deviation)
      -1.16 mg/str  Injection Quantity Deviation Cyl. 1
      -0.23 mg/str  Injection Quantity Deviation Cyl. 2
      1.43 mg/str  Injection Quantity Deviation Cyl. 3
      -0.02 mg/str  Injection Quantity Deviation Cyl. 4
    16:01:03 Group 004: Unit Injector
      808 /min  Engine Speed (G28)
      5.0 °ATDC  Injection Start (specified)
      3.7°KW  Injection Duration (specified)
      1.49°  Torsion Value
    16:01:03 Group 018: Piezo Unit Injector Status
      0.0  Injector Status Cylinder 1
      999  Injector Status Cylinder 2
      999  Injector Status Cylinder 3
      999  Injector Status Cylinder 4
    16:03:06 Group 019
      167.50 V  Voltage
      159.25 V  Voltage
      160.25 V  Voltage
      163.25 V  Voltage
  10. #9
    Aug 2014
    Very unlikely all unit injectors could fail at one time. Check the black connector for the unit injectors on the side of cylinder head for proper/tight connection. If possible disconnect and check contacts for rusts, clean and reconnect. If possible, unplug the mass flow sensor and drive to see if it makes any change.
    Has there been any recent work on this engine?
  11. #10
    Feb 2017
    bonnie scotland UK
    ok will do thanks as for work new tandem an intank pump an ecu and injector loom as the other ecu had been mucked about with ie bad tuning is what i was told after i got the car. Needing a new dual mass also as shes banging a bit i have a new one on order i might get egr deleted an dpf make it breath better
    is it worth ultra sonic cleaning injectors an putting new seals on an cleaning the turbo vnt with cleaner
