Hi. I have a problem with an Audi A4 B5. After I have replaced a battery, I have tried to do a Throttle Body Alignment (TBA), but I didn't manage this. I have done an Auto Scan of the car (attached). I will be very thankful if somebody with more expirience with TBA can look at the scanning and possible send me an suggestion regarding the problem. Thanks in advance.
VCDS-Lite Version: Release 1.2
Saturday, 11 March 2017, 13:10:28:53892
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77
Controller: 8D0 906 018 E
Component: 1.8L R4/5V MOTR G01 0001
Coding: 04031
Shop #: WSC 06335
VCID: 2925AC23C0E1
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Address 02: Auto Trans Labels: None
Controller: 01N 927 733 ED
Component: AG4 Getriebe 01N 4533
Coding: 00000
VCID: 7781BA5B46D5
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
Controller: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D10
Coding: 0273004283
Shop #: BB 24332
VCID: 1D4D88F384A9
Address 08: Auto HVAC Labels: 8D0-820-043-1D.LBL
Controller: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D56
Coding: 00040
Shop #: WSC 06335
VCID: 2B29562BCA1D
Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
Controller: 8D0 959 655 F
Component: Airbag Front+Kopf 0001
Coding: 00304
Shop #: WSC 06335
VCID: 39057C633041
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Controller: 8D0 920 900 K
Component: KOMBI+WEGFAHRS. M73 D10
Coding: 00142
VCID: 2B29562BCA1D
Ident.-Nr. Wegfahrs.:AUZ5Z0X8284322
Address 25: Immobilizer Labels: None
Controller: Bit teA dre sst
Component: e 17 eingeben
VCID: CEEFBFBF19CF
No Faults Found
or a communication error ocurred
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12865
Shop #: WSC 06335
VCID: 2C2B5537CF13
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
01571 - Signal for Seat Memory
00000 - End of Output
00-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
00957 - Key 3
00958 - Key 4
End --------------------------------------------------------------------------------------------------
