Monday,02,July,2018,19:26:26:24261
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: 3VWH17AUXJM761673 License Plate: UYB3474
Mileage: 1658km-1030mi Repair Order: Christians's alltrack
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
VIN: 3VWH17AUXJM761673 Mileage: 1658km-1030miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311D00122426002F0000
Shop #: WSC 00066 790 00424
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 46D5AAC7282201670BB-8012
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01707061446
ROD: EV_TCMDQ250021.rod
VCID: 59EF71BB899C9E9F569-800C
Address 03: ABS Brakes (J104) Labels:| 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 53057000002614
Coding: 43FA6AA13426096D807D0307A0C629C2562C9001C005943C00435050E009430000010312121212B435351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
VCID: 00597CDF4A86EF57717-8054
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 G HW: 5GM 907 426 G
Component: AC Manuell H03 2001
Revision: 00001K05
Coding: 02020004200110000000000000000002
ASAM Dataset: EV_ACManueBHBVW37X 004134
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 4CC198EF364EFB37DDF-8018
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0245
Revision: -------- Serial number: C86407121700VC
Shop #: WSC 00066 790 00395
ROD: EV_BCMCONTI.rod
VCID: 0B435BF373C0BC0F145-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 171021 043 0551
Serial number: 97022066171028153214
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S4Y17M09D13H12M27S26
Coding: 00A8DD
Component: AirbagVW20 010 0830
Serial number: 003GCR08VLSH
VCID: 47CBA7C32F28186FF0D-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000008162M%
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 001 310 17
Serial number: 35700000000D4D31282I
Subsystem 3 - Part No SW: ----------- HW: 480 001 310 17
Serial number: 3580000000063D31282B
Subsystem 4 - Part No SW: ----------- HW: 480 401 211 17
Serial number: 3510001B32777383415S
Subsystem 5 - Part No SW: ----------- HW: 480 401 211 17
Serial number: 3520001C927FFB82455K
Subsystem 6 - Part No SW: ----------- HW: 480 401 810 17
Serial number: 3550002AF25629A63298
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 810 17
Serial number: 3560002AF25629A4A29E
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 18111704221447
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 025D76D7448AFD47673-8056
Part No SW: 5G1 920 840 C HW: 5G1 920 840 C
Component: KOMBI 242 0310
Coding: 0BB4100DA180CF0502082B001000000000000000
VCID: 270B07438F68F86F10D-8072
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Fault Frequency: 40
Reset counter: 88
Mileage: 219 km
Date: 2018.06.21
Time: 19:28:40
Part No SW: 3Q0 907 530 F HW: 3Q0 907 530 B
Component: GW MQB Mid 517 5304
Serial number: 17101700840125
Coding: 0101000830085900FB0020081E0F00000001070000000000000000000000
Shop #: WSC 00066 790 00067
ROD: EV_GatewNF_VW27.rod
VCID: 323DE617B4AA8DC7B73-8066
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 26170001894540071439
Coding: 31FFFF
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00024.08.17
Coding: 0001
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038731600287
Coding: 003A03200000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006814883
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 8102
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FFB8FE3C758C02FB8D-801A
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038731702967
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007105428
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 5G6 035 868 HW: 5G6 035 868
Component: MU-E--ER 671 8395
Serial number: 01091700021479
Coding: 02731200FF00000041220001001000009F0008D40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 70B92C1F7A26FFD7817-8024
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
