Results 11 to 20 of 31
Thread: 2017 VW Golf Alltrack coding questions
    Dec 2016
    Amsterdam
    Traditionally VAG have included the tick boxes for sunroof open but not actually implemented the feature in firmware - if this is the same on the MQB then there's nothing can be done.
    Sunroof opening was disabled from the factory on my MQB tiguan, but the settings are really there? At least on my Tiguan. Enabled that and the sunroof now tilts open and closed when using the remote/kessy. You can also set it to tilt open or slide open.
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
    Current:
  2. #12
    Feb 2018
    Israel
    I will double check but quite sure all the above are enabled for me, just under different category - I remember the SAD part
  3. #13
    Feb 2018
    Israel
    Are you sure you enabled IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen? The function should be working flawlessly on a O3RS. Also; the aftermarket HMI could place an issue here.
    yea, I think the infodapter is causing the issue. although the manufacturer tech says the sunroof is on a different data platform. before i installed it, the sunroof was tilting when I opened the windows from the remote
  4. #14
    Verified VCDS User shwagondawheels's Avatar
    Jul 2018
    Could not find these options via adaptation on my friends 2018 alltrack. Need to spend some more time with his car.
  5. #15
    Jul 2018
    I found this about the rain light sensors on vortex with this user stating:
    I tried many RLFS (RLHS,RLS) Rain Light sensors in my Golf Mk7.
    5Q0 955 559 is compatible (Rain Close Works)
    8U0 955 559 is compatible (Rain Close Not Work)
    5Q0 955 547 is compatible (Rain Close Works)
    7N0 955 559 is compatible (Rain Close Not Work)
    Even though I noticed this in your auto scan
    Component: RLHS 042 0105
    Serial number: S2Y16M12D01H20M31S23
    Coding: 00A8DD
    It shows the RLS the part number as one he stated will work with auto close via rain detect but the component comes up as an RLHS
    Which user hadez16 on the ross-tech forums here has stated
    RLHS = rain closing not possible
    RLFS = rain closing possible
    Period.
    So what isn't jiving here?
    My friends 2018 alltrack shows the component as RLFS and a PN: of 5Q0 955 559 which according to the statement above should work "in theory"
    Hopefully by Tuesday I can confirm if the feature in functional on his car. Here is the auto scan on his car for comparison...
    Monday,02,July,2018,19:26:26:24261
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: 3VWH17AUXJM761673   License Plate: UYB3474
    Mileage: 1658km-1030mi   Repair Order: Christians's alltrack
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
    VIN: 3VWH17AUXJM761673   Mileage: 1658km-1030miles
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 311D00122426002F0000
       Shop #: WSC 00066 790 00424
       ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
       ROD: EV_ECM18TFS0208V0906264M.rod
       VCID: 46D5AAC7282201670BB-8012
       Part No SW: 0D9 300 018     HW: 02E 927 770 AS
       Component: DQ250-6A MQB  H54 5201
       Revision: 06454104    Serial number: TFK01707061446
       ROD: EV_TCMDQ250021.rod
       VCID: 59EF71BB899C9E9F569-800C
    Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
       Component: ESC           H62 0400
       Revision: 00000000    Serial number: 53057000002614
       Coding: 43FA6AA13426096D807D0307A0C629C2562C9001C005943C00435050E009430000010312121212B435351919323200
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
       ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
       VCID: 00597CDF4A86EF57717-8054
       Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
       Component: AC Manuell    H03 2001
       Revision: 00001K05
       Coding: 02020004200110000000000000000002
       ROD: EV_ACManueBHBVW37X_004_VW37.rod
       VCID: 4CC198EF364EFB37DDF-8018
       Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
       Component: BCM PQ37BOSCH 034 0245
       Revision: --------    Serial number: C86407121700VC
       Shop #: WSC 00066 790 00395
       ROD: EV_BCMCONTI.rod
       VCID: 0B435BF373C0BC0F145-805E
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    171021  043 0551
       Serial number: 97022066171028153214
       Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  047 0105
       Serial number: S4Y17M09D13H12M27S26
       Coding: 00A8DD
       Serial number: 003GCR08VLSH
       VCID: 47CBA7C32F28186FF0D-8012
       Occupant Detection:
       Serial number: IBH000000000008162M%
       Coding: 303135
       Subsystem 2 - Part No SW: -----------    HW: 480 001 310 17
       Serial number: 35700000000D4D31282I
       Subsystem 3 - Part No SW: -----------    HW: 480 001 310 17
       Serial number: 3580000000063D31282B
       Subsystem 4 - Part No SW: -----------    HW: 480 401 211 17
       Serial number: 3510001B32777383415S
       Subsystem 5 - Part No SW: -----------    HW: 480 401 211 17
       Serial number: 3520001C927FFB82455K
       Subsystem 6 - Part No SW: -----------    HW: 480 401 810 17
       Serial number: 3550002AF25629A63298
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 810 17
       Serial number: 3560002AF25629A4A29E
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 18111704221447
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 025D76D7448AFD47673-8056
       Part No SW: 5G1 920 840 C    HW: 5G1 920 840 C
       Component: KOMBI         242 0310
       Coding: 0BB4100DA180CF0502082B001000000000000000
       VCID: 270B07438F68F86F10D-8072
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Fault Frequency: 40
                        Reset counter: 88
                        Mileage: 219 km
                        Date: 2018.06.21
                        Time: 19:28:40
       Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
       Component: GW MQB Mid    517 5304
       Serial number: 17101700840125
       Coding: 0101000830085900FB0020081E0F00000001070000000000000000000000
       Shop #: WSC 00066 790 00067
       ROD: EV_GatewNF_VW27.rod
       VCID: 323DE617B4AA8DC7B73-8066
       Component: E221__MFL-DC1  H17 0103
       Serial number: 26170001894540071439
       Coding: 31FFFF
       Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7084
       Serial number: HA1-00024.08.17
       Coding: 0001
       Component: TSG FS        011 0032
       Serial number: 5038731600287
       Coding: 003A03200000020000000000
       Serial number: 00000000000006814883
       Coding: 011000
       Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
       Component: EPS_MQB_ZFLS  171 1072
       Coding: 8102
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 4FFB8FE3C758C02FB8D-801A
       Component: TSG BFS       011 0032
       Serial number: 6038731702967
       Serial number: 00000000000007105428
       Coding: 091000
       Part No SW: 5G6 035 868     HW: 5G6 035 868
       Component: MU-E--ER      671 8395
       Serial number: 01091700021479
       Coding: 02731200FF00000041220001001000009F0008D40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001041
       VCID: 70B92C1F7A26FFD7817-8024
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
    I attempted to get rain closing to work today on another friend's 2016 Golf R and we have the option in vehicle settings now to activate or deactivate auto rain closing but I did not get an auto scan (like a rookie) to verify the RLS part number. I'll try to find out which one it is the next time I see him!
  6. #16
    Jul 2018
    Quote Originally Posted by shwagondawheels View Post
    His comes up showing an RLHS sensor so no go on the 2016 R for auto rain closing. Seems to be one rain light sensors part numbers I listed that should work. It's a 5Q0 955 547 A
    Here is his auto scan for reference.
    Sunday,08,July,2018,17:08:31:24261
    VIN: WVWUF7AU7GW286611   License Plate: BPM2427
    Mileage: 49032km-30467mi   Repair Order: Matt's 2016 R
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 05 08 09 14 15 16 17 19 22 2B 42 44 47 52 55 5F 75 A9
    VIN: WVWUF7AU7GW286611   Mileage: 49032km-30467miles
    A9-Struct. Borne Sound -- Status: Malfunction 0010
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 091900122426000E3000
       ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
       ROD: EV_ECM20TFS0208V0906259H.rod
       VCID: 45D7ADCB15240A7F021-8010
    21406 - EVAP Emission Control Sys
              P0441 00 [096] - Incorrect Flow
    Readiness: 0000 0001
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 60696000000288
       Coding: 01FA6BA154280972057D030141C46980D62A90A0C08296B7004000D4C008
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 79AF113B295CBE9F369-802C
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 2
                        Mileage: 36493 km
                        Date: 2017.11.26
                        Time: 11:22:09
       Revision: 00021000    Serial number: 0398067111
       Coding: 030C0C
       VCID: 3A2DCE376CDA75877F3-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020004200100000005000012111402
       VCID: 6A8D3E775CFA0507CF3-803E
       Air quality sensor:
       Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
       Component: BCM MQBAB HNA H24 0175
       Serial number: 01061602300595
       Coding: 00010A46C041A2E169E44000091C07201800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 045170CF5E9EF37755F-8050
       Component: WWS    160306  043 0551
       Serial number:         160311000649
       Component: RLHS  037 0059
       Serial number: S5Y16M03D21H01M04S25
       Coding: 96A8DD
       Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0120
       Serial number: 19021641350406
       ROD: EV_DRCONTITEMIC_VW27.rod
       VCID: 372BD7035FC868EF80D-8062
       Serial number: 003GCR04J6AB
       Occupant Detection:
       Component: BF-Gewichtss.  H12 0021
       Serial number: IBH000000000004PCH6O
       Coding: 30324E
       Subsystem 2 - Part No SW: -----------    HW: 480 001 603 16
       Serial number: 3570000000020B11B918
       Subsystem 3 - Part No SW: -----------    HW: 480 001 603 16
       Serial number: 358000000000FC501A1H
       Subsystem 4 - Part No SW: -----------    HW: 480 401 203 16
       Serial number: 3510002A91F35392818%
       Subsystem 5 - Part No SW: -----------    HW: 480 401 703 16
       Serial number: 3520002A7200CA01613L
       Subsystem 6 - Part No SW: -----------    HW: 480 401 703 16
       Serial number: 3550002B9200CA01D31Y
       Subsystem 7 - Part No SW: -----------    HW: 480 401 703 16
       Serial number: 356000299200CA05D1D4
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 19031604401255
       Coding: 0400
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 074B67C36FA8D86F30D-8052
       Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
       Component: KOMBI         303 6420
       Coding: 0BAD08123B80CF0502086A001400000000000000
       VCID: 2E05F267A092A927D3B-807A
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1244
       Revision: --------    Serial number: 0004629411
       Coding: 0101000838085900FB00022A880F00000001050000000000000000000000
       ROD: EV_GatewLear_013_VW37.rod
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29150002564280076012
       Coding: 30FFFF
       Serial number: HA1-00020.02.16
       Coding: 0001
       VCID: 4ACD9EF73C3AE507EF3-801E
       Revision: 00000000    Serial number: 16000049177001
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E00F4EBE83F7A5F-8060
       Serial number: 180216EBG12689
       Coding: 003E13208000040000000000
       VCID: 43D3B3D31B10344F2C5-8016
       Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000009395600
       Coding: 111000
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8102
       VCID: 392FD13B69DC7E9F769-806C
    22272 - Databus
              [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                        Reset counter: 206
                        Mileage: 40714 km
                        Date: 2018.03.09
                        Time: 10:32:42
                        Motor status: 00
                        Supply voltage: 12.25 V
                        Temperature: 34.0 °C
                        KFC: 57
                        KFA: 00 00
                        Environmental conditions: 20
                        uioUdNotFilt_xdu16: 12.17 V
                        uAdSensI_SwitchedKl30_xdu16: 12.16 V
    22528 - Databus
              [MOTOR_12 Botschaft - CAN-Timeout]
                        Reset counter: 206
                        Mileage: 40714 km
                        Date: 2018.03.09
                        Time: 10:32:42
                        Motor status: 00
                        KFC: 58
                        KFA: 00 00
    23040 - Databus
              [MOTOR_20 Botschaft - CAN-Timeout]
                        Reset counter: 206
                        Mileage: 40714 km
                        Date: 2018.03.09
                        Time: 10:32:42
                        Motor status: 03
                        System status: Driving mode
                        KFC: 5A
                        KFA: 00 00
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0150
       Revision: 00000001    Serial number: VWZ8Z1FBA01LZU7
       VCID: 6D87356B6D14123FAA1-8038
       Serial number: 190216EBH1351A
       Coding: 003E13208C00040000800000
       VCID: 42DDB6D7040A3D47273-8016
       Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000009433662
       Coding: 091000
       Coding: 022202010B000400
       VCID: 40D9BCDF0A062F57317-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0002
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0002
       Coding: 2E0000
       Part No SW: 3Q0 035 876     HW: 3Q0 035 876
       Component: MU-S-NS-US    H25 0245
       Serial number: VWZAZ2S0104316
       Coding: 027300020000000051220002001808001F0207F401200105C6
       ROD: EV_MUStd4CTSAT_VW27.rod
       VCID: 71BF291B712CF6DF8E9-8024
       Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
       Component: ABT_Std-2_Nav  H53 1031
       Serial number: VWZ8Z9SJX004TW
       Subsystem 2 - Part No SW: 3G0 919 866 R    HW: -----------
       Component: NAR 2016  --- 0321
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 160130201606
       VCID: 2F3BEF63A798A02FD8D-807A
    0010 - Databus
              [Keine Funktion durch CAN FehlerMotorsteuergerätebotschaft fehlt--> keine Klangerzeugung]
                        Mileage: 40714 km
                        Date: 2018.03.09
                        Time: 10:32:42
    End----------(Elapsed Time: 01:54, VBatt start/end: 12.2V/12.2V)-----------
  7. #17
    Dec 2016
    DE
    @shwagondawheels: Did you try rain closing on the index B "RLHS" after an hour or instant after locking the car? I was told, that with the B-sensors the function first works but fades away when all modules go to sleep.
  8. #18
    Jun 2017
    Quote Originally Posted by MasterTommy View Post
    Slide open via comfort opening might not work until you change the according adaptation channel is the Unit "CA" (Sunroof module, only accessible with new Interfaces)
  9. #19
    Jul 2018
    I tried it right after locking the car. Once with the wiper stalk in the neutral position and a second time in the intermittent position which I've read that the stalk needs to be in the intermittent position for rain closing to work along with the option turned on in the menu under vehicle settings. Either way with no luck.
    Just to clarify, what do you mean about index B?
  10. #20
    Jul 2018
    You mean under the drop down in the coding screen of VCDS?
    Stole this from a google image search. You mean here?
    And yes I did if this is what you are referring to.
