G450 Adaptation
paradise city
C?ID=295376
I replaced the G450 sensor today and attempted to adapt it using the Ross Wiki instructions
UDS Protocol (G450) procedure
Key ON, Engine OFF
[Basic Settings]
Select Adaptation of diff. pressure sensor particulate filter
[Go!] to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
Select Resetting of learned values of difference pressure sensor
[Done, Go Back]
I was able to do the first bit no problem but when I went to do the second part, the "Resetting of learned values of difference pressure sensor" option was not available.
I'm using version 17.1.3
Just wondering if the second part is essential to allow me to drive the car safely.
Any advice is greatly appreciated.
Golf VI 1.6 TDi Bluemotion 1K
Chris
Please post an Auto-Scan so people can see exactly what ECU you have and what software is in it.
paradise city
C?ID=295376
Tuesday,07,March,2017,15:08:22:63220
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170203 DS267.2
VIN: WVWZZZ1KZBW115393   License Plate:
Mileage: 128350km-79752mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 61 62 72 77
VIN: WVWZZZ1KZBW115393   Mileage: 128350km-79752miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 DQ    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 6302
   Coding: 00114034032501080000
   ASAM Dataset: EV_ECM16TDI02103L906023DQ 003007
   ROD: EV_ECM16TDI02103L906023FL.rod
   VCID: 78AAE24C525C2487159-802C
Readiness: 1110 1000
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 133B200D092300FFC80E04ED901C0091310000
   VCID: 76B6EC7458C852F7075-8022
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000003
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D84C3182D1E912FF6F-8038
   Part No SW: 1K0 937 086 H    HW: 1K0 937 086 H
   Component: BCM PQ35  M   103 0615
   Revision: 00103 AD
   Coding: 48180A3A8825F1C040080080340081E443510088436D8160648087200041
   VCID: 35342B78054E19EFCEF-8060
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 24091  26  0512
   Coding: 009795
   Component: RLS 100910 05  54  0403
   Coding: 0330AD
   Subsystem 4 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
01134 - Alarm Horn (H12)
                    Reset counter: 116
                    Mileage: 128101 km
                    Date: 2011.06.22
                    Time: 09:51:10
                    Voltage: 14.80 V
                        Term 50 On
                    Reset counter: 160
                    Mileage: 128342 km
                    Date: 2011.07.25
                    Time: 19:19:26
                    Voltage: 11.55 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 C    HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0008
   Revision: --------    Serial number: 12941025315830
   Coding: 100001
   VCID: 36362C74184812F7C75-8062
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRADVJGP
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B203D4023EACF9F38B-806E
   Serial number: 3572MSME37363358ZZZV
   Serial number: 3582MSME2F316354ZZZX
   Serial number: 3512QSME28007122ZZZD
   Serial number: 3522QSME22067178ZZZP
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JIN001J3
   Coding: 1082140000
   ROD: EV_SMLSNGKUDS_VW32.rod
   VCID: 72BED06434204ED72BD-8026
   Serial number: 00000000000000281436
   Coding: E20000
   Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
   Component: KOMBI         H20 0420
   Coding: 470B00
   VCID: 2D040318ED9E512FB6F-8078
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 270910F1003239
   Coding: E9A07F0600061204000003
   VCID: 2E060414EC182A378F5-807A
   Component: IMMO          H20 0420
   VCID: 6A8EC8041CF0861793D-803E
   Revision: A1001003    Serial number: 7668692255
   VCID: 2708F130CFE27B7F4C3-8072
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2152
   Coding: 0131764
   VCID: 33301560073A07DFE0B-8066
   Part No: 1K0 909 144 J
   Revision: 00H17000
   VCID: 313C1F68FD2635CF927-8064
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Component: Tuer-SG         009 2120
   Coding: 0132020
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  040 0166
   Revision: 00000001    Serial number: VWZ1Z3K9798004
   Coding: 0100040004
   VCID: 2616FC34C8E86277775-8072
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Component: Batt.regelung H25 5603
   Coding: 030B085A
   VCID: 71BCDF6831A675CFD27-8024
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790439144
   Coding: 0131216
   Shop #: WSC 01357 011 1012552
   VCID: 35342B78094E19EFCEF-8060
   Coding: 0131216
   VCID: 36362C74144812F7C75-8062
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668646387
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 313C1F68F1A635CF927-8064
End----------(Elapsed Time: 01:11, VBatt start/end: 11.7V/11.7V)-----------
Hmm, not sure why your ECU doesn't seem to have the second one.
I might have a look at what currently shows in the following measuring values, both with the engine off, and with it idling.
IDE00427-ENG101722 - Particle filter; difference pressure
IDE00428-ENG100917 - Particle filter; offset for differential press.
MartinsX
Riga, Latvia
C?ID=268515
After G450 adaptation you have to leave car with ignition off for at least 1min.
Some ECU's do not require any additional basic settings as only that one "Adaptation of diff. pressure sensor particulate filter"
Check measured values as Uwe suggested ;)
billywhizz
C?ID=278038
Uwe/paradise city, I have a 2010 golf 1.6 tdi, it uses the uds system, I have fitted a new g 450 sensor too mine a while ago , it follows the same pattern as you have taken with resetting of learned values ,this was not available too me either. so I left it at that and a drove it. as Uwe suggests to you I have checked the difference pressure and offset difference figures since fitting the unit, mine engine off ,shows 4.6 mbs in both sections,, should be zero. when running at idle still shows the same but with higher revs shows increasing mb pressure in the difference pressure readings and 4.6 mb in the offset difference figures. everything functions as normal and regens continue as normal with ash and soot figures as should be. I hope this helps you .paul.
I'm not sure it should. I suspect that if the offset shows what the sensor does with the engine off, and both values are within reason, i.e. no more than single-digit milibars, then it's good to go.
paradise city
C?ID=295376
Thanks for the replies, I'll check that out this evening when I get back from work.
paradise city
C?ID=295376
So these are the readings
Engine off
Particle filter; difference pressure 0.00
Offset for differential pressure -30.02 hPa
Idling
Same values
Sound good?
Engine off
Idling
Same values
Sound good?
I'm a bit surprised there's no difference pressure at idle...
paradise city
C?ID=295376
Yeah me too but I tried it a couple of times and that's what came up. Is a negative offset value normal?
MartinsX
Riga, Latvia
C?ID=268515
Have You replaced G450 with original correct part? What was wrong with the old one?
paradise city
C?ID=295376
Yeah, VW genuine part. Was getting intermittent P2453 and P2454 codes.
MartinsX
Riga, Latvia
C?ID=268515
What does measured values show with old sensor connected?
paradise city
C?ID=295376
I didn't measure those. I've adapted the new sensor now. If I put the old sensor back in would that not mess things up?
billywhizz
C?ID=278038
it would be help full if you just slipped the old one on and checked the reading (don't need too fix it in properly ) just check a reading and then refit the new one ,doesn't take long too adapt the new one again. a thought what is the part number on your old unit and what is it on the new unit? there is also a make and where made sticker on both.
paradise city
C?ID=295376
I'll do a bit of tinkering and measuring tomorrow and post the results.
paradise city
C?ID=295376
Original G450 sensor
Replacement part
So when I put the original back in I immediately got a P2454 error. I adapted it and got the following measurements:
Engine off
IDE00427 Particle filter; difference pressure 0.00
IDE00428 Offset for differential pressure 1.41 hPa
Idling
I switched it for the new one and adapted it and got
Engine off
Idling
IDE00427 Particle filter; difference pressure 2.82
2000 rpm
IDE00427 Particle filter; difference pressure 11.11
What do you all reckon?
MartinsX
Riga, Latvia
C?ID=268515
1) Old sensor is not measuring at all.
2) New sensor is measuring adequately, if we assume that Your DPF is ok.
3) 1,41 hPa is ok for offset value, You can leave it as it is.
4) One of sensors is not correct part for Your car, 059906051C and 076906051B is not the same part, and measurement characteristics may be different. You have to check with dealer or use PL24 to check it by VIN.
paradise city
C?ID=295376
I believe the part originally had the suffix 'A' but it was replaced by the newer part with suffix 'B'. I checked with the VW parts guys that I ordered it from and they assured me it was the correct part for my car.
