Results 1 to 1 of 1
Thread: Golf 7 pulsing brake light with indicator
    Mar 2015
    Australia
    Golf 7 pulsing tail lights with left indicator
    Hi all,
    Owner of this Golf R wagon had replaced the incandescent globes in his rear light housings with some generic LEDs.
    They had been functioning initially but at some point subsequently the tail lights started to pulse in synch with the left indicator (when right indicator is on all lights function normally)
    The right brake light is not affected and functions normally.
    Also when the brakes are engaged and the outer tails are fully illuminated, they no longer pulse.
    I initially thought it might have been an issue with changing the BCM adaptation to allow the inner tail lights to function as brake lights per DV52's instructions:
    http://www.vwwatercooled.com.au/foru...ml#post1125601
    However I changed back to the factory configuration and the outer tail lights continues to pulse in phase with the left indicator.
    Swapping back to the factory incandescent globes likewise did not resolve the issue.
    No faults being reported by the BCM.
    I suspect that the LED globes have caused an issue with the BCM that will require it to be replaced, just wondering if anyone has come across this?
    Wednesday,01,March,2017,15:30:01:02396
    VCDS Version: 17.1.3.0 (x64)
    Workshop Code: 123 12345 000000
    VIN: WVWZZZAUZGP5   License Plate: GOLFR_WAGON
    Mileage: 15105km-9385mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
              5F A9
    VIN: WVWZZZAUZGP5   Mileage: 15105km-9385miles
    Address 01: Engine (J623-CJXB)       Labels: 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 J    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 091D00122466050B3000
       Shop #: WSC 00028 028 00073
       ASAM Dataset: EV_ECM20TFS0205G0906259J 001002
       ROD: EV_ECM20TFS0205G0906259F_VW37.rod
       VCID: 356AD37794482AE90A-8060
    15072 - Engine Start Blocked by Immobilizer
              P1570 00 [032] - -
       Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4913
       Revision: 06253104    Serial number: TFK01506221604
       Shop #: WSC 00028 028 00067
       ROD: EV_TCMDQ250021.rod
       VCID: 53AE8DEF3AFC14D904-8006
    21595 - Invalid Data Received from Diagnostic Gateway Module
              U0447 00 [002] - -
       Revision: 00000000    Serial number: 61835000001862
       Coding: 04FA93A15422296E077E070141C36920C92A94E0E08296F718  4250B8C288
       VCID: 7AF0004BFDD60591A7-802E
       Revision: 00021000    Serial number: 0372247001
       Coding: 030C0C
       VCID: 3A70C04BBD56C591E7-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 02120024100100001005004012101402
       Shop #: WSC 12345 123 00000
       VCID: 6AD0300B8D76B51157-803E
       Air quality sensor:
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86580507150556
       Coding: 03511A46C24122F30BA44080B10C0728180000000000000000  0000000000
       ROD: EV_BCMBOSCH_016_AU37.rod
       VCID: 030E7DAF8A1C4459F4-8056
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    150624  042 0551
       Serial number:         150627042240
       Component: RLHS  037 0059
       Serial number: S5Y15M07D10H20M18S17
       Coding: 90A8DD
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY151613CXL
       Serial number: 00000000000032816111
       Sun Roof:
       Subsystem 5 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS22.409  H03 0004
       Serial number: 0000FST000E2MHJ00000
       Coding: 191900
       Roof Blind:
       Subsystem 6 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS22.409  H03 0004
       Serial number: 0000FST000E2M6800000
       Coding: 191900
    Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
       Revision: --------    Serial number: 39391515206889
       Coding: 0071155011
       ROD: EV_EPHVA18AU3700000_VW37.rod
       VCID: 438EBDAFCA9C8459B4-8016
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572-V1.clb
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 10061503211295
       Coding: 001C1300FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0120
       Serial number: 24051541350431
       ROD: EV_DRCONTITEMIC.rod
       VCID: 3776D97F8E44D8F918-8062
       Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
       Component: AirbagVW20    015 0388
       Serial number: 003MLR0WMN9U
       Coding: 98CCC000000000005C00000000C800000065
       Shop #: WSC 00028 028 00065
       VCID: 7F06F15FE6F420B990-802A
       Belt Pretensioner left:
       Serial number: 34169677B01071540855
       Coding: 333135
       Belt Pretensioner right:
       Serial number: 34169676B02071540699
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 207 15
       Serial number: 35767000000959C8051Y
       Subsystem 4 - Part No SW: -----------    HW: 480 000 207 15
       Serial number: 358670000005E7C8051
       Subsystem 5 - Part No SW: -----------    HW: 480 400 107 15
       Serial number: 3516502B11B65D52B35A
       Subsystem 6 - Part No SW: -----------    HW: 480 400 107 15
       Serial number: 3526502AF1B65D52F21N
       Subsystem 7 - Part No SW: -----------    HW: 480 400 107 15
       Serial number: 3556502AB1C52F32A34I
       Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150707400720
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 73EE2D6FDABC74D9E4-8026
       Part No SW: 5G1 920 758 A    HW: 5G1 920 758 A
       Component: KOMBI         302 6420
       Coding: 27AD10183F88000801886A095400000000000000
       VCID: 2D5AFB177C18622972-8078
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2223
       Revision: --------    Serial number: 01071510800394
       Coding: 030100043F085900FB00027E9C0F0001000105000000000000  0000000000
       ROD: EV_GatewConti_013.rod
       VCID: 75EA1377D4C86AE9CA-8020
       Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0040
       Serial number: 29150001266130025253
       Coding: 2DFFFF
       Serial number: 4314607003
       Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7082
       Serial number: HA1-00027.05.15
       Coding: 0001
       ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
       ROD: EV_AllWheelContrHA1VW37X_SK12.rod
       VCID: 4688A4BBF9AEB17193-8012
       Revision: 00000000    Serial number: 15000168833008
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_SK25.rod
       VCID: 346CEE739F3233E13D-8060
    Address 3C: Lane Change (J1086)       Labels: None
       Component: HRE_Master    H11 0071
       Serial number: 0372936959
       Coding: 02011203
       ROD: EV_HREntryHella.rod
       VCID: 3C7CC653B762FBA1F5-8068
       Component: TSG FS        010 0031
       Serial number: 0000156940474
       Coding: 001F1220D001028000001000
       VCID: 4796A9BFFEA4A87968-8012
       Serial number: 00000000000009574218
       Coding: 0D0000
       Coding: 8103
       ROD: EV_SteerAssisMQB_VW31.rod
       Component: TSG BFS       010 0031
       Serial number: 0000157097670
       Coding: 001F1020DE01028000801000
       Serial number: 00000000000009580300
       Coding: 050000
       Coding: 06A602000B000200
       VCID: 4084B2A3DB8A9F41A9-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0002
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0002
       Coding: 2E0000
       Part No SW: 3Q0 035 846     HW: 3Q0 035 846
       Component: MU-S-N-ER     H24 0241
       Serial number: VWZAZ2R0302152
       Coding: 02730208FF00000051510001000828001F0207D601200100C7
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 6ED83C1BB19E59310B-803A
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9RU303X4K
       Subsystem 2 - Part No SW: 3G0 919 866 K    HW: -----------
       Component: MRM2 2015/16  --- 0420
              B201A 00 [009] -  -
                        Reset counter: 67
                        Mileage: 10606 km
                        Date: 2016.08.19
                        Time: 11:27:26
                        Voltage terminal 30: 11.8 V
                        Status_Software_Version_Management-module_name:
    7193 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 89
                        Mileage: 10700 km
                        Date: 2016.09.01
                        Time: 10:06:00
                        Voltage terminal 30: 14.5 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 150608201427
       VCID: 2F66E11F7614103940-807A
    End-------------------------(Elapsed Time: 05:06)--------------------------
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
