Results 1 to 5 of 5
Thread: 2008 Transporter T5 4motion 2.5 TDi BNZ
    Feb 2017
    Barnstaple, England and Linz, Austria
    Mods: remapped by Pendle Performance
    Saturday,04,March,2017,18:56:31:61795
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170220 DS267.3
    VIN: WV1ZZZ7HZ9H012117   License Plate:
    Mileage: 173200km-107621mi   Repair Order:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ9H012117   Mileage: 173200km-107621miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 906 016 EC    HW: 070 906 016 EC
       Component: R5 2,5L EDC G001SG  2539
       Revision: --H06---    Serial number: VWZ7Z0H6765279
       Coding: 0001172
       Shop #: WSC 66565 257 00032
       VCID: 55A60D0AFFF035E9EA-5168
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ABS.clb
       Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
       Component: (M)ABS MK25E        0103
       Revision: 00H21001
       Coding: 0000092
       Shop #: WSC 02736 790 00000
       VCID: 4586DD4A0F5085699A-514A
    Address 08: Auto HVAC        Labels: Redir Fail!
       Part No: 7H0 820 045 AM
       Component: CLIMA/AC            0303
       VCID: 70E85C9E605270C119-512E
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 7H0-937-049.lbl
       Part No: 7H0 937 049 AD
       Component: BORDNETZ SGVER 1.0  2101
       Coding: 0000102
       VCID: 74E0508E144A4CE1FD-512E
                014 - Defective
    00991 - Interior Lights
       Part No: 1C0 909 605 A
       Component: 3C AIRBAG VW51      0011
       Coding: 13123
       Shop #: WSC 02736
       VCID: 224C66D6AE3E9251DF-514A
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 951 T
       Component: KOMBI+WEGFAHRSP VDO V03
       Coding: 00413
       Shop #: WSC 00373
       VCID: 3D76B5AA3780CDA9C2-512E
       WV1ZZZ7HZ9H012117     VWZ7Z0H6765279
       Part No: 6N0 909 901
       Coding: 00022
       Shop #: WSC 02736
       VCID: 70E85C9E305270C119-514A
       Part No: 7H0 907 554 F
       Component: HALDEX 4Motion      2110
       VCID: 3362939251C40BD924-514A
    Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
       Part No: 7H0 951 171 B
       Component: Innenraumueberw.    2920
       Coding: 0000021
       Shop #: WSC 02737 790 00000
       VCID: 295E71FA830841099E-51DE
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: C1W KomfortgerŠt     0004
       Coding: 00020
       Shop #: WSC 02736
       VCID: 326C9696FEDE02D12F-4B28
    Address 56: Radio        Labels: None
       Part No SW: 7H0 057 152 HX    HW: 7H0 057 152 HX
       Component: Radio LG3           0018
       Revision: 00009000    Serial number: VWZCZ5I0100151
       Coding: 0020200
       Shop #: WSC 00461 210 87671
       VCID: 0302035241E47B59F4-512E
    00003 - Control Module
                014 - Defective
    End-------------------------(Elapsed Time: 05:51)--------------------------
    Last edited by andythechief; 03-04-2017 at 02:20 PM. Reason: delete vehicle reg number
  2. Likes Uwe, Dana liked this post
  3. #2
    Feb 2017
    Note- I neglected to mention a mod; I have added cruise control to this vehicle too.
    Feb 2017
    Hi. Yes mine has the optional rear diff lock ( switch on dash, air solenoids under the van) . Be sure you use the correct generation Haldex too.
    United States
    Hi Andy,
    Would you be able to run a blockmap (Measuring Blocks function) on address 46 at some point in time?
    We had a recent customer inquiry with power window problems in addition to coding concerns and I'm not entirely sure if 2008+ model year vehicles offfer any data related to front door modules in MVBs 011 and 012. (2007 and older used different coding and some even show full slave part numbers such as Subsystem 1 - Part No: 7H2959802).
    Thanks,
    Dana
  6. Likes Uwe liked this post
    Feb 2017
    Hi Dana- hopefully this is what you are looking for:
    ;SW:7H0-959-433-B   HW: ---  Central Conv.
    ;Component:C1W KomfortgerŠt     0004, Coding:00020
    ;Saturday,30,March,2019,14:22:39:39877
    ;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    ;VCID: B2287DBC7CB424DA9B-4B1E
    1,0,Window Regulator (Driver Door),
    1,1,WR-Button (E40),Driver Door,Display Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.
    ;Not Installed, ,
    1,2,Window Regulator,Therm. Prot. (V147),Display Range: Yes/No
    ;Not Installed, ,
    1,3,Rear Window,Safety Switch (E39),Display Range: Not Installed/ON/OFF
    ;Not Installed, ,
    1,4,,,
    ;N/A,,
    2,0,Window Regulator Buttons (Driver Door),
    2,1,WR-Button (E81),Passenger Door,Display Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.
    ;Not Installed, ,
    2,2,WR-Button (E53),Rear Left Door,Display Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.
    ;Not Installed, ,
    2,3,WR-Button (E55),Rear Right Door,Display Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.
    ;Not Installed, ,
    2,4,,,
    ;N/A,,
    3,0,Mirror Adjustment/Heating,
    3,1,Mirror Adjustment,Switch (E43),Display Range: Pos X+/Pos X-/Pos Y+/Pos Y-/Not Oper./Not Installed
    ;Not Installed, ,
    3,2,Mirror Selector,Switch (E48),Display Range: Left/Right/ON (Mirror Heater Switch)/OFF (Mirror Heater Switch)/Not Oper.
    ;Not Installed, ,
    3,3,,,
    ;Not Installed, ,
    3,4,Mirror Heater,Switch,Display Range: ON/OFF/Not Installed
    ;Not Installed, ,
    4,0,Window Regulator (Passenger Door),
    4,1,WR-Button (E107),Driver Door,Display Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper./Not Installed
    ;Not Installed, ,
    4,2,Window Regulator,Therm. Prot. (V148),Display Range: Yes/No/Not Installed
    ;Not Installed, ,
    4,3,,,
    ;Not Installed, ,
    4,4,,,
    ;N/A,,
    5,0,Window Regulators (Rear),
    5,1,WR-Button (E52),Driver Door,Display Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper./Not Installed
    ;Not Installed, ,
    5,2,Window Regulator,Therm. Prot. (V26),Display Range: Yes/No/Not Installed
    ;Not Installed, ,
    5,3,WR-Button (E54),Driver Door,Display Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper./Not Installed
    ;Not Installed, ,
    5,4,Window Regulator,Therm. Prot. (V27),Display Range: Yes/No/Not Installed
    ;Not Installed, ,
    6,0,,
    6,1,Voltage,(Terminal 30),Specification: 9.0...14.0 V
    ;12.32 V,Voltage,
    6,2,Ignition,(Terminal 15),Display Range: Term 15 On/Term 15 Off
    ;Term 15 On, ,
    6,3,S-Contact,,Display Range: Activated
    ;Activated, ,
    6,4,Vehicle Speed,,
    ;0.0 km/h,Speed,
    7,0,Key Switches && Interior Lock Buttons,
    7,1,Driver Door,Key Switch,Display Range: Not Oper./Open/Close/Implausible
    ;Not Oper., ,
    7,2,Passenger Door,Key Switch,Display Range: Not Oper./Open/Close/Implausible
    ;Not Oper., ,
    7,3,Driver Door,Lock Butt. (E150),Display Range: Not Oper./Locking/Unlocking/Implausible
    ;Not Oper., ,
    7,4,Passenger Door,Lock Butt. (E198),Display Range: Not Oper./Locking/Unlocking/Implausible
    ;Not Oper., ,
    8,0,,
    8,1,Hood Contact,Switch (F120),Display Range: Operated/Not Oper./Not Installed
    ;Closed, ,
    8,2,Rear Lid,Key Switch,Display Range: Open/Close/Not Oper.
    ;Not Oper., ,
    8,3,Rear Lid,Contact Switch (F124),Dispplay Range: Open/Closed
    ;Closed, ,
    8,4,Central Locking,Thermal Protection,Display Range: Yes/No
    ;No, ,
    9,0,Central Locking Units,
    9,1,Driver Door,Status (F220),Display Range: Locked/Unlocked/Safe/Implausible
    ;Unlocked, ,
    9,2,Passenger Door,Status (F221),Display Range: Locked/Unlocked/Safe/Implausible
    ;Unlocked, ,
    9,3,Rear Left Door,Status (F222),Display Range: Locked/Unlocked/Safe/Implausible
    ;Unlocked, ,
    9,4,Rear Right Door,Status (F223),Display Range: Locked/Unlocked/Safe/Implausible
    ;Not Installed, ,
    10,0,Door Contact Switches,
    10,1,Driver Door,Door Contact (F2),Display Range: Door Closed/Door Open
    ;Door Open, ,
    10,2,Passenger Door,Door Contact (F3),Display Range: Door Closed/Door Open
    ;Door Closed, ,
    10,3,Rear Left Door,Door Contact (F10),Display Range: Door Closed/Door Open
    ;Door Closed, ,
    10,4,Rear Right Door,Door Contact (F11),Display Range: Door Closed/Door Open
    ;Not Installed, ,
    11,0,,
    11,1,Immobilizer,Key Recognition,Display Range: Yes/No
    ;Yes, ,
    11,2,Automatic,Lock/Unlock Switch,Specification: Operated/Not Oper./Implausible/Not Installed
    ;Not Oper., ,
    11,3,Sunroof,Close Signal,Display Range: ON/OFF
    ;OFF, ,
    11,4,Databus,Condition,Specification: 2-Wire
    Display Range: 1-Wire/2-Wire
    ;2-Wire, ,
    13,0,Immobilizer,
    13,1,Fixed Code,,Display Range: No Value/OK/Not OK
    ;no Value, ,
    13,2,Code in,Catch Area,Display Range: No Value/OK/Not OK
    ;no Value, ,
    13,3,Algorithm,,Display Range: No Value/OK/Not OK
    ;no Value, ,
    13,4,Key Number,,
    ;0,Count,
    14,0,,
    14,1,Remote Control,Buttons,Display Range: 0 = Not Operated / 1 = Operated
    ?xxx = Open
    x?xx = Close
    xx?x = Rear Lid
    xxx? = Panic (USA only)
    ; 0 0 0 0,Bin. Bits,
    14,2,Interior Monitoring,Sensor (G209),Display Range: Not Installed
    ;No, ,
    14,3,Interior Monitoring,Shut-Off,Display Range: Not Installed
    ;OFF, ,
    14,4,Rear Lid,Feedback,Range: locked/implausible/unlocked/safe
    ;Unlocked, ,
    15,0,Alarm Sources,
    15,1,1st Alarm Source,,1 = Driver Door Rotary Switch
    2 = Passenger Door Rotary Switch
    4 = Rear Left Door Rotary Switch
    8 = Rear Right Door Rotary Switch
    16 = Rear Lid Rotary Switch
    17 = Immobilizer Recognition
    18 = Backup Horn
    32 = Hood Contact Switch
    64 = Ignition (Terminal 15)
    128 = Interior Monitoring
    255 = No Alarm
    ;128,Count,
    15,2,2nd Alarm Source,,1 = Driver Door Rotary Switch
    18 = Backup Horn
    255 = No Alarm
    ;128,Count,
    15,3,3rd Alarm Source,,1 = Driver Door Rotary Switch
    18 = Backup Horn
    255 = No Alarm
    ;128,Count,
    15,4,4th Alarm Source,,1 = Driver Door Rotary Switch
    18 = Backup Horn
    255 = No Alarm
    ;128,Count,
    80,0,Advanced Control Module Identification I,
    80,1,Identification,,
    ;HLO-KSG 02.06.08 00460104 0000 0000,Identification,
    137,0,,
    137,1,,,
    ;Data for,,
    137,2,,,
    ;Group 137,,
    137,3,,,
    ;Not,,
    137,4,,,
    ;Available,,
