I'm a long time user, luckily I have not had to use my KEY-USB (Dual-K VAG-COM KC104429 Rev. B) cable on my 2010 VW CC or 2008 Passat 3.6l Wagon for some time. It's always worked great and is a great tool!
Since using VCDS and cable, I updated my laptop to Windows 10 Pro (32-bit OS, x-64 based Processor), and updated to VCDS Release 17.1.3.
The Test function finds the cable, and once connected to a vehicle it says: Port Status: OK and Interface Found! USB library version 03.02.07 and driver version 02.10.00 K1 and K2 OK
When I go to the OBD2 function it states: Car is NOT ISO/OBD-II Compatible! (I have used this before.)
When I go to Open Controller, and click Engine(or any controller), it states: No Response from Controller!
I tried both of our VW's and have the same issue.
I read through the Forums and F&Q's to see if anyone experienced my issues, and tried the "USB selective suspend setting" under "Power Options" set to "Disabled", that did not work.
Any suggestions? What did I miss? Thanks for any input!
