Results 1 to 10 of 17
Thread: need coding abs vw passat 3C
    Feb 2017
    Morocco
    hi guys
    the first time i post this thread
    i need coding abs vw passat 3C the coding change after change parking brake ecu was damaged by water
    any help please
    thanks
    Monday,27,February,2017,20:11:30:13545
    VCDS Version: 16.8.4.2
    VIN: WVWZZZ3CZ8P020401   License Plate: VW PASSAT ABS CODING
    Mileage: 132870km-82561mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 5D 62 72 76
              77
    VIN: WVWZZZ3CZ8P020401   Mileage: 132870km-82561miles
    15-Airbags -- Status: Malfunction 1010
    5D-Operations -- Status: OK 0000
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018 FH    HW: 03G 906 018 FH
       Component: R4 2.0l PPD1.5 G    1605
       Revision: --H45---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 00028 028 00001
       VCID: 70EF25D26397FAC239-8024
    005685 - Powertrain Data Bus
                   P1635 - 009 - Missing Message from A/C Controller - Intermittent
                        Reset counter: 38
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:19:09
                        RPM: 768 /min
                        Torque: 24.0 Nm
                            0.00 %
                        Voltage: 11.53 V
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    005686 - Powertrain Data Bus
                   P1636 - 009 - Missing Message from Airbag Controller - Intermittent
                        Reset counter: 38
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:19:09
                        RPM: 768 /min
                        Torque: 24.0 Nm
                            0.00 %
                        Voltage: 11.53 V
                        Bin. Bits: 00001100
                        Torque: 0.0 Nm
    049448 - No Communications with Parking Brake Control Module
                   U0128 - 009 -  - Intermittent
                        Reset counter: 38
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:19:09
                        RPM: 768 /min
                        Torque: 24.0 Nm
                            0.00 %
                        Voltage: 13.90 V
                        Bin. Bits: 11001100
                        Bin. Bits: 00000000
    Readiness: N/A
       Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
       Component: J104    C4 440 V1   0003
       Revision: --020---    Serial number: 00000775629621
       Coding: 0000279
       Shop #: WSC 00012 000 00000
       VCID: 1E332B6AC9833CB2DB-804A
                000 -  -
                        Reset counter: 200
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 00:58:18
                        Hex Value: 0x0000
                        Voltage: 14.25 V
                        Bin. Bits: 00011110
                        Count: 199
                000 -  -
                        Reset counter: 200
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011110
                        Count: 149
                        Reset counter: 200
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 CB    HW: 3C0 907 044 CB
       Component: ClimatronicPQ46 122 0707
       Revision: 00122021    Serial number: 00000000000000
       VCID: 63C55A9EA261515AB4-8036
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Revision: 00H52000    Serial number: 00000004970057
       Coding: E5808F0700041A00470A00000F00000000095D435C0001
       VCID: 6CD731A24FBF1E2205-8038
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 250507 003  0205
       Coding: 00046997
       Shop #: WSC 00028
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     290607 046  0204
       Coding: 00208933
       Shop #: WSC 00028
    02092 - Enabling Heated Seat
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 200
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:00
                        Voltage: 14.00 V
                        Reset counter: 238
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:00
                        Voltage: 14.00 V
                        Fault Frequency: 8
                        Reset counter: 238
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:00
                        Voltage: 14.00 V
       Part No SW: 3C0 909 605 M    HW: 3C0 909 605 M
       Component: 0B AIRBAG VW8   032 2522
       Revision: 12032000    Serial number: 003B1PCG50H4
       Coding: 0012354
       VCID: 306FE5D2A317BAC279-8064
       Subsystem 1 - Serial number: 6332MSME1C330014
       Subsystem 2 - Serial number: 6342MSME1C0D301C
       Subsystem 3 - Serial number: 6351HTS6D3KGK397
       Subsystem 4 - Serial number: 6361HTS6OFJSM696
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
       Part No SW: 3C0 953 549 M    HW: 3C0 953 549 M
       Component: J0527               0015
       Revision: 00006000    Serial number: 3C5953507BJ
       Coding: 0000311
       VCID: 3663D3CA417394F223-8062
       Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007105
       Shop #: WSC 80093 222 69422
       VCID: 2643038A91D3E47293-8072
                        Reset counter: 238
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:17
    Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P0762003D0
       Coding: F9807F0E4026021002
       VCID: 23451A9EE2E1115AF4-8076
                        Reset counter: 238
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:18
                        Reset counter: 238
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:18
                        Reset counter: 198
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:22
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       VCID: 3979D8F6706D7B8ACE-806C
       Subsystem 1 - Part No: 3C0 959 433 R
       Subsystem 2 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0 959 433 R      IMMO         042 03833C0905861G     ELV          027 0380
    No Faults Found
    Address 37: Navigation        Labels: 1K0-035-191.lbl
       Part No SW: 1K0 035 191 D    HW: 1K0 035 191 D
       Component: J401                0303
       Revision: 00018000    Serial number: VWZ1Z2G7267025
       Coding: 0043400
                        Reset counter: 198
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:16
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1131
       Revision: 31008001    Serial number: 00000539778530
       Coding: 0000247
       VCID: 3C77C1E27F5F4EA2D5-8068
                        Fault Status: 01100101
                        Reset counter: 200
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:18
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.135 H08 1901
       VCID: 3561D4C65C759FEA2A-8060
    02546 - Steering Limit Stop
                        Mileage: 132860 km
                        Temperature: 25.0C
                        Voltage: 14.00 V
                        Voltage: 13.80 V
                000 -  -
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 042 0472
       Coding: 01910A0001860E763004941570084FCE707C00
       Component: LIN BACKUP HORN H07 9001
                        Reset counter: 239
                        Reset counter: 238
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:20
                        Reset counter: 239
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:14:14
    01134 - Alarm Horn (H12)
                        Reset counter: 239
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:14:14
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1131
       Revision: 31008001    Serial number: 00000005278531
       Coding: 0000246
       VCID: 3D71CCE6644547AAE2-8068
                        Reset counter: 200
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:18
       Part No SW: 3C8 907 801 E    HW: 3C0 907 801 J
       Component: J540 EPB3  VW-15417 0007
       Revision:   008       Serial number: 00000000063054
       Coding: 0000056
       VCID: 2C57F1A28F3FDE2245-8078
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
                011 - Open Circuit - MIL ON
                        Fault Status: 11101011
                        Reset counter: 200
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 00:56:28
                        Voltage: 14.10 V
                        Count: 31
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0404
                000 -  -  - MIL ON
                        Fault Status: 11110000
                        Reset counter: 0
                        Voltage: 5.00 V
                        Count: 43
                        Hex Value: 0x4040
                        Hex Value: 0x0082
                        Hex Value: 0x1010
    Address 56: Radio        Labels: 1K0-035-191.lbl
       Component: R                   0303
       Coding: 0043400
                        Reset counter: 198
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:16
    Address 5D: Operations        Labels: 3C0-035-151.lbl
       Part No SW: 3C0 035 151 C    HW: 3C0 035 151 C
       Component: J738            011 0019
       Revision: 00011000
       VCID: 183F3D722BA7428211-804C
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1118
       Revision: 11006001    Serial number: 00000001929675
       Coding: 0000208
                        Reset counter: 200
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:18
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1118
       Revision: 11006001    Serial number: 00000001923892
       Coding: 0000208
       VCID: 3E73CBEA69435CB2FB-806A
    00935 - Electric Window Motor; Rear Right (V27)
                        Reset counter: 200
                        Mileage: 132871 km
                        Date: 2017.02.25
                        Time: 02:23:18
    Address 76: Park Assist        Labels: 3C0-919-283.lbl
       Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
       Component: Parkhilfe 8-Kan 004 0013
       Revision: 00004000    Serial number: 90630717214353
       Coding: 0000014
       VCID: 295908B680CDCB0ABE-807C
    Address 77: Telephone
    End-------------------------(Elapsed Time: 02:52)--------------------------
    United States
    This is one of those PPD TDIs with a C4 ABS controller so we may need some additional time to dig but I believe 0000282 is a good starting point for that 03-ABS coding.
    011A | 0000282
  3. Likes scanboy83 liked this post
    United States
    PR Data:
    Vehicle Identification No.	WVWZZZ3CZ8P020401
    Model	passat sedan
    PA
    Date of production	04.07.2007
    Year	2008
    Sales type	3C2332
    Engine Code	BMA
    Transmission Code	KDN
    G0K	6-speed manual transmission
    MS9	4-cyl. turbo diesel engine 2.0 L/100 kW 16V (TDI) with pump-jet injection system Base engine is T9G/TB3/TQ0/TN0
    TB3	4-cylinder diesel engine 2.0 L unit 03G.B
    L0L	Left-hand drive vehicle
    1SA	Without additional front underbody guard
    8T2	Cruise control system (CCS) electronic
    Feb 2017
    Morocco
    i tested this code before but still error....
  6. Likes Dana liked this post
    United States
    OK, hopefully someone else has a suggestion. The dealer would code that module online via SVM and if you have to go that route we would highly appreciate the final Auto-Scan.
    Feb 2017
    Morocco
    thanks
    ok how can do online ; you can do by vcds ...?
    Coding: 0000267
  10. Likes scanboy83 liked this post
  11. #8
    Feb 2017
    Morocco
    i tried this 0000258- 0000267 and 0000309
    0001291........................................... ..
    but nothing
  12. #9
    Coding: 0000348
  13. #10
    MODEL MY ENGINE-CODE PART# COMPONENT CODING
    VW Passat Sedan 2006 BKC 3C0 614 095 K ESP 440 C2 H014 0001 13569
    VW Passat Sedan 2006 BLF 3C0 614 095 M ESP 440 C2 H015 0001 13698
    VW Passat Sedan 2006 BKC 3C0 614 095 P ESP 440 C2 H015 0003 13569
    VW Passat Sedan 2006 BKP 3C0 614 095 P ESP 440 C2 H015 0003 29986
    VW Passat Sedan 2006 BKP 3C0 614 095 P ESP 440 C2 H015 0003 13602
    VW Passat Variant 2006 BKC 3C0 614 095 P ESP 440 C2 H015 0003 13569
    VW Passat Sedan US 2006 BLV 3C0 614 095 Q ESP 440 C2 H015 0003 46541
    VW Passat Variant 2006 BKP 3C0 614 095 P ESP 440 C2 H015 0003 13602
    VW Passat Variant 2006 BLR 3C0 614 095 N ESP 440 C2 H015 0001 30094
    VW Passat Variant 2006 BKP 3C0 614 095 Q ESP 440 C2 H015 0003 15650
    VW Passat Sedan 2006 BKP 3C0 614 095 M ESP 440 C2 H015 0001 13602
    VW Passat Sedan 2006 BKC 3C0 614 095 M ESP 440 C2 H015 0001 13569
    VW Passat Variant 2006 BXE 3C0 614 095 P ESP 440 C2 H015 0003 13569
    VW Passat Sedan 2006 BMR 3C0 614 095 Q ESP 440 C2 H015 0003 13629
    VW Passat Sedan 2006 BKP 3C0 614 095 Q ESP 440 C2 H015 0003 29989
    VW Passat Variant 2007 BXE 3C0 614 095 P ESP 440 C2 H015 0004 13569
    VW Passat Variant 2006 BMR 3C0 614 095 P ESP 440 C2 H015 0004 13626
    VW Passat Variant 2007 BMR 3C0 614 095 S ESP 440 C2 H015 0004 30013
    VW Passat Sedan 2007 AXZ 3C0 614 095 S ESP 440 C2 H015 0004 46535
    VW Passat Sedan 2007 BWA 3C0 614 109 ESP 440 C4 H018 0001 30112
    VW Passat Variant 2007 AXZ 3C0 614 109 A ESP 440 C4 H018 0001 13767
    VW Passat Sedan 2005 BMP 3C0 614 095 P ESP 440 C2 H015 0003 13602
    VW Passat Sedan 2007 BMR 3C0 614 109 ESP 440 C4 H018 0001 13626
    VW Passat Sedan 2007 BKP 3C0 614 095 S ESP 440 C2 H015 0004 13602
    VW Passat Variant 2008 BMR 3C0 614 109 D J104 C4 440 V2 0003 285
    VW Passat Sedan 2007 BXE 3C0 614 095 S ESP 440 C2 H015 0004 13569
    VW Passat Variant 2006 BMP 3C0 614 095 Q ESP 440 C2 H015 0003 13605
    VW Passat Var. BlueM 2008 BLS 3C0 614 109 C J104 C4 440 V1 0003 258
    VW Passat Variant 2008 BMP 3C0 614 109 C J104 C4 440 V1 0003 267
    VW Passat Variant 2008 BZB 3C0 614 109 C J104 C4 440 V1 0003 309
    VW Passat Sedan 2007 BMR 3C0 614 095 P ESP 440 C2 H015 0004 13626
    VW Passat Variant 2007 BXE 3C0 614 109 ESP 440 C4 H018 0001 13569
    VW Passat Variant 2008 BWS 3C0 614 109 D J104 C4 440 V2 0003 381
    VW Passat Sedan 2008 CBBB 3C0 614 109 P J104 C4 440 V2 0011 301
    VW Passat CC 2009 CAWB 3C0 614 109 P J104 C4 440 V2 0011 2412
    VW Passat CC 2009 BWS 3C0 614 109 P J104 C4 440 V2 0011 415
    VW Passat CC 2009 CBAB 3C0 614 109 P J104 C4 440 V2 0011 2322
    VW Passat 2006 BPY 3C0 614 095 Q ESP 440 C2 H015 0003 13755
    VW Passat Variant 2009 CBAB 3C0 614 109 S J104 C4 440 V1 0013 274
    VW Passat Var. BlueM 2009 CBDC 3C0 614 109 M J104 C4 440 V2 0021 33272
    VW Passat Variant 2008 BMR 3C0 614 109 E J104 C4 440 V3 0003 2333
    VW Passat Variant 2008 BMR 3C0 614 109 K J104 C4 440 V2 0005 285
    VW Passat Variant 2006 BVY 3C0 614 095 P ESP 440 C2 H015 0003 13710
    VW Passat Variant 2009 CBBB 3C0 614 109 R J104 C4 440 V3 0013 26925
    VW Passat Sedan 2009 CAXA 3C0 614 109 S J104 C4 440 V1 0013 307
    VW Passat CC 2009 CAWB 3C0 614 109 T J104 C4 440 V2 0013 2415
    VW Passat Variant 2006 BMP 3C0 614 095 P ESP 440 C2 H015 0003 13602
    VW Passat Variant 2007 BKP 3C0 614 109 ESP 440 C4 H018 0001 29998
    VW Passat Var. BlueM 2010 CBDC 3C0 614 109 AH J104 C4 440 V2 0024 33272
    VW Passat 2010 CBBB 3C0 614 109 AE J104 C4 440 V1 0015 293
    VW Passat 2010 CAXA 3C0 614 109 AH J104 C4 440 V2 0024 33269
    VW Passat 2007 BKP 3C0 614 109 A ESP 440 C4 H018 0001 15653
