Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: A4/B9 Reverse Mirror Tilt coding
    Feb 2017
    Belgium
    Hey guys,
    I'm still searching for the correct coding to make the passengers side mirror tilt when I'm in reverse.
    I've seen lots of coding (mod 52...byte 4...bit 2 & 3) but this is the coding for a B8, I assume. However I have a B9 and guess what: that is n't working on a B9.
    So, my question is simple: has anyone figured out yet how to do it on a A4/B9?
    BTW: I don't have memory seats and I don't have foldable mirrors...
    Thx!
    JST
    I don't have the answer to your question, but it might be helpful if you would post an Auto-Scan so people can see exactly what control modules are installed in your car and how they are configured.
    Verified VCDS User Mrclopec's Avatar
    May 2015
    Nipomo, CA
    I thought all you had to do was:
    1. Mirror selector switch to right mirror.
    2. Place foot on brake, shift to reverse.
    3. Use mirror adjuster to put mirror into desired tilt position.
    4. Shift back into park.
    Previously that used to store the desired tilt position within the door control module. Does that process not work anymore for the new B9?
    I retrofit not because I settled for a car that didn't have everything. I retrofit for the challenge!
    Nov 2016
    Quote Originally Posted by Mrclopec View Post
    That's how it is on my B8 A4 (although left not right as it's a RHD model) and also on my Son's Golf and whilst my A4 has both memory seats and auto-folding mirrors, the Golf has neither.
    2014 Audi S4 Avant, 'black edition'.
    2019 Audi Q2 Sport 30 tdi.
    2011 VW Golf 'Match' 1.4 tsi.
    2004 VW Polo 1.2.
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    This is done via a combination of Long Coding and TXT Coding, so not possible via VCDS. You could try the following in the hope that the needed TXT Coding setting might be set from the factory:
    Module 52 - Pass Door
    Long Coding
    Byte 4
    Activate Bit 2
    Activate Bit 3
    *No Memory seats or folding mirrors needed for this to work on MQB and MLBevo platforms
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  6. #6
    Dec 2016
    DE
    Quote Originally Posted by DJAlix View Post
    Uhh, well, speaking for MQB: when you want to set a specific "dipping location", you have to wire the mirror accordingly (with memory seats this wire is always present). Else it will only dip to a sort of hardcoded location.
  7. #7
    Feb 2017
    Belgium
    Long Coding
    Byte 4
    Activate Bit 2
    Activate Bit 3
    I've tried this before but it won't work. When I set these bits in VCDS I can't move the mirror at all. It's locked into the position at that time and won't move again until I put these bits back to "0".
    Below you can find the log of my car:
    Thursday,09,February,2017,19:48:24:59652
    VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
    Data version: 20170203 DS267.2
    Chassis Type: F4 (4M1)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 46 52 5F 81 A5 AC BB BC
    VIN: WAUZZZF44GA035931
    Address 01: Engine (J623-DETA)       Labels: None
       Part No SW: 04L 906 026 AG    HW: 04L 907 309 L
       Component: R4 2.0l TDI   H33 1969
       Revision: B1H33---
       Coding: 0A254032232605083408
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM20TDI01104L906026AG 001006
       ROD: EV_ECM20TDI01104L906026AG.rod
       VCID: 6FB8D9CD37139C3FC43-803A
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 8W0 927 155 K    HW: 0CK 927 156 S
       Component: 0CL 20TDIRdWH06 0002
       Revision: --H06---    Serial number: 0000001463
       ASAM Dataset: EV_TCMDL382021 002021
       ROD: EV_TCMDL382021_VW51.rod
       VCID: 47C8516D7F23647FAC3-8012
       Manual Transmission Fluid Pump:
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  HB1 0572
       Serial number: 75117051150348000842
       Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
       Component: ESP9 Plus     H06 0593
       Coding: 0CAA489928A50A9B15A74894007E5292E6A59230121450A812004A4967A549
       Shop #: WSC 58530 002 1048576
       ASAM Dataset: EV_ESP9BOSCHAU49X 012014
       ROD: EV_ESP9BOSCHAU49X_012.rod
    Address 08: Auto HVAC (E87)       Labels: None
       Part No SW: 8W0 820 043 L    HW: 8W0 820 043 L
       Component: Klima Zone 1  H40 0055
       Coding: 141800285140000500000100000000000000000000000000000000000000
       Shop #: WSC 06325 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 3C223E8136E537A7311-8068
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000693052
       Subsystem 2 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
       Component: Humidity_Sens  H01 0003
       Serial number: D7280DD7000000000001
       Part No SW: 8W0 907 063 AC    HW: 8W0 907 063 C
       Component: BCM1 MLBevo   H12 0228
       Coding: 80453342451800CD01445118182C00B911031100000000000000000020001A2000410023025601
       ASAM Dataset: EV_BCM1BOSCHAU736 015005
       ROD: EV_BCM1BOSCHAU736_015.rod
       VCID: 7CA2FE817665F7A7711-8028
       Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A
       Component: WWS491 151022  043 0813
       Serial number: 894353?0301529500282
       Coding: 5BC7F7
       Serial number: 61063111
       Coding: 03005D
       Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
       Component: E1 - LDS  H06 0008
       Serial number: 07 10 2015  00124853
       Interior Light Module:
       Subsystem 4 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
       Component: J528-Dachele  H13 0082
       Serial number: Q00038549
       Subsystem 5 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H15 0010
       Serial number: 2615000121581007
    Address 15: Airbags (J234)       Labels: None
       Part No SW: 8W0 959 655     HW: 8W0 959 655
       Component: Airbag10.44   H52 0084
       Serial number: 003M6001243+
       Coding: AECCF0C00C800000585400F3C00C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_AU49.rod
       VCID: 06569C6938A9BD77175-8052
       Subsystem 1 - Part No SW: -----------    HW: 442 062 811 15
       Component: SideSensor_Df  1E2 0887
       Serial number: 3577Y00B71A828835291
       Subsystem 2 - Part No SW: -----------    HW: 442 062 811 15
       Component: SideSensor_Pf  1E2 0887
       Serial number: 3587Y00A51AF3D1233B5
       Subsystem 3 - Part No SW: -----------    HW: 442 0B0 911 15
       Component: SideSensor_Dr  1C7 0148
       Serial number: 35177009D1C81BB691DW
       Subsystem 4 - Part No SW: -----------    HW: 442 0B0 911 15
       Component: SideSensor_Pr  1C7 0148
       Serial number: 3527700B31E2DF0371DL
       Subsystem 5 - Part No SW: -----------    HW: 442 0C3 011 15
       Component: FrontSensor_D  1C5 014A
       Serial number: 3557500AF1E0EEC2E372
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C3 011 15
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500AF1E0EEC181F2
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 711 15
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500C11DEB202A175
       Subsystem 8 - Part No SW: -----------    HW: 442 430 412 15
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00C71AF3CF473B%
       Subsystem 9 - Part No SW: -----------    HW: 442 430 412 15
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00C11A8288260EF
       Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 76B6ECA94849ADF7075-8022
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 8W5 920 741     HW: 8W5 920 741
       Component: MM--M--DSLRW- H06 0265
       Revision: 0251v1      Serial number:    NASI0C9CR
       Coding: 00A551C0688000080D0369601000000000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       ROD: EV_DashBoardAU736.rod
       VCID: 7BA0FD9D736BF09F78B-802E
       Part No SW: 4M1 907 468 A    HW: 4M1 907 468 A
       Component: Gateway       H13 4079
       Revision: 3B040053    Serial number: 5343B01A815C11
       Coding: 0301000100000F404400000000590012C8100007000000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002.rod
       VCID: 35342BA515CFE6EFCEF-8060
       Subsystem 1 - Part No SW: 8W0 951 523 D    HW: 8W0 951 523 D
       Component: J453 MFL  H02 0002
       Serial number: 20151121015047 RD157
       Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9052
       Serial number: 4951208603
       Part No SW: 8W0 959 593 G    HW: 8W0 959 593
       Component: TSG FS        005 0052
       Serial number: 0000178624610
       Coding: 001D0B214000000000001080
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       VCID: 4EC664499059B537EF5-801A
    Address 44: Steering Assist (J500)       Labels: None
       Part No SW: 8W0 909 144 D    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0405
       Coding: 09008080008000
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_EPSZFAU49X 002015
       ROD: EV_EPSZFAU49X.rod
       VCID: 3E26348920F925B71F5-806A
    Address 46: Central Conv. (J393)       Labels: None
       Part No SW: 8W0 907 064 AA    HW: 8W0 907 064 A
       Component: BCM2 MLBevo   016 0307
       Coding: 01340000400000A0638180000600000033020000004300502F04000000040030001F0000000000
       ASAM Dataset: EV_BCM2HellaAU736 010010
       ROD: EV_BCM2HellaAU736_010.rod
       Part No SW: 8W0 959 592 A    HW: 8W0 959 592
       Component: TSG BFS       005 0050
       Serial number: 0000178311063
       ROD: EV_DCU2PasseSideMAXHCONT.rod
       Part No SW: 8W0 035 193     HW: 8W0 035 193
       Component: MU-HS-LN-EU   042 0102
       Coding: 01940101FF0A000013110001000A00102F00024401700100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 74B2D6A15E35BFE7391-8020
       Subsystem 1 - Part No SW: 8W0 919 866 C    HW: -----------
       Component: ECE 2016  --- 0009
       Subsystem 2 - Part No SW: 8W0 919 604     HW: 8W0 919 604
       Component: AU49x_DU_STD  H40 0008
       Serial number: AUZ8Z9FBG00C37
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 N    HW: 8W0 919 614 N
       Component: ControlUnit_B  H22 0134
       Serial number: C1000021101500050080
       Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
       Component: GSM-LL        H07 0068
       Revision: 0L0D5012    Serial number: 20151123003267
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736_AU49.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
       Part No SW: 8W0 907 217 A    HW: 8W0 907 217
       Component: BVS           H13 0030
       Coding: 0404090100000401022023A0AD0000FC80F0C010C000
       ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
       VCID: 3A2E38993CD1099723D-806E
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736.rod
       VCID: 6E86C4C930199537CF5-803A
    Address BB: Door Rear Drv (J388)       Labels: None
       Part No SW: 8W0 959 595 A    HW: 8W0 959 595
       Component: TSG HFS       005 0050
       Serial number: 0000178628925
       Coding: 000D09200000000000001080
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       VCID: 4ACE68596C319917B3D-801E
    Address BC: Door Rear Pass (J389)       Labels: None
       Component: TSG HBFS      005 0050
       Serial number: 0000178628924
       ROD: EV_DCU2RearPasseMAXHCONT.rod
    End----------(Elapsed Time: 01:21, VBatt start/end: 12.1V/12.2V)-----------
  8. #8
    Apr 2015
    I have had passenger mirror dip on my pre facelift A3 8V, also have it on my Facelift A3 8V with no memory seats. In fact memory seats are not a factory option on the A3 8V's.
    Have activated this on many 8V's without power adjustable folding mirrors without issue however for a small number, 3 or 4, the mirror would never return to its exact normal driving position.
    VAG Car Coding
    @vagcarcoding
  9. #9
    Apr 2015
    Quote Originally Posted by JST1963 View Post
       Revision: B1H33---
       Coding: 5BC7F7
       Coding: 03005D
    That would be because there is another parameter which needs activating in addition to the long coding, which unfortunately VCDS is unable to access.
    VAG Car Coding
    @vagcarcoding
  10. #10
    Feb 2017
    Belgium
    Can you access it with ODB11?
