Hi I need your help, I dont have a Vw amarok worckshop manual, I unassambled a turbo for change a gasket, but now have a problem, I need a procedure for adjust a turbos,
This is a total auto scan.
thanks
thanks
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Wednesday,23,July,2014,15:15:11:30029
Chassis Type: 2H (6N0)
Scan: 01 03 08 09 15 17 19 22 25
VIN: WV1ZZZ2HZB8010403
Address 01: Engine (J623-CDCA) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 022 SL HW: 03L 907 309 K
Component: R4 2,0L EDC H33 9743
Revision: 26H33--- Serial number: 00000000000000
Coding: 01190012230600080000
Shop #: WSC 03128 229 100586
ASAM Dataset: EV_ECM20BTD01103L906022SL 002012
ROD: EV_ECM20BTD01103L906022SL.rod
VCID: 8103EA01107CC716149-80D4
5249 - Boost Pressure Regulation
P154F 00 [101] - Malfunction
Mileage: 138882 km
Date: 2045.14.17
Time: 04:16:18
Address 03: ABS Brakes Labels: 2H0-907-379.clb
Part No SW: 2H0 907 379 B HW: 2H0 907 379 B
Component: ASR MK25 E 0104
Revision: 00H23001
Coding: 0000065
Shop #: WSC 00000 059 00000
VCID: 2F67FCB9BE68016632D-807A
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 2H0 907 047 A HW: 2H0 907 047 A
Component: Climatic-T5 H10 0101
Revision: 00004001
Coding: 0000000002
ASAM Dataset: EV_ClimaticT5 A01002
ROD: EV_ClimaT5Basis_VN81.rod
VCID: 2649199D5992402EC1B-8073
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R7 937 086 B HW: 6R7 937 086
Component: PQ25 BCM H09 0015
Revision: -3------ Serial number: 0500253003
Coding: 3C0002380C010000003000003C0B04C40000410F600200003000
VCID: 4281A50DDDFA9C0ECD3-8017
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3321
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3321
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3321
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3321
Part No SW: 2H0 959 655 HW: 2H0 959 655
Component: VW10Airbag00N H05 0011
Revision: -------- Serial number: 003DQ00086KX
Coding: 00000000000000000000000000000000304E
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
ROD: EV_AirbaVW10BPAVN750_SE12.rod
VCID: F1E3BAC120DCD796E49-80A4
Serial number: 3555YRB405F6KCRCA9VQ
Crash sensor for front airbag; passenger side:
Serial number: 3565YRB405F6KCRCEGKR
Part No SW: 2H0 920 851 HW: 2H0 920 851
Component: KOMBI H09 0206
Coding: 170000
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: E3CFC089EA207506665-80B6
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 086
Component: GW-K-CAN TP20 0015
Revision: -3------
Coding: 742200
VCID: F0E5BFC523D6DE9EEB7-80A5
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
Component: SG offroad VTG 0153
Revision: 00H06000 Serial number: T1IRB0520BVH2R
Coding: 0000013
Component: IMMO H09 0206
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EAD1ADAD0D0A244EA53-80BF
End ---------------------------------------------------------------------
