Results 1 to 6 of 6
Thread: 01 engine help
    Feb 2017
    01 engine help
    Hey everyone this is my first post and pretty new to the VAGCOM
    It pretty awesome like
    But my question is whenever I go to 01 engine and then go to measure block it isn't lit up to click only the advanced measure block why is that?
    Because I want to check my boost and stuff like that
    Whenever I look I'm advanced measuring block
    Welcome.
    It might be helpful if you told us what make, model, year, and engine you car has. Or even better, if you would post an Auto-Scan
    Without that all we can do is guess, and if I had to do that, I'd guess the answer is could be found here.
  3. Likes MartinsX liked this post
    Feb 2017
    My car is a vw scirocco 2011 tdi 140brake then remapped to 185
    Ill get an auto scan I saved here
    Feb 2017
    Welcome.
    heres my auto scan
    it was done awhile ago but I done one today but didn't save because everything is the same
    Sunday,05,February,2017,17:02:10:35461
    VCDS Version: 17.1.2.1 (x64)  HEX-V2 CB: 0.4334.4
    Data version: 20170131 DS267.1
    VIN: WVWZZZ13ZBV024399   License Plate:
    Chassis Type: 13 (7N0)
    Scan: 01 03 08 09 14 15 16 17 19 25 2E 42 44 46 52 56 61
    VIN: WVWZZZ13ZBV024399   Mileage: 114630km-71227miles
    Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 GF    HW: 03L 907 309 N
       Component: R4 2.0l TDI   H23 9979
       Revision: 41H23---    Serial number:
       Coding: 00190012040501080000
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM20TDI01103L906018GF 003010
       ROD: EV_ECM20TDI01103L906018GA.rod
       VCID: 74B2D6A49E3387F739A-8020
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 763B40F5492400FE6E0E02ED92220092350000
       Shop #: WSC 00020 790 00000
       VCID: 76B6ECAC88CF95E707E-8022
       Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000003
       Shop #: WSC 00020 999 00000
       VCID: 005A8A74DA8BAB572D2-8054
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0046
       Revision: BC011001
       Coding: 48100A388025E100408800843400012643513B88436D81605C8087000041
       VCID: 3B203D98F36D088F380-806E
       Subsystem 1 - Part No SW: 1K8 955 119 G    HW: 1K8 955 119 G
       Component: Wischer 27101  10  0603
       Coding: 009795
       Component: RLS 071210 05  54  0403
       Coding: 0330ED
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
    Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
       Revision: 00000000    Serial number: 10121001560001
       Coding: 000180
       VCID: 2708F1E81FE5BC6F4C8-8072
       Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
       Component: 0H AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 003D1D036NDW
       Coding: 0012360
       VCID: 6FB8D9C8FB95A42FC48-803A
       Subsystem 1 - Serial number: 6332MSME586040464
       Subsystem 2 - Serial number: 6342MSME59312601%
       Subsystem 3 - Serial number: 6352QSME387B3718P
       Subsystem 4 - Serial number: 6362QSME7A7B450E-
       Part No SW: 5K0 953 521 BM    HW: 5K0 953 569 D
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101210201579
       Coding: 1082040000
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 78AAE294825BE397152-802C
       Component: E221__MFL-TAS  H07 0013
       Coding: 820000
       Part No SW: 1K8 920 972 A    HW: 1K8 920 972 A
       Component: KOMBI         H20 0420
       Coding: 470B01
       VCID: 323E10BC24A7C9C7EB6-8066
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 041210F2002616
       Coding: 354001
       VCID: 313C1FB02121F2DF92C-8064
                        Reset counter: 10
                        Mileage: 113341 km
                        Date: 2011.06.07
                        Time: 13:23:54
       Component: IMMO          H20 0420
       VCID: 6A8EC8DCCCF74107936-803E
    Address 2E: Media Player 3
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
       Component: Tuer-SG         009 2130
       Coding: 0148021
       VCID: 392C2790F5513A9F2AC-806C
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 178    3201
       Revision: 00H20000
       VCID: 343216A4D233C7F7F9A-8060
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
       Coding: 0148020
       VCID: 3A2E389CF0573187236-806E
    Address 56: Radio
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: 71BCDFB0E1A1B2DFD2C-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370224644
    End----------(Elapsed Time: 01:11, VBatt start/end: 14.7V/14.8V)-----------
    Yep. Your ECU uses the UDS protocol, which doesn't support the traditional VAG Measuring Blocks. Use Advanced Measuring Values instead.
    "Boost" can be found here:
    IDE00190 - Charge air pressure specified value
    IDE00191 - Charge air pressure; actual value
    Feb 2017
    thanks very much ill check this out later
