Results 1 to 10 of 16
Thread: Disable stop/start, 2014 S4 Avant
    Nov 2016
    Probably been asked/discussed before but my S4 Avant has stop/start which can be switched off but needs to be done every time the engine is started otherwise it reverts to being on and I'm really not keen on it cutting out when I don't want it to.
    I would prefer that I could switch it off and it stay off, or leave it on and it stay on i.e. 'remember' the last state but I understand that is probably not possible? If that is the case then I would rather it be permanently off than default to on, if possible.
    There was mention in another thread about a different model that it can be permanently disabled with some adaptation? can anyone tell me how?
    Here's a scan in case it helps;
    Tuesday,15,November,2016,12:38:47:24986
    VCDS Version: 16.8.3.1
    VIN: WAUZZZ8K7EA150192   License Plate:
    Mileage: 27250km-16932mi   Repair Order:
    Chassis Type: 8K (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 30 36 42 44 46 47 52 53 56 5F
              62 6D 72 A9
    VIN: WAUZZZ8K7EA150192   Mileage: 27250km-16932miles
    Address 01: Engine (J623-CGWC)       Labels: 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 D    HW: 4H0 907 551
       Component: 3.0l V6 TFSIH07 0004
       Revision: --H07---
       Coding: 12250034052701020800
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
       ROD: EV_ECM30TFS0218K5907551D.rod
       VCID: 377CA0AB8E2C1EFA4D-8062
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 8K5 927 156 B    HW: 0B5 927 156 K
       Component: 0B5 30TFSIRdW H03 0003
       Revision: --H03---
       Coding: 000001
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDL501021_VW51.rod
       VCID: 387EA3978332118244-806C
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Component: ESP8 quattro  H09 0020
       Coding: 291DCC01
       Shop #: WSC 06335 000 00000
       VCID: 09181653A058D80AEB-805C
       Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
       Component: BCM2 2.0      H14 0650
       Coding: 01B24040000000000000
       VCID: 7EF2758FE996EFB2CE-802A
       Subsystem 1 - Part No SW: 8K0 959 754 BH    HW: 8K0 959 754 BH
       Serial number: 0514000046829005
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 0214000068278002
       Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
       Component: KLIMA 3 ZONEN H04 0122
       Revision: D1000000    Serial number: 01100420140302
       Coding: 6624028000
       VCID: 78FE6397CBB2D18284-802C
       Revision: 08016001    Serial number: 00000789946701
       Coding: 260000108034AFC00081404300001D0D0F1D470A27090201000008004400030100000024000000
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 010414  H06 0080
       Serial number: SWF14044015610
       Coding: 00FD11
       Serial number: 22487512
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000104144832
       Serial number: FA780227000000000001
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003KFDC0WUTP
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 60782 001 1048576
       VCID: 489ED357F3D2610234-801C
       Serial number: 6334MSME443A333AD
       Serial number: 6344MSME443C6E75T
       Serial number: 6352QSME1E400648E
       Serial number: 6362QSME1A401B6EP
       Serial number: 63732SME40404A66X
       Serial number: 63832SME4F400F689
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NDE001IC
       Coding: 000037
       VCID: 489ED357FBD2610234-801C
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 982 T    HW: 8K0 920 982 T
       Component: KOMBIINSTR.   H35 0564
       Revision: 00100000    Serial number: ZAE62M34F
       Coding: 33A7110003012600010000
       VCID: 4580DA63CCC07C6ACF-8010
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y143310158
       Coding: 80CF07FF00
       VCID: 4A9AE95FE5DE931222-801E
       Serial number: 9802233103
       Serial number: 14099003849011200410
       Part No SW: 8K0 907 440 B    HW: 8K0 907 440
       Component: STS           H04 0020
       Revision: S0H04000    Serial number: 00000000084090
       Coding: 01010101000000000001000102
       VCID: 2D5082C37470A42A27-8078
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0077
       Revision: AA000000    Serial number: 00000097259421
       Coding: 01781300000000000000
       VCID: 3B74BC9BBA043A9AA9-806E
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000098884238
       Coding: 011C02205E21410001
       VCID: 4FACF84B1EBCB63A75-801A
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0003457337
       Coding: 100000000001
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3560AAA39420ECEA5F-8060
       Revision: 00002001    Serial number: 0332027708
       Coding: 013B0622A0B938948330023680000047
       Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
       Component: J245 PS151  H08 0043
       Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
       Component: J394 PS240  H08 0043
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Revision: 00005001    Serial number: 94813028507104
       Revision:             Serial number: 0000098720192
       VCID: 4E92E54F19B6BF327E-801A
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H01 0005
       Revision: --------    Serial number: 20000000431915
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 3A7AB99FBD3E0392B2-806E
       Part No SW: 4G0 035 061 N    HW: 4G0 035 061
       Component: Radio U DAB   H60 0139
       Revision: AB001007    Serial number: 109D20E7915856
       Coding: 010103010000000001
       VCID: 285E73D75B928102D4-807C
       Part No SW: 8R2 035 666 E    HW: 8R2 035 666 C
       Component: H-BN-EU       H47 0793
       Revision: --------    Serial number: 206DZ0E7560780
       Coding: 110101010206A1ED41808B5E00000403E40100020000000000
       Subsystem 1 - Part No: 8R0 060 884 BK
       Component: EUR 2014  1703
       Component: DU7 High  H42 0104
       Serial number: A130DI0E3000809
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000001824649
       Component: CD-Database  5571
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000098922402
       Coding: 010C02204021210001
       VCID: 4682DD6FF1C67772C6-8012
       Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
       Component: J605  Master  H53 0330
       Revision: --------    Serial number: 8K9827851C
       VCID: 3E72B58FA9162FB28E-806A
       Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
       Component: J756  Slave  H53 0330
       Serial number: 8K9827852C
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000098919842
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 140301200807
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: 72EA51BFA5CEBBD2BA-8026
    End-------------------------(Elapsed Time: 04:42)--------------------------
    Thanks in advance.
    2014 Audi S4 Avant, 'black edition'.
    2019 Audi Q2 Sport 30 tdi.
    2011 VW Golf 'Match' 1.4 tsi.
    2004 VW Polo 1.2.
    Dec 2016
    DE
    Module 09 > SA: 20113 > Adaptions > Read channel 34 > with the value you have some options:
    - substract 4 from the value = stop/start off by default
    - add 32 to the value = enable stop/start memory
    - add 64 to the value = invert the light in the stop/start switch (light on when stop/start on)
    I hope this works.
    Oh and you can do all of the above, if you want.
  3. Likes Dukedesmo, Eric, Boki Ar, D-Dub, Jetta ,97 liked this post
    Nov 2016
    Now if that works, that would be perfect.
    2004 VW Polo 1.2.
    Nov 2016
    To follow up, I did the above and it works fine.
    Actually I tried the -4 first and that changed the default, then I tried the +32 and it now retains the last setting - perfect.
    2004 VW Polo 1.2.
  6. Likes Eric, Uwe, D-Dub, TBAx liked this post
    I hope this works.
    TBAx: - if only you could provide advise about the same options for my mk7 Golf?
  8. Likes PetrolDave liked this post
  9. #6
    Mar 2015
    Australia
    What is name of adaptation channel 34?
    Perhaps the same channel is available in the Golf BCM at a different address?
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
  10. #7
    Quote Originally Posted by kamold View Post
    34. Non-UDS modules have channel numbers, not names.
  11. #8
    Mar 2015
    Australia
    Is there some way to map those channel numbers with a possible adaptation channel name of same function?
  12. #9
    Nov 2016
    I don't pretend to understand what all these channels etc. are but I'm happy to run any scan on it if it helps anyone?...
    2004 VW Polo 1.2.
  13. #10
    You can certainly make channel maps, but I can't think of any way to correlate them other than to look at the descriptions in the UDS ones.
