Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 98
Thread: V10 doesn't start
    Verified VCDS User Harris's Avatar
    Feb 2017
    North Carolina, USA
    Today I was able to get the VCDS w/Hex-V2 to communicate w/ two modules - Address 25Immobilizer) and 05Access/Start Authority) located under the "electronics 1" section of OPEN CONTROLLERS. AUTO SCAN would fail and never complete. Looks like its a KESSY module issue, anyone??? Does anyone have the security code? Or does anyone know what the correct settings are?
    In addition to whats below:
    Incorrect synch byte: $0
    VBat 12.4v/and VLGN 0.001v w/ no jumper
    VBat 09.5v/and VLGN 09.4v w/ jumper cables attached.
    Hope this might help me narrow down my troubleshooting!!!
    Friday,17,February,2017,13:14:02:02409
    VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4334.4
    Data version: 20170203 DS267.2
    VIN: WVGPT77L57D009872 License Plate:
    Mileage: 146662 Repair Order:
    Address 25: Immobilizer Labels: None
    Control Module Part Number: 7L0 909 135 A HW: 5WK 485 01
    Component and/or Version: Kessy 6700
    Software Coding: 0000232
    Work Shop Code: WSC 31414 000 00000
    Additional Info: 4E0905852E ELV 1940
    Additional Info: Geraet 00000
    VCID: 2F38193CFB0DDAEF843-5160
    00185 - Control Circuit; Relay for Supply Voltage Terminal 15
    00164 - Battery Monitoring Control Module (J367) in Emergency Mode
    00087 - Terminal 30 for Starting Relevant Consumers
    002 - Lower Limit Exceeded
    Address 25: DTCs cleared
    Address 05: Acc/Start Auth. Labels: None
    Advanced Identification
    Serial number: VWZ3Z0F2502801
    Identification: RBG-SME
    Revision: 67006015
    Date: 26.06.06
    Test stand number: 0001
    Manufacturer number: 0156
    Software
    A04.24
    K02.57
    Misc.
    Hardware number: 5WK 485 01
    Car Info
    Chassis Number: WVGPT77L57D009872
    VCDS Info:
    Labels: None
    Address 05,7L0 909 135 A,recoded (Short coding),from,0000232,to,0000232,(31414/000/00000),
    Last edited by Harris; 02-17-2017 at 05:53 PM. Reason: To be clearer in description
  2. #12
    My guess: You have some relay that isn't working, or possibly a blown fuse somewhere.
  3. Likes Harris, Jack@European_Parts liked this post
  4. #13
    Feb 2017
    North Carolina, USA
    That would be great! Now if I can find which one. I do have the Bentley publishing online manuals that might help.
  5. Likes Jack@European_Parts liked this post
  6. #14
    Jul 2014
    Have you sorted out the battery issue
  7. Likes Harris liked this post
  8. #15
    Feb 2017
    North Carolina, USA
    No, I have not pulled the batteries, full charged, and then load tested. At the moment all i know is they were good until there seemed to be a short draining everything down. I guess maybe I should pull and test first?
  9. #16
    Better check those modules for water............and sort the tracks directly using WD.
    Check ignition switch and terminal relays.
  10. Likes Harris liked this post
  11. #17
    Oct 2016
    Canada
    I would start by looking at those battery feed relays and their fuses, they're all under the driver seat, you have 2 bolts to undo and seat lifts right up in 45deg angle
    Open up there and also check your main battery ground which is bolted to the floor, failure of this ground or any fuse under the seat will not get the treg started.
  12. Likes Jack@European_Parts, Uwe, Harris liked this post
  13. #18
    Feb 2017
    North Carolina, USA
    Current update: Haven't yet found any bad fuses or relays from under the seat of the left and right side-dash panels. Observations: when key is turned i noticed bulb failure symbol flashing and air suspension button on console. The color screen in instrument cluster shows vehicle normal, but shows the air suspension symbol at top of screen. I'm currently parked on a slope.
  14. #19
    Jun 2014
    My guess is bad front battery. Did you know that turning the key counterclockwise will engage both batteries?
    As you probably know, voltage under load is what counts. The Intervention Load Management is a sure indication your volatage has fallen too low.
    As a last resort check under your feet for a wet carpet. Many a Treg has been stopped by great green globs of corrosion inside the bundle of wires there.
  15. Likes ivagp, Harris liked this post
  16. #20
    Oct 2016
    Canada
    @ Harris, air suspension bulb fault will be attributed when you lose power and it loses its basic settings, when a battery is replaced, for that error to clear out you need to drive 25-50 feet in a straight line.
    It means you have either a battery drain issue or something wrong with the main battery. Have you tried seeing the current draw on that battery when the truck's asleep? (all doors locked and alarm on for 15 min)
    Forgot to add the max tolerance draw is 30mA, should never go over 60mA
  17. Likes Harris, Uwe, MartinsX liked this post
