Page 1 of 11 123 ... LastLast
Results 1 to 10 of 103
Thread: V10 doesn't start
    Verified VCDS User Harris's Avatar
    Feb 2017
    North Carolina, USA
    V10 doesn't start
    My first post on forum. Today I was using my new VCDS w/Hex-V2 on my Touareg V10 and during an Autoscan It stopped and said "unable to communicate with controller" then I turned off vehicle and tried to restart. My dash screen seems normal w/ "push brake" message but nothing ever happens. It doesn't start. I push the brakes but nothing happens. Brake pedal seems stiff. I've since seen messages like, "AFS, No function veh. wallet", gearbox workshop, but ultimately when I put my key in it just says push brake. It does have the symbol of the vehicle up/down lite up above the push brake message. Anyone have a suggestion. Funny thing - I was in the parking lot of the repair shop discussing a long waiting repair on the a/c compressor. I come back out and vehicle doesn't start. other than the a/c vehicle did run great. I'll keep everyone posted on what I find out but any suggestions would be appreciated.
    Quote Originally Posted by Harris View Post
    Any chance you ran the battery down while playing with your new scan tool? It wouldn't be the first time someone did that.
    PS: I split this into its own thread.
  3. Likes Eric, Harris liked this post
    Feb 2017
    North Carolina, USA
    Thanks for the response UWE. Yes, I've been having lots of fun with the VCDS w/Hex-V2. I haven't yet test the power, but it appears good. Maybe it could be the starter battery in the rear cargo? But, the vehicle was idling in parking lot for 10 min. I was scanning while running engine. Then I came back out and turned it off. I returned a few minutes later and tried to start and nothing. BTW, BEFORE I got to this destination, maybe 5 miles up the road, I did get a CAR-WASH - twice!!! Not sure if it may have got something wet. Leaving now to go back over and check on this girl. I'll keep you posted.
  6. #4
    With a HEX-NET or HEX-V2, [Options] -> [Test] will show you the battery voltage available in the vehicle. You don't even have to turn the ignition on. In fact, it's better to evaluate the battery's state-of-charge based on voltage while it is "at rest".
    Based on what you wrote above, I'm less convinced that's what the problem is, but worth looking at in any case.
  7. Likes Harris liked this post
  8. #5
    Feb 2017
    North Carolina, USA
    Thanks for the added insight on Hex functionality. Batteries are great -11.9 and 12.5v. The Hex-v2 does turn green when I plug it in but the actual scan does ZERO communication with any system or modules. The same was with the mechanics "Snap-on" scanner - that is, no communication with vehicle. Even the locks are acting funny. Windows not rolling down. When I try locking the vehicle some doors lock while others don't. Then try locking again, and same thing, just different arrangement of locked doors. Also replaced the brake switch but didn't help. No load is being applied to the batteries when trying to start.
  9. #6
    12.5v is OK, but 11.9 is hardly great. Then again, it's not low enough to cause what you describe.
    What model year is this?
    Have you ever done a full Auto-Scan? If so, please post it so people can see how it's equipped. Hint: All Auto-Scans are auto-saved to he Scans folder whether you manually save them or not.
  10. Likes Harris liked this post
  11. #7
    Feb 2017
    North Carolina, USA
    My model is 2007 (made july 2006) Touareg V10 5.0 TDI
    Here is the last Auto scan I ran.
    Tuesday,14,February,2017,12:16:38:02409
    VCDS Version: 17.1.3.0  HEX-V2 CB: 0.4334.4
    Data version: 20170203 DS267.2
    VIN: WVGPT77L57D009872   License Plate:
    Mileage: 236010km-146649mi   Repair Order: 2
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGPT77L57D009872   Mileage: 236010km-146649miles
       Part No SW: 070 906 016 CQ    HW: 028 101 196 2
       Component: V10 5,0L EDCG000AGMª8472
       Revision: --H02---    Serial number: VWZ3Z0F2502801
       Coding: 0060575
       Shop #: WSC 31414 000 00000
       VCID: 619CAF04FD593C9F427-5184
       Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
       Component: AL 750 6A           0856
       Revision: 00H51000    Serial number:
       Coding: 0004216
       VCID: 7F58097C6BEDEA6F543-5160
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0022786
       VCID: 3D2433742161387F06F-5184
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 135 A    HW: 5WK 485 01
       Component:    Kessy            6700
       Revision: 67006015    Serial number: VWZ3Z0F2502801
       Coding: 0000232
       VCID: 2F38193CFB0DDAEF843-5184
    00955 - Key 1
    Address 08: Auto HVAC        Labels: 7L6-907-044.clb
       Part No: 7L6 907 044 AB
       Component: CLIMAtronic 2+2     4325
       Coding: 0020030
       Shop #: WSC 25807 128 68113
       VCID: 74B2D65052ABB937391-5184
       Subsystem 1 - Part No: 7L6 907 049 E
       Component: CLIMAtronic FOND    0400
    00898 - Control Circuit A/C compressor
                009 - Open or Short to Ground
    02599 - Rear Left Temperature Flap Motor (V313)
    00362 - Rear Left Air Flap Motor (V239)
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 N
       Component:                     3002
       Coding: 0110815
       VCID: 47C8519C73BD62AFAC3-5184
    Address 11: Engine II        Labels: Redir Fail!
       Component: V10 5,0L EDCG000AGSª8472
       Coding: 0060575
       Part No: 3D0 909 601 L
       Component: 03 Airbag 8.4E++H02 0662
       Revision: BB62060     Serial number: 0000199>
       Coding: 0012339
       Shop #: WSC 06485 444 10329
       VCID: 2C020E30CA1BA1F7A11-5184
       Subsystem 1 - Part No: 7L0 959 339 C
       Component: BF-Gewichtsens. 006 0008
       Part No: 7L6 953 549 H
       Component: Lenksäulenmodul     3401
       Coding: 0010031
       VCID: 44D24690428B49B7491-5184
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 981 R
       Component: KOMBIINSTRUMENT RB8 3211
       Coding: 0007231
       VCID: 48CA52A07EA36DD7A59-5184
    Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
       Part No: 7L6 815 071 D
       Component: Standheizung E1MAC
       Coding: 0000100
       VCID: 3330154C1725FE0FE0B-5184
    01126 - Engine Speed Signal
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70BADA4026B38517DD9-5184
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879 A
       Component: JCI PathPoint       2200
       VCID: 45D45B9449B170BF5EF-5184
       Part No: 0AD 927 755 AT
       Component: TRANSFERCASE        0114
       VCID: 0D44A3B45141C8FF56F-5184
    Address 32: Differential Locks        Labels: None
       Part No: 0AC 927 771 C
       Component: SG-Quersperre       5020
       VCID: 382A22600E431D57D59-5160
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 H
       Component: LUFTFDR.-CDC- 3C3P1 3099
       Coding: 0015521
       VCID: 382A22600E431D57D59-5184
       Part No: 7L0 959 760
       Component: Sitzverstellung     0702
       VCID: 77A8E15C43DDD22F1C3-5184
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 M
       Component:      Navigation     0047
       Coding: 0000101
       VCID: 50FA7AC086F3A517FD9-5184
       Part No: 7L0 959 933 H
       Component: YM HSG              0400
       Coding: 0000085
       VCID: 41DC4F845D995C9F627-4B1E
       Subsystem 1 - Part No: 7L0 959 701 G
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 G
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 C
       Subsystem 4 - Part No: 7L0 959 704 C
    00915 - Window Regulator Switch; Rear Right; Driver (E55)
    Address 47: Sound System        Labels:
       VCID: 55F48BD4BC01C03F2EF-5184
       Note: Excessive Comm Errors
    Address 55: Headlight Range        Labels: 7L6-907-357.lbl
       Part No SW: 7L6 907 357     HW: 7L6 907 357
       Component: AFS-Steuergeraet    0003
       Revision:   H09       Serial number:
       Coding: 0000009
       VCID: 78AAE2604EC3DD57159-5184
       Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    X018
       Coding: 00000034
       Subsystem 2 - Part No: 7L6 941 330
       Component: AFS-Lst.-Modul r    X018
       Coding: 00000034
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 E
       Component:        Radio        0047
       Coding: 0014062
       VCID: 35342B541951E03FCEF-5184
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000341
       Shop #: WSC 31414 000 376832
       VCID: 3C223E703A7B3177311-5184
       Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
       Component: RLS     071006 020  0105
       Coding: 00208933
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
       Component: ANHAENGERELEKTRONIK 8854
       Part No SW: 7L6 907 441     HW: 7L6 907 441
       Component: J772__Rearview      0051
       Revision: 00H07000    Serial number:    PA8 J640552
       Coding: 0000101
       VCID: 72BED04828BFB7072BD-5184
    Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
       Part No SW: 7L6 959 107     HW: 7L6 959 107
       Component: J605  HECKKLAPPE    1110
       Revision: --H05---    Serial number: --------004007
       Coding: 0022110
    03074 - Rear Lid Inclination Sensor (G549)
                        Fault Status: 00101001
                        Fault Frequency: 23
                        Reset counter: 61
    Address 6E: Ctrl Head Roof        Labels: 7L6-919-044.clb
       Part No: 7L6 919 044 T
       Component: DACHDISPLAY         0539
       Revision: 00900539    Serial number: 2009289.07
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 392C27643549045F2A7-5184
    End----------(Elapsed Time: 09:40, VBatt start/end: 14.1V/14.0V)-----------
    Address 01: DTCs cleared
    Address 02: DTCs cleared
    Address 03: DTCs cleared
    Address 05: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 11: DTCs cleared
    Address 15: DTCs cleared
    Address 16: DTCs cleared
    Address 17: DTCs cleared
    Address 18: DTCs cleared
    Address 19: DTCs cleared
    Address 1C: DTCs cleared
    Address 22: DTCs cleared
    Address 32: DTCs cleared
    Address 34: DTCs cleared
    Address 36: DTCs cleared
    Address 37: DTCs cleared
    Address 46: DTCs cleared
    Address 55: DTCs cleared
    Address 56: DTCs cleared
    Address 68: DTCs cleared
    Address 69: DTCs cleared
    Address 6C: DTCs cleared
    Address 6D: DTCs cleared
    Address 6E: DTCs cleared
    Address 76: DTCs cleared
       Coding: 0060575
       Coding: 0004216
       Coding: 0022786
       Coding: 0000232
       Coding: 0020030
       Component:                     3002
       Coding: 0110815
       Coding: 0060575
       Coding: 0012339
       Coding: 0010031
       Coding: 0007231
       Coding: 0000100
       Coding: 0000006
       VCID: 0D44A3B45141C8FF56F-5160
       Coding: 0015521
       Coding: 0000101
       Coding: 0000085
       Coding: 0000009
       Coding: 00000034
       Coding: 00000034
       Coding: 0014062
       Coding: 0000341
       Coding: 00208933
       Shop #: WSC 31414
       Coding: 0000101
       Coding: 0022110
    End----------(Elapsed Time: 11:00, VBatt start/end: 13.9V/13.9V)-----------
    Control Module Part Number: 7L6 907 044 AB
      Component and/or Version: CLIMAtronic 2+2     4325
               Software Coding: 0020030
                Work Shop Code: WSC 25807
               Additional Info: 7L6907049E  CLIMAtronic FOND    0400
               Additional Info: Geraet 68113
    Misc.
    VCDS Info:
    Misc.
    VCDS Info:
    Misc.
    VCDS Info:
    Address 08,7L6 907 044 AB,recoded (Short coding),from,0020030,to,0020030,(25807/128/68113),
                    Address 08: Auto HVAC  (7L6 907 044 AB)
    12:36:56 Group 001: General Basic Setting
      Basic setting
      N/A
      N/A
      N/A
      Basic setting
      N/A
      N/A
      N/A
  12. Likes Uwe, Jack@European_Parts liked this post
  13. #8
    I'm moving this to car repair support because I believe it's the car that's broken, not VCDS.
  14. Likes Harris liked this post
  15. #9
    Th
    DING DING!
    Check your Kessy and Engine ecu for taking on water or any other ingress point.
    Component: 3002
    Coding: 0110815
    Oh no.....!
  16. Likes Harris, Jetta ,97 liked this post
  17. #10
    Feb 2017
    North Carolina, USA
    Thanks for the advice. Will keep everyone posted on what I find out.
  18. Likes Uwe, Jack@European_Parts liked this post
