Results 1 to 3 of 3
Thread: Audi TT ABS coding
    Feb 2017
    Italy
    Audi TT ABS coding
    Hi All,
    just mounted on my TT 2015 a couple of 340 mm front brakes from TTS model. Original was 312 mm.
    I was wondering if an ABS recoding is necessary to update the brakes size.
    The issue is that coding has no long coding helper. Any hint to update this ECU coding ?
    Here autoscan, please help me.
    Stefano
    Tuesday,14,February,2017,14:14:45:58654
    VCDS Version: 17.1.3.0  HEX-V2 CB: 0.4334.4
    Data version: 20170203 DS267.2
    VIN: TRUZZZFV1F100xxxx   License Plate: xxxxxxx
    Mileage: xxxxx   Repair Order:
    Chassis Type: FV (8S0)
    Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A5 A9
    Address 01: Engine (J623-CHHC)       Labels: 06K-907-425-V1.clb
       Part No SW: 8S0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 0A1900322424050B3002
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208S0906259 001006
       ROD: EV_ECM20TFS0208S0906259.rod
       VCID: 7AAEF860DC51083763D-802E
    Readiness: 1110 0001
       Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
       Component: ESC           H31 0504
       Revision: 00000000    Serial number: 63094000000178
       Coding: 32AA108D0A9915AF40990067C299930EC44C0850A8020043C97023
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
       ROD: EV_Brake1UDSContiMK100IPB_052.rod
       VCID: 40DA4A88FA0D92E76D9-8014
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0351661254
       Coding: 000F0F1620
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77A8E154EF43155F1C3-8022
    Address 08: Auto HVAC (E87)       Labels: None
       Part No SW: 8S0 820 043     HW: 8S0 820 043
       Component: AC Automat    H05 0020
       Revision: 20008000    Serial number: 14070000009000
       Coding: 400040000011101000
       ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
       ROD: EV_AirCondiVAPrehAU33x.rod
       VCID: 6C82CE38A605A687E11-8038
       Serial number: AD598C57000000000001
       Operating and display unit 2 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H06 0010
       Serial number: 00000000000000002095
       Operating and display unit 3 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H06 0010
       Operating and display unit 4 for air conditioning:
       Subsystem 4 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H06 0010
       Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0136
       Serial number: 01011431504022
       Coding: 04054C42C20106FD43044004001807A80080000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 094C97AC89B713AF7A7-805C
       Subsystem 1 - Part No SW: 8S1 955 119 A    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
       Component: 43x LL 140619  032 0371
       Serial number: 00000001406170701496
       Coding: 1BC7F7
       Serial number: 23452498
       Coding: 00005D
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 26 09 2014  00001508
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39211432204542
       Coding: 0000040001
       ROD: EV_EPHVA14AU3700000_AU37.rod
       VCID: 3B203D6493EBF13F38B-806E
       Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
       Component: AirbagVW20    009 0870
       Serial number: 003M7R005EYQ
       Coding: 88CCF0000C8000005C5000CFC04800000065
       VCID: 4DC463BC3D5F4F8F96F-8018
       Subsystem 1 - Part No SW: -----------    HW: 480 001 411 14
       Serial number: 3570000000048BA4B11M
       Subsystem 2 - Part No SW: -----------    HW: 480 001 411 14
       Serial number: 35800000000BFAA4B11-
       Subsystem 3 - Part No SW: -----------    HW: 480 012 909 14
       Component: SideSensor_Dr  004 0108
       Serial number: 351001A01DD52E021F66
       Subsystem 4 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3550002AD18166A572B9
       Front Sensor Passenger:
       Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3560002AD18166A3D2BE
       Pedestrian Protection Center:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 411 14
       Serial number: 2300002BD1860BC421B1
       Subsystem 7 - Part No SW: -----------    HW: 480 000 210 14
       Serial number: I0M000000006B485311-
       Subsystem 8 - Part No SW: -----------    HW: 480 000 210 14
       Serial number: I0N00000000A4485311Y
       Part No SW: 8S0 907 129 AC    HW: 8S0 907 129 AC
       Component: Lenks. Modul  H06 0140
       Revision: --------    Serial number: 91335NKJ00197
       Coding: 280C
       ASAM Dataset: EV_SMLSKLOMQB 019002
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 7BA0FD64D36B313F78B-802E
    Address 17: Instruments (J285)       Labels: Redir Fail!
       Part No SW: 8S0 920 790     HW: 8S0 920 790
       Component: FBenRDW       H32 0221
       Coding: 04250110698000080420E8C09000800000000000
       ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
       ROD: EV_DashBoardBOSCHAU33X.rod
       VCID: 76B6EC50E8496C57075-8022
       Part No SW: 8S0 907 468 A    HW: 8S0 907 468
       Component: GW MQB TT3    012 0203
       Revision: --------    Serial number: 24091410800543
       Coding: 030100042F025A004B000268080000000000000000000000000000000001
       ASAM Dataset: EV_GatewContiAU33X 011002
       ROD: EV_GatewContiAU33X.rod
       VCID: 3E26347080F9E4171F5-806A
       Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
       Component: J453 MFL  H06 0001
       Serial number: 20140924161427 RD862
       Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
       Serial number: 5917184503
       Serial number: 14000192704011
       Coding: 0100000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BCDF4C81274B6FD27-8024
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 09111403111295
       Coding: 001E47225C00040100001402
       VCID: 42DE4080F40180F77BD-8016
       Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 F
       Component: EPS_MQB_ZFLS  503 5061
       Coding: 9103
       ROD: EV_SteerAssisMQB_VW31.rod
       VCID: 37282154AFC3D55FDC3-8062
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 08111403111192
       Coding: 001E47225E00040100001402
       VCID: 41DC4F8CF1079BEF627-8014
    Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
       Coding: 03DA00102B230200
       Shop #: WSC 47824 001 1048576
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
       VCID: 34321658BEB53E47F91-8060
       Coding: E01800
       Coding: E01800
       Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 S002
       Coding: E01800
       Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 S002
       Coding: E01800
    Address 5F: Information Electr. (J794)       Labels: Redir Fail!
       Part No SW: 8S0 035 044     HW: 8S0 035 044
       Component: MU-H-LN-EU    H33 0117
       Serial number: A258K0E7503640
       Coding: 01330401FF00000011110001000800102F0000E100700000DE
       ASAM Dataset: EV_MUHig4CGen2HBAS 001115
       VCID: 6B80CD24A30BA1BFE8B-803E
       Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
       Component: ECE 2017  --- 0157
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8S0 919 614 A    HW: 8S0 919 614 A
       Component: ControlUnit_H  H21 0124
       Serial number: C1000015101400010237
       Component: Gracenote  --- 1010
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
       Part No SW: 8S0 980 653     HW: 5Q0 980 653
       Component: MQB_MFK       H06 0002
       Serial number: 10000156378
       Coding: 0100000001010305000501000000000100
       ROD: EV_MFKBoschAU370.rod
       Part No SW: 8S0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0002
       Serial number: 141015200336
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
    End-------------------------(Elapsed Time: 01:15)--------------------------
    Sep 2016
    Riga, Latvia
    Theoretically in MY2015 (and a lot earlier already) ABS is not anymore just a system detecting blocked wheel and releasing it, keeping on the edge of slipping to achieve maximum braking efficiency. It is complicate system for road safety helping driver to control his car in several situations. For correct work of this system ABS/ESP electronics should know all the mechanical parameters of brake system parts to divide brake force between wheels correctly. That's why coding should be changed when retrofitting mechanical parts with different parameters. ABS/ESP long coding has complicate calculation including a lot of parameters and a VIN code of vehicle. At this time how far I know, it is possible only with dealers ODIS online for this type of ABS/ESP control modules, but I'm not sure will it work with retrofitted different parts.
  3. Likes Uwe liked this post
    Feb 2017
    Italy
    Thanks for the answer.
    So you're telling me that recoding is a must in this case, since brakes diameter is greater, but you don't know if the dealer can do it too ..
    You're thinking also that stability of the vehicle is compromised ?
    Is it correct ?
