Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72 77
VIN: WAULF78K49N059494 Mileage: 154830km-96206miles
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Revision: E1H14---
Coding: 0104010A180F0160
VCID: 79ACE777495A543F6AD-802C
2856 - Oxygen (Lambda) Sensor; B1 S2
P1114 00 [096] - Internal Resistance too High
Mileage: 154643 km
Date: 2017.02.01
Time: 22:34:27
Engine speed: 2532.00 /min
Normed load value: 23.9 %
Vehicle speed: 85 km/h
Coolant temperature: 75 °C
Intake air temperature: 0 °C
Voltage terminal 30: 13.476 V
Unlearning counter according OBD: 33
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AF HW: 8K0 907 379 AF
Component: ESP8 quattro H04 0210
Coding: 070500
Shop #: WSC 02391 823 56573
VCID: 7DA4F3675DF2681F465-8028
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0145
Coding: 0B0100
Shop #: WSC 02399 823 56573
VCID: 3330155F2B366E6FE01-8066
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000002061010
Component: ELVAUDIB8 H36 0041
Serial number: 0208000112874007
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0150
Revision: A1000000 Serial number: 01230120091051
Coding: 64002000
VCID: 70BADA531AA01577DD3-8024
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000307278
Coding: 26001091063C00010000000300001D0D0F14120800000001000000
VCID: 303A1A53DA2055779D3-8064
Component: WWS 290109 H06 0070
Serial number: SWF09010296554
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 T HW: 8K0 941 531 T
Component: E1 - LDS H07 0080
Serial number: 00000000002201092008
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Serial number: 0039KD14T2B6
Shop #: WSC 02145 785 00200
VCID: 40DA4A936A00C5F76D3-8014
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0800001M51
Serial number: 6334MSME4441780CD
Serial number: 6344MSME43002F7BG
Serial number: 6352QSME36204034%
Serial number: 6362QSME681F0E28W
Serial number: 63732SME141F282C1
Serial number: 63832SME521F1932
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H15 0013
Revision: -------- Serial number: 90304IAR00081
Coding: 000014
VCID: 3D2433671D72A81F065-8068
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H18 0224
Revision: 00000000 Serial number: 9DR227P19
Coding: 8B1109000300D705020200
VCID: 2D040327CD12389FB65-8078
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G0912500F8
Coding: 000303
VCID: 4BC06DBF53C616AF881-801E
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 19061EDD140109
Fault Frequency: 8
Reset counter: 219
Mileage: 154620 km
Date: 2017.02.01
Time: 14:08:00
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Revision: 00000000
Coding: 020302
VCID: 78AAE27372D04D37153-802C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008386561
Coding: 011C03204000410001
VCID: 41DC4F97618ACCFF62D-8014
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0116892190
Coding: 0106023A007A004400B001
Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 15
Reset counter: 187
Mileage: 150950 km
Date: 2016.11.26
Time: 20:07:09
02615 - Fuel Tank Cap; Lock
Fault Frequency: 36
Reset counter: 188
Mileage: 151220 km
Date: 2016.11.29
Time: 15:00:57
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6E86C42B00940387CFF-803A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008422325
VCID: 40DA4A936A80C5F76D3-8014
Part No SW: 8K0 907 801 F HW: 8K0 907 801 F
Component: EPB Audi B8 H06 0070
Revision: 00000003 Serial number: 00000000300660
VCID: 323E105BD42C6767EB7-8066
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H01 0301
Revision: 00000003 Serial number: AUZ5Z6H1158299
Coding: 04020002010185004119070800
VCID: 46D65C8B48A4EBC757F-8012
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Reset counter: 19
Mileage: 145646 km
Date: 2016.09.13
Time: 09:34:53
Fault Frequency: 88
Reset counter: 227
Mileage: 145812 km
Date: 2016.09.15
Time: 13:51:48
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000100684548
Coding: 010C03204000210001
VCID: 44D246837E98D9D749B-8010
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 13140790039596
Coding: 0CD154
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100684545
Part No SW: 8T0 862 336 C HW: 8T0 862 336 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005031180
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3B203D7F0F66A62F381-806E
End----------(Elapsed Time: 01:26, VBatt start/end: 11.6V/11.5V)-----------
