Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 96
Thread: A8 [D3] & A6 [4F] Battery ECU compatability? ...
    Quote Originally Posted by JulianHicks View Post
    So instead of fixing the issues they turned off all the messages.
    Conceptually not that different than the temperature "gauge" that shows a rock-solid 90C anywhere between about 70C and 110C -- and VWAG has been doing that for decades.
  2. #12
    Jul 2015
    Kent, UK
    And there's a rumour going round that they may have tinkered with the emissions stuff as well!
  3. Likes NZDubNurd liked this post
  4. #13
    Since i mentioned the Beta in this thread, here goes:
    http://download.ross-tech.com/VCDS/d...p/VCDS-x86.zip
    http://download.ross-tech.com/VCDS/d...p/VCDS-x64.zip
    Put the .exe that matches your install in the 17.1 folder. Go to Applications->History Data:
    pick the address where your BDM/BEM resides (typically 61 in the older cars, 19 in the newer ones?):
    hit Start and if everything goes well, you should get something like this:
    ;Tuesday,14,February,2017,17:08:17:18206
    ;                Address 19: CAN Gateway
    ;Control Module Part Number: 8R0 907 468 P
    ;  Component and/or Version: GW-BEM 5CAN-M H11 0060
    ;           Software Coding: 80C303FF00
    ;            Work Shop Code: WSC 06325
    ;                      VCID: 4CC26E5D76CF66879CA-8018
    ;History Data
    Record 1/16: No-load voltage underranging
    2017-02-14-09:01*00.5*01*00872***
    2017-02-13-08:21*00.3*01**
    2017-02-09-20:12*02.5*01**
    2017-02-08-13:13*00.3*01**
    2017-02-07-09:08*01.2*01**
    2017-02-06-08:58*04.0*01**
    2017-02-04-18:04*01.3*01**
    2000-01-01-00:00*00.0*00*00000***
    2000-01-01-00:00*00.0*00**
    Record 2/16: No-load current overranging
    2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00*00000**
    2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
    Record 3/16: Shut-off stage history
    2015-09-28-16:54*4*0*070*072*-14.10*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-08-01-18:06*4*0*083*087*-22.32*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-07-14-17:45*4*0*080*084*-19.11*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-07-14-15:26*4*0*085*090*-33.40*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-07-14-01:43*4*0*087*092*-39.46*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-07-10-19:00*4*0*091*097*-20.73*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-07-10-18:44*4*0*088*092*-27.97*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-06-30-15:00*4*0*089*094*-47.67*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-06-29-20:54*4*0*089*093*-00.93*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-06-24-19:53*4*0*091*097*-50.53*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-06-10-14:33*4*0*092*094*-26.63*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-06-09-06:21*4*0*094*095*-14.02*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-06-08-08:52*4*0*092*092*-14.14*0-0-1-0-0-0*0*0*00.0*00.0**
    2015-06-08-07:52*4*0*095*096*-20.77*0-0-0-0-0-0*0*0*00.0*00.0**
    2015-06-02-21:31*4*0*089*094*-19.74*0-0-0-0-0-0*0*0*00.0*00.0**
    Record 4/16: Battery change history
    2015-05-29-05:00*01*8K0915105F *MLA*150515F9HO*10009*01798*0000*0000*0000**
    2000-01-01-00:00*00*-----------*XXX*----------*09999*00000*0000*0000*0000**
    2000-01-01-00:00*00*-----------*XXX*----------*00000*00000*0000*0000*0000**
    Record 5/16: Energy-critical vehicle states
    2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*
    000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
    Record 6/16: Energy balances (last 20 trips)
    2017-02-14-16:23*047*+07*+000.0*00.01**
    2017-02-14-14:13*053*+07*+000.6*00.17**
    2017-02-14-13:10*051*+07*+000.8*00.17**
    2017-02-14-08:50*055*+08*+000.7*00.11**
    2017-02-13-18:09*054*+07*+000.8*00.15**
    2017-02-13-13:52*051*+07*+000.5*00.10**
    2017-02-13-13:21*054*+07*+000.3*00.08**
    2017-02-13-13:12*054*+07*+000.2*00.05**
    2017-02-13-08:21*063*+09*+000.6*00.13**
    2017-02-12-16:46*067*+09*+000.2*00.08**
    2017-02-12-14:31*073*+10*+000.4*00.10**
    2017-02-12-14:02*072*+10*+001.1*00.41**
    2017-02-12-12:58*068*+10*+000.4*00.10**
    2017-02-11-16:53*084*+12*+002.1*00.69**
    2017-02-11-16:51*066*+11*+000.1*00.02**
    2017-02-11-12:49*067*+09*+000.5*00.12**
    2017-02-11-11:28*071*+08*+002.1*00.64**
    2017-02-11-10:08*059*+07*+000.9*00.20**
    2017-02-11-09:21*063*+07*+000.7*00.20**
    2017-02-10-18:08*068*+04*+000.4*00.18**
    Record 7/16: Energy balances (last 20 standing times)
    2017-02-14-14:24*039*-000.5*001.9*00.0*00.0**
    2017-02-14-13:20*049*-000.4*000.8*00.0*00.0**
    2017-02-14-08:57*047*-000.4*001.1*00.0*00.0**
    2017-02-13-18:18*054*-001.2*014.5*00.0*00.0**
    2017-02-13-13:59*054*-001.3*004.1*00.0*00.0**
    2017-02-13-13:26*051*-000.5*000.4*00.0*00.0**
    2017-02-13-13:15*054*-000.2*000.0*00.0*00.0**
    2017-02-13-08:29*053*-000.7*004.7*00.0*00.0**
    2017-02-12-16:52*057*-000.8*002.0*00.0*00.0**
    2017-02-12-14:38*058*-000.7*002.1*00.0*00.0**
    2017-02-12-14:26*072*-000.4*000.0*00.0*00.0**
    2017-02-12-13:04*057*-000.6*000.9*00.0*00.0**
    2017-02-11-17:35*067*-001.3*019.2*00.0*00.0**
    2017-02-11-12:57*064*-000.8*003.8*00.0*00.0**
    2017-02-11-12:07*064*-000.6*000.7*00.0*00.0**
    2017-02-11-10:20*056*-000.9*001.1*00.0*00.0**
    2017-02-11-09:33*058*-000.7*000.5*00.0*00.0**
    2017-02-10-18:19*062*-001.2*015.0*00.0*00.0**
    2017-02-10-15:04*056*-000.8*002.9*00.0*00.0**
    2017-02-10-13:53*056*+001.8*001.1*00.7*00.7**
    Record 8/16
    2017-02-14-16:26*1*99*00*00*02*01*2000-01-01-00:00*01**
    2017-02-10-13:58*1*99*00*00*02*01*2000-01-01-00:00*01**
    2017-01-19-09:08*1*99*00*00*02*01*2000-01-01-00:00*01**
    2017-01-17-12:16*1*99*00*00*02*01*2000-01-01-00:00*01**
    2017-01-17-10:00*1*99*00*00*02*01*2000-01-01-00:00*01**
    Record 9/16
    2015-05-29-06:25*100*100*092*091*00003*12.70*+24*01*12.70*00000*00000**
    2017-01-20-19:45*094*089*080*071*01695*12.50*+07*01*12.70*00000*00000**
    2016-12-22-18:03*097*089*079*071*01570*12.50*+08*01*12.70*00000*00000**
    2016-11-25-09:39*092*088*076*063*01485*12.50*+08*01*12.70*00000*00000**
    2016-10-27-09:09*091*091*092*082*01344*12.70*+09*01*12.70*00000*00000**
    2016-09-29-20:05*094*093*069*063*01215*12.40*+16*01*12.70*00000*00000**
    2016-08-31-19:05*097*098*089*088*01128*12.60*+29*01*12.70*00000*00000**
    2016-08-02-10:54*094*094*083*082*01093*12.60*+28*01*12.70*00000*00000**
    2016-07-05-10:29*094*096*081*080*00970*12.50*+24*01*12.70*00000*00000**
    2016-06-08-08:46*095*094*074*069*00823*12.40*+21*01*12.70*00000*00000**
    2016-05-10-08:45*087*091*084*074*00704*12.60*+17*01*12.70*00000*00000**
    2016-04-13-07:26*091*091*068*056*00578*12.40*+09*01*12.70*00000*00000**
    Record 10/16: Dynamic energy management
    2000-01-01-00:00*0*000.0*0*000.0*00.00**
    2000-01-01-00:00*0*0*0*00.00**
    2000-01-01-00:00*0*000.0*00.00**
    2017-02-12-14:16*99*15.00*14.81*013.9**
    2017-02-11-17:30*99*15.00*14.81*009.1**
    2017-02-11-11:48*99*15.00*14.88*007.4**
    2017-02-10-09:52*99*15.00*14.79*015.0**
    2017-02-09-12:49*99*15.00*14.86*004.6**
    Record 11/16
    2016-07-19-09:07*000*000*005*000*0045*006*00.2*00.4*090*094*091*093*01*00017*00037*00017*00042*00068**
    2016-07-18-17:51*000*002*006*000*0060*009*01.0*00.6*092*095*091*094*01**
    2016-07-11-15:13*000*000*001*000*0000*001*00.1*00.1*091*095*091*093*01**
    2016-06-28-13:13*000*002*006*000*0100*010*01.1*00.8*091*094*091*095*01**
    2016-06-18-18:49*000*000*002*000*0032*003*00.0*00.4*089*091*089*089*01**
    2016-06-18-17:59*000*000*011*015*0235*057*00.0*00.6*090*088*090*091*01**
    2016-06-15-09:45*000*000*001*000*0001*001*00.0*00.1*089*087*089*087*01**
    2016-06-15-09:32*000*000*000*000*0000*000*00.0*00.0*090*089*090*089*01**
    2016-06-15-09:25*000*000*003*001*0074*029*00.0*00.1*090*086*091*090*01**
    2016-06-13-17:17*000*000*001*020*0216*052*00.0*00.8*090*084*091*090*01**
    Record 12/16: Start-Stop
    2000-01-01-00:00*0-0-0-0-0-0-0-0**
    00000*00000*00000*00000*00000*00000*00000*00000**
    2017-02-14-16:23*1*064*039*+07*03*-030*-26.82*10.9*0**
    2017-02-14-14:13*1*065*049*+07*03*-030*+09.85*11.7*1**
    2017-02-14-13:10*1*064*047*+07*03*-030*+12.90*10.9*0**
    2017-02-14-08:50*1*070*054*+08*03*-030*-27.60*10.8*0**
    2017-02-13-18:09*1*070*054*+07*03*-030*-26.83*10.6*0**
    02006*00027*00000**
    Record 13/16: Sporadic alternator faults
    2000-01-01-00:00*0-0-0-0-0*000.0*00000**
    2000-01-01-00:00*0-0-0-0-0*000.0**
    Record 14/16: Small battery for hybrid vehicle
    2000-01-01-00:00*00*---*---*----------*00000*00000**
    2000-01-01-00:00*0*00*00*00*00*00**
    00000*00000*00000**
    2000-01-01-00:00*0*000*+00*00*00000*00000**
    00000*00000*00000**
    Record 15/16: Local activ.
    2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
    Record 16/16: Vehicle energy balance
    017362**
    00146*00734*01349*00017*00000**
    01986*00040*00025*00079**
    04704*02496*00037*00000**
    00136*01218*00361*00318**
    01273*00624*00136**
    03037*00191*00066*00076**
    01383*00002*00000**
    00000*00000*00000**
    00003*00000*00000**
    00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**
    for my 8K, or
    ;Tuesday,14,February,2017,16:17:23:18206
    ;                Address 61: Battery Regul.
    ;Control Module Part Number: 4F0 910 181 E
    ;  Component and/or Version: ENERGIEMANAGER  H12 0490
    ;           Software Coding:
    ;            Work Shop Code: WSC 12345
    ;                      VCID: 2310E5E1B7D189FF0D1-8076
    ;           Additional Info: 000915105DK von VA0  020627R0Z5
    ;           Additional Info: Geraet 12345
    ;History Data
    Record 1/18: No-load voltage underranging
    2017-02-06,21:00:00*0075*019**
    2017-02-05,11:00:00*0003*019**
    2017-02-01,22:00:00*0028*019**
    2017-01-29,13:00:00*0001*019*06465***
    2016-03-27,16:00:00*0045*019**
    2016-02-26,20:00:00*0040*019**
    2016-02-24,12:00:00*0001*019**
    2016-02-23,15:00:00*0015*019*00374***
    2000-01-01,00:00:00*0000*000**
    2000-01-01,00:00:00*0000*000*00000***
    Record 2/18: No-load current overranging
    2017-02-05,15:35:07*0000*01.81*019**
    2017-02-05,09:14:14*0000*01.79*019**
    2017-01-29,12:42:50*0000*01.31*019**
    2017-01-22,15:30:17*0000*01.85*019**
    2017-01-22,14:22:20*0000*01.85*019**
    2017-01-22,08:21:53*0000*01.90*019**
    2017-01-19,13:40:25*0001*00.04*019**
    2017-01-15,14:37:37*0000*01.83*019**
    2017-01-15,10:53:29*0002*00.06*019**
    2017-01-10,10:14:24*0001*00.04*019*00034***
    Record 3/18: Energy-critical vehicle states
    00.02*24.56*-20.33*09*07*+0758*-00031*055202*2016-04-14,20:36:33*0-0-1-1-0-0*01.6*01.6*001.6*00*01*02*019**
    Record 4/18: Shut-off stage history
    3*5*+07.00*03*2016-04-14,20:39:08*0-0-0-0-0-0*01.7**
    5*6*-22.00*20*2016-04-14,20:05:56*0-0-1-1-0-0*01.1**
    2*6*-24.75*20*2016-04-14,20:05:46*0-0-1-1-0-0*01.1**
    2*0*-06.33*45*2016-02-12,11:32:22*0-0-0-0-0-0*00.0**
    6*2*-00.10*46*2016-01-22,13:54:06*0-0-0-0-0-0*00.0**
    3*2*-07.22*46*2016-01-22,13:53:56*0-0-0-0-0-0*00.0**
    5*2*-07.22*46*2016-01-22,13:53:46*0-0-0-0-0-0*00.0**
    2*2*-06.97*46*2016-01-22,13:53:36*0-0-0-0-0-0*00.0**
    2*2*-12.80*46*2016-01-22,13:49:16*0-0-0-0-0-0*00.0**
    6*4*-00.06*16*2015-10-27,11:49:27*0-0-0-0-0-0*00.0**
    3*4*-06.11*16*2015-10-27,11:49:17*0-0-0-0-0-0*00.0**
    5*4*-06.14*16*2015-10-27,11:49:07*0-0-0-0-0-0*00.0**
    2*4*-06.81*16*2015-10-27,11:48:56*0-0-0-0-0-0*00.0**
    6*2*-04.60*36*2015-10-27,00:04:45*0-0-1-0-0-0*00.0**
    3*2*-11.23*36*2015-10-27,00:04:35*0-0-1-0-0-0*00.0**
    Record 5/18: Battery change history
    018*310314E04G*2007-02-04,00:00:00*+00000*+0000**
    017*020627R0Z5*2007-02-04,00:00:00*+00000*+0000**
    016*310314E04G*2007-02-04,00:00:00*+00000*+0000**
    Record 6/18: Energy balances (last 5 trips)
    +000.0*000.0**
    +000.5*000.3**
    +001.5*001.0**
    +000.1*000.0**
    +003.0*001.9**
    Record 7/18: Energy balances (last 5 standing times)
    -000.1*000.0**
    -000.3*000.1**
    -000.4*000.1**
    -000.4*000.1**
    -004.4*102.6**
    Record 8/18
    +006.1*019**
    Record 9/18
    0000.0*0000.0
    Record 10/18: Dynamic energy management
    00.0*00.0
    Record 11/18
    0000.00*0000.00*0000.00*0000.00
    Record 12/18: Start-Stop
    00.00*00.00*00.00*00.00
    Record 13/18: Sporadic alternator faults
    0000.0*0000.0
    Record 14/18: Small battery for hybrid vehicle
    00.0*00.0
    Record 15/18: Local activ.
    99*99*00*00*00
    Record 16/18: Vehicle energy balance
    00*00*00*00*00
    Record 18/18: Date reprogramming in instrument cluster
    15**
    2006-07-20,18:00:00*2005-11-18,12:00:00**
    2006-07-20,18:00:00*2006-07-20,11:00:00**
    2000-01-01,01:00:00*2006-07-09,00:00:00**
    for Katie's 4F.
    Seeing how differently the modules behave between the two cars, I wouldn't be shocked if it's not quite there yet on the A8 or earlier 8Ks.
    As far as interpreting the data, Niels is already working on a LCode-style app to do this, in the meantime those who send us data will get back a document on how to interpret it.
    This version will autosave a file like "Hist-19-8R0-907-468-P-20170214-1708.txt" in the logs folder, email us (support@ross-tech.com) that plus a Debug 1024 (put 1024 in Options->Debug Level before you use this new function) from whichever controller you picked (typically DEBUG19.DLM or DEBUG61.DLM from the Debug folder).
    I don't expect the user interface for this to be final since Uwe hasn't seen it so suggestions are welcome but don't be offended if they're ignored
  5. #14
    Jun 2014
    Newcastle, England
    :Bursts with excitement:
    It's 23:43 but I'm popping out to the car...
  6. Likes mattylondon, Eric liked this post
  7. #15
    Quote Originally Posted by Zenerdiode View Post
    You remind me of myself 16 years ago, braving the night and the cold to test Uwe's KWP-2000 code on the 2001 Octavia's ABS
    Beta updated to 17.2.0.2 (same download link) thanks to your early feedback:
    -Fixed hiccups with HEX-USB+CAN
    -Improved display of retrieval progress on Open Controller screen
    -Beta actually self-identifies as a Beta now
  8. Likes Uwe, jyoung8607, NEtech, Dana, PetrolDave liked this post
  9. #16
    Jun 2014
    Newcastle, England
    Quote Originally Posted by Eric View Post
    Howsabout a TabControl for each of the history items, then a ListBox for each line of the history, that then is parsed by a file that Niels produces?
  10. Likes NEtech, delboy, Uwe, PetrolDave liked this post
  11. #17
    Very nice.
    Right now it looks like this:
  12. Likes Eric, delboy, Dana, PetrolDave liked this post
  13. #18
    How do I like the above more than once?
  14. #19
    Jun 2015
    Did you make a Microsoft Access database to display the data like that?
    I'm talking about the screen from Zenerdiode
  15. #20
    Verified VCDS User GaryM's Avatar
    Nov 2014
    Oxford, UK
    Quote Originally Posted by delboy View Post
    It was created using Microsoft Visual Studio.
    As a (improved in my opinion) variation on Zenerdiode's screen layout I would recommend using a TreeView on the left with a node for each record for a better UIX instead of load of tabs which can be a pain to have to scroll through if there are more than a page widths worth of them.
    Just my 2 pence worth
  16. Likes delboy liked this post
