Page 10 of 10 FirstFirst ... 8910
Results 91 to 96 of 96
Thread: A8 [D3] & A6 [4F] Battery ECU compatability? ...
  1. #91
    Dec 2017
    Croatia
    It would probably be easier for others to if you would post the whole battery history log here to look at.
    Sorry, Uwe, forgot about this simple thing :-)
    Here is the log:
    ;Tuesday,26,December,2017,22:16:09:38456
    ;                Address 61: Battery Regul.
    ;Control Module Part Number: 4F0 910 181 F
    ;  Component and/or Version: J0644 BEM       H12 0760
    ;           Software Coding:
    ;            Work Shop Code: WSC 02335
    ;                      VCID: 2412E5E302D29CA71E9-8070
    ;           Additional Info: FF0915105D  von VA0  2706011736
    ;           Additional Info: Geraet 00000
    ;History Data
    Record 1/18: No-load voltage underranging
    2017-12-26,20:00:00*0001*002**
    2017-12-26,05:00:00*0004*002**
    2017-12-25,20:00:00*0007*002**
    2017-12-25,15:00:00*0002*002*96628***
    2017-12-25,15:00:00*0002*002**
    2017-12-23,04:00:00*0002*002**
    2017-12-19,01:00:00*0013*002**
    2017-12-18,03:00:00*0005*002*75602***
    2017-08-12,09:00:00*0046*002**
    2000-01-01,00:00:00*0000*000**
    2000-01-01,00:00:00*0000*000*00046***
    Record 2/18: No-load current overranging
    2017-12-26,10:54:04*0000*03.80*002**
    2017-12-26,04:06:55*0000*00.21*002**
    2017-12-25,17:23:29*0000*03.95*002**
    2017-12-24,09:54:54*0000*01.35*002**
    2017-12-23,03:18:27*0000*00.21*002**
    2017-12-22,17:46:38*0000*01.48*002**
    2017-12-22,13:50:05*0000*01.34*002**
    2017-12-22,02:30:38*0000*00.21*002**
    2017-12-20,18:46:26*0000*02.10*002**
    2017-12-20,08:45:51*0000*01.88*002*00184***
    Record 3/18: Energy-critical vehicle states
    00.00*19.10*-08.53*19*06*+9999*-00025*180398*2007-03-04,14:35:15*0-0-0-0-0-0*00.0*00.0*000.0*00*03*18*002**
    Record 4/18: Shut-off stage history
    1*2*-99.99*45*2017-12-25,17:38:18*0-0-0-0-0-0*00.0**
    2*0*-00.03*45*2017-12-25,13:59:40*0-0-0-0-0-0*00.0**
    1*2*-05.22*45*2017-12-25,12:57:58*0-0-0-0-0-0*00.0**
    1*2*-10.55*45*2017-12-25,12:54:45*0-0-0-0-0-0*00.0**
    6*2*-04.93*48*2017-12-20,11:25:54*0-0-1-0-0-0*00.0**
    3*2*-09.25*48*2017-12-20,11:25:44*0-0-1-0-0-0*00.0**
    5*2*-09.26*48*2017-12-20,11:25:34*0-0-1-0-0-0*00.0**
    2*2*-09.92*48*2017-12-20,11:25:24*0-0-1-0-0-0*00.0**
    1*2*-13.94*49*2017-12-20,11:22:14*0-0-1-0-0-0*00.0**
    6*2*-05.04*50*2017-12-20,10:56:21*0-0-1-0-0-0*00.0**
    3*2*-09.27*50*2017-12-20,10:56:11*0-0-1-0-0-0*00.0**
    5*2*-09.30*50*2017-12-20,10:56:02*0-0-1-0-0-0*00.0**
    2*2*-09.78*50*2017-12-20,10:55:51*0-0-1-0-0-0*00.0**
    1*2*-15.09*52*2017-12-20,10:49:25*0-0-1-0-0-0*00.0**
    6*2*-04.26*44*2017-12-06,13:58:12*0-0-1-0-0-0*00.0**
    Record 5/18: Battery change history
    001*2706011736*2007-06-04,00:00:00*+00005*-0041**
    000*2706011736*2000-01-01,00:00:00*+00000*+0000**
    000*----------*2000-01-01,00:00:00*+00000*+0000**
    Record 6/18: Energy balances (last 5 trips)
    +001.3*000.2**
    +003.4*000.9**
    +000.4*000.0**
    +000.6*000.1**
    +005.1*001.0**
    Record 7/18: Energy balances (last 5 standing times)
    -001.4*000.3**
    -001.3*003.6**
    -000.4*000.1**
    -000.7*000.1**
    -001.0*015.6**
    Record 8/18: Battery manipulation (e.g. charging)
    +002.4*002**
    Record 9/18: Battery aging
    0000.0*0000.0
    Record 10/18: Dynamic energy management
    00.0*00.0
    Record 11/18: Recuperation
    0000.00*0000.00*0000.00*0000.00
    Record 12/18: Start-Stop
    00.00*00.00*00.00*00.00
    Record 13/18: Sporadic alternator faults
    0000.0*0000.0
    Record 14/18: Small battery for hybrid vehicle
    00.0*00.0
    Record 15/18: Local activ.
    99*99*99*00*99
    Record 16/18: Vehicle energy balance
    00*00*00*00*00
    Record 18/18: Date reprogramming in instrument cluster
    15**
    2007-09-17,07:00:00*2006-09-17,08:00:00**
    2017-09-14,07:00:00*2007-09-14,08:00:00**
    2007-09-13,07:00:00*2017-09-13,08:00:00**
    2007-03-22,05:00:00*2007-06-04,13:00:00**
    2000-01-01,00:00:00*2007-03-02,12:00:00**
  2. Likes Uwe liked this post
  3. #92
    Dec 2017
    Croatia
    Is it possible to to tell if this is first or second battery inside the car?
  4. #93
    Maybe the Battery is changed (with new or used) after the car was produced in 2007.
    But if so, it was not coded for battery change!
    Look at the Battery, are there any date codes ?
    Else it would be more than 10 years old!
    From all History files I have, you have the record, in hours below 12.5, 12.2, 11.5 Volt
    It is normal to show Battery sequential number #2 for record 1, 2.., even if it show #1 in Record 5.
    I don't know why.
  6. #94
    Dec 2017
    Croatia
    I don't know why.
    Thank you - that was the answer I was looking for. There are no date codes on batrery (or I can't recognize one) and it is original OEM battery (no reason not to be coded - if change done at dealership) - so it is most probably more then 10 yerars old... Low voltages are from playing with VCDS, aside from that battery does well, car starts with no problem, MMI indicator is on 100%, but it feels like it has not much capacity left, because it drains pretty fast (about 1 hour with ignition ON and indicator tells 50%, and quiescent stages DTC's are written)
    So, it is probably time for new battery...
  7. #95
    Dec 2017
    Croatia
    Something is wrong with this record... More hours (little bit more than 11 years) then the hours passed since the car has been produced (10,5 years)...
    Look at the #8 data. Is from 2017-12-18 and has 75602 "hours" below marked Volts... The difference is around 21000 hours in 7 days... So it must be in seconds....
  8. #96
    I don't think so, it is 5 hours for that date.
    The 75602 is the total hours from new battery.
  9. Likes Uwe, Jack@European_Parts liked this post
