I think that I've managed to get past the ROD file update loop (downloading and updating ROD file - rinse and repeat).
Used the standalone config jar, to try the update a few times, and then VCDS Mobile.
But now when attempting and completing a scan (via VCDS Mobile), I get the ASAM update required.
I updated, it seems to download and extract the files.. but per the ROD file update, just keeps telling me that an ASAM update is required.
Log includes:
No ASAM data for: "EV_ACCBOSCHVW416" (AU37)
No ASAM data for: "EV_GatewNF" (AU37)
S3 8V MY17 - Is this problem just due to the support for this car being a work in progress?
Many thanks.
Log includes:
Many thanks.
Tuesday,07,February,2017,09:19:52:44359
VCDS Version: 17.1.2.0 (x64) HEX-NET CB: 0.4334.4
Data version: 20170131 DS267.1
Dealer/Shop Name: JMMI
VIN: WAUZZZ8V2H1038043 License Plate: SEC73Y
Mileage: 1066km-662mi Repair Order:
Chassis Type: 8V (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
55 5F 6C A5 A9 BB BC CF
VIN: WAUZZZ8V2H1038043 Mileage: 1066km-662miles
Address 01: Engine (J623-DJHB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A2500322466010B3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259J 001004
ROD: EV_ECM20TFS0208V0906259E.rod
VCID: 47DEBAFBFE00B37962-8012
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0GC 300 011 HW: 0DE 927 711 C
Component: GSG DQ381 H12 0403
Revision: 00H12V32
ROD: EV_TCMDQ381061_VW37.rod
VCID: 5F8E429B4690DBB9BA-800A
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 62536000000082
Coding: 319C938D549C1BB18B910B684194698CC92AD8D1D0829677184150B482A812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 393ACC03B8F4D589E4-806C
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0420810731
Coding: 030C0C
VCID: 3B36D60BB2C8E799F6-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001073284
Coding: 03100014110000011000000000001500
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
VCID: 40CCA1E7DB2E8441A3-8014
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: 2AD8845800PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001629300258
ROD: EV_BCMBOSCH_017.rod
VCID: 7EB01F1FE15A32B191-802A
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160710 043 0585
Serial number: 160722021752
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62377733
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 06 08 2016 00001312
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1624911C4
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000036721081
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST0018UR9300000
Coding: 901E00
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 B HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0038
Serial number: 000308417616286
Coding: 0370167051
ASAM Dataset: EV_EPHVA2CAU3700000 009032
ROD: EV_EPHVA2CAU3700000_009.rod
VCID: 4FEE92DB16706B392A-801A
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 3500E7C319FFC42474988055000026
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: N/A
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 180716006
ROD: EV_AudiMagneRide_002_AU37.rod
VCID: 43C6AEEBCA389F59BE-8016
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR296E7O
Coding: 98CCC000000000005C54000000C800000065
VCID: 106C51A7CBCE34C173-8044
Subsystem 1 - Part No SW: ----------- HW: 480 002 810 16
Serial number: 3570000000029355DE1O
Subsystem 2 - Part No SW: ----------- HW: 480 002 810 16
Serial number: 358000000006A355DE1U
Subsystem 3 - Part No SW: ----------- HW: 480 402 110 16
Serial number: 3510001C922E94D3B65E
Subsystem 4 - Part No SW: ----------- HW: 480 402 110 16
Serial number: 3520001B9229A9E1A608
Subsystem 5 - Part No SW: ----------- HW: 480 401 810 16
Serial number: 35500029F22E8E135125
Part No SW: 8V0 953 521 KT HW: 5Q0 953 549 E
Revision: -------- Serial number: 23101604400872
Coding: E818
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 166027BFE92ADAF129-8042
Part No SW: 8V0 920 790 HW: 8V0 920 790
Component: FBenRDW H13 0045
Coding: 248D18527F9800080181E8001000000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001023
ROD: EV_DashBoardFPKAU37X.rod
VCID: 79BA0C03F8741589A4-802C
Component: GW MQB High 515 5286
Serial number: 24101610521248
Coding: 030100043F085A005B008278BC0B00000001010000000000000000000000
ROD: N/A
VCID: 2F2EF25B76B00B394A-807A
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20161019085549 20575
Serial number: 75410803001610255759
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7755
Serial number: HA1-00005.10.16
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_SK12.rod
VCID: 45C2B0F3C40CA16990-8010
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000178187010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 3424FD379F9628E137-8060
Address 3C: Lane Change (J769) Labels: None
Part No SW: 3Q0 907 566 D HW: 3Q0 907 566
Component: MRR1Rear H16 0410
Revision: --------
Coding: 44C002
Component: TSG FS 020 0041
Serial number: 081016EJ800401
Coding: 005D1A205C01040000001003
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A38D30FBDF2DE91ED-806E
Part No SW: 81A 035 466 A HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0420
Revision: 00000001 Serial number: AUZ8ZAGHX00AQT1
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C8Gen2ALPI.rod
VCID: 23060E6B2A78BF59DE-8076
Component: TSG BFS 020 0041
Serial number: 071016EJ71174A
Coding: 005D12205E01040000001003
VCID: 42C8ABEFD5229651B5-8016
Address 55: Headlight Range (J745) Labels: None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Coding: 0EE602202B100200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E30DF1FA1DAF2B1D1-806A
Part No SW: 8V1 035 041 A HW: 8V1 035 041
Component: MU-P-LND-RW 053 0875
Serial number: A838J0GB003878
Coding: 017351080000000011511102000A00102F0027E6017001045E
VCID: 2D12E8537CBC792978-8078
Subsystem 1 - Part No SW: V03 959 801 FQ HW: -----------
Component: ROW 2017 --- 0062
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY2087GM
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL114101600010261
Component: Gracenote2 --- 4011
Address 6C: Back-up Cam. (J772) Labels: 5Q0-980-556.clb
Component: RVC Compact H12 0231
Coding: 0273010102002001400040
ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 06101612K20273
Coding: 040307010000010101022346C048A90080000E200080
ROD: EV_MFKBoschMQBB.rod
Part No SW: 8V0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160924200755
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 041016EJ31185A
Coding: 000C12204001040000001002
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 041016EJ311913
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 3Q0 907 590 D HW: 3Q0 907 590
Revision: --------
Coding: 44C002
VCID: 3620C73F89EA3AF109-8062
End----------(Elapsed Time: 01:49, VBatt start/end: 13.7V/13.7V)-----------
