Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Lost oil pressure
    Nov 2014
    New Zealand
    You could try it!
    It's not something I would expect, there still has to be a wide open leak path somewhere, assuming the oil pump is capable of creating real pressure.
  2. #12
    New User
    Feb 2017
    Is there some where in the head that could of failed?
  3. #13
    New User
    Feb 2017
    Still nothing, ready to pull motor out!
  4. #14
    Nov 2014
    New Zealand
    These things are very hard to diagnose remotely - there may be some subtle thing you don't see right now, or there could be a major internal fault, or mis-assembly.
    The ONLY time I've seen 0 oil pressure on a properly running/assembled engine, is on a gravity feed system, like our '29 Ford Model A - it has a pump that pumps oil from the sump, up to a trough that feeds the bearings by gravity. With 15W-40, you can have 0 oil pressure when warm, because there is NO restriction, really. Simply adding the restriction of an oil filter gives it a very low pressure reading (2 to 5 PSI) - Your Golf would need no restriction to flow, to get a ZERO reading, or the pump has to stop pumping (mechanically stopped, or sucking air from a damaged pickup etc).
    We're really going to struggle with helping remotely
  5. Likes Uwe liked this post
  6. #15
    New User
    Feb 2017
    Found the problem. One of the balancer shafts broke and it took out a couple o rings on it.
  7. Likes Uwe, NZDubNurd liked this post
  8. #16
    New User
    Feb 2017
    Put in two new balancer shafts. Got good pressure now..
  9. #17
    New User
    Jan 2020
    Czech Republic
    Within a month, the engine has been running a 1.4 TSi 90kw CAXA engine.
    Cold oil pressure 1bar at idle, 2-3 bar at 2000 / rev.
    After 20-30min, idle 0.2-0.4 bar, at 2000 rpm 1.5 bar.
    Cams with head cover checked, second oil pump, intake manifold replaced,
    Ol.filter exchanged - origo according to VIN, turbo mesh, wiring including adjusters also second.
    Both engines are all checked equally and the result is the same.
    Any idea where to look? Has anyone met anything like this?
    Thanks for the advice
  10. #18
    Oct 2018
    why do people HIJACK these posts ??????????
  11. #19
    Quote Originally Posted by maxx16v View Post
    Laziness - instead of creating their own thread?
  12. Likes Jack@European_Parts liked this post
