Audi A5 Coupe RoW Tail LED retrofit failure
jonixins
Latvia
C?ID=151647
Hello.
Please help me!
I have problem with Audi A5 Coupe 2009. RoW/ DE
After a crash a car garage wanted to retrofit LED tail lights, used adapters and adatations similar to this:
https://dl.dropboxusercontent.com/u/106316530/Rückleuchten Halogen -zu- VFL LED.pdf
But they did fail somewhere and all adaptations were set to something like failsafe and tail lights stopped working at all.
I managed to get them working, but have 3 major issues:
1) When turn indicators are used, in cluster it blinks 2x faster than normal. Lamps outside blinks normal speed.
2) Control module gives fault, it cannot be cleared:
                Address 46: Central Conv.       Labels: 8K0-907-064-46.CLB
Control Module Part Number: 8K0 907 064 C    HW: 8K0 907 064 C
  Component and/or Version: BCM2 1.1      H80 0145
           Software Coding: 0100068000390400012000
            Work Shop Code: WSC 06325 000 00000
                      VCID: 30653E0763A122C153-8064
1 Faults Found:
03389 - Data Set Implausible
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.06.01
                    Time: 02:42:43
3)
If in adaptation chanel 181 I use 64608 as manual suggests or 65535 instruments gives faults about brake and turn signals. At the same time control unit gives faults only about brake lights.
If I use 0 in adaptation chanel 181, no faults in display or control unit except 03389 as check is disabled.
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.06.01
                    Time: 02:42:43
03554 - Left Brake Light Lamp 3
            012 - Electrical Fault in Circuit - MIL ON
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.06.01
                    Time: 02:42:43
03533 - Right Brake / Signal Light Lamp 2
                    Fault Status: 11101100
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.06.01
                    Time: 02:43:49
Autoscan:
VIN: WAUZZZ8T19A028300   License Plate:
Chassis Type: 8T (8T0)
Scan: 01 02 03 05 06 08 09 0E 10 14 15 16 17 18 19 1B 36 42 46 52
          53 55 56 5F
VIN: WAUZZZ8T19A028300   Mileage: 175140km-108826miles
Address 01: Engine (J623-CCWA)       Labels: 059-907-401-V1.clb
   Part No SW: 8K2 907 401     HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H01 0006
   Revision: 15H01---
   Coding: 0114002C191F0120
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TDI0118K2907401 001006
   ROD: EV_ECM30TDI0118K2907401.rod
   VCID: 6AD1EC6F8DFD98115D-803E
Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
   Part No SW: 8K0 927 158 A    HW: 0B6 927 156
   Component: 0B6 30 TDIRdW H04 0050
   Revision: --H04---
   Coding: 001001
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 346D32179FB91EE137-8060
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AH    HW: 8K0 907 379 AH
   Component: ESP8 quattro  H04 0230
   Coding: 142D00
   VCID: 7F072D3BEE7F0DB99A-802A
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H80 0145
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0508000062591019
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000076912011
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
   Component: MEM-BFS       H09 0043
   Revision: AA000000    Serial number: 00001001174044
   Coding: 08017025002400001000
   VCID: 428164CFDD0DA051B5-8016
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01221020081344
   Coding: 361A0000
   VCID: 72E1F40FAD2D50D1E5-8026
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000255694
   Coding: 260050914034AF311F09000300005D5D4F9CC3C800010141000000
   Shop #: WSC 06325 123 12345
   Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 231008  H13 0040
   Serial number: SWF08100230486
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10298549
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001810080614
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H47 0050
   Revision: 00000011
   VCID: 2143CB43384B9B49CC-8074
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52840829103200
   Coding: 100101
   VCID: 3B7F192BBAE7D199F6-806E
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364     HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0052
   Revision: 00000000    Serial number: 08100807120002
   Coding: 050181
   Shop #: WSC 26875 136 95249
   VCID: 70E5FE07A32162C113-8024
00775 - Level Control System Sensor; Rear Right (G77)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.05.29
                    Time: 08:37:49
03262 - Comfort Restriction
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.05.29
                    Time: 08:37:49
                    Error Code: 2
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1C0SLJ
   Coding: 30313433363030303030554A304C38543053
   VCID: 3C7D1A37B7E9D6A1FF-8068
   Serial number: 6334MSME4164186BE
   Serial number: 6344MSME42420C49B
   Serial number: 6352QSME0B112E04A
   Serial number: 6362QSME7C092C18T
   Serial number: 63732SME33111820I
   Serial number: 63832SME4B121420P
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90319HJ8000DA
   Coding: 000036
   VCID: 3E79103FA9F5C4B1D1-806A
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 931 A    HW: 8T0 920 931 A
   Component: KOMBIINSTR.   H31 0224
   Revision: 00100000    Serial number: 9D552NVA8
   Coding: 0F07010033000008000000
   VCID: 356B0F139CC307E900-8060
Address 18: Aux. Heat (J364)       Labels: None
   Part No SW: 8K0 265 105 A    HW: 8K0 265 105 A
   Component: Standheizung  H07 0040
   Revision: 11001001    Serial number: 20081006084236
   Coding: 550000
   VCID: 2757D55B566F657982-8072
   Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0095
   Revision: EB500046    Serial number: 4600E08A1584CA
   Coding: 000303
   VCID: 4E9940FF1955543121-801A
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1804E3E9021008
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.05.29
                    Time: 08:37:00
01304 - Radio
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.05.29
                    Time: 08:38:49
   Part No SW: 8K0 907 144 C    HW: 8K0 907 144 C
   Component: DYNAMIKLENK.  H06 0500
   Revision: 50001003    Serial number: --------------
   Coding: 040000
   Shop #: WSC 06324 000 00000
   VCID: 2F673D7B7E9F3D394A-807A
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H09 0043
   Revision: AA000000    Serial number: 00001001174317
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1301
   Coding: 011C02224000120102
   Shop #: WSC 29644 000 1048576
   VCID: 50A55E87036142C133-8004
   Revision: 00002001    Serial number: 0115401055
                    Reset counter: 252
                    Mileage: 175146 km
                    Date: 2008.05.29
                    Time: 08:37:49
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000007893736
   VCID: 40856EC7D301B241A3-8014
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000248866
   VCID: 31633B0368AB2BC95C-8064
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000003
   VCID: 346D321757B91EE137-8060
Address 56: Radio
End-------------------------(Elapsed Time: 03:06)--------------------------
Adaptations MAP
. Most of adaptations 181-208 are copy form similar car, so something at least started working.
chanels 199-202 cannot be changed. For any different value it gives ERROR.
;SW:8K0-907-064-C   HW:8K0-907-064-C ---  Central Conv.
;Component:BCM2 1.1      H80 0145	 Coding:0100068000390400012000
;Saturday	4	February	2017	15:17:06:33393
;VCDS Version: Release 17.1.2 (x64)  Data version: 20170107 DS267.0
;VCID: 30653E0763A122C153-8064
Channel		Field 1	Field 2	Field 3	Field 4
1	35264	N/A	N/A	N/A	N/A
2	35264	N/A	N/A	N/A	N/A
3	32864	N/A	N/A	N/A	N/A
4	32864	N/A	N/A	N/A	N/A
5	0	N/A	N/A	N/A	N/A
6	0	N/A	N/A	N/A	N/A
7	0	N/A	N/A	N/A	N/A
8	0	N/A	N/A	N/A	N/A
9	36832	N/A	N/A	N/A	N/A
10	0	N/A	N/A	N/A	N/A
11		ERROR:	Channel 11	Not	Available
12		ERROR:	Channel 12	Not	Available
13	87	N/A	N/A	N/A	N/A
14		ERROR:	Channel 14	Not	Available
15		ERROR:	Channel 15	Not	Available
16		ERROR:	Channel 16	Not	Available
17		ERROR:	Channel 17	Not	Available
18		ERROR:	Channel 18	Not	Available
19		ERROR:	Channel 19	Not	Available
20		ERROR:	Channel 20	Not	Available
21		ERROR:	Channel 21	Not	Available
22		ERROR:	Channel 22	Not	Available
23		ERROR:	Channel 23	Not	Available
24		ERROR:	Channel 24	Not	Available
25		ERROR:	Channel 25	Not	Available
26		ERROR:	Channel 26	Not	Available
27		ERROR:	Channel 27	Not	Available
28		ERROR:	Channel 28	Not	Available
29		ERROR:	Channel 29	Not	Available
30		ERROR:	Channel 30	Not	Available
31		ERROR:	Channel 31	Not	Available
32		ERROR:	Channel 32	Not	Available
33		ERROR:	Channel 33	Not	Available
34		ERROR:	Channel 34	Not	Available
35		ERROR:	Channel 35	Not	Available
36		ERROR:	Channel 36	Not	Available
37		ERROR:	Channel 37	Not	Available
38		ERROR:	Channel 38	Not	Available
39		ERROR:	Channel 39	Not	Available
40		ERROR:	Channel 40	Not	Available
41		ERROR:	Channel 41	Not	Available
42		ERROR:	Channel 42	Not	Available
43		ERROR:	Channel 43	Not	Available
44		ERROR:	Channel 44	Not	Available
45		ERROR:	Channel 45	Not	Available
46		ERROR:	Channel 46	Not	Available
47		ERROR:	Channel 47	Not	Available
48		ERROR:	Channel 48	Not	Available
49		ERROR:	Channel 49	Not	Available
50		ERROR:	Channel 50	Not	Available
51		ERROR:	Channel 51	Not	Available
52		ERROR:	Channel 52	Not	Available
53		ERROR:	Channel 53	Not	Available
54		ERROR:	Channel 54	Not	Available
55		ERROR:	Channel 55	Not	Available
56		ERROR:	Channel 56	Not	Available
57		ERROR:	Channel 57	Not	Available
58		ERROR:	Channel 58	Not	Available
59		ERROR:	Channel 59	Not	Available
60	15	N/A	N/A	N/A	N/A
61	9947	N/A	N/A	N/A	N/A
62	48059	N/A	N/A	N/A	N/A
63	40	N/A	N/A	N/A	N/A
64	40	N/A	N/A	N/A	N/A
65		ERROR:	Channel 65	Not	Available
66		ERROR:	Channel 66	Not	Available
67		ERROR:	Channel 67	Not	Available
68		ERROR:	Security	access	required
69	0	N/A	N/A	N/A	N/A
70		ERROR:	Channel 70	Not	Available
71		ERROR:	Channel 71	Not	Available
72		ERROR:	Channel 72	Not	Available
73		ERROR:	Channel 73	Not	Available
74		ERROR:	Channel 74	Not	Available
75		ERROR:	Channel 75	Not	Available
76		ERROR:	Channel 76	Not	Available
77		ERROR:	Channel 77	Not	Available
78		ERROR:	Channel 78	Not	Available
79		ERROR:	Channel 79	Not	Available
80		ERROR:	Channel 80	Not	Available
81		ERROR:	Channel 81	Not	Available
82		ERROR:	Channel 82	Not	Available
83		ERROR:	Channel 83	Not	Available
84		ERROR:	Channel 84	Not	Available
85		ERROR:	Channel 85	Not	Available
86		ERROR:	Channel 86	Not	Available
87		ERROR:	Channel 87	Not	Available
88		ERROR:	Channel 88	Not	Available
89		ERROR:	Channel 89	Not	Available
90		ERROR:	Channel 90	Not	Available
91		ERROR:	Channel 91	Not	Available
92		ERROR:	Channel 92	Not	Available
93		ERROR:	Channel 93	Not	Available
94		ERROR:	Channel 94	Not	Available
95		ERROR:	Channel 95	Not	Available
96		ERROR:	Channel 96	Not	Available
97		ERROR:	Channel 97	Not	Available
98		ERROR:	Channel 98	Not	Available
99		ERROR:	Channel 99	Not	Available
100		ERROR:	Channel 100	Not	Available
101		ERROR:	Channel 101	Not	Available
102		ERROR:	Security	access	required
103		ERROR:	Channel 103	Not	Available
104		ERROR:	Channel 104	Not	Available
105		ERROR:	Channel 105	Not	Available
106		ERROR:	Channel 106	Not	Available
107		ERROR:	Channel 107	Not	Available
108		ERROR:	Channel 108	Not	Available
109		ERROR:	Channel 109	Not	Available
110		ERROR:	Channel 110	Not	Available
111		ERROR:	Channel 111	Not	Available
112		ERROR:	Channel 112	Not	Available
113		ERROR:	Channel 113	Not	Available
114		ERROR:	Channel 114	Not	Available
115		ERROR:	Channel 115	Not	Available
116		ERROR:	Channel 116	Not	Available
117		ERROR:	Channel 117	Not	Available
118		ERROR:	Channel 118	Not	Available
119		ERROR:	Channel 119	Not	Available
120		ERROR:	Channel 120	Not	Available
121		ERROR:	Channel 121	Not	Available
122		ERROR:	Channel 122	Not	Available
123		ERROR:	Channel 123	Not	Available
124		ERROR:	Channel 124	Not	Available
125		ERROR:	Channel 125	Not	Available
126		ERROR:	Channel 126	Not	Available
127		ERROR:	Channel 127	Not	Available
128		ERROR:	Channel 128	Not	Available
129		ERROR:	Channel 129	Not	Available
130		ERROR:	Channel 130	Not	Available
131		ERROR:	Channel 131	Not	Available
132		ERROR:	Channel 132	Not	Available
133		ERROR:	Channel 133	Not	Available
134		ERROR:	Channel 134	Not	Available
135		ERROR:	Channel 135	Not	Available
136		ERROR:	Channel 136	Not	Available
137		ERROR:	Channel 137	Not	Available
138		ERROR:	Channel 138	Not	Available
139		ERROR:	Channel 139	Not	Available
140		ERROR:	Channel 140	Not	Available
141		ERROR:	Channel 141	Not	Available
142		ERROR:	Channel 142	Not	Available
143		ERROR:	Channel 143	Not	Available
144		ERROR:	Channel 144	Not	Available
145		ERROR:	Channel 145	Not	Available
146		ERROR:	Channel 146	Not	Available
147		ERROR:	Channel 147	Not	Available
148		ERROR:	Channel 148	Not	Available
149		ERROR:	Channel 149	Not	Available
150		ERROR:	Channel 150	Not	Available
151		ERROR:	Channel 151	Not	Available
152		ERROR:	Channel 152	Not	Available
153		ERROR:	Channel 153	Not	Available
154		ERROR:	Channel 154	Not	Available
155		ERROR:	Channel 155	Not	Available
156		ERROR:	Channel 156	Not	Available
157		ERROR:	Channel 157	Not	Available
158		ERROR:	Channel 158	Not	Available
159		ERROR:	Channel 159	Not	Available
160		ERROR:	Channel 160	Not	Available
161		ERROR:	Channel 161	Not	Available
162		ERROR:	Channel 162	Not	Available
163		ERROR:	Channel 163	Not	Available
164		ERROR:	Channel 164	Not	Available
165		ERROR:	Channel 165	Not	Available
166		ERROR:	Channel 166	Not	Available
167		ERROR:	Channel 167	Not	Available
168		ERROR:	Channel 168	Not	Available
169		ERROR:	Channel 169	Not	Available
170		ERROR:	Channel 170	Not	Available
171		ERROR:	Channel 171	Not	Available
172		ERROR:	Channel 172	Not	Available
173		ERROR:	Channel 173	Not	Available
174		ERROR:	Channel 174	Not	Available
175		ERROR:	Channel 175	Not	Available
176		ERROR:	Channel 176	Not	Available
177		ERROR:	Channel 177	Not	Available
178		ERROR:	Channel 178	Not	Available
179		ERROR:	Channel 179	Not	Available
180		ERROR:	Channel 180	Not	Available
181	0	N/A	N/A	N/A	N/A
182	255	N/A	N/A	N/A	N/A
183	16383	N/A	N/A	N/A	N/A
184	255	N/A	N/A	N/A	N/A
185	65535	N/A	N/A	N/A	N/A
186	255	N/A	N/A	N/A	N/A
187	16383	N/A	N/A	N/A	N/A
188	1	N/A	N/A	N/A	N/A
189	16380	N/A	N/A	N/A	N/A
190	1021	N/A	N/A	N/A	N/A
191	16383	N/A	N/A	N/A	N/A
192	3	N/A	N/A	N/A	N/A
193	6	N/A	N/A	N/A	N/A
194	7	N/A	N/A	N/A	N/A
195	5125	N/A	N/A	N/A	N/A
196	5157	N/A	N/A	N/A	N/A
197	5124	N/A	N/A	N/A	N/A
198	5156	N/A	N/A	N/A	N/A
199	10248	N/A	N/A	N/A	N/A
200	10280	N/A	N/A	N/A	N/A
201	10248	N/A	N/A	N/A	N/A
202	10280	N/A	N/A	N/A	N/A
203	73	N/A	N/A	N/A	N/A
204	105	N/A	N/A	N/A	N/A
205	13	N/A	N/A	N/A	N/A
206	45	N/A	N/A	N/A	N/A
207	12	N/A	N/A	N/A	N/A
208	44	N/A	N/A	N/A	N/A
209	0	N/A	N/A	N/A	N/A
210	0	N/A	N/A	N/A	N/A
211	51214	N/A	N/A	N/A	N/A
212	15	N/A	N/A	N/A	N/A
213	12336	N/A	N/A	N/A	N/A
214	1	N/A	N/A	N/A	N/A
215		ERROR:	Channel 215	Not	Available
216		ERROR:	Channel 216	Not	Available
217		ERROR:	Channel 217	Not	Available
218		ERROR:	Channel 218	Not	Available
219		ERROR:	Channel 219	Not	Available
220		ERROR:	Channel 220	Not	Available
221	51400	N/A	N/A	N/A	N/A
222	51400	N/A	N/A	N/A	N/A
223	51400	N/A	N/A	N/A	N/A
224	51400	N/A	N/A	N/A	N/A
225	51400	N/A	N/A	N/A	N/A
226	51400	N/A	N/A	N/A	N/A
227	51400	N/A	N/A	N/A	N/A
228	51400	N/A	N/A	N/A	N/A
229	51400	N/A	N/A	N/A	N/A
230	2771	N/A	N/A	N/A	N/A
231	2772	N/A	N/A	N/A	N/A
232	2901	N/A	N/A	N/A	N/A
233	2902	N/A	N/A	N/A	N/A
234	3532	N/A	N/A	N/A	N/A
235	3533	N/A	N/A	N/A	N/A
236	3554	N/A	N/A	N/A	N/A
237	3555	N/A	N/A	N/A	N/A
238	0	N/A	N/A	N/A	N/A
239	0	N/A	N/A	N/A	N/A
240	0	N/A	N/A	N/A	N/A
241	0	N/A	N/A	N/A	N/A
242	0	N/A	N/A	N/A	N/A
243	0	N/A	N/A	N/A	N/A
244	0	N/A	N/A	N/A	N/A
245	0	N/A	N/A	N/A	N/A
246	1504	N/A	N/A	N/A	N/A
247	1503	N/A	N/A	N/A	N/A
248		ERROR:	Channel 248	Not	Available
249		ERROR:	Channel 249	Not	Available
250		ERROR:	Channel 250	Not	Available
251		ERROR:	Channel 251	Not	Available
252		ERROR:	Channel 252	Not	Available
253		ERROR:	Channel 253	Not	Available
254		ERROR:	Channel 254	Not	Available
255		ERROR:	Channel 255	Not	Available
rlarsen
Copenhagen, Denmark
C?ID=78998
The coding is normally the below (I think the same as in your link) - but channel 199 -> 202 is normally coded to 0 on an A5 - maybe this could be the cause of the 2x faster than normal indicator (I have heard of this behavior before, where channel 200 and 201 has been given a value).
And why does channel 212 have the value 15 - it normally has the value 51215 ??
Another reason for your errors could be the wiring - have you double checked this ??
jonixins
Latvia
C?ID=151647
Thank you rlarsen!
I did check wiring. Adapters are the same as in the link I provided before.
Is it worth trying to go for full led wiring like one I can get in autodata or elsa?
Maybe control unit is not compatible to led's?
About channels 199 -> 202.
It caught my eye too and I'm looking for any info how it can be changed and what are those channels responsible for. Do you have any info?
I'm not familiar with abbreviation CH/LH. What does it mean?
jonixins
Latvia
C?ID=151647
Also one more thing.
Radio module is missing as it was damaged in crash. I connected i/o optical cables to get mmi working, but I'm quite sure it should not interfere.
rlarsen
Copenhagen, Denmark
C?ID=78998
Thank you rlarsen!
I don't know what channel 199 -> 202 are used for on the A5 and the A4 Sedan - on an A4 Avant channel 200 and 201 are used for the Fog light, but 199 and 202 - no idea, I have just heard that other who has retrofitted LED tails, and if they have values in these four channels, have the 2x faster signal in the dash.
jonixins
Latvia
C?ID=151647
I might try change coding to A4 Avant and try saving there 0. Is it reasonable idea or it is bad idea?
jonixins
Latvia
C?ID=151647
rlarsen
What are channels 189 and 191 responsible for?
rlarsen
Copenhagen, Denmark
C?ID=78998
rlarsen
I don't know what 189 is doing - I think Audi is the only who know this in detail.
Channel 191 is for disabling bulb out check
jonixins
Latvia
C?ID=151647
OK, so 181 and 191 are for bulb checks.
191 also might be responsible for increased speed of turn signals?
I guess this car will be fun. Already is :cool:
jonixins
Latvia
C?ID=151647
Wou, that's one great piece of info!
Will make similar sheet with calc formulas for me too.
jonixins
Latvia
C?ID=151647
So it did not work.
I changed coding to A4 Avant. Coding accepted, but channels 199-202 still not active/not possible to change.
Is there a way how to read this control unit eeprom and try manual byte change?
If I look at Advanced Identification, I see:
     Programming Attempts(application): 0
     Successful Attempts(application): 0
     Programming Attempts(data): 2
     Successful Attempts(data): 2
Where Programming Attempts (data) should mean programming of adaptation memory (I guess)
rlarsen
Copenhagen, Denmark
C?ID=78998
You can't change the eeprom with VCDS.
Is your new unit from a facelift model ?? - if it is, then maybe that's why channel 199 - 202 need a value, because all channels are used on the Facelift.
jonixins
Latvia
C?ID=151647
There is no new unit. It is original.
jonixins
Latvia
C?ID=151647
I finally got it working. Not sure if it is right way or there won't be any glitches, but all lights are working, turn indicators in cluster are working normal.
Tomorrow I'll check for possible issues.
What I did?
After quite lot of time spent trying I found VCP (not VCDS) function of automatic coding for LED/Bulb EU/US lights. I did try all options for A5, then started using codes for A4 and one of possible variations for A4 sedan worked.
Now adaptations are for EU A4 VF LED and I have not noticed any issues about that. Also I'm not sure I want to try changing anything.
The most strange part is that adaptation channels 199-202 has changed too. I guess those should be related to some other chanels and maybe display something like cks.
AdpMap:
;Wednesday	8	February	2017	17:34:55:33393
5	0	N/A	N/A	N/A	N/A
6	0	N/A	N/A	N/A	N/A
7	0	N/A	N/A	N/A	N/A
8	0	N/A	N/A	N/A	N/A
181	65535	N/A	N/A	N/A	N/A
187	16368	N/A	N/A	N/A	N/A
189	16368	N/A	N/A	N/A	N/A
191	16143	N/A	N/A	N/A	N/A
195	5251	N/A	N/A	N/A	N/A
196	5283	N/A	N/A	N/A	N/A
199	0	N/A	N/A	N/A	N/A
200	32	N/A	N/A	N/A	N/A
201	0	N/A	N/A	N/A	N/A
202	32	N/A	N/A	N/A	N/A
212	51215	N/A	N/A	N/A	N/A
213	13618	N/A	N/A	N/A	N/A
214	3	N/A	N/A	N/A	N/A
230	2740	N/A	N/A	N/A	N/A
231	2741	N/A	N/A	N/A	N/A
232	2738	N/A	N/A	N/A	N/A
233	2739	N/A	N/A	N/A	N/A
234	0	N/A	N/A	N/A	N/A
235	0	N/A	N/A	N/A	N/A
236	0	N/A	N/A	N/A	N/A
237	0	N/A	N/A	N/A	N/A
238	1502	N/A	N/A	N/A	N/A
239	1506	N/A	N/A	N/A	N/A
240	1518	N/A	N/A	N/A	N/A
241	1519	N/A	N/A	N/A	N/A
242	1501	N/A	N/A	N/A	N/A
243	1505	N/A	N/A	N/A	N/A
