Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Audi A5 Coupe RoW Tail LED retrofit failure
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by jonixins View Post
    OK, so 181 and 191 are for bulb checks.
    191 also might be responsible for increased speed of turn signals?
    I guess this car will be fun. Already is
    You can below see how channel 181, 191 and 192 are set up
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
  2. Likes jonixins, Uwe, Eric liked this post
  3. #12
    Jun 2014
    Latvia
    Wou, that's one great piece of info!
    Will make similar sheet with calc formulas for me too.
  4. #13
    Jun 2014
    Latvia
    I might try change coding to A4 Avant and try saving there 0. Is it reasonable idea or it is bad idea?
    So it did not work.
    I changed coding to A4 Avant. Coding accepted, but channels 199-202 still not active/not possible to change.
    Is there a way how to read this control unit eeprom and try manual byte change?
    If I look at Advanced Identification, I see:
         Programming Attempts(application): 0
         Successful Attempts(application): 0
         Programming Attempts(data): 2
         Successful Attempts(data): 2
    Where Programming Attempts (data) should mean programming of adaptation memory (I guess)
  5. #14
    May 2015
    Copenhagen, Denmark
    You can't change the eeprom with VCDS.
    Is your new unit from a facelift model ?? - if it is, then maybe that's why channel 199 - 202 need a value, because all channels are used on the Facelift.
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  6. #15
    Jun 2014
    Latvia
    There is no new unit. It is original.
  7. #16
    Jun 2014
    Latvia
    I finally got it working. Not sure if it is right way or there won't be any glitches, but all lights are working, turn indicators in cluster are working normal.
    Tomorrow I'll check for possible issues.
    What I did?
    After quite lot of time spent trying I found VCP (not VCDS) function of automatic coding for LED/Bulb EU/US lights. I did try all options for A5, then started using codes for A4 and one of possible variations for A4 sedan worked.
    Now adaptations are for EU A4 VF LED and I have not noticed any issues about that. Also I'm not sure I want to try changing anything.
    The most strange part is that adaptation channels 199-202 has changed too. I guess those should be related to some other chanels and maybe display something like cks.
    AdpMap:
    ;SW:8K0-907-064-C   HW:8K0-907-064-C ---  Central Conv.
    ;Component:BCM2 1.1      H80 0145	 Coding:0100068000390400012000
    ;Wednesday	8	February	2017	17:34:55:33393
    ;VCDS Version: Release 17.1.2 (x64)  Data version: 20170107 DS267.0
    ;VCID: 30653E0763A122C153-8064
    Channel		Field 1	Field 2	Field 3	Field 4
    1	35264	N/A	N/A	N/A	N/A
    2	35264	N/A	N/A	N/A	N/A
    3	32864	N/A	N/A	N/A	N/A
    4	32864	N/A	N/A	N/A	N/A
    5	0	N/A	N/A	N/A	N/A
    6	0	N/A	N/A	N/A	N/A
    7	0	N/A	N/A	N/A	N/A
    8	0	N/A	N/A	N/A	N/A
    9	36832	N/A	N/A	N/A	N/A
    10	0	N/A	N/A	N/A	N/A
    11		ERROR:	Channel 11	Not	Available
    12		ERROR:	Channel 12	Not	Available
    13	87	N/A	N/A	N/A	N/A
    14		ERROR:	Channel 14	Not	Available
    15		ERROR:	Channel 15	Not	Available
    16		ERROR:	Channel 16	Not	Available
    17		ERROR:	Channel 17	Not	Available
    18		ERROR:	Channel 18	Not	Available
    19		ERROR:	Channel 19	Not	Available
    20		ERROR:	Channel 20	Not	Available
    21		ERROR:	Channel 21	Not	Available
    22		ERROR:	Channel 22	Not	Available
    23		ERROR:	Channel 23	Not	Available
    24		ERROR:	Channel 24	Not	Available
    25		ERROR:	Channel 25	Not	Available
    26		ERROR:	Channel 26	Not	Available
    27		ERROR:	Channel 27	Not	Available
    28		ERROR:	Channel 28	Not	Available
    29		ERROR:	Channel 29	Not	Available
    30		ERROR:	Channel 30	Not	Available
    31		ERROR:	Channel 31	Not	Available
    32		ERROR:	Channel 32	Not	Available
    33		ERROR:	Channel 33	Not	Available
    34		ERROR:	Channel 34	Not	Available
    35		ERROR:	Channel 35	Not	Available
    36		ERROR:	Channel 36	Not	Available
    37		ERROR:	Channel 37	Not	Available
    38		ERROR:	Channel 38	Not	Available
    39		ERROR:	Channel 39	Not	Available
    40		ERROR:	Channel 40	Not	Available
    41		ERROR:	Channel 41	Not	Available
    42		ERROR:	Channel 42	Not	Available
    43		ERROR:	Channel 43	Not	Available
    44		ERROR:	Channel 44	Not	Available
    45		ERROR:	Channel 45	Not	Available
    46		ERROR:	Channel 46	Not	Available
    47		ERROR:	Channel 47	Not	Available
    48		ERROR:	Channel 48	Not	Available
    49		ERROR:	Channel 49	Not	Available
    50		ERROR:	Channel 50	Not	Available
    51		ERROR:	Channel 51	Not	Available
    52		ERROR:	Channel 52	Not	Available
    53		ERROR:	Channel 53	Not	Available
    54		ERROR:	Channel 54	Not	Available
    55		ERROR:	Channel 55	Not	Available
    56		ERROR:	Channel 56	Not	Available
    57		ERROR:	Channel 57	Not	Available
    58		ERROR:	Channel 58	Not	Available
    59		ERROR:	Channel 59	Not	Available
    60	15	N/A	N/A	N/A	N/A
    61	9947	N/A	N/A	N/A	N/A
    62	48059	N/A	N/A	N/A	N/A
    63	40	N/A	N/A	N/A	N/A
    64	40	N/A	N/A	N/A	N/A
    65		ERROR:	Channel 65	Not	Available
    66		ERROR:	Channel 66	Not	Available
    67		ERROR:	Channel 67	Not	Available
    68		ERROR:	Security	access	required
    69	0	N/A	N/A	N/A	N/A
    70		ERROR:	Channel 70	Not	Available
    71		ERROR:	Channel 71	Not	Available
    72		ERROR:	Channel 72	Not	Available
    73		ERROR:	Channel 73	Not	Available
    74		ERROR:	Channel 74	Not	Available
    75		ERROR:	Channel 75	Not	Available
    76		ERROR:	Channel 76	Not	Available
    77		ERROR:	Channel 77	Not	Available
    78		ERROR:	Channel 78	Not	Available
    79		ERROR:	Channel 79	Not	Available
    80		ERROR:	Channel 80	Not	Available
    81		ERROR:	Channel 81	Not	Available
    82		ERROR:	Channel 82	Not	Available
    83		ERROR:	Channel 83	Not	Available
    84		ERROR:	Channel 84	Not	Available
    85		ERROR:	Channel 85	Not	Available
    86		ERROR:	Channel 86	Not	Available
    87		ERROR:	Channel 87	Not	Available
    88		ERROR:	Channel 88	Not	Available
    89		ERROR:	Channel 89	Not	Available
    90		ERROR:	Channel 90	Not	Available
    91		ERROR:	Channel 91	Not	Available
    92		ERROR:	Channel 92	Not	Available
    93		ERROR:	Channel 93	Not	Available
    94		ERROR:	Channel 94	Not	Available
    95		ERROR:	Channel 95	Not	Available
    96		ERROR:	Channel 96	Not	Available
    97		ERROR:	Channel 97	Not	Available
    98		ERROR:	Channel 98	Not	Available
    99		ERROR:	Channel 99	Not	Available
    100		ERROR:	Channel 100	Not	Available
    101		ERROR:	Channel 101	Not	Available
    102		ERROR:	Security	access	required
    103		ERROR:	Channel 103	Not	Available
    104		ERROR:	Channel 104	Not	Available
    105		ERROR:	Channel 105	Not	Available
    106		ERROR:	Channel 106	Not	Available
    107		ERROR:	Channel 107	Not	Available
    108		ERROR:	Channel 108	Not	Available
    109		ERROR:	Channel 109	Not	Available
    110		ERROR:	Channel 110	Not	Available
    111		ERROR:	Channel 111	Not	Available
    112		ERROR:	Channel 112	Not	Available
    113		ERROR:	Channel 113	Not	Available
    114		ERROR:	Channel 114	Not	Available
    115		ERROR:	Channel 115	Not	Available
    116		ERROR:	Channel 116	Not	Available
    117		ERROR:	Channel 117	Not	Available
    118		ERROR:	Channel 118	Not	Available
    119		ERROR:	Channel 119	Not	Available
    120		ERROR:	Channel 120	Not	Available
    121		ERROR:	Channel 121	Not	Available
    122		ERROR:	Channel 122	Not	Available
    123		ERROR:	Channel 123	Not	Available
    124		ERROR:	Channel 124	Not	Available
    125		ERROR:	Channel 125	Not	Available
    126		ERROR:	Channel 126	Not	Available
    127		ERROR:	Channel 127	Not	Available
    128		ERROR:	Channel 128	Not	Available
    129		ERROR:	Channel 129	Not	Available
    130		ERROR:	Channel 130	Not	Available
    131		ERROR:	Channel 131	Not	Available
    132		ERROR:	Channel 132	Not	Available
    133		ERROR:	Channel 133	Not	Available
    134		ERROR:	Channel 134	Not	Available
    135		ERROR:	Channel 135	Not	Available
    136		ERROR:	Channel 136	Not	Available
    137		ERROR:	Channel 137	Not	Available
    138		ERROR:	Channel 138	Not	Available
    139		ERROR:	Channel 139	Not	Available
    140		ERROR:	Channel 140	Not	Available
    141		ERROR:	Channel 141	Not	Available
    142		ERROR:	Channel 142	Not	Available
    143		ERROR:	Channel 143	Not	Available
    144		ERROR:	Channel 144	Not	Available
    145		ERROR:	Channel 145	Not	Available
    146		ERROR:	Channel 146	Not	Available
    147		ERROR:	Channel 147	Not	Available
    148		ERROR:	Channel 148	Not	Available
    149		ERROR:	Channel 149	Not	Available
    150		ERROR:	Channel 150	Not	Available
    151		ERROR:	Channel 151	Not	Available
    152		ERROR:	Channel 152	Not	Available
    153		ERROR:	Channel 153	Not	Available
    154		ERROR:	Channel 154	Not	Available
    155		ERROR:	Channel 155	Not	Available
    156		ERROR:	Channel 156	Not	Available
    157		ERROR:	Channel 157	Not	Available
    158		ERROR:	Channel 158	Not	Available
    159		ERROR:	Channel 159	Not	Available
    160		ERROR:	Channel 160	Not	Available
    161		ERROR:	Channel 161	Not	Available
    162		ERROR:	Channel 162	Not	Available
    163		ERROR:	Channel 163	Not	Available
    164		ERROR:	Channel 164	Not	Available
    165		ERROR:	Channel 165	Not	Available
    166		ERROR:	Channel 166	Not	Available
    167		ERROR:	Channel 167	Not	Available
    168		ERROR:	Channel 168	Not	Available
    169		ERROR:	Channel 169	Not	Available
    170		ERROR:	Channel 170	Not	Available
    171		ERROR:	Channel 171	Not	Available
    172		ERROR:	Channel 172	Not	Available
    173		ERROR:	Channel 173	Not	Available
    174		ERROR:	Channel 174	Not	Available
    175		ERROR:	Channel 175	Not	Available
    176		ERROR:	Channel 176	Not	Available
    177		ERROR:	Channel 177	Not	Available
    178		ERROR:	Channel 178	Not	Available
    179		ERROR:	Channel 179	Not	Available
    180		ERROR:	Channel 180	Not	Available
    181	65535	N/A	N/A	N/A	N/A
    182	255	N/A	N/A	N/A	N/A
    183	16383	N/A	N/A	N/A	N/A
    184	255	N/A	N/A	N/A	N/A
    185	65535	N/A	N/A	N/A	N/A
    186	255	N/A	N/A	N/A	N/A
    187	16368	N/A	N/A	N/A	N/A
    188	1	N/A	N/A	N/A	N/A
    189	16368	N/A	N/A	N/A	N/A
    190	1021	N/A	N/A	N/A	N/A
    191	16143	N/A	N/A	N/A	N/A
    192	3	N/A	N/A	N/A	N/A
    193	6	N/A	N/A	N/A	N/A
    194	7	N/A	N/A	N/A	N/A
    195	5251	N/A	N/A	N/A	N/A
    196	5283	N/A	N/A	N/A	N/A
    197	5124	N/A	N/A	N/A	N/A
    198	5156	N/A	N/A	N/A	N/A
    199	0	N/A	N/A	N/A	N/A
    200	32	N/A	N/A	N/A	N/A
    201	0	N/A	N/A	N/A	N/A
    202	32	N/A	N/A	N/A	N/A
    203	73	N/A	N/A	N/A	N/A
    204	105	N/A	N/A	N/A	N/A
    205	13	N/A	N/A	N/A	N/A
    206	45	N/A	N/A	N/A	N/A
    207	12	N/A	N/A	N/A	N/A
    208	44	N/A	N/A	N/A	N/A
    209	0	N/A	N/A	N/A	N/A
    210	0	N/A	N/A	N/A	N/A
    211	51214	N/A	N/A	N/A	N/A
    212	51215	N/A	N/A	N/A	N/A
    213	13618	N/A	N/A	N/A	N/A
    214	3	N/A	N/A	N/A	N/A
    215		ERROR:	Channel 215	Not	Available
    216		ERROR:	Channel 216	Not	Available
    217		ERROR:	Channel 217	Not	Available
    218		ERROR:	Channel 218	Not	Available
    219		ERROR:	Channel 219	Not	Available
    220		ERROR:	Channel 220	Not	Available
    221	51400	N/A	N/A	N/A	N/A
    222	51400	N/A	N/A	N/A	N/A
    223	51400	N/A	N/A	N/A	N/A
    224	51400	N/A	N/A	N/A	N/A
    225	51400	N/A	N/A	N/A	N/A
    226	51400	N/A	N/A	N/A	N/A
    227	51400	N/A	N/A	N/A	N/A
    228	51400	N/A	N/A	N/A	N/A
    229	51400	N/A	N/A	N/A	N/A
    230	2740	N/A	N/A	N/A	N/A
    231	2741	N/A	N/A	N/A	N/A
    232	2738	N/A	N/A	N/A	N/A
    233	2739	N/A	N/A	N/A	N/A
    234	0	N/A	N/A	N/A	N/A
    235	0	N/A	N/A	N/A	N/A
    236	0	N/A	N/A	N/A	N/A
    237	0	N/A	N/A	N/A	N/A
    238	1502	N/A	N/A	N/A	N/A
    239	1506	N/A	N/A	N/A	N/A
    240	1518	N/A	N/A	N/A	N/A
    241	1519	N/A	N/A	N/A	N/A
    242	1501	N/A	N/A	N/A	N/A
    243	1505	N/A	N/A	N/A	N/A
    244	0	N/A	N/A	N/A	N/A
    245	0	N/A	N/A	N/A	N/A
    246	1504	N/A	N/A	N/A	N/A
    247	1503	N/A	N/A	N/A	N/A
    248		ERROR:	Channel 248	Not	Available
    249		ERROR:	Channel 249	Not	Available
    250		ERROR:	Channel 250	Not	Available
    251		ERROR:	Channel 251	Not	Available
    252		ERROR:	Channel 252	Not	Available
    253		ERROR:	Channel 253	Not	Available
    254		ERROR:	Channel 254	Not	Available
    255		ERROR:	Channel 255	Not	Available
  8. Likes MartinsX liked this post
