Results 1 to 10 of 16
Thread: Audi A5 Coupe RoW Tail LED retrofit failure
    Jun 2014
    Latvia
    Hello.
    Please help me!
    I have problem with Audi A5 Coupe 2009. RoW/ DE
    After a crash a car garage wanted to retrofit LED tail lights, used adapters and adatations similar to this:
    https://dl.dropboxusercontent.com/u/...0VFL%20LED.pdf
    But they did fail somewhere and all adaptations were set to something like failsafe and tail lights stopped working at all.
    I managed to get them working, but have 3 major issues:
    1) When turn indicators are used, in cluster it blinks 2x faster than normal. Lamps outside blinks normal speed.
    2) Control module gives fault, it cannot be cleared:
                    Address 46: Central Conv.       Labels: 8K0-907-064-46.CLB
    Control Module Part Number: 8K0 907 064 C    HW: 8K0 907 064 C
      Component and/or Version: BCM2 1.1      H80 0145
               Software Coding: 0100068000390400012000
                Work Shop Code: WSC 06325 000 00000
                          VCID: 30653E0763A122C153-8064
    1 Faults Found:
    03389 - Data Set Implausible
                000 -  -
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.06.01
                        Time: 02:42:43
    3)
    If in adaptation chanel 181 I use 64608 as manual suggests or 65535 instruments gives faults about brake and turn signals. At the same time control unit gives faults only about brake lights.
    If I use 0 in adaptation chanel 181, no faults in display or control unit except 03389 as check is disabled.
                000 -  -
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.06.01
                        Time: 02:42:43
    03554 - Left Brake Light Lamp 3
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.06.01
                        Time: 02:42:43
    03533 - Right Brake / Signal Light Lamp 2
                        Fault Status: 11101100
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.06.01
                        Time: 02:43:49
    Autoscan:
    VIN: WAUZZZ8T19A028300   License Plate:
    Chassis Type: 8T (8T0)
    Scan: 01 02 03 05 06 08 09 0E 10 14 15 16 17 18 19 1B 36 42 46 52
              53 55 56 5F
    VIN: WAUZZZ8T19A028300   Mileage: 175140km-108826miles
    Address 01: Engine (J623-CCWA)       Labels: 059-907-401-V1.clb
       Part No SW: 8K2 907 401     HW: 8K1 907 401 A
       Component: 3.0TDI EDC17  H01 0006
       Revision: 15H01---
       Coding: 0114002C191F0120
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TDI0118K2907401 001006
       ROD: EV_ECM30TDI0118K2907401.rod
       VCID: 6AD1EC6F8DFD98115D-803E
    Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
       Part No SW: 8K0 927 158 A    HW: 0B6 927 156
       Component: 0B6 30 TDIRdW H04 0050
       Revision: --H04---
       Coding: 001001
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 346D32179FB91EE137-8060
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 AH    HW: 8K0 907 379 AH
       Component: ESP8 quattro  H04 0230
       Coding: 142D00
       VCID: 7F072D3BEE7F0DB99A-802A
       Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
       Component: BCM2 1.1      H80 0145
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Serial number: 0508000062591019
       Serial number: 0208000076912011
    Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
       Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
       Component: MEM-BFS       H09 0043
       Revision: AA000000    Serial number: 00001001174044
       Coding: 08017025002400001000
       VCID: 428164CFDD0DA051B5-8016
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0150
       Revision: C1000000    Serial number: 01221020081344
       Coding: 361A0000
       VCID: 72E1F40FAD2D50D1E5-8026
    Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Revision: 05022001    Serial number: 00000000255694
       Coding: 260050914034AF311F09000300005D5D4F9CC3C800010141000000
       Shop #: WSC 06325 123 12345
       Subsystem 1 - Part No SW: 8T1 955 119 C    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 231008  H13 0040
       Serial number: SWF08100230486
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10298549
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000001810080614
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
       Component: CDC-MP3-Pana  H47 0050
       Revision: 00000011
       VCID: 2143CB43384B9B49CC-8074
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0020
       Revision: 11001001    Serial number: 52840829103200
       Coding: 100101
       VCID: 3B7F192BBAE7D199F6-806E
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8K0 907 364     HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H08 0052
       Revision: 00000000    Serial number: 08100807120002
       Coding: 050181
       Shop #: WSC 26875 136 95249
       VCID: 70E5FE07A32162C113-8024
    00775 - Level Control System Sensor; Rear Right (G77)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.05.29
                        Time: 08:37:49
    03262 - Comfort Restriction
                000 -  -
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.05.29
                        Time: 08:37:49
                        Error Code: 2
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Serial number: 0038JD1C0SLJ
       Coding: 30313433363030303030554A304C38543053
       VCID: 3C7D1A37B7E9D6A1FF-8068
       Serial number: 6334MSME4164186BE
       Serial number: 6344MSME42420C49B
       Serial number: 6352QSME0B112E04A
       Serial number: 6362QSME7C092C18T
       Serial number: 63732SME33111820I
       Serial number: 63832SME4B121420P
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90319HJ8000DA
       Coding: 000036
       VCID: 3E79103FA9F5C4B1D1-806A
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 931 A    HW: 8T0 920 931 A
       Component: KOMBIINSTR.   H31 0224
       Revision: 00100000    Serial number: 9D552NVA8
       Coding: 0F07010033000008000000
       VCID: 356B0F139CC307E900-8060
    Address 18: Aux. Heat (J364)       Labels: None
       Part No SW: 8K0 265 105 A    HW: 8K0 265 105 A
       Component: Standheizung  H07 0040
       Revision: 11001001    Serial number: 20081006084236
       Coding: 550000
       VCID: 2757D55B566F657982-8072
    Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0095
       Revision: EB500046    Serial number: 4600E08A1584CA
       Coding: 000303
       VCID: 4E9940FF1955543121-801A
       Component: J367-BDM  H04 0150
       Serial number: 1804E3E9021008
                000 -  -
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.05.29
                        Time: 08:37:00
    01304 - Radio
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.05.29
                        Time: 08:38:49
       Part No SW: 8K0 907 144 C    HW: 8K0 907 144 C
       Component: DYNAMIKLENK.  H06 0500
       Revision: 50001003    Serial number: --------------
       Coding: 040000
       Shop #: WSC 06324 000 00000
       VCID: 2F673D7B7E9F3D394A-807A
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Component: MEM-FS        H09 0043
       Revision: AA000000    Serial number: 00001001174317
    Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
       Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
       Component: TSG FA        H07 1301
       Coding: 011C02224000120102
       Shop #: WSC 29644 000 1048576
       VCID: 50A55E87036142C133-8004
    Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0115401055
                000 -  -
                        Reset counter: 252
                        Mileage: 175146 km
                        Date: 2008.05.29
                        Time: 08:37:49
    Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000007893736
       VCID: 40856EC7D301B241A3-8014
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 00000000248866
       VCID: 31633B0368AB2BC95C-8064
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000003
       VCID: 346D321757B91EE137-8060
    Address 56: Radio
    End-------------------------(Elapsed Time: 03:06)--------------------------
    Adaptations MAP
    . Most of adaptations 181-208 are copy form similar car, so something at least started working.
    chanels 199-202 cannot be changed. For any different value it gives ERROR.
    ;SW:8K0-907-064-C   HW:8K0-907-064-C ---  Central Conv.
    ;Component:BCM2 1.1      H80 0145	 Coding:0100068000390400012000
    ;Saturday	4	February	2017	15:17:06:33393
    ;VCDS Version: Release 17.1.2 (x64)  Data version: 20170107 DS267.0
    ;VCID: 30653E0763A122C153-8064
    Channel		Field 1	Field 2	Field 3	Field 4
    1	35264	N/A	N/A	N/A	N/A
    2	35264	N/A	N/A	N/A	N/A
    3	32864	N/A	N/A	N/A	N/A
    4	32864	N/A	N/A	N/A	N/A
    5	0	N/A	N/A	N/A	N/A
    6	0	N/A	N/A	N/A	N/A
    7	0	N/A	N/A	N/A	N/A
    8	0	N/A	N/A	N/A	N/A
    9	36832	N/A	N/A	N/A	N/A
    10	0	N/A	N/A	N/A	N/A
    11		ERROR:	Channel 11	Not	Available
    12		ERROR:	Channel 12	Not	Available
    13	87	N/A	N/A	N/A	N/A
    14		ERROR:	Channel 14	Not	Available
    15		ERROR:	Channel 15	Not	Available
    16		ERROR:	Channel 16	Not	Available
    17		ERROR:	Channel 17	Not	Available
    18		ERROR:	Channel 18	Not	Available
    19		ERROR:	Channel 19	Not	Available
    20		ERROR:	Channel 20	Not	Available
    21		ERROR:	Channel 21	Not	Available
    22		ERROR:	Channel 22	Not	Available
    23		ERROR:	Channel 23	Not	Available
    24		ERROR:	Channel 24	Not	Available
    25		ERROR:	Channel 25	Not	Available
    26		ERROR:	Channel 26	Not	Available
    27		ERROR:	Channel 27	Not	Available
    28		ERROR:	Channel 28	Not	Available
    29		ERROR:	Channel 29	Not	Available
    30		ERROR:	Channel 30	Not	Available
    31		ERROR:	Channel 31	Not	Available
    32		ERROR:	Channel 32	Not	Available
    33		ERROR:	Channel 33	Not	Available
    34		ERROR:	Channel 34	Not	Available
    35		ERROR:	Channel 35	Not	Available
    36		ERROR:	Channel 36	Not	Available
    37		ERROR:	Channel 37	Not	Available
    38		ERROR:	Channel 38	Not	Available
    39		ERROR:	Channel 39	Not	Available
    40		ERROR:	Channel 40	Not	Available
    41		ERROR:	Channel 41	Not	Available
    42		ERROR:	Channel 42	Not	Available
    43		ERROR:	Channel 43	Not	Available
    44		ERROR:	Channel 44	Not	Available
    45		ERROR:	Channel 45	Not	Available
    46		ERROR:	Channel 46	Not	Available
    47		ERROR:	Channel 47	Not	Available
    48		ERROR:	Channel 48	Not	Available
    49		ERROR:	Channel 49	Not	Available
    50		ERROR:	Channel 50	Not	Available
    51		ERROR:	Channel 51	Not	Available
    52		ERROR:	Channel 52	Not	Available
    53		ERROR:	Channel 53	Not	Available
    54		ERROR:	Channel 54	Not	Available
    55		ERROR:	Channel 55	Not	Available
    56		ERROR:	Channel 56	Not	Available
    57		ERROR:	Channel 57	Not	Available
    58		ERROR:	Channel 58	Not	Available
    59		ERROR:	Channel 59	Not	Available
    60	15	N/A	N/A	N/A	N/A
    61	9947	N/A	N/A	N/A	N/A
    62	48059	N/A	N/A	N/A	N/A
    63	40	N/A	N/A	N/A	N/A
    64	40	N/A	N/A	N/A	N/A
    65		ERROR:	Channel 65	Not	Available
    66		ERROR:	Channel 66	Not	Available
    67		ERROR:	Channel 67	Not	Available
    68		ERROR:	Security	access	required
    69	0	N/A	N/A	N/A	N/A
    70		ERROR:	Channel 70	Not	Available
    71		ERROR:	Channel 71	Not	Available
    72		ERROR:	Channel 72	Not	Available
    73		ERROR:	Channel 73	Not	Available
    74		ERROR:	Channel 74	Not	Available
    75		ERROR:	Channel 75	Not	Available
    76		ERROR:	Channel 76	Not	Available
    77		ERROR:	Channel 77	Not	Available
    78		ERROR:	Channel 78	Not	Available
    79		ERROR:	Channel 79	Not	Available
    80		ERROR:	Channel 80	Not	Available
    81		ERROR:	Channel 81	Not	Available
    82		ERROR:	Channel 82	Not	Available
    83		ERROR:	Channel 83	Not	Available
    84		ERROR:	Channel 84	Not	Available
    85		ERROR:	Channel 85	Not	Available
    86		ERROR:	Channel 86	Not	Available
    87		ERROR:	Channel 87	Not	Available
    88		ERROR:	Channel 88	Not	Available
    89		ERROR:	Channel 89	Not	Available
    90		ERROR:	Channel 90	Not	Available
    91		ERROR:	Channel 91	Not	Available
    92		ERROR:	Channel 92	Not	Available
    93		ERROR:	Channel 93	Not	Available
    94		ERROR:	Channel 94	Not	Available
    95		ERROR:	Channel 95	Not	Available
    96		ERROR:	Channel 96	Not	Available
    97		ERROR:	Channel 97	Not	Available
    98		ERROR:	Channel 98	Not	Available
    99		ERROR:	Channel 99	Not	Available
    100		ERROR:	Channel 100	Not	Available
    101		ERROR:	Channel 101	Not	Available
    102		ERROR:	Security	access	required
    103		ERROR:	Channel 103	Not	Available
    104		ERROR:	Channel 104	Not	Available
    105		ERROR:	Channel 105	Not	Available
    106		ERROR:	Channel 106	Not	Available
    107		ERROR:	Channel 107	Not	Available
    108		ERROR:	Channel 108	Not	Available
    109		ERROR:	Channel 109	Not	Available
    110		ERROR:	Channel 110	Not	Available
    111		ERROR:	Channel 111	Not	Available
    112		ERROR:	Channel 112	Not	Available
    113		ERROR:	Channel 113	Not	Available
    114		ERROR:	Channel 114	Not	Available
    115		ERROR:	Channel 115	Not	Available
    116		ERROR:	Channel 116	Not	Available
    117		ERROR:	Channel 117	Not	Available
    118		ERROR:	Channel 118	Not	Available
    119		ERROR:	Channel 119	Not	Available
    120		ERROR:	Channel 120	Not	Available
    121		ERROR:	Channel 121	Not	Available
    122		ERROR:	Channel 122	Not	Available
    123		ERROR:	Channel 123	Not	Available
    124		ERROR:	Channel 124	Not	Available
    125		ERROR:	Channel 125	Not	Available
    126		ERROR:	Channel 126	Not	Available
    127		ERROR:	Channel 127	Not	Available
    128		ERROR:	Channel 128	Not	Available
    129		ERROR:	Channel 129	Not	Available
    130		ERROR:	Channel 130	Not	Available
    131		ERROR:	Channel 131	Not	Available
    132		ERROR:	Channel 132	Not	Available
    133		ERROR:	Channel 133	Not	Available
    134		ERROR:	Channel 134	Not	Available
    135		ERROR:	Channel 135	Not	Available
    136		ERROR:	Channel 136	Not	Available
    137		ERROR:	Channel 137	Not	Available
    138		ERROR:	Channel 138	Not	Available
    139		ERROR:	Channel 139	Not	Available
    140		ERROR:	Channel 140	Not	Available
    141		ERROR:	Channel 141	Not	Available
    142		ERROR:	Channel 142	Not	Available
    143		ERROR:	Channel 143	Not	Available
    144		ERROR:	Channel 144	Not	Available
    145		ERROR:	Channel 145	Not	Available
    146		ERROR:	Channel 146	Not	Available
    147		ERROR:	Channel 147	Not	Available
    148		ERROR:	Channel 148	Not	Available
    149		ERROR:	Channel 149	Not	Available
    150		ERROR:	Channel 150	Not	Available
    151		ERROR:	Channel 151	Not	Available
    152		ERROR:	Channel 152	Not	Available
    153		ERROR:	Channel 153	Not	Available
    154		ERROR:	Channel 154	Not	Available
    155		ERROR:	Channel 155	Not	Available
    156		ERROR:	Channel 156	Not	Available
    157		ERROR:	Channel 157	Not	Available
    158		ERROR:	Channel 158	Not	Available
    159		ERROR:	Channel 159	Not	Available
    160		ERROR:	Channel 160	Not	Available
    161		ERROR:	Channel 161	Not	Available
    162		ERROR:	Channel 162	Not	Available
    163		ERROR:	Channel 163	Not	Available
    164		ERROR:	Channel 164	Not	Available
    165		ERROR:	Channel 165	Not	Available
    166		ERROR:	Channel 166	Not	Available
    167		ERROR:	Channel 167	Not	Available
    168		ERROR:	Channel 168	Not	Available
    169		ERROR:	Channel 169	Not	Available
    170		ERROR:	Channel 170	Not	Available
    171		ERROR:	Channel 171	Not	Available
    172		ERROR:	Channel 172	Not	Available
    173		ERROR:	Channel 173	Not	Available
    174		ERROR:	Channel 174	Not	Available
    175		ERROR:	Channel 175	Not	Available
    176		ERROR:	Channel 176	Not	Available
    177		ERROR:	Channel 177	Not	Available
    178		ERROR:	Channel 178	Not	Available
    179		ERROR:	Channel 179	Not	Available
    180		ERROR:	Channel 180	Not	Available
    181	0	N/A	N/A	N/A	N/A
    182	255	N/A	N/A	N/A	N/A
    183	16383	N/A	N/A	N/A	N/A
    184	255	N/A	N/A	N/A	N/A
    185	65535	N/A	N/A	N/A	N/A
    186	255	N/A	N/A	N/A	N/A
    187	16383	N/A	N/A	N/A	N/A
    188	1	N/A	N/A	N/A	N/A
    189	16380	N/A	N/A	N/A	N/A
    190	1021	N/A	N/A	N/A	N/A
    191	16383	N/A	N/A	N/A	N/A
    192	3	N/A	N/A	N/A	N/A
    193	6	N/A	N/A	N/A	N/A
    194	7	N/A	N/A	N/A	N/A
    195	5125	N/A	N/A	N/A	N/A
    196	5157	N/A	N/A	N/A	N/A
    197	5124	N/A	N/A	N/A	N/A
    198	5156	N/A	N/A	N/A	N/A
    199	10248	N/A	N/A	N/A	N/A
    200	10280	N/A	N/A	N/A	N/A
    201	10248	N/A	N/A	N/A	N/A
    202	10280	N/A	N/A	N/A	N/A
    203	73	N/A	N/A	N/A	N/A
    204	105	N/A	N/A	N/A	N/A
    205	13	N/A	N/A	N/A	N/A
    206	45	N/A	N/A	N/A	N/A
    207	12	N/A	N/A	N/A	N/A
    208	44	N/A	N/A	N/A	N/A
    209	0	N/A	N/A	N/A	N/A
    210	0	N/A	N/A	N/A	N/A
    211	51214	N/A	N/A	N/A	N/A
    212	15	N/A	N/A	N/A	N/A
    213	12336	N/A	N/A	N/A	N/A
    214	1	N/A	N/A	N/A	N/A
    215		ERROR:	Channel 215	Not	Available
    216		ERROR:	Channel 216	Not	Available
    217		ERROR:	Channel 217	Not	Available
    218		ERROR:	Channel 218	Not	Available
    219		ERROR:	Channel 219	Not	Available
    220		ERROR:	Channel 220	Not	Available
    221	51400	N/A	N/A	N/A	N/A
    222	51400	N/A	N/A	N/A	N/A
    223	51400	N/A	N/A	N/A	N/A
    224	51400	N/A	N/A	N/A	N/A
    225	51400	N/A	N/A	N/A	N/A
    226	51400	N/A	N/A	N/A	N/A
    227	51400	N/A	N/A	N/A	N/A
    228	51400	N/A	N/A	N/A	N/A
    229	51400	N/A	N/A	N/A	N/A
    230	2771	N/A	N/A	N/A	N/A
    231	2772	N/A	N/A	N/A	N/A
    232	2901	N/A	N/A	N/A	N/A
    233	2902	N/A	N/A	N/A	N/A
    234	3532	N/A	N/A	N/A	N/A
    235	3533	N/A	N/A	N/A	N/A
    236	3554	N/A	N/A	N/A	N/A
    237	3555	N/A	N/A	N/A	N/A
    238	0	N/A	N/A	N/A	N/A
    239	0	N/A	N/A	N/A	N/A
    240	0	N/A	N/A	N/A	N/A
    241	0	N/A	N/A	N/A	N/A
    242	0	N/A	N/A	N/A	N/A
    243	0	N/A	N/A	N/A	N/A
    244	0	N/A	N/A	N/A	N/A
    245	0	N/A	N/A	N/A	N/A
    246	1504	N/A	N/A	N/A	N/A
    247	1503	N/A	N/A	N/A	N/A
    248		ERROR:	Channel 248	Not	Available
    249		ERROR:	Channel 249	Not	Available
    250		ERROR:	Channel 250	Not	Available
    251		ERROR:	Channel 251	Not	Available
    252		ERROR:	Channel 252	Not	Available
    253		ERROR:	Channel 253	Not	Available
    254		ERROR:	Channel 254	Not	Available
    255		ERROR:	Channel 255	Not	Available
  2. Likes Uwe liked this post
  3. #2
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    The coding is normally the below (I think the same as in your link) - but channel 199 -> 202 is normally coded to 0 on an A5 - maybe this could be the cause of the 2x faster than normal indicator (I have heard of this behavior before, where channel 200 and 201 has been given a value).
    And why does channel 212 have the value 15 - it normally has the value 51215 ??
    Another reason for your errors could be the wiring - have you double checked this ??
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
  4. Likes jonixins, Uwe liked this post
  5. #3
    Jun 2014
    Latvia
    Thank you rlarsen!
    I did check wiring. Adapters are the same as in the link I provided before.
    Is it worth trying to go for full led wiring like one I can get in autodata or elsa?
    Maybe control unit is not compatible to led's?
    About channels 199 -> 202.
    It caught my eye too and I'm looking for any info how it can be changed and what are those channels responsible for. Do you have any info?
    I'm not familiar with abbreviation CH/LH. What does it mean?
    Jun 2014
    Latvia
    Also one more thing.
    Radio module is missing as it was damaged in crash. I connected i/o optical cables to get mmi working, but I'm quite sure it should not interfere.
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by jonixins View Post
    Thank you rlarsen!
    I don't know what channel 199 -> 202 are used for on the A5 and the A4 Sedan - on an A4 Avant channel 200 and 201 are used for the Fog light, but 199 and 202 - no idea, I have just heard that other who has retrofitted LED tails, and if they have values in these four channels, have the 2x faster signal in the dash.
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  8. Likes jonixins liked this post
  9. #6
    Jun 2014
    Latvia
    I might try change coding to A4 Avant and try saving there 0. Is it reasonable idea or it is bad idea?
  10. #7
    Coming Home / Leaving Home
  11. Likes jonixins liked this post
  12. #8
    Jun 2014
    Latvia
    rlarsen
    What are channels 189 and 191 responsible for?
  13. #9
    May 2015
    Copenhagen, Denmark
    rlarsen
    I don't know what 189 is doing - I think Audi is the only who know this in detail.
    Channel 191 is for disabling bulb out check
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  14. Likes jonixins liked this post
  15. #10
    Jun 2014
    Latvia
    OK, so 181 and 191 are for bulb checks.
    191 also might be responsible for increased speed of turn signals?
    I guess this car will be fun. Already is
