I newly purchased HEX-V2 for my Passat GTE advance (MY2016).
Sometimes I got an Error pop-up saying "Sorry, no coding information is available for this ECU. ......"
so here i send my Auto-scan as below and would like to have any advise on this, thanks.
Friday,03,February,2017,13:59:56:14427
VCDS Version: 17.1.2.0 HEX-V2 CB: 0.4334.4
Data version: 20170131 DS267.1
VIN: WVWZZZ3CZGE181573 License Plate:
Mileage: 8041km-4996mi Repair Order: 01
Chassis Type: 3C (5QE)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 23 2B 36 3C 42 44 51
52 55 57 5F 6C 6D 75 82 8C A5 A9 BB BC C6 CA CF
VIN: WVWZZZ3CZGE181573 Mileage: 8041km-4996miles
C6-Batt. Chrg. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUKC) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 023 S HW: 04E 907 309 F
Component: 1.4l TFSI hy H22 2882
Revision: X3H22---
Coding: 011D0012636405083000
Shop #: WSC 05311 115 00106
ASAM Dataset: EV_ECM14TFS01104E906023S 006006
ROD: EV_ECM14TFS01104E906023S_006.rod
VCID: 303A1A6D0AA0D6379D3-8064
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0DD 300 045 T HW: 0DD 927 770 B
Component: GSG DQ400E H31 1124
Revision: 00031033 Serial number: TFK01602010042
ASAM Dataset: EV_TCMDQ400021 001001
ROD: EV_TCMDQ400021.rod
VCID: 382A224DE2D00E77D53-806C
18 Faults Found:
32317 - Unknown Error Code
U04B5 00 [002] - -
10893 - Implausible Data Received from Battery Energy Control Module 2
U0413 00 [002] - -
60354 - ROD - Unknown Error Code
- 00 [002]
60355 - ROD - Unknown Error Code
- 00 [002]
60356 - ROD - Unknown Error Code
- 00 [002]
60357 - ROD - Unknown Error Code
- 00 [002]
60358 - ROD - Unknown Error Code
- 00 [002]
60359 - ROD - Unknown Error Code
- 00 [002]
60360 - ROD - Unknown Error Code
- 00 [002]
60361 - ROD - Unknown Error Code
- 00 [002]
60362 - ROD - Unknown Error Code
- 00 [002]
60363 - ROD - Unknown Error Code
- 00 [002]
60364 - ROD - Unknown Error Code
- 00 [002]
60365 - ROD - Unknown Error Code
- 00 [002]
60366 - ROD - Unknown Error Code
- 00 [002]
60367 - ROD - Unknown Error Code
- 00 [002]
60368 - ROD - Unknown Error Code
- 00 [002]
60369 - ROD - Unknown Error Code
- 00 [002]
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 3Q0 907 379 S HW: 3Q0 907 379 G
Component: ESC H42 0823
Revision: 00000000 Serial number: 60236000000115
Coding: 0FEC808F3828336D077C060781C649F0011CCCE0608192F538B1F0B8CAA2
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_Brake1UDSContiMK100OMG 002001
ROD: EV_Brake1UDSContiMK100OMG_VW48.rod
VCID: 4ACE68858C3C8CE7B37-801E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0393607662
Coding: 0F00000F03
ASAM Dataset: EV_KessyHellaMQBAB 004032
VCID: 3A2E3845DCDC1C67237-806E
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8043481
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GE 907 044 D HW: 5GE 907 044 D
Component: Climatronic H04 1301
Revision: 00001K07
Coding: 1212102410010001011550001110180A
ASAM Dataset: EV_ACClimaBHBVW37X 005137
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 3D243359CDF22B5F065-8068
Subsystem 3 - Part No SW: 3Q0 963 231 A HW: 3Q0 963 231 A
Component: J848 HV-PTC 200 0202
Serial number: -00100.5T.4B20340125
H02
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 AB HW: 5Q0 937 087 AB
Revision: -------- Serial number: 86582012150494
Coding: 03911C4643D102F771CC5004001C573C1880000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 7BA0FD419366E56F781-802E
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 151211 043 0607
Serial number: 160107164505
Subsystem 2 - Part No SW: 8UD 955 559 B HW: 8UD 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 30021107
Coding: 30006E
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 S HW: 3G0 941 633 S
Component: E1 - LDS MQB H01 0032
Serial number: 24 07 2015 10000547
Sun Roof:
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616033
Coding: 1371267851
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000_009.rod
VCID: 0D44A399BDD2DBDF565-8058
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 520467D359FFC728949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3432167DFEB8EA17F9B-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 04011641350188
ROD: EV_DRCONTITEMIC.rod
VCID: 37282171EFCE010FDC9-8062
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR01TTLI
Coding: 98FCC0C0002000005C5400CF00C800000065
Shop #: WSC 05314 000 00001
VCID: 50FA7AED6A60B637FD3-8004
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G2857705E0041Q01457
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G2857706E0041Q00418
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 202 16
Serial number: 35700000000FB8E0091U
Subsystem 4 - Part No SW: ----------- HW: 480 000 202 16
Serial number: 358000000002D8E0091K
Subsystem 5 - Part No SW: ----------- HW: 480 401 601 16
Serial number: 3510002A11E9F103903Y
Subsystem 6 - Part No SW: ----------- HW: 480 401 301 16
Serial number: 3520002AF1E85EA0B14J
Subsystem 7 - Part No SW: ----------- HW: 480 403 001 16
Serial number: 3550002B318166C3A2D5
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160114401287
Coding: 0C10
Shop #: WSC 00015 115 00001
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FD84951C7FE394F149-806A
Part No SW: 3G0 920 794 HW: 3G0 920 794
Component: KOMBI 410 1340
Coding: 27A50B187FCC000E02886B3F1301002000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009048
VCID: 698CB709E9FA67FF9AD-803C
16777012 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Reset counter: 81
Mileage: 8041 km
Date: 2017.02.03
Time: 13:34:59
16776991 - Databus
Reset counter: 81
Mileage: 8041 km
Date: 2017.02.03
Time: 13:40:07
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5QE 907 530 E HW: 5QE 907 530 A
Component: GW MQB EV 312 3244
Revision: -------- Serial number: 01021610800007
Coding: 020300172EF21000FB00527EDC1F00000001070100010000000300000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 48CA528D92307EF7A53-801C
Subsystem 1 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160000027810126015
Coding: 2DFFFF
Subsystem 2 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 9921078903
Analog clock:
Subsystem 3 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430010783
Coding: 05720100431A00000002060500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_003.rod
VCID: 4FF87991775EA9CFE49-801A
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861290116215105
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000024225016
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BCDF69C12A9F3FD2D-8024
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H04 0020
Serial number: Y0006PAS16938
Coding: 0014000200000500818480808080000000008181000000F400
ROD: EV_SeatMemorDriveSide_VW37.rod
Address 3C: Lane Change (J769) Labels: None
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
Component: TSG FS 020 0041
Serial number: 070116EA402551
Coding: 003F1F20D201028000001000
VCID: 43D045A1AB165DAF701-8016
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: D303
Shop #: WSC 00015 115 00102
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 44D246BDAE185A9749B-8010
Address 51: Electric Drive (J841) Labels: None
Part No SW: 3G0 907 080 C HW: 3G0 907 080 C
Component: LE Gen 3.3H09 0060
Revision: 00H09000
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM12030113G0907080C 001015
ROD: EV_DMCM12030113G0907080B.rod
VCID: 2514FB394562839F7E5-8070
Component: TSG BFS 020 0041
Serial number: 080116EA702097
Coding: 003F1120DE01028200001000
VCID: 42DE40A5B40C54A77B7-8016
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 039602000F210200
Shop #: WSC 05311 000 08193
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Address 57: TV Tuner (R78) Labels: None
Part No SW: 8V0 919 129 B HW: 8V0 919 129 B
Component: JP-DTV H11 1360
Coding: 02041C0000000100000000
ASAM Dataset: EV_TVMELC 001033
ROD: EV_TVMELC_VW37.rod
Part No SW: 3G0 035 050 B HW: 3G0 035 050
Component: MU-H-N-JP 040 0031
Serial number: K5F AW7FV0675O
Coding: 02840206FF00000051330001001038001F0209E601200000F6
ASAM Dataset: EV_MUHig4CGen2AW7 001081
ROD: EV_MUHig4CGen2AW7_VW48.rod
VCID: 196CC7C9791A377FCAD-804C
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU304P8U
Subsystem 2 - Part No SW: V03 959 803 EG HW: -----------
Component: JPN 2017 --- 7720
Chip Card Reader Control Module:
Subsystem 3 - Part No SW: 8V0 919 813 B HW: 8V0 919 813 B
Component: DSRC UNIT H08 0002
Serial number: 502129373646
Traffic Data Aerial:
Subsystem 4 - Part No SW: 8V0 035 504 B HW: 8V0 035 504 B
Component: VICS Antenna H06 0001
Serial number: 503360036302
Subsystem 5 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 2007
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 5Q0 907 556 HW: 5Q0 907 556
Component: Areaview 2 H11 0329
Serial number: C854706JG003241
Coding: 01840201E60F200000204094
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
VCID: 76B6EC75A844B80707F-8022
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30454267400000
Coding: 0208
ASAM Dataset: EV_DeckLidCONTIAU736 001012
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 012 0715
Coding: 028472041082BA0300F800000000
ROD: EV_OCULowMQB.rod
Address 82: Heads Up Display (J898) Labels: None
Part No SW: 3G0 919 608 HW: 3G0 919 608
Component: HeadupDisplay 040 0152
Coding: 464060
ASAM Dataset: EV_HeadUpDisplContiVW481 001010
ROD: EV_HeadUpDisplContiVW481.rod
VCID: 6B80CD01E30675EFE81-803E
Address 8C: Hybrid Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 3Q0 915 227 K HW: 3Q0 915 227 K
Component: K8C H05 0430
Serial number: 14121516010074
ASAM Dataset: EV_BECM09620213Q0915227K 002006
ROD: EV_BECM09620213Q0915227K.rod
VCID: 392C2749D9DA177F2AD-806C
Battery Junction Box:
Subsystem 1 - Part No SW: 3Q0 915 227 J HW: 3Q0 915 227 J
Component: A2 HVSMBJBECU H08 0410
Serial number: 00000006011615010078
Cell Module Controller 1:
Subsystem 2 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC1 H04 0430
Serial number: 15A17ZKK311A01040028
Cell Module Controller 2:
Subsystem 3 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC2 H04 0430
Serial number: 15A17ZKK311A01040168
Cell Module Controller 3:
Subsystem 4 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC3 H04 0430
Serial number: 15A17ZKK311A01040362
Cell Module Controller 4:
Subsystem 5 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC4 H04 0430
Serial number: 15A17ZKK311A01040048
Cell Module Controller 5:
Subsystem 6 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC5 H04 0430
Serial number: 15A17ZKK311A01040655
Cell Module Controller 6:
Subsystem 7 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC6 H04 0430
Serial number: 15A24ZKK311A01040145
Cell Module Controller 7:
Subsystem 8 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC7 H04 0430
Serial number: 15A17ZKK311A01040661
Cell Module Controller 8:
Subsystem 9 - Part No SW: 5QE 915 591 H HW: 5QE 915 591 H
Component: J1068MQB CMC8 H04 0430
Serial number: 15A17ZKK311A01040003
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 653 D HW: 3Q0 980 653
Component: MQB_B_MFK H08 0072
Serial number: 30011611K11617
Coding: 00040802070005010002234EC040A100840084300000
ROD: EV_MFKBoschMQBB.rod
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 3G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 160121200712
ROD: EV_SoundActuaGen2AU64X_VW26.rod
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 200116BAI08895
Coding: 000E11200101028000001000
VCID: 45D45BB9A522639F5E5-8010
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0041
Serial number: 200116BAI08899
Address C6: Batt. Chrg. (J1050) Labels: None
Part No SW: 5QE 915 682 M HW: 5QE 915 682 M
Component: OBC KOSTAL H22 4006
Revision: -------- Serial number: 2101160AF000XA
Coding: 105168022000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
ROD: EV_OBCSinglPhaseKLOMQB11P.rod
VCID: 57E881F14F8EE10F3C9-8002
Address CA: Sunroof (J245) Labels: None
Part No SW: 4M0 907 594 D HW: 4M0 907 594
Component: SAD_STG_1 011 0003
Coding: 308040748202
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_VW37.rod
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 3Q0 907 590 B HW: 3Q0 907 590
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
End----------(Elapsed Time: 02:34, VBatt start/end: 13.1V/13.1V)-----------
