03 audi A4 B6 cranks but wont start. Drove it in the shop replaced C.V. boot then sat for 3 days and battery went dead. Has fuel pressure and spark, New timing belt that is still timed correctly and two months old. I suspect that injectors are not getting signal
Patrick
Patrick
Wednesday,25,January,2017,21:21:04:07911
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
VIN: WAULC68E13A204809 License Plate:
67 69 75 76 77
VIN: WAULC68E13A204809 Mileage: 189330km-117644miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
Component: 1.8L R4/5VT G01 0001
Coding: 0016751
Shop #: WSC 06158 444 10376
VCID: 74E7CAB914A5C8E1DB-515E
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 P
Component: AG5 01V 1.8l5VT USA 0910
Coding: 0001002
Shop #: WSC 63351 000 00000
VCID: 3B752185797B4799DA-5140
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04277
Shop #: WSC 06435
VCID: 2D511FDDE70FD92954-5140
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2A5B14C1D6E1CE11B1-5140
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
VCID: 34670AB9042588E11B-4B00
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
VCID: 377D3DB5455363F93E-515E
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
VCID: 3C7722992C7540A1D3-4B00
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 00001
VCID: 326B0CA1FE3186D109-5140
WAULC68E13A204809 AUZ6Z0B0268196
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
VCID: 6BD5D1C5199B17190A-515E
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
VCID: 72EBCCA13EB1C6D1C9-4B00
Subsystem 1 - Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0002
Subsystem 3 - Part No: Steuerger
Component: t HL antwortet nicht
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 F
Component: symphony II NP2 0051
Coding: 01001
Shop #: WSC 08101
VCID: 2A5B14C1D6E1CE11B1-4EB2
End-------------------------(Elapsed Time: 05:31)--------------------------
