Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 56
Thread: NEW TO AUDI NEW TO VCDS NEED SERIOUS HELP!!!
  1. #41
    The 4E A8 is one of the most power-hungry cars every made. If you're going to be working on this car extensively and don't wish to run the engine while scanning, you're going to need a good battery charger, 20-30A at the absolute minimum.
  2. Likes Dana, Jack@European_Parts liked this post
  3. #42
    Administrator Andy's Avatar
    Sector 7G
    Here's a handy pic showing how the charger should be connected:
    http://wiki.ross-tech.com/wiki/index...ger_hookup.jpg
  4. #43
    Mar 2015
    Rhode Island
    Quote Originally Posted by sheed44 View Post
    I did this and the battery level meter shows up but not the suspension, oil or anything else that might have shown up when doing this
    Looks like most of your problems are voltages as Eric said in a previous post, I would connect a battery charger to this car and let it charge right up and then clear out the DTC's. Keep in mind for some reason sometimes when you go clear all DTC's it doesn't. I always go into the Modules in question by double clicking on it and clear it out individually. Also when you run a full AutoScan a Battery charger should always be connected to get a proper scan. After you do these steps please post up another full AutoScan...
  5. #44
    Mar 2015
    Rhode Island
    so the battery in the vehicle is not an Audi battery, and with the key turned on but not over before the complete scan is ran I get a energy management message on the dash display, or am I supposed to run it with the car started instead? and I took the battery to get tested and I keep getting told its a good battery and im not sure it was coded to the vehicle, its a Super Start Extreme battery and I was told its less than a year old after tracking down the last owner and asking him
    Do yourself a favor get an OEM Varta Battery from Audi!! then code it to the car, For now you can code this aftermarket one by just changing one number of the serial number in VCDS.
  6. Likes Andy, Dana, Eric, Uwe, Jack@European_Parts, sheed44 liked this post
  7. #45
    Jan 2017
    so this is my scan after clearing all DTC's and with the battery charger hooked up. also for the bulbs that I need to replace can I get them from the auto parts store or do I have to get them from Audi also? or the internet?
    Tuesday,31,January,2017,13:29:35:42098
    VCDS Version: 17.1.2.0 (x64)  HEX-V2 CB: 0.4334.4
    Data version: 20170131 DS267.1
    VIN: WAUML44E04N018154   License Plate:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
              47 4F 52 53 55 56 61 62 65 72 75 76
    VIN: WAUML44E04N018154   Mileage: 228150km-141765miles
    Address 01: Engine        Labels: None
       Part No SW: 4E0 910 560 P    HW: 4E0 907 560
       Component: 4.2L V8/5V      G   0020
       Revision: --------    Serial number: AUX3Z0D0532489
       Coding: 0007773
       Shop #: WSC 24103 444 84355
       VCID: 2E06043A5C1D02578FF-807A
    18061 - Please check DTC Memory of ABS Controller
                P1653 - 008 -
                        Mileage: 228157 km
                        Temperature: 27.0°C
                        Temperature: 27.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 11.684 V
    Readiness: 0110 1101
       Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
       Component: AG6 09E 4,2L5V USA  0110
       Revision: 00000001    Serial number:        0028405
       Shop #: WSC 02313 785 00200
       VCID: 2412E61202D1B80769B-8070
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
       Component: ESP 5.7 allrad  H44 0500
       Coding: 0007597
       Shop #: WSC 24103 000 00000
       VCID: 221EE00A18C5B6371B7-8076
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 A
       Component:     FBS AUDID3  H03 0140
       Revision: 01403903    Serial number: AUX3Z0D0532489
       Coding: 0263168
       Shop #: WSC 02311 785 00200
       VCID: 58EA82E20E192CE7353-800C
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H07  0060
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 3940448
       VCID: 2310E50E07DFBF3F101-8076
    Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
       Part No SW: 4E0 910 732 B    HW: 4E0 035 729
       Component: Interfacebox    H43 4140
       Revision: 00000000    Serial number: 346AB047509000
       Coding: 0000000
       VCID: 211CEF061DC3AD2F02D-8074
       Subsystem 1 - Part No: 4E0 910 609 C
       Component: Bedienteil MMI  H42 0100
       Subsystem 2 - Serial number: 390FU057502768
       Subsystem 3 - Serial number: 7422.06.0500000000290B0023˙
       Subsystem 4 - Serial number: 0B0023˙
                        Time Indication: 15
       Part No SW: 4E0 910 043     HW: 4E0 820 043 B
       Component: KLIMAAUTOMAT    016 0240
       Revision: 00000022    Serial number: 00000000034086
       Coding: 1085761
       VCID: 5AEE98EA70153EF7037-800E
       Subsystem 1 - Part No: 4E0 910 772 A
       Component: Sitzluefter  FS H02  010
       Subsystem 2 - Part No: 4E0 910 772 A
       Component: Sitzluefter BFS H02  010
       Subsystem 3 - Serial number: 898053000
       Subsystem 4 - Serial number: HO16012004065A000000000424˙†89
       Subsystem 5 - Serial number: 000424˙†898053000      000-SHO
       Subsystem 6 - Serial number:     000-SHO16012004065A00000000
       Subsystem 7 - Serial number: 65A000000000467˙
    Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
       Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
       Component: ILM Fahrer      H11 0100
       Coding: 0111113
       VCID: 2A0E082A60F56E77537-807E
       Subsystem 1 - Part No: 4E1 910 113 B
       Component: Wischer WWS D3  H40 0380
       Coding: 00000036
       Shop #: WSC 02313
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 214
                        Mileage: 228157 km
                        Date: 2017.01.31
                        Time: 13:14:25
                        Reset counter: 214
                        Mileage: 228157 km
                        Date: 2017.01.31
                        Time: 13:14:26
                        Reset counter: 214
                        Mileage: 228157 km
                        Date: 2017.01.31
                        Time: 13:14:26
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111
       Component: CD-Changer      H43 0470
       Revision: 00000501    Serial number: AUZ5ZBC1022182
       VCID: 1C62DEF23AA180C7D1B-8048
    Address 15: Airbags        Labels: 4E0-910-655-84.lbl
       Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
       Component: Airbag 8.4E+    H10 0920
       Coding: 0530707
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549 A
       Coding: 0012241
       VCID: 6594BB16496B810FBE5-8030
       Component: Lenkradmodul    H04 0080
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 900     HW: 4E0 920 950 B
       Component: KOMBIINSTR. VDO H44 0090
       Revision: D15         Serial number: AUDID3D0006575
       Coding: 0016203
       VCID: 5CE29EF27A21C0C711B-8008
    Address 19: CAN Gateway        Labels: 4E0-910-468.clb
       Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
       Component: Gateway         H07 0030
       Revision: 07          Serial number: 0200503C08128A
       Coding: FCFE7BDD1B2304
       VCID: 2616FC1A74ED4A1777F-8072
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0263168
       XXXXXXXXXXX ELV                 XXXX
    Address 34: Level Control        Labels: 4E0-910-553.lbl
       Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
       Component: LUFTFDR.-CDC    H05 4290
       Coding: 0015510
       VCID: 2514FB1609EB410F7E5-8070
    01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
                        Fault Status: 11101010
                        Reset counter: 214
                        Mileage: 228157 km
                        Date: 2017.01.31
                        Time: 13:25:04
       Component: Sitzmemory FS  H07  0060
       Coding: 4071522
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
       Component: MNS US          H43 1100
       Revision: 00000000    Serial number: 355AM047515059
       VCID: 382A2262AE59CCE7D53-806C
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135
       Component: Dachknoten D3   H01 0090
       Serial number: 00000334300180
       Coding: 0003989
       VCID: 1D64D3F621BB89CF265-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 801
       Component: Türsteuer.FS BRM005 0110
       Coding: 0028196
       VCID: 5EE694FA6C3DD2D77FF-800A
    Address 46: Central Conv.        Labels: 4E0-910-289.lbl
       Part No SW: 4E0 910 289 A    HW: 4E0 907 289
       Component: Komfortgeraet   H03 0030
       Revision: 00300003    Serial number:  W040312180022
       Coding: 0065150
       VCID: 2708F11E73E7531F4C9-8072
       Component: Heckdeckel      H06 0060
       Component: Neigungssensor  H02 0020
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 214
                        Mileage: 213427 km
                        Date: 2003.10.09
                        Time: 20:24:59
    01134 - Alarm Horn (H12)
                        Reset counter: 102
                        Mileage: 219722 km
                        Date: 2016.01.03
                        Time: 16:39:11
                        Reset counter: 102
                        Mileage: 219722 km
                        Date: 2016.01.03
                        Time: 16:39:11
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 M    HW: 4E0 035 223 B
       Component: DSP-High D3/AUX H13 0450
       Revision: Dev_D01     Serial number: 00000000674361
       Coding: 0000016
    02084 - Component Protection
                        Fault Status: 01100101
                        Reset counter: 216
                        Mileage: 160971 km
                        Date: 2010.11.11
                        Time: 19:44:50
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H08 0020
       Revision:             Serial number: 00000000031180
       Coding: 0010111
       VCID: 1E66D4FA2CBD92D73FF-804A
       Subsystem 1 - Part No: 4E0 910 511 A
       Component: UGDO HL US      H02 0030
       Subsystem 2 - Serial number: VK4978T0B79E
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802     HW: 4E1 959 802
       Component: Türsteuer.BF BRM007 0110
       Coding: 0028196
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 A    HW: 4E0 907 801
       Component: EPB  AV1C1010   H01 1010
       Revision: AV1C1010
       Coding: 0000532
       Shop #: WSC 24103 444 52497
    02434 - Supply Voltage for Control Module for Left Channel
                006 - Short to Plus - MIL ON
                        Fault Status: 11110110
                        Fault Frequency: 25
                        Reset counter: 201
                        Voltage: 9.21 V
                        Count: 110
    02596 - Rear Brake Pads Worn
                        Fault Status: 01111000
                        Reset counter: 201
                        Voltage: 9.21 V
                        Count: 61
    Address 55: Headlight Range        Labels: 4E0-910-357.lbl
       Part No SW: 4E0 910 357     HW: 4E0 907 357
       Component: Pre-AFS         H01 0040
       VCID: 629EA00A5845F6375B7-8036
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541
       Component: TUNER EU/US/RDW H41 0620
       Revision: 00000000    Serial number: 304AH047557504
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 B    HW: 4E0 915 181
       Component: ENERGIEMANAGER  H02 0240
       Revision: 00000000    Serial number: 00000006225939
       Shop #: WSC 24101 444 01039
       VCID: 1F18E9FE2BB79BDF349-804A
       Subsystem 1 - Part No: 000 915 105 AK
       Component: von VA0  1401010139
       Coding: 303030393135313035414B56413031343031303130313339
       Shop #: WSC 00000 128 00289
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 801 A
       Component: Türsteuer.HL BRM007 0110
       Coding: 0028196
       VCID: 5DE493F6613BC9CF665-8008
    Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
       Part No SW: 4E0 910 273     HW: 4E0 907 273
       Component: Reifendruck 2   H01 0210
       Coding: 0212127
       VCID: 5F98A9FE6B37DBDF749-800A
    01477 - System Switched Off
                        Reset counter: 214
                        Mileage: 228157 km
                        Date: 2017.01.31
                        Time: 13:26:13
                        Temperature: 7.0°C
                        Error Code: 32768
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802     HW: 4E0 959 802 A
       Component: Türsteuer.HR BRM007 0110
       Coding: 0028196
    Address 75: Telematics        Labels: None
       Part No SW: 4E0 910 616     HW: 4E0 035 616 A
       Component: Telematik USA1      0070
       Revision: 00000004    Serial number: 0000ATD3007687
       Coding: 0000005
       VCID: 609AAA025659E4274D3-513C
       Subsystem 1 - Part No: 4E0 910 616
    No Faults Found
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
       Component: Parkhilfe 8-Kan H11 0010
       Revision: --.--.--    Serial number: 00000400900020
       Coding: 0001208
    End----------(Elapsed Time: 02:51, VBatt start/end: 11.6V/11.7V)-----------
  8. Likes BostonSlaya, Uwe liked this post
  9. #46
    Mar 2015
    Rhode Island
    Now that looks a lot better!!! starting to get somewhere...The bulbs you have in question are they actually burned out? This could just be the wiring and not the bulb. Some of these might not be a problem getting at a regular part store, others like the Fog lights will more then likely be dealer or online only. This car is just way to temperamental for anything aftermarket, This includes the Battery.
    I will start from the top of your scan, 01:Engine - 18062 ABS Controller (This could very well be because of your rear brakes DTC being worn) I would start by inspecting both rear brakes to see how much is left on both side os the rotors then report back. They just might need to be replaced and then coded, or they where replaced and somebody didn't code the module correctly. Also please check that Alarm Horn for bad wiring or bad Alarm, Most likely it's going to be the Alarm itself.
    65:Tire pressure (Looks like it's switched off so why not pull the fuse and code the TPS out of the install list 19.. Telematics I would pull the front driver seat out and remove it from the black box and then pull the fuse and code that out as well.. I purchase all my parts from a wonderful source great OEM parts at a fantastic price www.fcpeuro.com... I would stop going zig zag on things and work on one DTC at a time and report your findings.
  10. Likes Uwe, JGiardino89 liked this post
  11. #47
    Mar 2015
    Rhode Island
    34:Level Control DTC
    Possible causes:
    Wiring and / or connections faulty
    (G290) defect
    Possible solutions:
    Check / repair wiring and connections
    Check (measuring blocks) / replace (G290)
    This also could be that the compressor is getting hot by working to hard, There are air Compressor rebuild kits out there for real cheap and easy for a DIY. Best way to tell is do you here the compressor loader then normal? You should barely hear it, mine was running HOT and I rebuilt it with a new piston ring and it is now extra quite and works amazing.
  12. Likes Uwe, sheed44 liked this post
  13. #48
    Jan 2017
    Quote Originally Posted by BostonSlaya View Post
    Ok thank you and the fog light on the passenger side is burnt out and so are the parking lamps these are also displayed on the instrument display,i will check the rear brake pads today, and I will check the alarm horn, I appreciate all of your help im going to have an amazing running machine here in a sec lol
  14. #49
    Mar 2015
    Rhode Island
    I would absolutely check the Rear Brakes for sure, I know you don't want them to get to a point it causes more damage if they are truly bad. The website I listed above will give you the price but better yet a full diagram of the vehicle to give you part #'s This is what I use for sure..
  15. #50
    Jan 2017
    im still having the issue of something draining the battery after about 6-8 hours of the car sitting it will light up and the key will turn but it will not start instead it makes a ticking sound like the battery is completely dead but it's not then after I put the charger on it for about a minute it starts right up?? what could be drawing this power from the battery? based off of my latest scan?
