NEW TO AUDI NEW TO VCDS NEED SERIOUS HELP!!!
sheed44
C?ID=297477
Hello so I just purchased this used 2004 Audi A8 with 135,000 miles on it and noticed some things off with it so instead of taking it to the dealership I opted to purchase the VagCom from Ross Tech I scanned my vehicle and now need a little help figuring out exactly what all the data is so I can start repairs from cheapest to most expensive PLEASE HELP.
 Tuesday,24,January,2017,10:30:48:42098
 VCDS Version: 17.1.2.0 (x64) HEX-V2 CB: 0.4334.4
 Data version: 20170107 DS267.0
 VIN: WAUML44E04N018154 License Plate:
 Mileage: 226430km-140697mi Repair Order:
 Chassis Type: 4E (4E0)
 Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
 47 4F 52 53 55 56 61 62 65 72 75 76
 VIN: WAUML44E04N018154 Mileage: 226430km-140697miles
 07-Control Head -- Status: Cannot be reached 1100
 0E-Media Player 1 -- Status: Cannot be reached 1100
 Address 01: Engine Labels: None
 Part No SW: 4E0 910 560 P HW: 4E0 907 560
 Component: 4.2L V8/5V G 0020
 Revision: -------- Serial number: AUX3Z0D0532489
 Coding: 0007773
 Shop #: WSC 24103 444 84355
 VCID: 2E06043A5C1D02578FF-807A
 18061 - Please check DTC Memory of ABS Controller
 P1653 - 008 -
 Mileage: 226432 km
 RPM: 690 /min
 Load: 19.6 %
 Temperature: 63.0°C
 Temperature: 15.0°C
 Absolute Pres.: 0.0 mbar
 Voltage: 13.970 V
 17981 - Left Engine Mount Solenoid Valve (N144)
 P1573 - 004 - Open Circuit
 Mileage: 226432 km
 RPM: 663 /min
 Load: 19.6 %
 Temperature: 63.0°C
 Temperature: 15.0°C
 Voltage: 14.097 V
 17985 - Right Engine Mount Solenoid Valve (N145)
 P1577 - 004 - Open Circuit
 Mileage: 226432 km
 RPM: 582 /min
 Load: 27.4 %
 Temperature: 84.0°C
 Temperature: 34.0°C
 Voltage: 14.097 V
 Readiness: 0010 1100
 Part No SW: 4E0 910 156 E HW: 09E 927 156 A
 Component: AG6 09E 4,2L5V USA 0110
 Revision: 00000001 Serial number: 0028405
 Shop #: WSC 02313 785 00200
 VCID: 2412E61202D1B80769B-8070
 Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
 Component: ESP 5.7 allrad H44 0500
 Coding: 0007597
 Shop #: WSC 24103 000 00000
 VCID: 221EE00A18C5B6371B7-8076
 01200 - ABS Valves Supply Voltage
 Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
 Part No SW: 4E0 910 131 HW: 4E0 909 131 A
 Component: FBS AUDID3 H03 0140
 Revision: 01403903 Serial number: AUX3Z0D0532489
 Coding: 0263168
 Shop #: WSC 02311 785 00200
 VCID: 58EA82E20E192CE7353-800C
 Component: ELV XXXX
 Address 06: Seat Mem. Pass Labels: None
 Part No SW: 4E0 910 760 C HW: 4E0 959 760
 Component: Sitzmemory BFS H07 0060
 Revision: 00000000 Serial number: 5DS 008 795-03
 Coding: 3940448
 VCID: 2310E50E07DFBF3F101-8076
 Address 07: Control Head
 Part No SW: 4E0 910 043 HW: 4E0 820 043 B
 Component: KLIMAAUTOMAT 016 0240
 Revision: 00000022 Serial number: 00000000034086
 Coding: 1085761
 VCID: 5AEE98EA70153EF7037-800E
 Subsystem 1 - Part No: 4E0 910 772 A
 Component: Sitzluefter FS H02 010
 Subsystem 2 - Part No: 4E0 910 772 A
 Component: Sitzluefter BFS H02 010
 Subsystem 3 - Serial number: 898053000
 Subsystem 4 - Serial number: HO16012004065A000000000424ÿ†89
 Subsystem 5 - Serial number: 000424ÿ†898053000 000-SHO
 Subsystem 6 - Serial number: 000-SHO16012004065A00000000
 Subsystem 7 - Serial number: 65A000000000467ÿ
 Fault Frequency: 16
 Reset counter: 232
 Mileage: 223215 km
 Date: 2003.10.10
 Time: 16:26:34
 01232 - A/C Compressor Regulator Valve (N280)
 Fault Status: 00101010
 Reset counter: 219
 Mileage: 224444 km
 Date: 2003.10.08
 Time: 08:31:31
 Load: 90.0 %
 Current: 0.000 A
 Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
 Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
 Component: ILM Fahrer H11 0100
 Coding: 0111113
 VCID: 2A0E082A60F56E77537-807E
 Subsystem 1 - Part No: 4E1 910 113 B
 Component: Wischer WWS D3 H40 0380
 Coding: 00000036
 Shop #: WSC 02313
 Fault Status: 01101010
 Reset counter: 193
 Mileage: 226432 km
 Date: 2003.10.08
 Time: 00:01:53
 Reset counter: 232
 Mileage: 226310 km
 Date: 2003.10.08
 Time: 15:47:41
 Reset counter: 193
 Mileage: 226432 km
 Date: 2003.10.08
 Time: 00:01:54
 02071 - Local Databus
 Reset counter: 232
 Reset counter: 193
 Mileage: 226432 km
 Date: 2003.10.08
 Time: 00:01:57
 Address 0E: Media Player 1
 Address 15: Airbags Labels: 4E0-910-655-84.lbl
 Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
 Component: Airbag 8.4E+ H10 0920
 Coding: 0530707
 Address 16: Steering wheel Labels: 4E0-910-549.lbl
 Part No SW: 4E0 910 549 HW: 4E0 953 549 A
 Coding: 0012241
 VCID: 6594BB16496B810FBE5-8030
 Component: Lenkradmodul H04 0080
 Fault Status: 01100010
 Fault Frequency: 14
 Mileage: 223170 km
 Date: 2003.10.09
 Time: 22:03:47
 00532 - Supply Voltage B+
 Reset counter: 233
 Fault Status: 00101110
 Reset counter: 233
 Date: 2063.15.31
 Time: 31:63:18
 Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
 Part No SW: 4E0 910 900 HW: 4E0 920 950 B
 Component: KOMBIINSTR. VDO H44 0090
 Revision: D15 Serial number: AUDID3D0006575
 Coding: 0016203
 VCID: 5CE29EF27A21C0C711B-8008
 Address 19: CAN Gateway Labels: 4E0-910-468.clb
 Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
 Component: Gateway H07 0030
 Revision: 07 Serial number: 0200503C08128A
 Coding: FCFE7BDD1B2304
 VCID: 2616FC1A74ED4A1777F-8072
 00384 - Optical Databus
 Reset counter: 193
 Mileage: 226432 km
 Date: 2003.10.08
 Time: 00:30:10
 Address 25: Immobilizer Labels: 4E0-910-131.lbl
 Coding: 0263168
 Component: ELV XXXX
 XXXXXXXXXXX ELV XXXX
 Address 34: Level Control Labels: 4E0-910-553.lbl
 Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
 Component: LUFTFDR.-CDC H05 4290
 Coding: 0015510
 VCID: 2514FB1609EB410F7E5-8070
 8 Faults Found:
 Fault Frequency: 109
 Reset counter: 233
 Mileage: 222857 km
 Date: 2003.10.09
 Time: 05:46:40
 01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
 Fault Status: 11101010
 Fault Frequency: 106
 Reset counter: 193
 Mileage: 222857 km
 Date: 2003.10.09
 Time: 05:46:48
 01772 - Signal from Level Control Pressure Sensor (G291)
 Fault Frequency: 81
 Reset counter: 168
 Mileage: 222858 km
 Date: 2003.10.09
 Time: 05:49:09
 01400 - Suspension Level Control
 Fault Frequency: 10
 Reset counter: 222
 Mileage: 224136 km
 Date: 2003.10.14
 Time: 19:28:06
 01598 - Drive Battery Voltage
 Reset counter: 0
 Mileage: 226310 km
 Date: 2003.10.08
 Time: 15:48:19
 Reset counter: 220
 Mileage: 223170 km
 Date: 2003.10.09
 Time: 21:56:01
 01398 - Signal Conductor for Central Locking; Doors Open
 Reset counter: 232
 Mileage: 223175 km
 Date: 2003.10.10
 Time: 15:18:29
 01487 - System Function Test
 Reset counter: 209
 Component: Sitzmemory FS H07 0060
 Coding: 4071522
 Reset counter: 232
 Mileage: 224580 km
 Date: 2012.11.17
 Time: 08:36:01
 Address 37: Navigation
 Address 38: Roof Electronics Labels: 4E0-910-135.lbl
 Part No SW: 4E0 910 135 A HW: 4E0 907 135
 Component: Dachknoten D3 H01 0090
 Serial number: 00000334300180
 Coding: 0003989
 VCID: 1D64D3F621BB89CF265-8048
 Reset counter: 221
 Mileage: 224296 km
 00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
 Reset counter: 217
 Mileage: 224232 km
 Date: 2003.10.15
 Time: 18:37:00
 00410 - Pre-Selection Signal for Opening Sunroof
 Fault Status: 00100111
 Fault Frequency: 15
 Reset counter: 224
 Mileage: 225436 km
 Date: 2003.10.08
 Time: 00:41:00
 Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
 Part No SW: 4E1 910 802 HW: 4E1 959 801
 Component: Türsteuer.FS BRM005 0110
 Coding: 0028196
 VCID: 5EE694FA6C3DD2D77FF-800A
 Reset counter: 221
 Mileage: 224576 km
 Date: 2003.10.08
 Time: 08:36:08
 02111 - Motor for Window Regulator
 Reset counter: 221
 Mileage: 224576 km
 Date: 2003.10.08
 Time: 08:36:28
 Reset counter: 221
 Mileage: 224576 km
 Date: 2003.10.08
 Time: 08:36:28
 Address 46: Central Conv. Labels: 4E0-910-289.lbl
 Part No SW: 4E0 910 289 A HW: 4E0 907 289
 Component: Komfortgeraet H03 0030
 Revision: 00300003 Serial number: W040312180022
 Coding: 0065150
 VCID: 2708F11E73E7531F4C9-8072
 Component: Heckdeckel H06 0060
 Component: Neigungssensor H02 0020
 6 Faults Found:
 009 - Open or Short to Ground
 Fault Status: 01101001
 Reset counter: 193
 Mileage: 213427 km
 Date: 2003.10.09
 Time: 20:24:59
 01134 - Alarm Horn (H12)
 Reset counter: 102
 Mileage: 219722 km
 Date: 2016.01.03
 Time: 16:39:11
 01829 - Bulb for Tail-Lamp; Right
 Fault Status: 00101001
 Reset counter: 197
 Mileage: 223044 km
 Date: 2003.10.10
 Time: 05:43:04
 Reset counter: 102
 Mileage: 219722 km
 Date: 2016.01.03
 Time: 16:39:11
 01828 - Bulb for Tail-Lamp; Left
 Reset counter: 197
 Mileage: 223044 km
 Date: 2003.10.10
 Time: 05:43:04
 01503 - Bulb for 3rd Brake Light (M25)
 Reset counter: 200
 Mileage: 223170 km
 Date: 2003.10.09
 Time: 21:56:15
 Address 47: Sound System
 Address 4F: Centr. Electr. II Labels: None
 Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
 Component: ILM Beifahrer H08 0020
 Revision: Serial number: 00000000031180
 Coding: 0010111
 VCID: 1E66D4FA2CBD92D73FF-804A
 Subsystem 1 - Part No: 4E0 910 511 A
 Component: UGDO HL US H02 0030
 Subsystem 2 - Serial number: VK4978T0B79E
 Fault Status: 00110010
 Reset counter: 221
 Mileage: 224580 km
 Date: 2003.10.08
 Time: 08:36:00
 Fault Frequency: 20
 Reset counter: 221
 Mileage: 224040 km
 Date: 2003.10.14
 Time: 09:34:00
 Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
 Part No SW: 4E1 910 802 HW: 4E1 959 802
 Component: Türsteuer.BF BRM007 0110
 Coding: 0028196
 Reset counter: 221
 Mileage: 224576 km
 Date: 2003.10.08
 Time: 08:36:08
 Address 53: Parking Brake Labels: 4E0-910-801.clb
 Part No SW: 4E0 910 801 A HW: 4E0 907 801
 Component: EPB AV1C1010 H01 1010
 Revision: AV1C1010
 Coding: 0000532
 Shop #: WSC 24103 444 52497
 Fault Status: 00101101
 Fault Frequency: 23
 Reset counter: 233
 Mileage: 226304 km
 Date: 2003.10.08
 Time: 02:41:30
 Voltage: 13.04 V
 Count: 236
 02596 - Rear Brake Pads Worn
 Fault Status: 01111000
 Reset counter: 192
 Voltage: 10.35 V
 Count: 61
 Address 55: Headlight Range Labels: 4E0-910-357.lbl
 Part No SW: 4E0 910 357 HW: 4E0 907 357
 Component: Pre-AFS H01 0040
 VCID: 629EA00A5845F6375B7-8036
 Fault Frequency: 0
 Reset counter: 203
 Mileage: 223048 km
 Date: 2003.10.08
 Time: 00:42:50
 00070 - Starting Battery Voltage
 Reset counter: 180
 Mileage: 223176 km
 Date: 2003.10.09
 Time: 21:55:27
 02233 - Left Headlight Power Output Stage (J667)
 Fault Frequency: 0
 Reset counter: 40
 Mileage: 223176 km
 Date: 2003.10.09
 Time: 21:55:27
 Fault Frequency: 0
 Reset counter: 203
 Mileage: 223048 km
 Date: 2003.10.08
 Time: 00:42:50
 Fault Frequency: 0
 Reset counter: 40
 Mileage: 223176 km
 Date: 2003.10.09
 Time: 21:55:27
 Address 56: Radio
 Address 61: Battery Regul. Labels: 4E0-910-181.lbl
 Part No SW: 4E0 910 181 B HW: 4E0 915 181
 Component: ENERGIEMANAGER H02 0240
 Revision: 00000000 Serial number: 00000006225939
 Shop #: WSC 24101 444 01039
 VCID: 1F18E9FE2BB79BDF349-804A
 Subsystem 1 - Part No: 000 915 105 AK
 Component: von VA0 1401010139
 Coding: 303030393135313035414B56413031343031303130313339
 Shop #: WSC 00000 128 00289
 02272 - Quiescent Current Stage 1
 Fault Frequency: 9
 Mileage: 222857 km
 Date: 2003.10.09
 Time: 05:31:04
 Fault Frequency: 71
 Mileage: 222857 km
 Date: 2003.10.09
 Time: 05:34:15
 02276 - Quiescent Current Stage 5
 Fault Frequency: 65
 Mileage: 222857 km
 Date: 2003.10.09
 Time: 05:34:25
 Mileage: 226361 km
 Date: 2003.10.08
 Time: 03:21:37
 Reset counter: 232
 Mileage: 224042 km
 Date: 2003.10.14
 Time: 09:35:28
 Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
 Part No SW: 4E0 910 802 HW: 4E0 959 801 A
 Component: Türsteuer.HL BRM007 0110
 Coding: 0028196
 VCID: 5DE493F6613BC9CF665-8008
 Reset counter: 232
 Address 65: Tire Pressure Labels: 4E0-910-273.lbl
 Part No SW: 4E0 910 273 HW: 4E0 907 273
 Component: Reifendruck 2 H01 0210
 Coding: 0212127
 VCID: 5F98A9FE6B37DBDF749-800A
 Fault Status: 10100010
 Reset counter: 212
 Mileage: 224042 km
 Date: 2003.10.14
 Time: 09:34:26
 Speed: 255.0 km/h
 Voltage: 8.10 V
 (no units): 42.0
 Not Recogn.
 Not Recogn.
 Not Recogn.
 Not Recogn.
 01477 - System Switched Off
 Reset counter: 233
 Mileage: 226310 km
 Date: 2003.10.08
 Time: 02:19:04
 Temperature: 0.0°C
 Error Code: 0
 Not Recogn.
 Not Recogn.
 Not Recogn.
 Not Recogn.
 Fault Status: 10100100
 Fault Frequency: 24
 Reset counter: 233
 Mileage: 224572 km
 Date: 2003.10.08
 Time: 00:47:55
 Speed: 17.0 km/h
 Temperature: -9.0°C
 Error Code: 32768
 Not Recogn.
 Not Recogn.
 Not Recogn.
 Not Recogn.
 Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
 Part No SW: 4E0 910 802 HW: 4E0 959 802 A
 Component: Türsteuer.HR BRM007 0110
 Coding: 0028196
 01482 - Motors for Central Locking
 Fault Status: 00100110
 Reset counter: 202
 Mileage: 223216 km
 Date: 2003.10.10
 Time: 19:05:06
 Reset counter: 221
 Mileage: 224576 km
 Date: 2003.10.08
 Time: 08:36:08
 Reset counter: 230
 Mileage: 225984 km
 Date: 2003.10.09
 Time: 03:13:10
 Address 75: Telematics Labels: None
 Part No SW: 4E0 910 616 HW: 4E0 035 616 A
 Component: Telematik USA1 0070
 Revision: 00000004 Serial number: 0000ATD3007687
 Coding: 0000005
 VCID: 609AAA025659E4274D3-513C
 01531 - Emergency Battery
 Address 76: Park Assist Labels: 4E0-910-283.lbl
 Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
 Component: Parkhilfe 8-Kan H11 0010
 Revision: --.--.-- Serial number: 00000400900020
 Coding: 0001208
 VCID: 211CEF061DC3AD2F02D-8074
 Reset counter: 232
 Mileage: 223170 km
 Date: 2003.10.09
 Time: 23:20:14
 Reset counter: 217
 Mileage: 224042 km
 Date: 2003.10.14
 Time: 09:34:14
 Reset counter: 199
 Mileage: 223170 km
 Date: 2003.10.09
 Time: 21:55:41
 End----------(Elapsed Time: 01:59, VBatt start/end: 11.6V/11.6V)-----------
sheed44 is online now Report Post
I'm not sure what you did that trimmed all the white-space from the scan before you posted it, but it's rather difficult to read the way it's formatted.
You have a boatload of fault codes, some of which appear to have been in the car for a long time, and many of which are flagged "Intermittent", meaning that the fault condition that set the code did not exist (or could not be detected) at the time the scan was done.
The first thing I would do with this car is clear all the fault codes, then see what comes back.
tuningbyamg
Canada
C?ID=230173
I 2nd what Uwe says, too may codes and not sure which are actually relevant.
This is a very sophisticated car you bought and taking it to a garage is probably not an option, i wouldn't...
Please clear all DTC's and post another scan
sheed44
C?ID=297477
Hey, so I ran the scan and cleared the codes then it continues the auto-scan function again so I couldn't get an accurate read on the codes, 2ndly it seems the codes are in conjunction with the little date and time in the left-hand corner of the instrument cluster as that is the time and date on it, the car does have plenty of issues one is if I let it sit for a few hours the battery will be weak and the car wont start so to combat this until I figure out whats wrong I disconnect the neg cable when I exit the vehicle for long periods of time.
sheed44
C?ID=297477
VIN: WAUML44E04N018154   Mileage: 226570km-140784miles
sheed44
C?ID=297477
Scan done aftr cleared DTC's
VIN: WAUML44E04N018154   Mileage: 226580km-140790miles
   Coding: 0007773
            P1653 - 008 -
                    Mileage: 226579 km
                    RPM: 692 /min
                    Load: 20.0 %
                    Temperature: 57.0°C
                    Temperature: 12.0°C
                    Voltage: 13.335 V
                    Mileage: 226579 km
                    RPM: 690 /min
                    Load: 20.0 %
                    Temperature: 57.0°C
                    Temperature: 12.0°C
                    Voltage: 13.843 V
                    Mileage: 226579 km
                    RPM: 690 /min
                    Load: 20.0 %
                    Temperature: 57.0°C
                    Temperature: 12.0°C
                    Voltage: 13.843 V
   Coding: 0007597
   Coding: 0263168
   Coding: 3940448
   Coding: 1085761
   Coding: 0111113
   Coding: 00000036
   Shop #: WSC 02313
                    Reset counter: 195
                    Mileage: 226579 km
                    Date: 2003.10.08
                    Time: 08:20:12
                    Reset counter: 195
                    Mileage: 226579 km
                    Date: 2003.10.08
                    Time: 08:20:12
                    Reset counter: 195
                    Mileage: 226579 km
                    Date: 2003.10.08
                    Time: 08:20:13
   Coding: 0530707
   Coding: 0012241
   Coding: 0016203
                    Reset counter: 195
                    Mileage: 226581 km
                    Date: 2003.10.08
                    Time: 08:41:58
   Coding: 0263168
   Coding: 0015510
                    Reset counter: 195
                    Mileage: 226581 km
                    Date: 2003.10.08
                    Time: 08:42:33
                    Fault Status: 11101000
                    Reset counter: 195
                    Mileage: 226581 km
                    Date: 2003.10.08
                    Time: 08:42:26
                    Reset counter: 235
                    Mileage: 226579 km
                    Date: 2003.10.08
                    Time: 08:39:01
   Coding: 4071522
   Coding: 0003989
   Coding: 0028196
   Coding: 0065150
                    Reset counter: 195
                    Mileage: 213427 km
                    Date: 2003.10.09
                    Time: 20:24:59
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
   Coding: 0010111
   Coding: 0028196
                    Reset counter: 195
                    Mileage: 226576 km
                    Date: 2003.10.08
                    Time: 08:31:54
   Revision: AV1C1010
   Coding: 0000532
                    Reset counter: 235
                    Mileage: 226576 km
                    Date: 2003.10.08
                    Time: 08:38:05
                    Voltage: 13.04 V
                    Count: 236
                    Reset counter: 192
                    Voltage: 10.35 V
                    Count: 61
Address 56: Radio
   Coding: 0028196
                    Reset counter: 195
                    Mileage: 226576 km
                    Date: 2003.10.08
                    Time: 08:32:38
   Coding: 0212127
                    Reset counter: 195
                    Mileage: 226579 km
                    Date: 2003.10.08
                    Time: 08:32:24
                    Temperature: 1.0°C
                    Error Code: 32768
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   Coding: 0000005
   Coding: 0001208
End----------(Elapsed Time: 01:53, VBatt start/end: 11.4V/11.5V)-----------
OK, that's some progress, and far easier to read than the first scan you posted.
It looks like your whole MMI system is off-line. Please do:
[Applications]
[Optical Bus Diagnostics]
... and post the result.
As for the rest of the scan results, if I were going to chase things on the basis of low-cost, I'd check the fuse(s) for the ABS valve supply voltage and inspect the wiring for the right front ABS wheel speed sensor.
You might also want to inspect the rear brake pads to see if they really are worn down low, or if whomever replaced them didn't know how to get rid of that fault in the EPB (addresse 53).
You may want to inspect the ignition switch for burn down..........
sheed44
C?ID=297477
ok thank you I will do the MMI scan, also I don't have the owners manual so im not sure as to what all of the fuse locations stand for its open spaces in both of the rear fuel boxes haven't been able to find a diagrams with specific locations and fuse requirements.
sheed44
C?ID=297477
so I did the Optical bus diagnostic and these were the results
Thursday,26,January,2017,09:50:04:42098
VCDS Version: Release 17.1.2 (x64)
Control Module Part Number: 4E0 910 468 A
  Component and/or Version: Gateway         H07 0030
Optical Bus Diagnostic : Standard
Controller          	Electrical          	Optical
19-CAN Gateway      	OK                  	ERROR
07-Control Head(High/D3)	OK                  	OK
0E-Media Player 1   	ERROR               	ERROR
47-Sound System     	OK                  	OK
56-Radio            	OK                  	OK
37-Navigation       	OK                  	OK
mattylondon
United Kingdom
C?ID=219022
2nd document in this link. Also lot's of other reading material there.
http://forum.a8parts.co.uk/showthread.php?t=9347
Check voltage supply to Media Player 1. I think this is your CD changer, but I'm not certain. If supply is all good, get an optical loop bypass gizmo (part number 4E0 973 802) and plug it in place of Media player 1 to see if your MMI will then come up.
sheed44
C?ID=297477
Thank you, the CD changer doesn't light up or even make a noise at all, and the screen is stuck in the up position and only comes with the Audi display and then cuts back off,
sheed44
C?ID=297477
mattylondon
United Kingdom
C?ID=219022
If that's dead then a used CD unit will need component protection removed to work in your car. How desperate are you to have CDs? I ask because you can swap this for the AMI unit (ipod, USB MP3's etc..) which has no CP. Essentially a 10 minute job just by dropping the glove box and switching units and using the same connections.
Here's a used AMI, if a little overpriced... I have part number 4E0035785C AMI in my A8
http://www.ebay.com/itm/152345285646?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
For the time being, add a MOST loop and bridge the media player. Then remove it from the installation list and you should be good to go. You can still install a new/used one or an aftermarket accessory later.
BostonSlaya
Rhode Island, USA
C?ID=240768
If you need any help at all I will say ask me for sure I have been fighting this battle with the same car and now it is in great working condition. Thanks to Uwe and Golf for all the great thoughts and ideas. I will say be prepared for some hard work and long hours to get this car in perfect working condition. I know now I will never buy another Audi without having VCDS by my side lol.. Most of these issues I can help guide you through any of the process and kind of give them a little brake lol.. I will start helping with another reply so it will be easier to read for you.
BostonSlaya
Rhode Island, USA
C?ID=240768
Like most people stated on your thread I would purchase at lease 2 Loops for your data bus it's nice to have an extra for the future but also great for running a diagnostics on the data bus. Erwin is your best friend for sure, I do have some PDF's I could share from Erwin when I purchased it Delete repeated word is expensive but much cheaper then going to the Stealers.... That is of course if that is OK with Uwe not sure if I'm allowed to share what I have from Erwin on the Thread?? Anyways for your Motor mount issue that was a problem from the start with the electronic Motor mounts and Audi created a plug special for them, I had to use a couple of them to get the codes replaced, I would just look at the mounts visually.. That is as far as I go for now until you get some progress on your data bus and I will continue to help...
This will help// Engine
1) Engine mount there is a plug that bypasses this DTC and if needed I can locate that part number for you tomorrow sometime.
