Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: NEW TO AUDI NEW TO VCDS NEED SERIOUS HELP!!!
    Jan 2017
    Question NEW TO AUDI NEW TO VCDS NEED SERIOUS HELP!!!
    Hello so I just purchased this used 2004 Audi A8 with 135,000 miles on it and noticed some things off with it so instead of taking it to the dealership I opted to purchase the VagCom from Ross Tech I scanned my vehicle and now need a little help figuring out exactly what all the data is so I can start repairs from cheapest to most expensive PLEASE HELP.
     Tuesday,24,January,2017,10:30:48:42098
     VCDS Version: 17.1.2.0 (x64) HEX-V2 CB: 0.4334.4
     Data version: 20170107 DS267.0
     VIN: WAUML44E04N018154 License Plate:
     Mileage: 226430km-140697mi Repair Order:
     Chassis Type: 4E (4E0)
     Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
     47 4F 52 53 55 56 61 62 65 72 75 76
     VIN: WAUML44E04N018154 Mileage: 226430km-140697miles
     07-Control Head -- Status: Cannot be reached 1100
     0E-Media Player 1 -- Status: Cannot be reached 1100
     Address 01: Engine Labels: None
     Part No SW: 4E0 910 560 P HW: 4E0 907 560
     Component: 4.2L V8/5V G 0020
     Revision: -------- Serial number: AUX3Z0D0532489
     Coding: 0007773
     Shop #: WSC 24103 444 84355
     VCID: 2E06043A5C1D02578FF-807A
     18061 - Please check DTC Memory of ABS Controller
     P1653 - 008 -
     Mileage: 226432 km
     RPM: 690 /min
     Load: 19.6 %
     Temperature: 63.0°C
     Temperature: 15.0°C
     Absolute Pres.: 0.0 mbar
     Voltage: 13.970 V
     17981 - Left Engine Mount Solenoid Valve (N144)
     P1573 - 004 - Open Circuit
     Mileage: 226432 km
     RPM: 663 /min
     Load: 19.6 %
     Temperature: 63.0°C
     Temperature: 15.0°C
     Voltage: 14.097 V
     17985 - Right Engine Mount Solenoid Valve (N145)
     P1577 - 004 - Open Circuit
     Mileage: 226432 km
     RPM: 582 /min
     Load: 27.4 %
     Temperature: 84.0°C
     Temperature: 34.0°C
     Voltage: 14.097 V
     Readiness: 0010 1100
     Part No SW: 4E0 910 156 E HW: 09E 927 156 A
     Component: AG6 09E 4,2L5V USA 0110
     Revision: 00000001 Serial number: 0028405
     Shop #: WSC 02313 785 00200
     VCID: 2412E61202D1B80769B-8070
     Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
     Component: ESP 5.7 allrad H44 0500
     Coding: 0007597
     Shop #: WSC 24103 000 00000
     VCID: 221EE00A18C5B6371B7-8076
     01200 - ABS Valves Supply Voltage
     Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
     Part No SW: 4E0 910 131 HW: 4E0 909 131 A
     Component: FBS AUDID3 H03 0140
     Revision: 01403903 Serial number: AUX3Z0D0532489
     Coding: 0263168
     Shop #: WSC 02311 785 00200
     VCID: 58EA82E20E192CE7353-800C
     Component: ELV XXXX
     Address 06: Seat Mem. Pass Labels: None
     Part No SW: 4E0 910 760 C HW: 4E0 959 760
     Component: Sitzmemory BFS H07 0060
     Revision: 00000000 Serial number: 5DS 008 795-03
     Coding: 3940448
     VCID: 2310E50E07DFBF3F101-8076
     Address 07: Control Head
     Part No SW: 4E0 910 043 HW: 4E0 820 043 B
     Component: KLIMAAUTOMAT 016 0240
     Revision: 00000022 Serial number: 00000000034086
     Coding: 1085761
     VCID: 5AEE98EA70153EF7037-800E
     Subsystem 1 - Part No: 4E0 910 772 A
     Component: Sitzluefter FS H02 010
     Subsystem 2 - Part No: 4E0 910 772 A
     Component: Sitzluefter BFS H02 010
     Subsystem 3 - Serial number: 898053000
     Subsystem 4 - Serial number: HO16012004065A000000000424˙†89
     Subsystem 5 - Serial number: 000424˙†898053000 000-SHO
     Subsystem 6 - Serial number: 000-SHO16012004065A00000000
     Subsystem 7 - Serial number: 65A000000000467˙
     Fault Frequency: 16
     Reset counter: 232
     Mileage: 223215 km
     Date: 2003.10.10
     Time: 16:26:34
     01232 - A/C Compressor Regulator Valve (N280)
     Fault Status: 00101010
     Reset counter: 219
     Mileage: 224444 km
     Date: 2003.10.08
     Time: 08:31:31
     Load: 90.0 %
     Current: 0.000 A
     Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
     Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
     Component: ILM Fahrer H11 0100
     Coding: 0111113
     VCID: 2A0E082A60F56E77537-807E
     Subsystem 1 - Part No: 4E1 910 113 B
     Component: Wischer WWS D3 H40 0380
     Coding: 00000036
     Shop #: WSC 02313
     Fault Status: 01101010
     Reset counter: 193
     Mileage: 226432 km
     Date: 2003.10.08
     Time: 00:01:53
     Reset counter: 232
     Mileage: 226310 km
     Date: 2003.10.08
     Time: 15:47:41
     Reset counter: 193
     Mileage: 226432 km
     Date: 2003.10.08
     Time: 00:01:54
     02071 - Local Databus
     Reset counter: 232
     Reset counter: 193
     Mileage: 226432 km
     Date: 2003.10.08
     Time: 00:01:57
     Address 0E: Media Player 1
     Address 15: Airbags Labels: 4E0-910-655-84.lbl
     Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
     Component: Airbag 8.4E+ H10 0920
     Coding: 0530707
     Address 16: Steering wheel Labels: 4E0-910-549.lbl
     Part No SW: 4E0 910 549 HW: 4E0 953 549 A
     Coding: 0012241
     VCID: 6594BB16496B810FBE5-8030
     Component: Lenkradmodul H04 0080
     Fault Status: 01100010
     Fault Frequency: 14
     Mileage: 223170 km
     Date: 2003.10.09
     Time: 22:03:47
     00532 - Supply Voltage B+
     Reset counter: 233
     Fault Status: 00101110
     Reset counter: 233
     Date: 2063.15.31
     Time: 31:63:18
     Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
     Part No SW: 4E0 910 900 HW: 4E0 920 950 B
     Component: KOMBIINSTR. VDO H44 0090
     Revision: D15 Serial number: AUDID3D0006575
     Coding: 0016203
     VCID: 5CE29EF27A21C0C711B-8008
     Address 19: CAN Gateway Labels: 4E0-910-468.clb
     Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
     Component: Gateway H07 0030
     Revision: 07 Serial number: 0200503C08128A
     Coding: FCFE7BDD1B2304
     VCID: 2616FC1A74ED4A1777F-8072
     00384 - Optical Databus
     Reset counter: 193
     Mileage: 226432 km
     Date: 2003.10.08
     Time: 00:30:10
     Address 25: Immobilizer Labels: 4E0-910-131.lbl
     Coding: 0263168
     Component: ELV XXXX
     XXXXXXXXXXX ELV XXXX
     Address 34: Level Control Labels: 4E0-910-553.lbl
     Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
     Component: LUFTFDR.-CDC H05 4290
     Coding: 0015510
     VCID: 2514FB1609EB410F7E5-8070
     8 Faults Found:
     Fault Frequency: 109
     Reset counter: 233
     Mileage: 222857 km
     Date: 2003.10.09
     Time: 05:46:40
     01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
     Fault Status: 11101010
     Fault Frequency: 106
     Reset counter: 193
     Mileage: 222857 km
     Date: 2003.10.09
     Time: 05:46:48
     01772 - Signal from Level Control Pressure Sensor (G291)
     Fault Frequency: 81
     Reset counter: 168
     Mileage: 222858 km
     Date: 2003.10.09
     Time: 05:49:09
     01400 - Suspension Level Control
     Fault Frequency: 10
     Reset counter: 222
     Mileage: 224136 km
     Date: 2003.10.14
     Time: 19:28:06
     01598 - Drive Battery Voltage
     Reset counter: 0
     Mileage: 226310 km
     Date: 2003.10.08
     Time: 15:48:19
     Reset counter: 220
     Mileage: 223170 km
     Date: 2003.10.09
     Time: 21:56:01
     01398 - Signal Conductor for Central Locking; Doors Open
     Reset counter: 232
     Mileage: 223175 km
     Date: 2003.10.10
     Time: 15:18:29
     01487 - System Function Test
     Reset counter: 209
     Component: Sitzmemory FS H07 0060
     Coding: 4071522
     Reset counter: 232
     Mileage: 224580 km
     Date: 2012.11.17
     Time: 08:36:01
     Address 37: Navigation
     Address 38: Roof Electronics Labels: 4E0-910-135.lbl
     Part No SW: 4E0 910 135 A HW: 4E0 907 135
     Component: Dachknoten D3 H01 0090
     Serial number: 00000334300180
     Coding: 0003989
     VCID: 1D64D3F621BB89CF265-8048
     Reset counter: 221
     Mileage: 224296 km
     00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
     Reset counter: 217
     Mileage: 224232 km
     Date: 2003.10.15
     Time: 18:37:00
     00410 - Pre-Selection Signal for Opening Sunroof
     Fault Status: 00100111
     Fault Frequency: 15
     Reset counter: 224
     Mileage: 225436 km
     Date: 2003.10.08
     Time: 00:41:00
     Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
     Part No SW: 4E1 910 802 HW: 4E1 959 801
     Component: Türsteuer.FS BRM005 0110
     Coding: 0028196
     VCID: 5EE694FA6C3DD2D77FF-800A
     Reset counter: 221
     Mileage: 224576 km
     Date: 2003.10.08
     Time: 08:36:08
     02111 - Motor for Window Regulator
     Reset counter: 221
     Mileage: 224576 km
     Date: 2003.10.08
     Time: 08:36:28
     Reset counter: 221
     Mileage: 224576 km
     Date: 2003.10.08
     Time: 08:36:28
     Address 46: Central Conv. Labels: 4E0-910-289.lbl
     Part No SW: 4E0 910 289 A HW: 4E0 907 289
     Component: Komfortgeraet H03 0030
     Revision: 00300003 Serial number: W040312180022
     Coding: 0065150
     VCID: 2708F11E73E7531F4C9-8072
     Component: Heckdeckel H06 0060
     Component: Neigungssensor H02 0020
     6 Faults Found:
     009 - Open or Short to Ground
     Fault Status: 01101001
     Reset counter: 193
     Mileage: 213427 km
     Date: 2003.10.09
     Time: 20:24:59
     01134 - Alarm Horn (H12)
     Reset counter: 102
     Mileage: 219722 km
     Date: 2016.01.03
     Time: 16:39:11
     01829 - Bulb for Tail-Lamp; Right
     Fault Status: 00101001
     Reset counter: 197
     Mileage: 223044 km
     Date: 2003.10.10
     Time: 05:43:04
     Reset counter: 102
     Mileage: 219722 km
     Date: 2016.01.03
     Time: 16:39:11
     01828 - Bulb for Tail-Lamp; Left
     Reset counter: 197
     Mileage: 223044 km
     Date: 2003.10.10
     Time: 05:43:04
     01503 - Bulb for 3rd Brake Light (M25)
     Reset counter: 200
     Mileage: 223170 km
     Date: 2003.10.09
     Time: 21:56:15
     Address 47: Sound System
     Address 4F: Centr. Electr. II Labels: None
     Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
     Component: ILM Beifahrer H08 0020
     Revision: Serial number: 00000000031180
     Coding: 0010111
     VCID: 1E66D4FA2CBD92D73FF-804A
     Subsystem 1 - Part No: 4E0 910 511 A
     Component: UGDO HL US H02 0030
     Subsystem 2 - Serial number: VK4978T0B79E
     Fault Status: 00110010
     Reset counter: 221
     Mileage: 224580 km
     Date: 2003.10.08
     Time: 08:36:00
     Fault Frequency: 20
     Reset counter: 221
     Mileage: 224040 km
     Date: 2003.10.14
     Time: 09:34:00
     Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
     Part No SW: 4E1 910 802 HW: 4E1 959 802
     Component: Türsteuer.BF BRM007 0110
     Coding: 0028196
     Reset counter: 221
     Mileage: 224576 km
     Date: 2003.10.08
     Time: 08:36:08
     Address 53: Parking Brake Labels: 4E0-910-801.clb
     Part No SW: 4E0 910 801 A HW: 4E0 907 801
     Component: EPB AV1C1010 H01 1010
     Revision: AV1C1010
     Coding: 0000532
     Shop #: WSC 24103 444 52497
     Fault Status: 00101101
     Fault Frequency: 23
     Reset counter: 233
     Mileage: 226304 km
     Date: 2003.10.08
     Time: 02:41:30
     Voltage: 13.04 V
     Count: 236
     02596 - Rear Brake Pads Worn
     Fault Status: 01111000
     Reset counter: 192
     Voltage: 10.35 V
     Count: 61
     Address 55: Headlight Range Labels: 4E0-910-357.lbl
     Part No SW: 4E0 910 357 HW: 4E0 907 357
     Component: Pre-AFS H01 0040
     VCID: 629EA00A5845F6375B7-8036
     Fault Frequency: 0
     Reset counter: 203
     Mileage: 223048 km
     Date: 2003.10.08
     Time: 00:42:50
     00070 - Starting Battery Voltage
     Reset counter: 180
     Mileage: 223176 km
     Date: 2003.10.09
     Time: 21:55:27
     02233 - Left Headlight Power Output Stage (J667)
     Fault Frequency: 0
     Reset counter: 40
     Mileage: 223176 km
     Date: 2003.10.09
     Time: 21:55:27
     Fault Frequency: 0
     Reset counter: 203
     Mileage: 223048 km
     Date: 2003.10.08
     Time: 00:42:50
     Fault Frequency: 0
     Reset counter: 40
     Mileage: 223176 km
     Date: 2003.10.09
     Time: 21:55:27
     Address 56: Radio
     Address 61: Battery Regul. Labels: 4E0-910-181.lbl
     Part No SW: 4E0 910 181 B HW: 4E0 915 181
     Component: ENERGIEMANAGER H02 0240
     Revision: 00000000 Serial number: 00000006225939
     Shop #: WSC 24101 444 01039
     VCID: 1F18E9FE2BB79BDF349-804A
     Subsystem 1 - Part No: 000 915 105 AK
     Component: von VA0 1401010139
     Coding: 303030393135313035414B56413031343031303130313339
     Shop #: WSC 00000 128 00289
     02272 - Quiescent Current Stage 1
     Fault Frequency: 9
     Mileage: 222857 km
     Date: 2003.10.09
     Time: 05:31:04
     Fault Frequency: 71
     Mileage: 222857 km
     Date: 2003.10.09
     Time: 05:34:15
     02276 - Quiescent Current Stage 5
     Fault Frequency: 65
     Mileage: 222857 km
     Date: 2003.10.09
     Time: 05:34:25
     Mileage: 226361 km
     Date: 2003.10.08
     Time: 03:21:37
     Reset counter: 232
     Mileage: 224042 km
     Date: 2003.10.14
     Time: 09:35:28
     Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
     Part No SW: 4E0 910 802 HW: 4E0 959 801 A
     Component: Türsteuer.HL BRM007 0110
     Coding: 0028196
     VCID: 5DE493F6613BC9CF665-8008
     Reset counter: 232
     Address 65: Tire Pressure Labels: 4E0-910-273.lbl
     Part No SW: 4E0 910 273 HW: 4E0 907 273
     Component: Reifendruck 2 H01 0210
     Coding: 0212127
     VCID: 5F98A9FE6B37DBDF749-800A
     Fault Status: 10100010
     Reset counter: 212
     Mileage: 224042 km
     Date: 2003.10.14
     Time: 09:34:26
     Speed: 255.0 km/h
     Voltage: 8.10 V
     (no units): 42.0
     Not Recogn.
     Not Recogn.
     Not Recogn.
     Not Recogn.
     01477 - System Switched Off
     Reset counter: 233
     Mileage: 226310 km
     Date: 2003.10.08
     Time: 02:19:04
     Temperature: 0.0°C
     Error Code: 0
     Not Recogn.
     Not Recogn.
     Not Recogn.
     Not Recogn.
     Fault Status: 10100100
     Fault Frequency: 24
     Reset counter: 233
     Mileage: 224572 km
     Date: 2003.10.08
     Time: 00:47:55
     Speed: 17.0 km/h
     Temperature: -9.0°C
     Error Code: 32768
     Not Recogn.
     Not Recogn.
     Not Recogn.
     Not Recogn.
     Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
     Part No SW: 4E0 910 802 HW: 4E0 959 802 A
     Component: Türsteuer.HR BRM007 0110
     Coding: 0028196
     01482 - Motors for Central Locking
     Fault Status: 00100110
     Reset counter: 202
     Mileage: 223216 km
     Date: 2003.10.10
     Time: 19:05:06
     Reset counter: 221
     Mileage: 224576 km
     Date: 2003.10.08
     Time: 08:36:08
     Reset counter: 230
     Mileage: 225984 km
     Date: 2003.10.09
     Time: 03:13:10
     Address 75: Telematics Labels: None
     Part No SW: 4E0 910 616 HW: 4E0 035 616 A
     Component: Telematik USA1 0070
     Revision: 00000004 Serial number: 0000ATD3007687
     Coding: 0000005
     VCID: 609AAA025659E4274D3-513C
     01531 - Emergency Battery
     Address 76: Park Assist Labels: 4E0-910-283.lbl
     Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
     Component: Parkhilfe 8-Kan H11 0010
     Revision: --.--.-- Serial number: 00000400900020
     Coding: 0001208
     VCID: 211CEF061DC3AD2F02D-8074
     Reset counter: 232
     Mileage: 223170 km
     Date: 2003.10.09
     Time: 23:20:14
     Reset counter: 217
     Mileage: 224042 km
     Date: 2003.10.14
     Time: 09:34:14
     Reset counter: 199
     Mileage: 223170 km
     Date: 2003.10.09
     Time: 21:55:41
     End----------(Elapsed Time: 01:59, VBatt start/end: 11.6V/11.6V)-----------
    sheed44 is online now Report Post
    A good start is Erwin for the repair manuals and printing to PDF.
    Trace the WD and check fuses.
    In addition using the wiki to search DTC's maybe helpful.
    http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
    I'm not sure what you did that trimmed all the white-space from the scan before you posted it, but it's rather difficult to read the way it's formatted.
    You have a boatload of fault codes, some of which appear to have been in the car for a long time, and many of which are flagged "Intermittent", meaning that the fault condition that set the code did not exist (or could not be detected) at the time the scan was done.
    The first thing I would do with this car is clear all the fault codes, then see what comes back.
  4. Likes PetrolDave liked this post
    Oct 2016
    Canada
    I 2nd what Uwe says, too may codes and not sure which are actually relevant.
    This is a very sophisticated car you bought and taking it to a garage is probably not an option, i wouldn't...
    Please clear all DTC's and post another scan
    Jan 2017
    Hey, so I ran the scan and cleared the codes then it continues the auto-scan function again so I couldn't get an accurate read on the codes, 2ndly it seems the codes are in conjunction with the little date and time in the left-hand corner of the instrument cluster as that is the time and date on it, the car does have plenty of issues one is if I let it sit for a few hours the battery will be weak and the car wont start so to combat this until I figure out whats wrong I disconnect the neg cable when I exit the vehicle for long periods of time.
    Jan 2017
    VIN: WAUML44E04N018154   Mileage: 226570km-140784miles
    Jan 2017
    Scan done aftr cleared DTC's
    VIN: WAUML44E04N018154   Mileage: 226580km-140790miles
       Coding: 0007773
                P1653 - 008 -
                        Mileage: 226579 km
                        RPM: 692 /min
                        Load: 20.0 %
                        Temperature: 57.0°C
                        Temperature: 12.0°C
                        Voltage: 13.335 V
                        Mileage: 226579 km
                        RPM: 690 /min
                        Load: 20.0 %
                        Temperature: 57.0°C
                        Temperature: 12.0°C
                        Voltage: 13.843 V
                        Mileage: 226579 km
                        RPM: 690 /min
                        Load: 20.0 %
                        Temperature: 57.0°C
                        Temperature: 12.0°C
                        Voltage: 13.843 V
       Coding: 0007597
       Coding: 0263168
       Coding: 3940448
       Coding: 1085761
       Coding: 0111113
       Coding: 00000036
       Shop #: WSC 02313
                        Reset counter: 195
                        Mileage: 226579 km
                        Date: 2003.10.08
                        Time: 08:20:12
                        Reset counter: 195
                        Mileage: 226579 km
                        Date: 2003.10.08
                        Time: 08:20:12
                        Reset counter: 195
                        Mileage: 226579 km
                        Date: 2003.10.08
                        Time: 08:20:13
       Coding: 0530707
       Coding: 0012241
       Coding: 0016203
                        Reset counter: 195
                        Mileage: 226581 km
                        Date: 2003.10.08
                        Time: 08:41:58
       Coding: 0263168
       Coding: 0015510
                        Reset counter: 195
                        Mileage: 226581 km
                        Date: 2003.10.08
                        Time: 08:42:33
                        Fault Status: 11101000
                        Reset counter: 195
                        Mileage: 226581 km
                        Date: 2003.10.08
                        Time: 08:42:26
                        Reset counter: 235
                        Mileage: 226579 km
                        Date: 2003.10.08
                        Time: 08:39:01
       Coding: 4071522
       Coding: 0003989
       Coding: 0028196
       Coding: 0065150
                        Reset counter: 195
                        Mileage: 213427 km
                        Date: 2003.10.09
                        Time: 20:24:59
                        Reset counter: 102
                        Mileage: 219722 km
                        Date: 2016.01.03
                        Time: 16:39:11
                        Reset counter: 102
                        Mileage: 219722 km
                        Date: 2016.01.03
                        Time: 16:39:11
       Coding: 0010111
       Coding: 0028196
                        Reset counter: 195
                        Mileage: 226576 km
                        Date: 2003.10.08
                        Time: 08:31:54
       Revision: AV1C1010
       Coding: 0000532
                        Reset counter: 235
                        Mileage: 226576 km
                        Date: 2003.10.08
                        Time: 08:38:05
                        Voltage: 13.04 V
                        Count: 236
                        Reset counter: 192
                        Voltage: 10.35 V
                        Count: 61
    Address 56: Radio
       Coding: 0028196
                        Reset counter: 195
                        Mileage: 226576 km
                        Date: 2003.10.08
                        Time: 08:32:38
       Coding: 0212127
                        Reset counter: 195
                        Mileage: 226579 km
                        Date: 2003.10.08
                        Time: 08:32:24
                        Temperature: 1.0°C
                        Error Code: 32768
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Coding: 0028196
       Coding: 0000005
       Coding: 0001208
    End----------(Elapsed Time: 01:53, VBatt start/end: 11.4V/11.5V)-----------
  9. #8
    Quote Originally Posted by sheed44 View Post
    OK, that's some progress, and far easier to read than the first scan you posted.
    It looks like your whole MMI system is off-line. Please do:
    [Applications]
    [Optical Bus Diagnostics]
    ... and post the result.
    As for the rest of the scan results, if I were going to chase things on the basis of low-cost, I'd check the fuse(s) for the ABS valve supply voltage and inspect the wiring for the right front ABS wheel speed sensor.
    You might also want to inspect the rear brake pads to see if they really are worn down low, or if whomever replaced them didn't know how to get rid of that fault in the EPB (addresse 53).
  10. Likes tuningbyamg liked this post
  11. #9
    You may want to inspect the ignition switch for burn down..........
  12. #10
    Jan 2017
    How would I do that exactly?
