Wednesday,11,January,2017,19:52:15:63750
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
VIN: 3VW447AU4HM001660 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 2B 32 3C 42 44 47 52 55
5F 75 A9
VIN: 3VW447AU4HM001660 Mileage: 9066km-5633miles
Address 01: Engine (J623-CXCB) Labels: None
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00124464002F1000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM20TFS0205G0906259L 001003
ROD: N/A
VCID: 3753D7C18EB482F93E-8062
No ASAM data for: "EV_ECM20TFS0205G0906259L" (VW37)
Part No SW: 0D9 300 020 L HW: 02E 927 770 AQ
Component: DQ250-6V MQB H54 4902
Revision: 06354004 Serial number: TFK01605060956
ROD: EV_TCMDQ250021.rod
VCID: 1E1D2265014ED3B1DD-804A
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 61146000000330
Coding: 01FA6BA15420096D807D020641C36880D62A900140821636164350D1C08903
Shop #: WSC 01383 790 50316
VCID: 7BDB0BF1F21C66999A-802E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0405941843
Coding: 032C0C
VCID: 3B5BCBF1B29CA699DA-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 C HW: 5GM 907 044 C
Component: Climatronic H04 1601
Revision: 00001K03
Coding: 00020014200100010005000012111402
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 44A9B00DCF62D961AB-8010
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 865827061601SQ
Coding: 00111A464041A2E969E44000111407201800000000000000000000000000
Shop #: WSC 00066 790 00215
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 7AD50EF5FD265F9181-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160313 043 0581
Serial number: 160628183144
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S3Y16M05D13H20M34S18
Coding: 06A8DD
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000058959741
Sun Roof:
Subsystem 4 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03691610252212150843
Coding: 981E03
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 3500008141FFC428949C8045000016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: N/A
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 02051641350177
ROD: EV_DRCONTITEMIC.rod
VCID: 3851D4FD83AA8D8137-806C
Component: AirbagVW20 010 0830
Serial number: 003GCR04WAR2
VCID: 47B3A701FE54F2794E-8012
Occupant Detection:
Component: BF-Gewichtss. H12 0021
Serial number: IBH0000000000058WEBU
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 000 905 16
Serial number: 357000000005A6351B1E
Subsystem 3 - Part No SW: ----------- HW: 480 000 905 16
Serial number: 35800000000174351B16
Subsystem 4 - Part No SW: ----------- HW: 480 400 905 16
Serial number: 3510002AD2076341314M
Subsystem 5 - Part No SW: ----------- HW: 480 400 905 16
Serial number: 3520002B32076341D24P
Subsystem 6 - Part No SW: ----------- HW: 480 400 905 16
Serial number: 3550002AD207634510F
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 905 16
Serial number: 3560002AF2076340B2D3
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160620400545
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 0429700D8FE21961EB-8050
Part No SW: 5G1 920 856 B HW: 5G1 920 856 B
Component: KOMBI 344 8311
Coding: 0BAD091ABD88CF0502886A095000000000000000
VCID: 2D7FF5A97CE8382954-8078
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 11051610801526
Coding: 0101000830085900FB00023B9C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07026
ROD: EV_GatewConti_013.rod
VCID: 7CD908EDF71261A193-8028
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001533520025324
Coding: 35FFFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000096295006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 3449E0CD9FC269E11B-8060
Address 32: Differential Locks (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00009.04.16
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0403591538
Coding: 01011103
ROD: EV_HREntryHella.rod
VCID: 3C59C8EDB792A1A1D3-8068
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 170616060500LL
Coding: 003E13200000020000000000
VCID: 43ABB311CA6CDE5992-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Serial number: 00000000000012816121
Coding: 011000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
ROD: EV_SteerAssisMQB_VW31.rod
VCID: 3957D1F9B8A09489C8-806C
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0150
Revision: 00000001 Serial number: VWZ8Z1GBA01RNM.
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DFF35A9BC68F82914-8038
Component: TSG BFS 020 0041
Serial number: 170616060502MO
Coding: 003E13200C00020000000000
VCID: 42A5B615D576D75199-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Serial number: 00000000000012806768
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021203000B000400
VCID: 40A1BC1DDB7AC5418F-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0751
Coding: 027300020000000051220002001808009F0203F401200101C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3245E6D565D667D109-8066
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX0067E
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2823A017F5E06000000
ROD: EV_OCULowMQB.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 160420201269
ROD: EV_SoundActuaGen2AU64X_VW26.rod
VCID: 6BFB3BB1827CF6190A-803E
End-------------------------(Elapsed Time: 04:19)--------------------------
