Results 11 to 20 of 30
Thread: New Hex V2 user - need some help please
    Verified VCDS User Vasco Ferraz's Avatar
    Jan 2017
    Portugal
    I know that this can be really frustrating.
    Did you change the coding on the HVAC or Telephone modules?
    Do you have an old scan to compare?
    Vasco Ferraz
  2. #12
    Jan 2017
    It is haha and to answer your question i have never changed the coding on anything as not too sure whats what with it if that makes sense. And i have a scan that a guy did and he also couldnt pick up the bluetooth.. i will double check soon and upload the first original scan that i had done.
  3. #13
    Jan 2017
    Portugal
    Maybe 1 :
    The problem is in the voice control module and like Uwe said there is a bug in VCDS which won't let you communicate with Telephone module.
    Maybe 2:
    The problem is (also) in the voice control and that problem is causing the lack of communication with telephone module.
    I don't know if this can be done. But worth a try.
    Try to disconnect the voice control module (not sure if you already know where it is!) and see if with it disconnected you can communicate with telephone.
    Also, you can try the inverse:
    Try to disconnect the telephone and see if with it disconnected the voice control error can be erased.
    Vasco Ferraz
  4. #14
    Jan 2017
    Portugal
       Part No SW: 8P0 820 043 AH    HW: 8P0 820 043 AH
       Component: KlimavollautomatH19 0420
       Revision: 093439      Serial number: 8P0820043AH
       Shop #: WSC 06314 000 00000
       VCID: 72BED07FB8A3C3572B7-8026
    01301 - Control Module for Voice Recognition (J507)
                        Reset counter: 156
                        Mileage: 116961 km
                        Date: 2015.03.18
                        Time: 05:24:20
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0004012
       VCID: 41DC4FB3CD8528CF62D-8014
    I don't understand why this error is thrown in HVAC (and also in Steering wheel)!
    Any ideas?
    Vasco Ferraz
  5. #15
    Jan 2017
    Is there a way to sort out the bug in vcds? I dont actually know where the voice control module is to be honest. Do you happen to know.
    I have tried with the bluetooth module disconnected to erase rhe vlice control fault but it doesnt work :/
    Thanks for your quick replies too vasco 👍
  6. #16
    Jan 2017
    Portugal
    Hi. I also don't have any clue where the voice control module is.
    Are you sure that the voice control module is not the telephone module?
    Vasco Ferraz
  7. #17
    Jan 2017
    Well that what im not sure of tbh
  8. #18
    Apr 2016
    United Kingdom
    Language input control unit -J507- is a separate module. Usually next to the telephone/telematics control unit under the front seat. In VCDS it should be at 0x66, but does not appear in your autoscan?? Check fuses, water ingress. The fault was logged in 2015, has a previous owner been messing?
  9. Likes Vasco Ferraz liked this post
  10. #19
    Jan 2017
    Thanks for the reply matty.. looking at that picture.. i dont have that other box next to my bluetooth module. And no one else has messed with my car i.e with vcds however the 2015 is probably when it stopped working on me..
    No signs of any water ingress either so perhaps it may all be linked in to my bluetooth module?
  11. #20
    Jan 2017
    Just had a look at my scan again and the fault for my voice recognition module (j507) is under (auto hvac)
