Results 11 to 20 of 32
Thread: Advanced Measuring Values grayed out !
    Verified VCDS User GaryM's Avatar
    Nov 2014
    Oxford, UK
    Quote Originally Posted by Danners74 View Post
    Or just go get the car Remapped by a reputable software company. Ive had my update done.
    That is true but then it would mean the OP having to shell out 200-300 pounds of his/her own money to get their car running as they want it to again after VW ruined a car that doesn't actually belong to them with a so called emissions "fix".
  2. Likes PetrolDave, Uwe liked this post
  3. #12
    Nov 2016
    i have both scans.......but i should of had an ecu reading taken by someone then put back on the car if i wasnt happy.........+ the fact i cant check dpf reading anymore is not good at all....not only that......but ,i find sometimes revs a bit high...on 1,000 rpm exactly.......then drops, and feel shake/vibrations in the car.........and who knows if the dpf is going get blocked quicker than before.........vw should put it back standard
  4. #13
    Nov 2014
    Oxford, UK
    I would like to see one of the major European car magazines do an independent before and after dyno test on the results of the fix but so far I've yet to see anyone come forward. It would also be good to find out what the actual difference in emissions are pre and post fix are (on the road under real driving conditions to circumvent any cheat algorithms). VW certainly seem a bit coy in releasing any figures of their own which can really only mean one thing.
    I think you're lucky that your 2.0 TDI came through the update without any noticeable issues. It seems to be a bit of pot luck whether you end up with any post-fix issues or not and it's certainly not a gamble that I'm prepared to take. If it ain't broke, don't fix it, and mine certainly isn't broken so it won't be getting "fixed". If there was a legal requirement to do it or some kind of government incentive for getting it done (or a penalty for not getting it done) from an emissions point of view then it might be a different story but until then I see no real reason to have the update applied, unless you really do want a clear conscience that your car is putting out the lowest possible emissions (assuming that the pre and post emissions really are that significant). But that may be at the expense of a shortened engine life, DPF issues, or something else due to the software changes that have been made. Whichever way you look at it, there are certainly going to be downsides to having the update applied otherwise there would have been absolutely no need for VW to implement a cheat algorithm in the first place.
  5. Likes Uwe liked this post
  6. #14
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Quote Originally Posted by GaryM View Post
    Yes very very fella. Unfortunately i secumbed to the powers that be......but knowing what i have in stall for my CAYD Caddy 2k with AMD in the future im hoping i can get rid of the few quirks its picked up since. I use BP ultimate fuel........Shell Vpower is BUNK,Castrol Edge oil and genuine parts! So non of the corporate BS can be thrown my way.
    Just a wee note if i may but its not soley the VAG group hiding this.........BMW Mercedes all of them are doing it yet they havent been fingered just yet. I believe FIAT have been just recently......im none too sure
    Regards Danners.
    PS you Intergrale is MINT btw GaryM http://forums.ross-tech.com/images/icons/icon14.png
  7. #15
    I concur. Early on in the big emissions scandal thread (currently 175 posts) in the Bar, I said there's no way that VW is the only manufacturer engaged in "cycle beating".
    I may prune some of the posts from this thread and graft them onto that one at some point in the near futures, 'cause it seems there more topical there than here in Product Support.
  8. Likes PetrolDave liked this post
  9. #16
    Jun 2016
    Hi ther Uwe here is my post emission UPDATE scan from my Caddy showing the ROD files missing. I can not read soot loadings or anything. basic settings and adaptations also are greyed out. I do understand this is the latest VAG software and you're
    having to crack this. Hope this helps
    Sunday,22,January,2017,22:44:31:44004
    VCDS Version: 17.1.2.0 (x64)
    Data version: 20170107 DS267.0
    Dealer/Shop Name: Victoria Volkswagen.
    Workshop Code: 210 01843 000002
    VIN: WV1ZZZ2KZFX049623   License Plate: MY 2K
    Mileage: 30780km-19125mi   Repair Order:
                    Address 01: Engine       Labels: None
    Control Module Part Number: 03L 906 023 TF    HW: 03L 907 425 C
      Component and/or Version: R4 1.6l TDI   H43 9978
               Software Coding: 00114014032500080000
                Work Shop Code: WSC 35110 790 50316
                  ASAM Dataset: EV_ECM16TDI02103L906023TF 003002 (VN35)
                           ROD: N/A
                          VCID: 7DF644BFEC5A8AA988-8028
    No ASAM data for: "EV_ECM16TDI02103L906023TF" (VN35)
    Sunday,22,January,2017,22:44:57:44004
    Chassis Type: 2K (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 77
    VIN: WV1ZZZ2KZFX049623   Mileage: 30780km-19125miles
    Address 01: Engine (J623-CAYD)       Labels: None
       Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9978
       Revision: --H43---    Serial number: 00000000000000
       Shop #: WSC 35110 790 50316
       ROD: N/A
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: 433C400D09260303C21102E6901CC081A0000020
       Shop #: WSC 35110 377 08192
       VCID: 7EF443B3E95C91B191-802A
       Part No SW: 7N0 907 426 BT    HW: 7N0 907 426 BT
       Component: AC Manuell    H20 0607
       Revision: 00001004
       Coding: 0010004002
       VCID: 071A2657BE86D079A2-8052
       Part No SW: 5K0 937 086 S    HW: 5K0 937 086 S
       Component: BCM PQ35 M+   122 0174
       Revision: BD122001
       Coding: 491A583E8027F16A088800829000016403017288524F8160648000000040
       VCID: 4480F15BC7303B6187-8010
       Subsystem 1 - Part No: 1T2 955 119 A
       Component: Wischer 01091  26  0512
       Coding: 009795
       Subsystem 2 - Part No: 7N0 951 171 A
       Component: DWA-Sensor 00  002 0206
    Address 10: Park/Steer Assist (J446)       Labels: 1Q0-919-475.clb
       Part No SW: 2K0 919 475     HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0004
       Revision: --------    Serial number: 32901424703364
       Coding: 108001
       ASAM Dataset: EV_EPHVA14VN3370000 001006
       ROD: EV_EPHVA14VN3370000.rod
       VCID: 70E86D8BAB08F7C113-8024
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag02Q H07 0013
       Revision: --------    Serial number: 003HL00SLGEY
       Coding: 000000000000000000000000000000003251
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 35669C9F94EA92E900-8060
       Part No SW: 5K0 953 521 DN    HW: 5K0 953 569 AF
       Revision: FF010042    Serial number: 20140908201664
       Coding: 5080160000
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 7BF24AA7F24E8499B6-802E
       Part No SW: 2K0 920 976 E    HW: 2K0 920 976 E
       Component: KOMBI         H03 0905
       Coding: 480800
       ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
       VCID: 3362A2879A9E8CD92E-8066
       Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1653
       Revision:   H57       Serial number: 190914F2000561
       Coding: 357401
       Component: IMMO          H03 0905
       VCID: 6ADC7FE38DD40D115D-803E
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2110
       Coding: 0000560
       VCID: 4898E56B3B181F016B-801C
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 397E90AF70F27689E4-806C
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000560
       VCID: 479AE6573606107962-8012
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195 H    HW: 3C8 035 195 H
       Component: Radio RCD510  005 0246
       Revision: 00000001    Serial number: VWZ1Z3N1917145
       Coding: 09000200000013
       VCID: 2D56B4FF74BADA2978-8078
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
       Component: TELEFON       H16 4217
       Revision: 1B001001    Serial number: 00007666635990
       Coding: 0A01010000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3C7089BBB7C043A1FF-8068
    End-------------------------(Elapsed Time: 02:29)--------------------------
    Sunday,22,January,2017,22:46:30:44004
    Mode 9 : Calibration Identification
    Type 02 - VIN : WV1ZZZ2KZFX049623 (Address E8)
    Type 04 - Calibration ID : 03L906023TF 9978 (Address E8)
    Type 06 - Calibration Verification Number : D361ADB9 (Address E8)
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0B - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 13
        Ignition cycle count : 40
        Conditions completion count / Specificied conditions encountered count
             NMHC Catalyst : 0 / 0
             NOx/SCR Catalyst : 0 / 0
             NOx Adsorber : 0 / 0
             PM Filter : 2 / 0
             Exhaust Gas Sensor : 20 / 13
             EGR and/or VVT : 28 / 13
             Boost Pressure : 32 / 13
             Fuel : 32 / 13
    Sunday,22,January,2017,22:46:51:44004
             PM Filter : 2 / 0
             Fuel : 32 / 13
    old software
    Monday,26,December,2016,18:07:52:44004
    VCDS Version: 16.8.4.2 (x64)
    Data version: 20161129 DS267.0
    VIN: WV1ZZZ2KZFX049623   License Plate: GL64UKE
    Mileage: 29950km-18610mi   Repair Order:
    VIN: WV1ZZZ2KZFX049623   Mileage: 29950km-18610miles
    Address 01: Engine (J623-CAYD)       Labels: 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 PC    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 6928
       ASAM Dataset: EV_ECM16TDI02103L906023PC 003008
       ROD: EV_ECM16TDI02103L906023DB.rod
       VCID: 76E45B93C96CD9F2E3-8022
       Revision: 00H46001
       VCID: 7EF443B3E95C91B2BB-802A
       Revision: 00001004
       Coding: 0010004002
       VCID: 071A2657BE86D07A88-8052
       Revision: BD122001
       VCID: 4480F15BC7303B62AD-8010
       Coding: 009795
       Coding: 108001
       VCID: 70E86D8BAB08F7C239-8024
       VCID: 35669C9F94EA92EA2A-8060
       Coding: 5080160000
       VCID: 7BF24AA7F24E849A9C-802E
       Coding: 480800
       VCID: 3362A2879A9E8CDA04-8066
       Coding: 357401
       VCID: 6ADC7FE38DD40D1277-803E
       Coding: 0000560
       VCID: 4898E56B3B181F0241-801C
       Revision: 00H22000
       VCID: 397E90AF70F2768ACE-806C
       Coding: 0000560
       VCID: 479AE6573606107A48-8012
       VCID: 2D56B4FF74BADA2A52-8078
       VCID: 3C7089BBB7C043A2D5-8068
    End-------------------------(Elapsed Time: 02:27)--------------------------
    Hoping this helps regards Danners
  10. Likes Uwe, Eric, Dana liked this post
  11. #17
    Do you have a pre-update scan somewhere too?
  12. #18
    United States
    Thanks for adding the original info! It will help as we sort through the pile of SW part number changes!
  13. Likes Uwe liked this post
  14. #19
    Jun 2016
    some more for you all..........two infact.
    This is the two VW recall after updates..........no rod files.
    Wednesday,25,January,2017,17:01:54:44004
    VIN: WV2ZZZ2KZFX108806   License Plate: WATKINS
    Mileage: 85940km-53400mi   Repair Order:
    Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
    VIN: WV2ZZZ2KZFX108806   Mileage: 85940km-53400miles
    52-Door Elect, Pass. -- Status: Sporadic communication error 1000
       Coding: 00114010030500080000
       ROD: N/A
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: 633C400D09220302C61302E4901FC081A0000021
       Shop #: WSC 35110 377 00147
       VCID: 0400315B87B0FB61C7-8050
       Part No SW: 5K0 937 085 AA    HW: 5K0 937 085 AA
       Component: BCM PQ35 B+   122 0174
       Revision: BB122001
       Coding: 411A0A3A8025182B088000829000006403017288524F0160648000000040
       VCID: 72EC6783AD04C5D1E5-8026
       Component: Wischer 09021  26  0512
       Coding: 009795
    6 Faults Found:
    00897 - Windshield Washer Pump (V5)
                        Reset counter: 97
                        Mileage: 85727 km
                        Date: 2017.01.24
                        Time: 12:24:34
                        Voltage: 14.05 V
                        Reset counter: 97
                        Mileage: 85727 km
                        Date: 2017.01.24
                        Time: 12:24:34
                        Reset counter: 138
                        Mileage: 85758 km
                        Date: 2017.01.24
                        Time: 17:27:21
                            Term 15 Off
                        Voltage: 12.30 V
                010 - Open or Short to Plus
                        Reset counter: 138
                        Mileage: 85758 km
                        Date: 2017.01.24
                        Time: 17:27:21
    02391 - Terminal 30 Reference
                        Fault Status: 00101011
                        Reset counter: 138
                        Mileage: 85758 km
                        Date: 2017.01.24
                        Time: 17:29:58
                            Term 15 Off
                        Voltage: 12.45 V
    03396 - Supply voltage terminal 30 for central locking
                        Reset counter: 138
                        Mileage: 85758 km
                        Date: 2017.01.24
                        Time: 17:29:58
       Component: VW10Airbag02F H07 0013
       Revision: --------    Serial number: 003HL00V9NW7
       Coding: 000000000000000000000000000000003246
       Part No SW: 5K0 953 521 DK    HW: 5K0 953 569 AF
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20150201300002
       Coding: 1080060000
       VCID: 78F855ABC378AF81DB-802C
       Part No SW: 2K0 920 966 C    HW: 2K0 920 966 C
       Coding: 480201
       VCID: 3068AD8B6B88B7C153-8064
       Revision:   H57       Serial number: 110215F1001230
       Coding: 357401
                        Fault Status: 00110100
                        Reset counter: 138
                        Mileage: 85758 km
                        Date: 2017.01.24
                        Time: 17:27:18
    Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
       Part No: 1K0 959 793
       Component: Tuersteuergeraet 04 0174
       Coding: 0000000
       VCID: 76E45B93016CD9F1C9-8022
       Revision: 00H22000
    Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
       Part No: 1K0 959 792
       Coding: 0000000
       VCID: 75E65C9F1C6AD2E9C0-8020
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5K0 035 156 A    HW: 5K0 035 156 A
       Component: Radio         H55 0107
       Revision: R0000000    Serial number: VWZAZ1R6847342
       Coding: 0000020001
       VCID: 25464CDF2C4AE269B0-8070
    End-------------------------(Elapsed Time: 01:46)--------------------------
    Thursday,26,January,2017,14:39:51:44004
    VIN: WV2ZZZ2KZFX109246   License Plate: WAT
    Mileage: 85890km-53369mi   Repair Order:
    This is the second vehicle post VW update.
    VIN: WV2ZZZ2KZFX109246   Mileage: 85890km-53369miles
       ROD: N/A
       Revision: 00H46001
       Coding: 633C400D09220303C60D02E8901FC081A0000021
       Revision: BB122001
       Component: Wischer 28011  26  0512
       Coding: 009795
       Revision: --------    Serial number: 003HL00VA78B
       Revision: FF010042    Serial number: 20150131301845
       Coding: 1080060000
       Coding: 480201
       Revision:   H57       Serial number: 060215F1001791
       Coding: 357401
       Coding: 0000000
       Revision: 00H22000
       Coding: 0000000
       Revision: R0000000    Serial number: VWZAZ1R6845236
       Coding: 0000020001
    End-------------------------(Elapsed Time: 01:49)--------------------------
    Ill sort the pre update for my Caddy as i dont have it on my lap top.
    These two Caddys i do not have a Pre software up date. Im sorry.
  15. Likes Uwe liked this post
  16. #20
    Magdeburg, Germany
    Should both be addressed with the next update/data version.
  17. Likes Uwe liked this post
