Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Advanced Measuring Values grayed out !
    Nov 2016
    hi.......i had a golf tdi 1.6 cr emissions updated at vw dealer.........since that update the advanced measuring values are grayed out.
    i can no longer check how the dpf is or othere stuff.........id post a full scan of the car, but i dont have it.
    previously the adv meas values were alright...i could access them no problem.....since update 4 weeks ago......i cant.
    i have full registered version of hex can usb
    any help or ideas?
    when i check for fault codes.....this comes up.....
    No ASAM data for ''EV_ECM16TDI02103L997557P'' (VW36)
    If i scroll above the advanced measuring blocks grayed out box i get this message
    unable to find a ROD file for:
    EV_ECM16TDI02103L997557P 003002 (VW36)
    Please make sure you are using the latest version (including beta)
    i know its not my cable or anything........because it works with no problem in my 2011 audi a5 tdi.
    CAN ANYONE HELP ?
    Correct, it's not your cable. It's the fact that VW installed brand-new software in your ECU for which VCDS doesn't have data yet.
    Do you have an older scan so we can see what the previous ASAM identifier was?
    Nov 2016
    i have both scans new and old.......but my rubbish laptop wont send emails....but as soon as it does il send both scans to you.
    i dont know if its possible to have the car back to original running with previous software? car seemed quieter and smoother.
    so no way of checking dpf now then?............or doing a regen if needed?
    Nov 2016
    when if ......will the vcds be updated for the new data?
    Quote Originally Posted by vw754 View Post
    You don't need to e-mail them, just post both here.
    How likely do you think it is that VW will put the old software back for you?
    I'm not really surprised. There must have been some reason why VW "cheated" on the emissions.
    Without being able to match some data to the ECU's ASAM identifier? No.
    Soonest we can possibly help you is after we see both old and new scans so we have a reference for data that might be appropriate.
    Nov 2016
    OLD SOFTWARE (ORIGINAL)
    Saturday,24,October,2015,15:41:33:07342
    VCDS Version: 15.7.1.0
    Data version: 20150904
    VIN: WVWZZZ1KZDP007980   License Plate: ******
    Mileage: 80500km-50020mi   Repair Order:
    Chassis Type: 1K (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZDP007980   Mileage: 80500km-50020miles
    Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 ML    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 9647
       Revision: --H43---    Serial number: 00000000000000
       Coding: 08114014032500080000
       Shop #: WSC 00028 028 00025
       ASAM Dataset: EV_ECM16TDI02103L906023ML 003007
       ROD: EV_ECM16TDI02103L906023MK_SE36.rod
       VCID: 7CFCE18BF7F7C9DE01-8028
       Revision: 00H31001
       Coding: 133B200D09220001C81404EC90190081310000
       Shop #: WSC 00028 028 00001
       VCID: 7DFAEC8FE4EDC0D636-8028
       Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010004002
       VCID: 7AF0E793FDC3F7EE13-802E
       Part No SW: 1K0 937 084 H    HW: 1K0 937 084 H
       Component: BCM PQ35  B   111 0709
       Revision: AB111709
       Coding: 48180A3A8827F1C0408800C0340400644B510288536D8160648000200040
       VCID: 336E0AB79229C6A690-8066
       Subsystem 1 - Part No: 5K2 955 119
       Component: Wischer 23051  26  0512
       Coding: 009795
       Component: RLS 020612 05  54  0403
       Coding: 0230AD
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
       Component: PARKHILFE 8K  H01 0012
       Revision: --------    Serial number: 12561213501780
       Coding: 108001
       VCID: 38743D9B8B4F25FEA5-806C
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serial number: 003G5RAKR02O
       Coding: 00004432
       Shop #: WSC 00028 028 00052
       ROD: EV_AirbaVW10SMEVW360_SE36.rod
       VCID: 316200BF6035F4B6E2-8064
       Serial number: 3572MSME2944106DZZZW
       Serial number: 3582MSME1B33136DZZZZ
       Serial number: 3512QSME5A33176BZZZ.
       Serial number: 3522QSME5626164BZZZX
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Revision: --------    Serial number:  90422LF6000Y2
       Coding: 1082140000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 72E0CFB3A5B38FAE5B-8026
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
       Serial number: 50000000000000581396
       Coding: E20000
       Part No SW: 5K0 920 973 A    HW: 5K0 920 973 A
       Coding: 470B00
       VCID: 2F6606C77601E246F4-807A
       Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
       Component: J533  Gateway H42 1632
       Revision:   H42       Serial number: 230512F2003592
       Coding: 350003
       VCID: 3F865687AE6112C664-806A
       VCID: 6AD0D7D38D63476EE3-803E
       Revision: A1001003    Serial number: 7662559425
       VCID: 2952E8DF40E58C762A-807C
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2106
       Coding: 0000692
       VCID: 37763EA746512A86AC-8062
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 69     3305
       Revision: 00H22000
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 5K0 959 702 J    HW: 5K0 959 702 J
       Coding: 0000948
       VCID: 3A702793754337EE53-806E
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195 H    HW: 3C8 035 195 H
       Component: Radio RCD510  005 0244
       Revision: 00000001    Serial number: VWZ1Z3M8104886
       Coding: 01000400040005
       VCID: 2D5A1CCF740D9056C6-8078
       Coding: 0000144
       Shop #: WSC 00028 028 1012545
       VCID: 356A34AF5C5DD896BE-8060
       Coding: 0000144
       VCID: 366833A3415BD38EB7-8062
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
       Revision: 1B001001    Serial number: 00007662696386
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3972389FB8453CF65A-806C
    End-------------------------(Elapsed Time: 03:37)--------------------------
    LATER SOFTWARE
    Saturday,21,January,2017,12:54:22:07086
    VCDS Version: 16.8.4.2
    Data version: 20161129 DS267.0
    VIN: WVWZZZ1KZDP007980   License Plate: KJ
    Mileage: 92990km-57781mi   Repair Order:
    VIN: WVWZZZ1KZDP007980   Mileage: 92990km-57781miles
    Address 01: Engine (J623-CAYC)       Labels: None
       Part No SW: 03L 997 557 P    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9980
       ASAM Dataset: EV_ECM16TDI02103L997557P 003002
       ROD: N/A
       VCID: 49934E6AE8A2AC0A5E-801C
    No ASAM data for: "EV_ECM16TDI02103L997557P" (VW36)
       Revision: 00H31001
       VCID: 7DFBEABAE4EAC0AAA2-8028
       Revision: 00001018
       Coding: 0010004002
       VCID: 7AF1E1A6FDC4F79287-802E
       Revision: AB111709
       VCID: 336F0C82922EC6DA04-8066
       Coding: 009795
       Coding: 0230AD
    00061 - Footwell Lights
                        Fault Status: 00101010
                        Fault Frequency: 11
                        Reset counter: 47
                        Mileage: 92692 km
                        Date: 2017.01.03
                        Time: 17:07:58
                            Term 15 Off
                        Voltage: 11.75 V
                            Term 50 Off
       Coding: 108001
       VCID: 38753BAE8B48258231-806C
       Coding: 00004432
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3163068A6032F4CA76-8064
       Coding: 1082140000
       ROD: EV_SMLSNGKUDS_VW32.rod
       VCID: 72E1C986A5B48FD2CF-8026
       Coding: E20000
    365080 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
                        Reset counter: 46
                        Mileage: 92808 km
                        Date: 2017.01.11
                        Time: 23:18:20
       Coding: 470B00
       VCID: 2F6700F27606E23A60-807A
       Coding: 350003
       VCID: 3F8750B2AE6612BAF0-806A
       VCID: 6AD1D1E68D64471277-803E
       VCID: 2953EEEA40E28C0ABE-807C
       Coding: 0000692
       VCID: 3777389246562AFA38-8062
       Revision: 00H22000
       Coding: 0000948
       VCID: 3A7121A675443792C7-806E
       VCID: 2D5B1AFA740A902A52-8078
       Coding: 0000144
       VCID: 356B329A5C5AD8EA2A-8060
       Coding: 0000144
       VCID: 36693596415CD3F223-8062
       ROD: EV_UHVNA_002.rod
       VCID: 39733EAAB8423C8ACE-806C
    End-------------------------(Elapsed Time: 03:07)--------------------------
    Address 09: DTCs cleared
    Address 16: DTCs cleared
  7. Likes Uwe, GaryM liked this post
    Verified VCDS User GaryM's Avatar
    Nov 2014
    Oxford, UK
    It's unfortunate that you didn't check for emissions fix problems before getting your software updated. Rattly engines and loss of torque between certain rev ranges seem to be the most common complaints after the software has been updated with the emissions fix. Most of the reported issues seem to be with the 2.0 engine although I did come across a few posts relating to the 1.6 engine as well.
    See the following web pages:-
    I think you might struggle to get the original software reinstalled without a fight. Apparently VW won't allow dealers to do that so if you really do want it reverted back and they don't play ball then you might have to resort to a threat of legal action.
    There is no legal requirement in the UK to have the emissions fix applied. It's a voluntary decision by the owner to book the car in and have the fix applied for free. I had my recall letter in December but have already decided that whenever my car needs to go in to the dealer for a service or any other work, I will be giving them explicit instructions not to go anywhere near the engine ECU software and that if they do then they will be in hot water. My car has been driving perfectly fine for the past 4 years so I see no point in taking any unnecessary risks with having a engine ECU software update applied.
    One good thing that you have managed to prove though is that the engine ECU software version does actually change after the update so thanks for posting up the before and after scans. There have been rumours that the update was just done under the original software version meaning that it wouldn't be possible to find out if the emissions fix update had been applied. Your scans have now disproved that rumour so it's good to know that there is a visible change in the engine ECU software version after the update is done.
  9. Likes Eric, Uwe, NZDubNurd, Danners74 liked this post
  10. #8
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Or just go get the car Remapped by a reputable software company. Ive had my update done.........to be honest im absolutely TAMPING! I love the whole VAG group etc but i wish they would stop making my life harder including Ross Tech by greying out this stuff.
    GRRRRRRRRRRRR
  11. #9
    Nov 2016
    my 2.0 tdi has been done and seems better on power......and nothing else has changed so all good thank god.
  12. #10
    Nov 2016
    hope rosstech can get vcds to check dpf and stuff as i usually could
