Thursday,26,January,2017,12:33:42:40259
VCDS Version: 17.1.1.0
Data version: 20170106 DS267.0
VIN: WVWZZZ1FZ9V004906 License Plate:
Mileage: 48470km-30117mi Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 26 42 44 46 52 55 56 62 63
72 73
VIN: WVWZZZ1FZ9V004906 Mileage: 48470km-30117miles
63-Entry Assist,D -- Status: OK 0000
73-Entry Assist, P -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1Q0 907 115 F HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H53N58BH
Coding: 041C00431C070160
Shop #: WSC 00020 790 00000
VCID: 2F66E1D3BE800F397C-807A
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - MIL ON
Fault Status: 11100100
Mileage: 48472 km
Time: 18:15:16
Temperature: 87.0°C
Temperature: 60.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.065 V
Readiness: 0010 0101
Part No SW: 02E 300 051 B HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1802
Revision: 04843012 Serial number: 00000804181305
Shop #: WSC 44551 111 44551
VCID: 122048270DF2C2D173-8046
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Shop #: WSC 06314 000 00000
VCID: 75EA13BBDC5C75E9F6-8020
Reset counter: 234
Count: 3
Count: 12
Count: 4608
Count: 195
Count: 43776
Part No SW: 1Q0 907 044 AE HW: 1Q0 907 044 AE
Component: ClimatronicPQ35 131 0405
Revision: 00131023 Serial number: 00000000000000
VCID: 70E422AF633E50C125-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 00000008494420
Coding: E7868F0700041500470A00000F000000000B5D035C000120000000000000
VCID: 336EEDA352A82BD918-8066
Subsystem 1 - Part No: 1Q2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 280408 022 0501
Coding: 00038805
Shop #: WSC 00020
Component: RLS 060608 054 0402
Coding: 00209101
Shop #: WSC 00020
Address 10: Park/Steer Assist (J446) Labels: 1K0-919-475.clb
Part No SW: 1K0 919 475 D HW: 1K0 919 475 D
Component: PARKHILFE 005 1406
Revision: 00005000 Serial number: 0 263 004 291
Coding: 101101
VCID: 336EEDA392A82BD918-8066
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 6J Airbag VW8C 0180
Revision: 92010018 Serial number: 003B3003NCR$
Coding: 0013898
VCID: 3A70C08775C2DA91DB-806E
Subsystem 1 - Serial number: 6332SRB4073DC51C8
Subsystem 2 - Serial number: 6342SRB4074E0727/
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 051 0101
Coding: 0012021
VCID: 040C7E7F47865C61F1-8050
Component: E0221 002 0010
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1Q0 920 874 HW: 1Q0 920 874
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H53N58BH
Coding: 0023103
Shop #: WSC 02280 002 1048576
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K086090EF0
Coding: EDA17F260C02025001
VCID: 356AD3BB5CDC35E936-8060
Component: IMMO VDD 2416
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 D HW: 1Q0 959 255 D
Component: Verdecksteuergeraet 0824
Revision: 0033100M Serial number: 081310101
Coding: 0655366
VCID: 3972DF8B70C4D189D2-806C
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1Q0 959 701 E HW: 1Q0 959 701 E
Component: Tuer-SG 006 1212
Coding: 0000695
VCID: 3668D4B741DA3EF13F-8062
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A50F0C785626A11AB-807E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 90908A000186285B080484056008DE0380FC00
Shop #: WSC 43004 986 88718
VCID: 030E7D6342885B59C8-8056
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1Q0 959 702 E HW: 1Q0 959 702 E
Coding: 0000950
VCID: 3776D9B346D0C7F924-8062
01035 - Electric Window Thermal Protection Active; Passenger
Component: AFS-Steuergeraet 0133
Coding: 2508035
VCID: 346CEEBF57A62CE101-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000038
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000038
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0126
Revision: 00000001 Serial number: VWZ1Z3H3248289
Coding: 0500040004
VCID: 65CA43FB6CFC856946-8030
Part No SW: 1Q0 959 703 A HW: 1Q0 959 703 A
Component: Tuer-SG 006 1301
Coding: 0000128
Shop #: WSC 00020 790 1012544
Address 63: Entry Assist,D Labels: 1Q0-959-790.lbl
Part No SW: 1Q0 959 790 A HW: 1Q0 959 790 A
Component: J572 EASYENTRY FS 0603
Revision: 00H02000 Serial number: 5DS008646-01--
Part No SW: 1Q0 959 704 A HW: 1Q0 959 704 A
Coding: 0000128
Address 73: Entry Assist, P Labels: 1Q0-959-790.lbl
Component: J573 EASYENTRY BFS 0603
End-------------------------(Elapsed Time: 02:33)--------------------------
