2011 Touareg EPG module 53 Basic settings help required
Loz
Berkeley, Gloucestershire, UK
C?ID=132132
2011 Touareg EPB module 53 Basic settings help required
Hello all
I have just replaced Rear Pads and Rotors on the Touareg, following the VW manual precisely I disconnected the parking brake actuator (Latest model has shoes in rotor drum) this caused the module to throw up a parking brake fault.
I have used the VCDS to correctly set the airgap and reset/recode the module but now it requires the Basic settings to be done to recalibrate.
The problem is the current version of VCDS does not suggest any 3 digit codes?
I can select Air Gap calibration from the pulldown, but a "1 to 3 digit code is required" does anyone know what these are?
I tried some of the previous version codes 010 but the module just says "Not Running"
Here is the current module coding.
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
   Component: EPB           H51 1000
   Revision: 00000000    Serial number: A111110063A
   Coding: 01040000
   Shop #: WSC 31414 790 00001
   ROD: EV_ParkbA7.rod
   VCID: 3462885A9F1F19BE4FF-8061
   Slave 1:
   Slave 3:
0025 - No Calibration
          B2010 F0 [008] - Deviation From Expected Range
                    Fault Frequency: 164
                    Reset counter: 1
                    Mileage: 540928 km
                    Date: 2118.03.14
                    Time: 27:13:01
0024 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 1
                    Mileage: 540928 km
                    Date: 2118.03.14
                    Time: 25:32:61
I was able to bring up the measuring blocks and read the airgap and have this set within the tolerances but despite calls to Ross-Tech support (this is not a criticism, just reporting the fact that I did contact support) and an extensive search all I can find are basic settings for the older module that has the actuator built into the floating caliper.
Any help to prevent me having a trip to the main dealer would be appreciated.
Regards Loz
(moderator at mytreg dot com)
full scan for reference
Saturday,12,July,2014,14:16:07:09334
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVGZZZ7PZBD041758   License Plate: W44MUD
Mileage: 44579   Repair Order:
Chassis Type: 7P (7P6)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 18 19 22 32 34 36 3C 42
          46 52 53 55 56 5F 62 65 6C 6D 72 85 8B 8E 8F 90
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CASA)       Labels: 059-907-401-CAS2.clb
   Part No SW: 7P0 907 401     HW: 7P0 907 401
   Component: 3.0TDI EDC17  H17 0007
   Revision: 51H17---
   Coding: 296A401A236E01020000
   ASAM Dataset: EV_ECM30TDI0117P0907401 002009
   ROD: EV_ECM30TDI0117P0907311.rod
   VCID: ECD2D03A07AF017ED7F-80B9
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
   Component: AL1000 AISIN  001 1885
   Coding: 001568
   Shop #: WSC 13678 000 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031.rod
   VCID: 316C814E600D2C96249-8064
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 408410010EC010
   Coding: 4B6B13C30B282F54D2FBC898D0DAF4507700
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4584C59EC4859036E81-8010
   Part No SW: 4H0 907 064 AH    HW: 4H0 907 064 AH
   Component: BCM2 2.0      H24 0217
   Coding: 05B60000000000000000
   VCID: 6FE84736BEB97A6672D-803A
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Revision: AA000000    Serial number: 00001002369378
   Coding: 0038330000004201000001010101202020202121202020
   VCID: 3462885A971F19BE4FF-8061
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 AJ    HW: 7P6 907 040 AJ
   Component: Klima 2 Zonen H18 0613
   Coding: 36F6000E10
   VCID: 7CF2607AF7CF11FEC7F-8029
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0092
   Revision: 15012002    Serial number: 00000000992707
   Coding: 26001091D1345F010021000380005D0C431D470807010241800000020000
   VCID: 316C814E680D2C96249-8064
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    110312  31  0020
   Coding: 004DBD
   Component: RLFS  H09 0011
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Subsystem 4 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Coding: 010300
Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
   Part No SW: 7P6 919 475     HW: 7P6 919 475
   Component: PARKHILFE 8K  H03 0016
   Revision: --------    Serial number: 55901105402492
   Coding: 508D01
   ASAM Dataset: EV_VW526ParkiAssis2 001008
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 55A415DE342520B6981-8000
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 7P6 907 561 A    HW: 7P6 907 561
   Component: ACC3          H13 0230
   Coding: 3E04010101
   ASAM Dataset: EV_AdaptCruisContrVW526 001004
   ROD: EV_AdaptCruisContrVW526.rod
   VCID: 3A7EA662BD7BEFCE953-806F
106240 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 204
                    Mileage: 71744 km
                    Date: 2014.07.12
                    Time: 12:42:51
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag00M H05 0023
   Revision: --------    Serial number: 003JX00215EY
   Coding: 00000000000000000000000000000000304D
   ROD: EV_AirbaVW10BPAVW526_VW52.rod
   VCID: 408AD48ADBA7B51EDB7-8015
   Serial number: 3575LRB40570EACC90K0
   Serial number: 3585LRB405V0BI7S9HE9
   Serial number: 3515RRB404V0HBR0COKE
   Serial number: 3525RRB404T0HBR0E18N
   Serial number: 3555NRB405N09GGS5OGA
   Crash sensor for front airbag; passenger side:
   Serial number: 3565NRB405N09GGSCH72
   Part No SW: 4H0 953 568 B    HW: 7P6 953 507 G
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KCG0000F
   Coding: 000C9D
   VCID: 326E8E426D0B178E5D3-8067
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 981 C    HW: 7P6 920 981 C
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658020311593025
   Coding: 331F3300FF082600010004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 3D74AD7EAC55D8F6B01-8068
Address 18: Aux. Heat (J364)       Labels: None
   Part No SW: 7P0 963 272 B    HW: 7P0 963 272 B
   Component: Standheizung  H23 0240
   Revision: 56005006    Serial number: 20110309174552
   Coding: 594200
   VCID: 3666B25281630BAE71B-8063
   Part No SW: 7P6 907 530 D    HW: 7P6 907 530
   Component: GW-CAN-L-FR-M H08 5202
   Revision: --------    Serial number: 00000000112570
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 397CB96EB87DE4D69C9-806C
   Serial number: 00000000005650815975
   Voltage stabilizer:
   Part No SW: 0BV 927 755 A    HW: 0BV 927 755 A
   Component: TRANSFERCASE        0217
   VCID: 4C92F0BA2FEF617E37F-8019
Address 32: Differential Locks        Labels: None
   Part No SW: 0BN 927 771     HW: 0BN 927 771
   Component: Quersperre          5220
   Revision: H04         Serial number: 108512251004
   VCID: 010C118E582D7C16949-8054
Address 34: Level Control (J197)       Labels: 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revision: 00000000    Serial number: 00000110710564
   Coding: 14210001
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 3F88D776A659CAE6A2D-806A
   Revision: AA000000    Serial number: 00001002369322
   Coding: 00383B0000004201000001010101202020202121202020
   Part No SW: 7P6 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH03 0110
   Revision: 00H03000    Serial number: 6PZ 010 316-01
   Coding: 0001151
   VCID: FEF6EA72A9D383EE69B-80AB
   Subsystem 1 - Part No: 7P6 907 568
   Component: J770  SWA Slave H01 0110
   Subsystem 2 - Serial number: 6PZ 010 316-21
   Subsystem 3 - Serial number: 5F05.03.1100H010003C520363ˇ
   Subsystem 4 - Serial number: 520363ˇ
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revision: --------    Serial number: 0000107831908
   Coding: 011D1620DE01459205080003
   VCID: 3B70A366BA41D6C68E5-806E
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 204
                    Mileage: 71744 km
                    Date: 2014.07.12
                    Time: 10:30:52
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0143761494
   Coding: 011B1E2228B910958B2004240F0000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H07 0006
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H07 0006
   Coding: 191100
01234 - Heated Windshield Control Module (J505)
                    Reset counter: 164
                    Mileage: 71744 km
                    Date: 2014.07.12
                    Time: 10:02:21
                    Reset counter: 204
                    Mileage: 71744 km
                    Date: 2014.07.12
                    Time: 11:08:03
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000114182932
   Coding: 011D1620DE01459205080000
                    Reset counter: 204
                    Mileage: 71745 km
                    Date: 2014.07.12
                    Time: 13:43:09
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
                    Reset counter: 1
                    Mileage: 540928 km
                    Date: 2118.03.14
                    Time: 27:13:01
          B2010 00 [009] - -
                    Reset counter: 1
                    Mileage: 540928 km
                    Date: 2118.03.14
                    Time: 25:32:61
Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AE00000F000A00
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: FCF2E07A77CF91FE47F-80A9
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo links  H01 0001
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo rechts  H01 0001
   Coding: 130000
   Part No SW: 4G0 035 061 G    HW: 4G0 035 061
   Component: Radio U DAB   H52 0097
   Revision: AB001007    Serial number: 109C.0B7513786
   Coding: 010105020100000001
   VCID: 214C710E38ED9C16B49-8074
   Part No SW: 7P6 035 670 B    HW: 7P6 035 670 B
   Component: H-BNT-EU      H44 0203
   Revision: --------    Serial number: 478CA0B7538778
   Coding: 010101060340FBEF7B105F0E00000003F0040100
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H24 0045
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
                    Reset counter: 164
                    Mileage: 71744 km
                    Date: 2014.07.12
                    Time: 10:02:22
                    Bin. Bits: 00000000 01000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000114447439
   Coding: 011C16200001259005080000
   VCID: 3A7EA662B57BEFCE953-806F
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000025962
   ROD: EV_RDKBERU25_VW52.rod
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 7P6 907 441 D    HW: 7P6 907 441 D_
   Component: TopView       H05 0097
   Revision: 11001001    Serial number: 82331010124705
   Coding: 0100000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 22010001    Serial number: 077100325
   Coding: 0533314002
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 TSG HR        H09 01620162
No Faults Found
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 7P6 907 217 A    HW: 7P6 907 217
   Component: DPC-SG        H23 0033
   Coding: E9070000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 387ABC6A8377FDDE637-806D
   Subsystem 1 - Part No: 7P6 .90 7.6 58
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000003022365_2022
Address 8B: Adaptive Cruise 2 (J428)       Labels: None
   Part No SW: 7P6 907 541 A    HW: 7P6 907 541
   Coding: 3E04010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 001004
   ROD: EV_AdaptCruisContr2VW526.rod
          U1113 00 [008] - -
                    Reset counter: 204
                    Mileage: 71744 km
                    Date: 2014.07.12
                    Time: 12:42:51
Address 8E: Image Processing (J851)       Labels: None
   Part No SW: 7P6 907 107 A    HW: 7P6 907 107
   Component: BV-SG         H28 0031
   Serial number: 000040192802117
   Coding: 01A2BE000000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR.rod
   VCID: 3666B25289630BAE71B-8063
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00660600031F037F00033810594097000000
   Shop #: WSC 00001 790 00001
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: EFE8C73636B9FA66F2D-80BA
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   Coding: 006606000317037F00033810594097000000
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: F0EAC44A2B87E59EEB7-80A5
Dana
Western PA, USA
We replied to Loz via email but I would like to explain why we do not have a procedure to offer after mechanical repairs to this VW Touareg (7P) Parking Brake EPB system at this time.
7P0 #53 control modules lose their coding after mechanical repairs to the brake pads and/or rotors (not the actual Electro-Mechanical Parking Brake (EPB) components) and they are extremely sensitive to Air Gap Calibration tolerances. Furthermore, the basic settings parameters are extremely complex in this system so R-T needs to get one of these vehicles onsite for live testing.
On that note, if an existing Ross-Tech customer with a 7P/BP T'reg happens live in the Lansdale area ... please contact us.
Loz
C?ID=132132
Thanks Dana
Yes, Paul Shu. was very helpful on the phone and in his reply.
As you say the unit remembers the air gap at each calibration and that changes if you adjust up the brake shoes as you do.
It is going in to VW in the morning but I am not hopeful of being allowed to observe what they do.
I'll report back after the visit.
Loz
C?ID=132132
All sorted now, I went into VW in Bristol and they adjusted the air gap and carried out the Basic Settings, which involved 2 techs going out in the car with a portable VAS unit.
I wasn't able to glean any info apart from the procedure includes driving the vehicle...
Iain Murray
C?ID=200189
Hi there Just wondering if there has been any updates on this problem. We have one with same problem, same DTC 's after vehicle came in with non operating EPB. Again this is the version with brake shoes inside the disc & we had to recode the module which was straight forward enough. Is this still a trip to the main dealer unfortunately. cheers.
RyMar
South Africa
C?ID=133909
I had similar problems after replacing rear brake pads & discs. This Touareq does not have the shoes inside the drum. Had to recode at VW. Adjusted the air gap according to this video. It worked 100%.
Now I am left with the basic setting!
Milan
C?ID=301890
Hi There,
How did you recode EPB?
Any help is very much appreciated,
Loz
C?ID=132132
Hi There,
I didn't recode as such, just needed to perform a basic settings procedure.
After adjusting the air gap, you need to follow a procedure to "grind in" the shoes. There is a YouTube vid showing how to do this that involves driving and pulling on the EPG at the same time, I'll try and find a link to it. (Someone might be able to post a link before me but I'll have a look when I get to my desk)
Loz
C?ID=132132
I have got an information that someone went into basic settings and gap adjustment and as soon as they clicked on it (gap adjustment )there have been those three faults since and EPB is inoperative,
Apparently the shoes haven't been changed
Many thanks
Yes, correct, just follow the video back in post #6 of this thread after doing any adjustments even if you didn't change the shoes.
RyMar
South Africa
C?ID=133909
The shoes needs to be mechanically adjusted. Max difference between the shoes 0.2mm. Then do like on the video. If it does not run in adjust again. I had to do it twice on a Touareq before.
Milan
C?ID=301890
I have just tried to adjust the EPB but it does not do anything,values dont change
RyMar
South Africa
C?ID=133909
This is from Elsa 5.3
The brake discs must rotate freely, if necessary press brake lining back slightly.
Connecting -VAS 5051- and selecting functions → Chapter.
– Select electromechanical parking brake and function “adjusting air gap”.
Air gap OK., example display on -VAS 5051-:
Evaluation
Air gap lies within tolerance.
Left air gap: 2.19 mm
Right air gap: 2.17 mm
Difference left/right air gaps: 0.02 mm
Air gap not OK., example display on -VAS 5051-:
Evaluation Specification 1 / Actual value 2 or 3)
Air gap lies outside tolerance.
Left air gap Spec./Act. 1.9 - 2.4 mm / 1.61 mm
Right air gap Spec./Act. 1.9 - 2.4 mm / 2.54 mm
Difference left/right air gaps: 0 - 0.2 mm / 0.93 mm
1 - Specification (black lettering)
2 - Actual value within tolerance (blue lettering)
3 - Actual value outside tolerance (red lettering)
If air gap lies outside tolerance, carry out following procedures:
– Unscrew sealing plug -arrow- for parking brake adjustment nut.
N46-10285
– Insert a screwdriver through the hole in the brake disc and turn the adjustment nut -A- back against the resistance of the spring -B-.
Note
Turning adjustment nut one tooth equals approx. 0.15 mm.
– Calculate difference between actual value and specified value and divide this figure by 0.15 mm. This will provide approx. number of teeth for which the adjustment nut must be turned in the respective direction (loosen or tighten).
N46-10283
Left adjustment nut:
t Turning in arrow direction -A- reduces air gap (= tightens).
t Turning in arrow direction -B- increases air gap (= loosens).
t Arrow -C- shows the direction of travel (forwards).
Note
The adjustment nut on the right side of the vehicle is a mirror image.
N46-10286
Right adjustment nut:
– After adjusting air gap, press Complete button to up-date actual values.
– Then perform basic setting of electromechanical parking brake.
– To do this, select electromechanical parking brake and function “Basic settings of electromechanical parking brake”.
N46-10289
– Install sealing plug -arrow- for parking brake adjustment nut.
– Fit rear wheels.
– Perform basic setting.
Milan
C?ID=301890
I have tried to adjust the shoes but the values did not change Left gap 2.2 right 2.5
Milan
C?ID=301890
Thanks for your post
I am using VCDS HEX NET and there is no such a menu chapter,
what do you mean excatly by Perform basic settings?
Milan
C?ID=301890
I have watched the video and I am going to do it tomorrow morning the only concern I have that they did not have that fault Regarding Control module Incorrectly Coded and it seems that their hand brake in operative,in my case there is no hand brake at all,Should it be coded at first place and then basic setting?If I need to do coding what is the procedure and code itself?
12652550 - Control Module Incorrectly Coded
U1014 00 [009] - -
Voltage: 12.2 V
RyMar
South Africa
C?ID=133909
The coding on my Touareq was current and even when I tried to recode with same coding it did not want to do it. The VW Dealer recoded it online to same coding and I was able to do the rest.
